EMHJ160ADA331MJA0G
EMHJ160ADA331MJA0G
    NCC(贵弥功)
    径向,Can-SMD
    330 µF 16 V 铝电解电容器 径向,Can - SMD 120 毫欧 @ 100kHz 125°C 时为 2000 小时
EMHJ160ADA331MJA0G 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM AIchip MHJ - Series High heat resistance, 125℃ MHK P128 Lower ESR ・Endurance : 2,000 to 3,000 hours at 125℃ ・Rated voltage range : 10 to 35V ・Nominal capacitance range : 47 to 470µF ・Solvent resistant type (see PRECAUTIONS AND GUIDELINES) ・Vibration resistant structure ・RoHS Compliant ・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information. MHJ Lower ESR MHB P124 ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -40 to +125℃ 10 to 35Vdc (at 20℃, 120Hz) ±20%(M) I=0.01CV Where, I : Max. leakage current (μA), C : Nominal capacitance (μF), V : Rated voltage (V) (at 20℃ after 2 minutes) Rated voltage(Vdc) 10V 16V 25V 35V tanδ(Max.) 0.30 0.23 0.18 0.16 (at 20℃, 120Hz) Rated voltage(Vdc) 10V 16V 25V 35V Z(-25℃)/Z(+20℃) 3 2 2 2 Z(-40℃)/Z(+20℃) 4 3 3 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 3,000 hours (2,000 hours for F80 size) at 125℃. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦300% of the initial specified value Leakage current ≦The initial specified value F80 HA0 JA0 ESR after 2,000 hours 20℃ 3.5 0.60 0.40 (Ω max./100kHz) -40℃ 40 4.5 3.5 The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 125℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦300% of the initial specified value Leakage current ≦The initial specified value Dissipation Factor (tanδ) Low Temperature Characteristics (Max. impedance Ratio) Endurance Shelf Life ◆DIMENSIONS [mm] ● Terminal ● Terminal ● Size Code : A code : F80 to JA0 ● Size Code : G(Vibration resistant structure) Size code code : HA0 to JA0 Vent for JA0 Vent for JA0 0.3max. Note : L±0.3 for F80 3 4 5 6 7 8 9 P 1.9 3.1 4.5 : Dummy terminals ◆PART NUMBERING SYSTEM 2 W 0.5 to 0.8 0.7 to 1.1 0.7 to 1.1 A±0.2 L±0.5 A±0.2 C B A L φD 6.3 7.7 6.6 6.6 7.2 8 10.0 8.3 8.3 9.0 10 10.0 10.3 10.3 11.0 P C±0.2 B±0.2 φD±0.5 P C±0.2 B±0.2 φD±0.5 W 0.3max. L±0.5 (Note) 1 F80 HA0 JA0 W 10 11 12 13 14 15 16 17 ◆MARKING EX) 16V100µF 18 E MH J A A A A D A A A A M A A A G Supplement code Size code Capacitance tolerance code Capacitance code (ex. 47µF:470, 100µF:101) Taping code Terminal code (A, G) Voltage code (ex. 16V:160, 35V:350) Series code Category 5j 100 CHJ ● Rated voltage symbol Rated voltage (Vdc) Symbol A 10 C 16 E 25 V 35 Please refer to "Product code guide (surface mount type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 126 CAT. No. E1001Q SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM AIchip High heat resistance, 125℃ MHJSeries - ◆STANDARD RATINGS WV (Vdc) 10 16 25 35 Cap (µF) Size code 220 330 330 470 100 100 220 330 470 100 220 330 47 47 100 220 HA0 HA0 JA0 JA0 F80 HA0 HA0 JA0 JA0 HA0 JA0 JA0 F80 HA0 HA0 JA0 ESR (Ω max./100kHz) 20℃ -40℃ 0.15 0.15 0.12 0.12 0.45 0.15 0.15 0.12 0.12 0.15 0.12 0.12 0.45 0.15 0.15 0.12 3.0 3.0 2.0 2.0 5.0 3.0 3.0 2.0 2.0 3.0 2.0 2.0 5.0 3.0 3.0 2.0 Rated ripple current (mArms/125℃, 100kHz) 350 350 550 550 220 350 350 550 550 350 550 550 220 350 350 550 Part No. EMHJ100□DA221MHA0G EMHJ100□DA331MHA0G EMHJ100□DA331MJA0G EMHJ100□DA471MJA0G EMHJ160ADA101MF80G EMHJ160□DA101MHA0G EMHJ160□DA221MHA0G EMHJ160□DA331MJA0G EMHJ160□DA471MJA0G EMHJ250□DA101MHA0G EMHJ250□DA221MJA0G EMHJ250□DA331MJA0G EMHJ350ADA470MF80G EMHJ350□DA470MHA0G EMHJ350□DA101MHA0G EMHJ350□DA221MJA0G □ : Enter the appropriate terminal code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Capacitance(µF) Frequency(Hz) 47 to 100 220 to 470 120 0.40 0.50 1k 0.75 0.85 10k 0.90 0.94 100k 1.00 1.00 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 127 CAT. No. E1001Q
EMHJ160ADA331MJA0G
物料型号:AIchip TM-MHJ系列
器件简介: - 耐热性:125℃ - 耐久性:在125℃下2000至3000小时 - 额定电压范围:10至35V - 标称电容范围:47至470微法拉 - 振动抵抗结构 - 符合RoHS标准 - 符合AEC-Q200标准(详情请联系Chemi-Con)
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 工作温度范围:-40至+125°C - 电容公差:±20%(M) - 漏电流:具体数值未提供 - 耗散因子(tan δ):在20°C, 120Hz时,10V时为0.30,16V时为0.23,25V时为0.18,35V时为0.16 - 低温特性:在-25°C和-40°C时的最大阻抗比分别为3和4 - 耐久性:在125°C下3000小时后,电容变化不超过初始值的30%,耗散因子不超过初始值的300%,漏电流不超过初始规定值
功能详解:文档中未提供详细的功能解释。
应用信息:文档中未明确提供应用信息
封装信息: - 尺寸代码:F80至JA0 - 封装尺寸:包括直径(D)、长度(L)、端头外径(A)、端头宽度(B)、端头高度(C)、焊盘宽度(W)和端头间距(P)
EMHJ160ADA331MJA0G 价格&库存
很抱歉,暂时无法提供与“EMHJ160ADA331MJA0G”相匹配的价格&库存,您可以联系我们找货
