BUK714R1-40BT,118
BUK714R1-40BT,118
    NEXPERIA(安世)
    TO-263-5
    表面贴装型 N 通道 40 V 75A(Tc) 272W(Tc) D2PAK
BUK714R1-40BT,118 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia BUK714R1-40BT N-channel TrenchPLUS standard level FET Rev. 02 — 10 February 2009 Product data sheet 1. Product profile 1.1 General description Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using NXP High-Performance Automotive (HPA) TrenchMOS technology. The devices include TrenchPLUS diodes for temperature sensing. This product has been designed and qualified to the appropriate AEC standard for use in automotive critical applications. 1.2 Features and benefits „ Allows responsive temperature monitoring due to integrated temperature sensor „ Q101 compliant „ Suitable for thermally demanding environments due to 175 °C rating „ Low conduction losses due to low on-state resistance 1.3 Applications „ 12 V loads „ General purpose power switching „ Electrical Power Assisted Steering (EPAS) „ Motors, lamps and solenoids 1.4 Quick reference data Table 1. Quick reference Symbol Parameter Conditions VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C ID drain current total power dissipation Ptot Min Typ Max Unit - - 40 V VGS = 10 V; Tmb = 25 °C; see Figure 2; see Figure 3 [1] - - 75 A VGS = 10 V; Tmb = 100 °C; see Figure 2 [1] - - 75 A Tmb = 25 °C; see Figure 1 - - 272 W VGS = 10 V; ID = 50 A; Tj = 25 °C; see Figure 7; see Figure 8 - 3.4 4.1 mΩ Static characteristics RDSon [1] drain-source on-state resistance Continuous current is limited by package. BUK714R1-40BT NXP Semiconductors N-channel TrenchPLUS standard level FET 2. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 G gate 2 A anode 3 D drain 4 K cathode 5 S source mb D mounting base; connected to drain Graphic symbol mb d a s k g 3 1 2 45 03nm72 SOT426 (D2PAK) 3. Ordering information Table 3. Ordering information Type number Package Name Description BUK714R1-40BT D2PAK plastic single-ended surface-mounted package (D2PAK); 5 leads (one lead cropped) BUK714R1-40BT_2 Product data sheet Version SOT426 © NXP B.V. 2009. All rights reserved. Rev. 02 — 10 February 2009 2 of 13 BUK714R1-40BT NXP Semiconductors N-channel TrenchPLUS standard level FET 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 40 V VDGR drain-gate voltage RGS = 20 kΩ VGS gate-source voltage ID drain current - 40 V -20 20 V Tmb = 25 °C; VGS = 10 V; see Figure 2; see Figure 3 [1] - 187 A [2] - 75 A Tmb = 100 °C; VGS = 10 V; see Figure 2 [2] - 75 A IDM peak drain current Tmb = 25 °C; tp ≤ 10 µs; pulsed; see Figure 3 - 748 A Ptot total power dissipation Tmb = 25 °C; see Figure 1 - 272 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C [1] - 187 A [2] - 75 A - 748 A - 1.5 J - 4 kV Source-drain diode IS ISM source current Tmb = 25 °C; peak source current tp ≤ 10 µs; pulsed; Tmb = 25 °C Avalanche ruggedness EDS(AL)S non-repetitive ID = 75 A; Vsup ≤ 40 V; RGS = 50 Ω; VGS = 10 V; drain-source avalanche Tj(init) = 25 °C; unclamped energy Electrostatic discharge Vesd electrostatic discharge voltage HBM; C = 100 pF; R = 1.5 kΩ [1] Current is limited by power dissipation chip rating. [2] Continuous current is limited by package. BUK714R1-40BT_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 10 February 2009 3 of 13 BUK714R1-40BT NXP Semiconductors N-channel TrenchPLUS standard level FET 03na19 120 03nm69 200 ID (A) Pder (%) 150 80 100 40 50 Capped at 75 A due to package 0 0 0 50 100 150 200 0 Tmb (°C) Fig 2. Fig 1. Normalized total power dissipation as a function of mounting base temperature 50 100 150 200 Tmb (°C) Continuous drain current as a function of mounting base temperature 03nm68 103 ID (A) tp = 10 µs limit RDSon = VDS/ ID 100 µs 102 1 ms Capped at 75 A due to package D.C. 10 ms 10 1 10-1 Fig 3. 