CUS-22TB
CUS-22TB
    NIDEC(尼得科)
    SMD
    滑动开关 双刀双掷 立贴
CUS-22TB 数据手册
LOW-PROFILE SLIDE SWITCHES RoHS compliant CUS INTERNAL STRUCTURE ⑦ ⑥ ③ ① ⑤ ④ Part name ② Material Flammability — ■ FEATURES ① Cover Nickel silver ● Low-profile of 1.4 mm ● RoHS compliant ② Slider Polyamide ③ Housing ④ Slider contact ⑤ Fixed contact ⑥ Terminal pin ⑦ Click spring ⑧ Ground terminal ■ APPLICATIONS ● Mobile stereo · LCD TV · Camcorder ⑧ Liquid crystal polymer UL94V-0 Copper alloy, Gold-plated — Stainless steel (SUS 301) Nickel silver ■ PART NUMBER DESIGNATION C U S - 1 2 T B Series name No. of poles 1:1 pole 2:2 poles(2 接点タイプのみ 2 contacts type only) No. of contacts 2:2 contacts 3:3 contacts 4:4 contacts ※ Please refer to the LIST OF PART NUMBERS when placing orders. Shape of terminal B:Gull wing Form of packaging T:Taping CUS LOW-PROFILE SLIDE SWITCHES ■ LIST OF PART NUMBERS Schematic No. of contacts Shape of terminal Form of packaging Part number CUS-12TB 2 1 3 B CUS-22TB Operating temp. range − 20 ~ 70 °C Storage temp. range − 40 ~ 85 °C Sealing Non washable Approx. 0.08 g (CUS-12) Approx. 0.10 g (CUS-13) Approx. 0.13 g (CUS-14) Approx. 0.11 g (CUS-22) ■ MECHANICAL CHARACTERISTICS No. of positions 2, 3, 4 Stroke 1.5 mm Operating force CUS-12 ※ 1 2 ± 1.7 N {0.2 ± 0.17 kgf} A → B : 1.5 ± 1.2 N {0.15 ± 0.12 kgf} B → C : 2 ± 1.7 N {0.2 ± 0.17 kgf} CUS-13 ※ 2 C → B : 1.5 ± 1.2 N {0.15 ± 0.12 kgf} B → A : 2 ± 1.7 N {0.2 ± 0.17 kgf} A → B : 1.5 ± 1.2 N {0.15 ± 0.12 kgf} B → C : 2 ± 1.7 N {0.2 ± 0.17 kgf} C → D : 2 ± 1.7 N {0.2 ± 0.17 kgf} CUS-14 ※ 3 D → C : 1.5 ± 1.2 N {0.15 ± 0.12 kgf} C → B : 2 ± 1.7 N {0.2 ± 0.17 kgf} B → A : 2 ± 1.7 N {0.2 ± 0.17 kgf} CUS-22 ※ 4 2 ± 1.7 N {0.2 ± 0.17 kgf} 10 N {1.02 kgf} 15 s Solderability 245 ± 3 °C 2 ~ 3 s Shear Substrate bending Pull-off strength 1400 pcs./reel ■ ELECTRICAL CHARACTERISTICS Contact rating DC50 V 100 mA DC4 V 300 mA DC20 mV 1 µA Non-switching Switching Minimum Non-shorting Contact timing 70 m Ω maximum Contact resistance Insulation resistance 100 M Ω minimum (DC 100 V) Dielectric strength AC100 V 60 s ■ ENVIRONMENTAL CHARACTERISTICS Stop strength Soldering heat CUS-14TB 2 ■ STANDARD SPECIFICATIONS Net weight 2500 pcs./reel CUS-13TB Taping Gull wing 4 2 Pieces in package Vibration (Amplitude) 1.5 mmor (Acceleration) 98 m/s2, 10-500-10 Hz, 3 directions for 10 cycles each Shock 490 m/s2, 11 ms, 6 directions for 3 times each Continuous load 10000 cycles, DC4 ± 0.5 V, 300 ± 10 mA 40 °C, Relative humidity 90 ~ 95 %, 240 h, No load Load life Humidity High temp. exposure 85 °C, 96 h, No load Low temp. exposure − 40 °C, 96 h, No load − 40 (0.5 h) ~ 85 °C (0.5 h), 5 cycles Thermal shock ※1 ※2 Reflow peak : 250 ~ 255 °C CUS-13 A B C CUS-12 Manual soldering : 350 ± 10 °C 3 ~ 4 s 5 N {0.5 kgf} 10 s ※3 ※4 Width 90 mm, bend 3 mm, 5 s, 1 time 5 N {0.5 kgf} 10 s { } : Reference only A CUS-14 B C D CUS-22 CUS LOW-PROFILE SLIDE SWITCHES ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.2 (Unit : mm) ● CUS-12B ● CUS-13B 1.5 1.5 0.4 +0.1 –0.05 0.4 Schematic 1.3 ( 0.1 0.75 2.25 1.5 –0.05 0.4 +0.1 Terminal No.1 0.4 ④ Production date code R 0.2 0.5 1.5 1.3 ( 0.1 2.6 0.2 max. 1.4 q 0.8 ( 0.05 5.9 1 0. 