Data Sheet
Customer:
Product:
Metal Film Precision MELF Resistor-CSRV Series
Size:
0102/0204/0207
Issued Date:
30-Jun-20
Edition:
REV.B6
VIKING TECH CORPORATION
VIKING TECH CORPORATION KAOHSIUNG BRANCH
VIKING ELECTRONICS (WUXI) CO., LTD.
No.70 Guangfu N. Rd., Hukou
Township, Hsinchu County 303,
Taiwan
No.248-3, Sin-Sheng Rd., Cian-Jhen Dist., Kaohsiung,
806, Taiwan
TEL:886-3-5972931
FAX:886-3-5972935•886-3-5973494
E-mail:sales@viking.com.tw
TEL:886-7-8217999
FAX:886-7-8228229
No.22 Xixia Road, Machinery & Industry Park,
National Hi-Tech Industrial Development Zone
of Wuxi, Wuxi, Jiangsu Province, China
Zip Code:214028
TEL:86-510-85203339
FAX:86-510-85203667•86-510-85203977
E-mail:china@viking.com.tw
Produced by
(QC)
Checked
(QC)
Approved by
(QC)
Prepared by
(Sales)
30-Jun-20
30-Jun-20
30-Jun-20
30-Jun-20
Susan Huang
J.C. Liu
J.C. Liu
Accepted by
(Customer)
CSRV Series
Features
AEC-Q200 Compliance
Thin film technology
Excellent overall stability
Sn termination on Ni barrier layer
Tight tolerance down to ±0.1%
Extremely low TCR down to ±5 PPM/°C
High power rating up to 1 Watts
SMD enabled structure
Lead-free and RoHS compliant
Applications
Automotive(non-safety parts)
Industrial
Telecommunication
Medical Equipment
Measurement/Testing Equipment
TECHNICAL SPECIFICATIONS
DESCRIPTION
CSRV0102
CSRV0204
CSRV0207
Resistance range
1Ω-1MΩ; 0Ω
0.1Ω-3.4MΩ; 0Ω
0.1Ω-3.4MΩ; 0Ω
±5%;±1%;±0.5%;±0.25%;±0.1%
Resistance tolerance
±100ppm/℃; ±50ppm/℃;
±25ppm/℃; ±15ppm/℃
Temperature coefficient
Operation mode
Standard
Power rating P70
1/8W
1/5W
Operating voltage Umax.
150V
200V
±100ppm/℃; ±50ppm/℃; ±25ppm/℃;
±15ppm/℃; ±10ppm/℃; ±5ppm/℃
High power
Standard
High power
Standard
High power
0.3W
1/4W
2/5W
1/2W
1W
200V
200V
200V
300V
350V
-55℃~155℃
Operating temperature range
Max. resistance change at P70
for resistance range,
ΔR/R max., after 1000 h
≦0.5%
≦0.5%
≦0.5%
Construction & Dimension
www.viking.com.tw
Insulation Coating
Electrode Cap
Trimming Line
Resistor Layer
Ceramic Rod
Marking
Type
L
(mm)
L1 min.
(mm)
ΦD
(mm)
ΦD1
(mm)
K
(mm)
Weight
1,000EA
(g)
CSRV0102
2.20±0.10
1.1
1.10±0.10
D +0/-0.15
0.45±0.05
7.7
CSRV0204
3.50±0.2
1.7
1.40±0.15
D +0/-0.2
0.8±0.1
18.7
CSRV0207
5.90±0.2
2.9
2.20±0.20
D +0/-0.2
1.3±0.1
80.9
For detail questions, contact sales@viking.com.tw
1
Edition: REV.B6
Revision: 30-Jun-2020
CSRV Series
Part Numbering
Part Number
Part Number
CSRV0204DTDV1001
CSRV0204JT-VR0R0
C
S
R
V
D
T
C
S
R
V
J
T
Product
Type
CSRV
Dimensions
(L×ΦD)
0102: 2.2x1.1
0204: 3.5x1.4
0207: 5.9x2.2
Resistance
Tolerance
B: ±0.1%
C: ±0.25%
D: ±0.5%
F: ±1%
J: ±5%
TCR
(PPM/°C)
Packaging
Code
T: Taping Reel
Recommend Land Pattern
D
S: ±5
B: ±10
N: ±15
C: ±25
D: ±50
E: ±100
-: Jumper
V
1
V
R
R
Power
Rating
T: 1W
U: 1/2W
V: 1/4W
G: 2/5W
P: 1/5W
W: 1/8W
L: 0.3W
Resistance
0010: 1Ω
0100: 10Ω
2201: 2200Ω
1001: 1KΩ
1004: 1MΩ
R050: 0.05Ω
22R1: 22.1Ω
R0R0: 0Ω
Derating
Curve
Derating
Curve
100
A
Type
A
(mm)
B
(mm)
C
(mm)
CSRV0102
1.0
0.8
1.5
CSRV0204
1.6
1.2
1.6
CSRV0207
3.0
1.7
2.4
Power ratio (%)
B
C
80
Except
for 5ppm
60
5ppm
40
60
80
100
120
140
160
Ambient Temperature ( ℃ )
Soldering Condition
IR Reflow Soldering
Wave Soldering (For R>10Ω)
(1) Time of IR reflow soldering at maximum temperature point 260C:10s
(2) Time of wave soldering at maximum temperature point 260C:10s
(3) Time of soldering iron at maximum temperature point 410C:5s
www.viking.com.tw
2
Edition: REV.B6
CSRV Series
Standard Electrical Specifications
Item
Type
0102
Power
Rating
at 70 C
1/8W
Operating
Max.
Max.
Temp.
Operating Overload
Range
Voltage
Voltage
-55 ~
+155C
150V
300V
Resistance Range
±0.1%
±0.25%
±0.5%
100Ω-56KΩ
49.9Ω100Ω-82KΩ
200KΩ
TCR
(PPM/ C)
±1%
±5%
49.9Ω390KΩ
1Ω-1MΩ
0204
200V
400V
200V
400V
1Ω-1MΩ
0207
600V
±10
10Ω-300KΩ
±15
10Ω-3.4MΩ
1Ω-3.4MΩ
±25
1Ω-3.4MΩ
0.2Ω-3.4MΩ
±50
0.1Ω-1MΩ
±100
0Ω(
很抱歉,暂时无法提供与“CSRV0204FTCV0100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.23650
- 200+0.15180
- 1500+0.13200
- 3000+0.11660
- 国内价格
- 20+0.27130
- 200+0.21892
- 600+0.18987
- 3000+0.15682
- 9000+0.14170