100 ms 1 10 VDS (V) 102 Safe operating area; continuous and peak drain currents as a function of drain-source voltage BUK714R1-40BT_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 10 February 2009 4 of 13 BUK714R1-40BT NXP Semiconductors N-channel TrenchPLUS standard level FET 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Rth(j-a) Rth(j-mb) Conditions Min Typ Max Unit thermal resistance from minimum footprint; mounted on a junction to ambient printed-circuit board - - 50 K/W thermal resistance from see Figure 4 junction to mounting base - - 0.55 K/W 03ni64 1 Z th(j-mb) (K/W) 10-1 δ = 0.5 0.2 0.1 0.05 0.02 10-2 δ= P tp T single shot t tp T 10-3 10-6 Fig 4. 10-5 10-4 10-3 10-2 10-1 1 tp (s) 10 Transient thermal impedance from junction to mounting base as a function of pulse duration BUK714R1-40BT_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 10 February 2009 5 of 13 BUK714R1-40BT NXP Semiconductors N-channel TrenchPLUS standard level FET 6. Characteristics Table 6. Symbol Characteristics Parameter Conditions Min drain-source breakdown voltage ID = 0.25 mA; VGS = 0 V; Tj = 25 °C 40 ID = 0.25 mA; VGS = 0 V; Tj = -55 °C 36 gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 9 2 ID = 1 mA; VDS = VGS; Tj = 175 °C; see Figure 9 Typ Max Unit - - V - - V 3 4 V 1 - - V ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 9 - - 4.4 V VDS = 40 V; VGS = 0 V; Tj = 25 °C - 0.02 1 µA VDS = 40 V; VGS = 0 V; Tj = 175 °C - - 500 µA VDS = 0 V; VGS = 20 V; Tj = 25 °C - 2 100 nA VDS = 0 V; VGS = -20 V; Tj = 25 °C - 2 100 nA VGS = 10 V; ID = 50 A; Tj = 25 °C; see Figure 7; see Figure 8 - 3.4 4.1 mΩ VGS = 10 V; ID = 50 A; Tj = 175 °C; see Figure 7; see Figure 8 - - 7.8 mΩ Static characteristics V(BR)DSS VGS(th) IDSS IGSS RDSon drain leakage current gate leakage current drain-source on-state resistance VF(TSD) temperature sense diode forward voltage IF = 1 mA; Tj = 25 °C 1.58 1.6 1.63 V SF(TSD) temperature sense diode temperature coefficient IF = 1 mA; Tj > 55 °C; Tj < 175 °C -2.55 -2.83 -3.11 mV/K ID = 25 A; VDS = 32 V; VGS = 10 V; Tj = 25 °C; see Figure 14 - 83 - nC - 18 - nC - 29 - nC - 5106 6808 pF - 1389 1667 pF - 527 721 pF - 38 - ns - 82 - ns - 141 - ns Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGD gate-drain charge Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance td(on) turn-on delay time tr rise time td(off) turn-off delay time tf fall time LD internal drain inductance LS internal source inductance VGS = 0 V; VDS = 25 V; f = 1 MHz; Tj = 25 °C; see Figure 12 VDS = 30 V; RL = 1.2 Ω; VGS = 10 V; RG(ext) = 10 Ω; Tj = 25 °C - 90 - ns from drain lead 6 mm from package to centre of die; Tj = 25 °C - 4.5 - nH from upper edge of drain mounting base to centre of die; Tj = 25 °C - 2.5 - nH from source lead to source bond pad; lead length 6 mm; Tj = 25 °C - 7.5 - nH BUK714R1-40BT_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 10 February 2009 6 of 13 BUK714R1-40BT NXP Semiconductors N-channel TrenchPLUS standard level FET Table 6. Characteristics …continued Symbol Parameter Conditions Min Typ Max Unit Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; see Figure 16 - 0.85 1.2 V trr reverse recovery time - 70 - ns Qr recovered charge IS = 20 A; dIS/dt = -100 A/µs; VGS = -10 V; VDS = 30 V; Tj = 25 °C - 55 - nC 03nq15 300 20 ID (A) 03nq17 12 Label is VGS (V) RDSon 10 (mΩ) 7 6.5 200 8 6 100 4 5.5 5 4.5 0 0 0 Fig 5. 2 4 6 8 10 VDS (V) Output characteristics: drain current as a function of drain-source voltage; typical values 4 Fig 6. RDSon 6 Lable is VGS (V) 12 16 VGS (V) 20 Drain-source on-state resistance as a function of gate-source voltage; typical values 03aa27 2 03nq16 20 8 a (mW) 6.5 15 1.5 1 10 7 5 8 0.5 10 20 0 0 Fig 7. 100 200 ID (A) 0 -60 300 Drain-source on-state resistance as a function of drain current; typical values Fig 8. 60 120 Tj (°C) 180 Normalized drain-source on-state resistance factor as a function of junction temperature BUK714R1-40BT_2 Product data sheet 0 © NXP B.V. 2009. All rights reserved. Rev. 02 — 10 February 2009 7 of 13 BUK714R1-40BT NXP Semiconductors N-channel TrenchPLUS standard level FET 03aa32 5 ID (A) VGS(th) (V) 4 typ max 10−3 typ 2 min 10−2 max 3 10−4 min 10−5 1 0 −60 Fig 9. 