0.5 ( 0.1 1 5 ( 0.05 C 0.9 0. 0.5 ( 0.1 C q 0.8 ( 0.05 0.8 ( 0.1 R 0.2 1 1.4 1.5 0.7 0.2 Travel 0.25 11.3 4.1 Travel 0.5 6.7 1.5 0.5 0.5 –0.05 0.2 +0.1 1.5 1.5 1.5 ⑤ ⑥ C Schematic –0.05 0.2 +0.1 1.3 ( 0.1 0.4 ( 0.1 Production date code C ② ③ ① 0.4 0.4 +0.1 –0.05 0.4 0.9 5 ( 0.05 ● CUS-22B Schematic 2.6 –0.05 0.2 +0.1 1.4 1.4 0.5 ( 0.1 q 0.8 ( 0.05 1.5 1.5 1.5 1.5 1.5 C ① ② ③ ④ ⑤ ⑥ 1.5 1 ● CUS-14B 0.4 0.5 0. 1 0. 0.9 3 ( 0.05 Terminal No.1 Travel 9.7 C C q 0.8 ( 0.05 0.5 2.6 –0.05 0.2 +0.1 1.5 0.2 0.5 1.1 ( 0.1 Travel R 0.2 1.5 1.5 1.1 ( 0.1 R 0.2 0.2 6.7 C ③ ④ ① ② Production date code 0.1 0.5 0.4 +0.1 –0.05 0.4 0.4 0.4 Schematic 1.5 0.5 ( 0.1 C ② ③ ① Production date code 1.3 ( 0.1 1.5 3 Terminal No.1 0.1 0.75 2.25 Terminal No.1 3 ( 0.05 ■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS (Unit : mm) 1 1 1 5 10.8 1 0.8 1.5 2.8 3.6 0.8 1.3 0 φ 0.9 +0.05 1.5 0.7 0 φ 0.9 +0.05 0.8 5 9.3 1 1.5 0.8 1 0.75 0.7 0.7 0 φ 0.9 +0.05 2.25 1.5 1.5 1.5 1.5 1.5 1.5 3 6.3 1.5 1.3 1.3 1 0.8 0 φ 0.9 +0.05 3 ● CUS-22B 0.8 1.5 1 1.5 1.5 0.7 ● CUS-14B 0.8 0.75 1 1.5 2.25 ● CUS-13B 0.8 ● CUS-12B 1 3 6.3 1 CUS LOW-PROFILE SLIDE SWITCHES ■ PACKAGING SPECIFICATIONS Taping version is packaged in 2500 pcs. par reel (1400 pcs. for CUS-22). Taping version is boxed with 1 reel (2500 pcs. or 1400 pcs.). Maximum number of consecutive missing pieces = 2. Leader length and reel dimension are shown in the diagrams below. Embossed tape dimensions Empty Filled Empty End Head 20 pitches min. ● CUS-13TB, CUS-14TB 2 ( 0.1 0.35 ( 0.1 12 ( 0.1 Installation example (CUS-13B) Installation example (CUS-12B) +0.1 0 4 ( 0.1 2 ( 0.1 7.5 ( 0.1 2.6 Direction of feed q 1.5 11.5 ( 0.1 7.5 ( 0.1 2 ( 0.1 4 ( 0.1 0.35 ( 0.1 ● CUS-22TB 24 4 ( 0.1 +0.1 0 +0.1 0 16 q 1.5 1.75 ( 0.1 q 1.5 12 ( 0.1 12 ( 0.1 1.75 ( 0.1 ● CUS-12TB Leader 400 mm min. Direction of feed Direction of feed ● Reel dimensions (Unit: mm) W1 2 ( 0.5 N A q 13 ( 0.2 q 21 ( 0.8 Label W2 Part number A W1 W2 N 12TB, 22TB 13TB, 14TB φ 330 ± 2 φ 330 ± 2 17.4 ± 1 25.4 ± 1 21.4 ± 1 29.4 ± 1 φ 80 ± 1 φ 80 ± 1 1.75 ( 0.1 Direction of feed 2.6 0.35 ( 0.1 Installation example (CUS-22B) 16 40 mm min. 4.2
CUS-22TB 价格&库存
很抱歉,暂时无法提供与“CUS-22TB”相匹配的价格&库存,您可以联系我们找货
CUS-22TB
  • 5+5.89424
  • 25+5.65888
  • 100+5.46310
  • 300+5.19026
  • 700+5.01323
库存:2785
CUS-22TB
  • 1400+4.88305
  • 2800+4.78516
库存:2785
CUS-22TB
  • 1+8.581571+1.11080
  • 10+7.3007510+0.94501
  • 25+6.7886425+0.87872
  • 100+6.05172100+0.78334
  • 250+5.60661250+0.72572
  • 500+5.29688500+0.68563
库存:13384
CUS-22TB
  • 1400+4.884981400+0.63231
  • 2800+4.640822800+0.60071
  • 4200+4.510284200+0.58381
  • 7000+4.358347000+0.56414
  • 9800+4.265679800+0.55215
  • 14000+4.1736114000+0.54023
库存:13384
CUS-22TB
  • 1+5.63760
  • 10+4.59000
  • 30+4.06080
  • 100+3.54240
  • 500+3.22920
  • 1400+3.07800
CUS-22TB
  • 25+5.65888
  • 100+5.46310
  • 300+5.19026
  • 700+5.01323
库存:2785