03aa35 10−1 10−6 0 60 120 0 180 2 4 Tj (°C) 6 VGS (V) Gate-source threshold voltage as a function of junction temperature Fig 10. Sub-threshold drain current as a function of gate-source voltage 03nq18 120 03nh35 8000 gfs (S) C (pF) Ciss 6000 80 Coss 4000 40 2000 Crss 0 0 25 50 75 I (A) 100 D Fig 11. Forward transconductance as a function of drain current; typical values 0 10-1 10 VDS (V) 102 Fig 12. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values BUK714R1-40BT_2 Product data sheet 1 © NXP B.V. 2009. All rights reserved. Rev. 02 — 10 February 2009 8 of 13 BUK714R1-40BT NXP Semiconductors N-channel TrenchPLUS standard level FET 03nq19 100 03nq21 10 VGS ID (A) (V) 8 75 VDD = 14 V 6 Tj = 175 °C 50 VDD = 32 V 4 Tj = 25 °C 25 2 0 0 0 2 4 6 VGS (V) Fig 13. Transfer characteristics: drain current as a function of gate-source voltage; typical values 03nq79 1.8 0 25 50 75 Q (nC) 100 g Fig 14. Gate-source voltage as a function of turn-on gate charge; typical values 03nq20 100 IS (A) VF (V) 75 1.6 Tj = 175 °C 1.4 50 1.2 25 Tj = 25 °C 0 1.0 0 50 100 150 T (°C) 200 j Fig 15. Forward voltage of temperature sense diode as a function of junction temperature; typical values 0.0 0.6 0.9 V 1.2 SD (V) Fig 16. Reverse diode current as a function of reverse diode voltage; typical values BUK714R1-40BT_2 Product data sheet 0.3 © NXP B.V. 2009. All rights reserved. Rev. 02 — 10 February 2009 9 of 13 BUK714R1-40BT NXP Semiconductors N-channel TrenchPLUS standard level FET 7. Package outline Plastic single-ended surface-mounted package (D2PAK); 5 leads (one lead cropped) SOT426 A A1 E D1 mounting base D HD 3 1 2 4 e e Lp 5 b e c e Q 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b c D max. D1 E e Lp HD Q mm 4.50 4.10 1.40 1.27 0.85 0.60 0.64 0.46 11 1.60 1.20 10.30 9.70 1.70 2.90 2.10 15.80 14.80 2.60 2.20 OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 05-03-09 06-03-16 SOT426 Fig 17. Package outline SOT426 (D2PAK) BUK714R1-40BT_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 10 February 2009 10 of 13 BUK714R1-40BT NXP Semiconductors N-channel TrenchPLUS standard level FET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes BUK714R1-40BT_2 20090210 Product data sheet - BUK71_794R1_40BT-01 Modifications: BUK71_794R1_40BT-01 (9397 750 13954) • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • Legal texts have been adapted to the new company name where appropriate. Type number BUK714R1-40BT separated from data sheet BUK71_794R1_40BT-01. 20041104 Product data sheet - BUK714R1-40BT_2 Product data sheet - © NXP B.V. 2009. All rights reserved. Rev. 02 — 10 February 2009 11 of 13 BUK714R1-40BT NXP Semiconductors N-channel TrenchPLUS standard level FET 9. Legal information 9.1 Data sheet status Document status [1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 9.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. TrenchMOS — is a trademark of NXP B.V. 10. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com BUK714R1-40BT_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 10 February 2009 12 of 13 BUK714R1-40BT NXP Semiconductors N-channel TrenchPLUS standard level FET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3 Thermal characteristics . . . . . . . . . . . . . . . . . . .5 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . .10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . .12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . .12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Contact information. . . . . . . . . . . . . . . . . . . . . .12 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2009. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: Rev. 02 — 10 February 2009 Document identifier: BUK714R1-40BT_2
BUK714R1-40BT,118 价格&库存
很抱歉,暂时无法提供与“BUK714R1-40BT,118”相匹配的价格&库存,您可以联系我们找货
