RJM73P0204F2T1005
RJM73P0204F2T1005
    THUNDER(盛雷城)
    MELF0204
    MELF电阻 MELF0204 10MΩ ±1% 1/4W ±50ppm/℃
RJM73P0204F2T1005 数据手册
APPROVAL SHEET RJM SERIES MELF TYPE METAL FILM RESISTORS RJM 系列 PRODUCE CHECK AND APPROVE ACCEPTED BY EM CE HONORABLE CUSTOMER Edison Chen Charles Chen March 05,2024 March 06,2024 www.thunder-resistor.com sales@thunder-resistor.com 1 of 9 1. PRODUCT: METAL FILM MELF TYPE PRECISION RESISTORS 2. PART NUMBER: Part number of the melf type precision metal film resistor is identified by the type name, power rating, size code, tolerance, temperature coefficient, packing type and resistance value. Example: RJM 16M Series Name Size Code 0207 Metric Size F 2 Resistance Tolerance T Temperature Packing Coefficient Style of Resistance 1004 Resistance Value (1) Type name: RJM series (2) Power Rating: 72P=0.20W; 73P=0.25W; 74M=0.4W; 74P=0.60W; 16M=1.0W; 17M=2W; 18M=3W (3) Metric size: DIN: 0102, DIN: 0204, DIN:0207, DIN0411, DIN0617 (4) Tolerance: W=±0.05%; B=±0.1%; C=±0.25%; D=±0.5%; F=±1%; G=±1% (5) T.C.R.: 7= 5ppm/℃; 6= 10ppm/℃; 5=15ppm/℃; 3=25ppm/℃; 2= 50ppm/℃; 1=100ppm/℃; 0=No TCR test and request (6) Packaging Type: 3. B=BULK/BOX T=REEL/BOX (7) Resistance Value: 100K(1003); 22K5(2252); 10R(10R0); 1.8R(1R80); 0.99R(R990)……… 2K15(2151); (8) RJM73P020400TR000 and RJM74P020700TR000 are jumpers with resistance lower than 15mΩ Structure of the resistors: www.thunder-resistor.com sales@thunder-resistor.com 2 of 9 120R(1200); 4. COLOR BAND-CODE: Four color bands codes for size 0102 and 0204. Five color bands for size 0207, 0411, 0516 www.thunder-resistor.com sales@thunder-resistor.com 3 of 9 5. ELECTRICAL CHARACTERISTICS * Unless otherwise specified, all values are tested at the following condition: Temperature: 21℃ to 25℃; Relative humidity: 45% to 70%; The parts must be well soldering with good soldering pads. * Rated Continuous Working Voltage (RCWV)= * Resistance value out of range is available on request. * Terminal caps of the resistors are all with three electroplating: the inner is copper Power Rating  Resistance Value plating + nickel plating to minimize the tin whisker phenomenon and final plating is tin to improve the solderability. The thickness of 3 layers of 0204 size are Cu:>0.8μm + Ni:3μm. * The post high temperature treatment after final tin plating is strictly controlled by our production procedure to minimize the tin whisker phenomenon * The resistances of all jumpers are lower than 15mΩ www.thunder-resistor.com sales@thunder-resistor.com 4 of 9 6. Derating curves The power dissipation on the resistor generates a temperature rise against the local ambient, depending on the heat flow support of the printed-circuit board (thermal resistance). The rated dissipation applies only if the permitted film temperature is not exceeded. These resistors do not feature a limited lifetime when operated within the permissible limits. However, resistance value drift increasing over operating time may result in exceeding a limit acceptable to the specific application, thereby establishing a functional lifetime. For MELF resistors working at an ambiance temperature of 70℃ or above, the power rating shall be derated in accordance with the above curves. 7. Pulse load capability www.thunder-resistor.com sales@thunder-resistor.com 5 of 9 8. ENVIRONMENTAL CHARACTERISTICS (1) Temperature Coefficient Test IEC 60115-1, 4.8: Test of resistors at room temperature and 60°C (or 100°C upon request) above room temperature. Then measure the resistance. The Temperature Coefficient is calculated by the following equation and its value should be within the range requested. Re sistor Temperature Coefficient  R R0 t t0 R  R0 1   10 6 R0 t  t0 = Resistance value under the testing temperature = Resistance value at the room temperature = the 2nd testing temperature = Room temperature (2) Short Time Over Load Test IEC60115-1 4.13: At 2.5 times rated voltage or 2 times the maximum working voltage whichever is lower for 5 seconds, the resistor should be free from defects. The change of the resistance value should be within ±(0.1%+0.05Ω) for resistors with tight tolerance and within ± (0.2%+0. 05Ω) for resistors with normal tolerance and tiny size as compared with the value before the load. (3) Solderability IEC 60115-1, 4.17: 235±5°C for 3±0.5 Seconds, there are at least 95% solder coverage on the termination. (4) Resistance to soldering heat: IEC 60115-1, 4.18: 260±3°C for 10±1 Seconds, immersed to a point 3±0.5mm from the body. The change of the resistance value should be within ±(0.15%+0.05Ω) as compared with the value before the test. (5) Rapid change of temperature (Thermal shock) IEC 60115-1, 4.19: 30 min at LCT; 30 min at UCT; LCT = -55°C; UCT = 125°C. 5 cycle from LCT to room Temp. and to UCT and to room Temp.. The change of the resistance value shall be within ±(0.25%+0.05Ω) for resistors with tight tolerance and within ±(0.50%+0.05Ω) for resistors with normal tolerance and tiny size as compared with the value before the load. www.thunder-resistor.com sales@thunder-resistor.com 6 of 9 (6) Damp Heat Steady State IEC 60115-1, 4.24: 40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV or the maximum working voltage whichever is lower. The change of the resistance value should be within ± (0.25%+0. 05Ω) for resistors with tight tolerance and within ± (1%+0. 05Ω) for resistors with normal tolerance and tiny size as compared with the value before the load. (7) Load Life Test IEC 60115-1, 4.25: 70±2°C at RCWV or the maximum working voltage whichever is lower for 1,000+48/-0 Hr. (1.5Hr. on, 0.5Hr. off). The resistors shall be arranged not much effected mutually by the temperature of others and the excessive ventilation shall not be performed. The change of the resistance value should be within ± (0.25%+0. 05Ω) for resistors with tight tolerance and within ± (1%+0. 05Ω) for resistors with normal tolerance and tiny size as compared with the value before the load. (8) Endurance at upper category temperature IEC60115-1, 4.25.3: put resistors in over with temperature at 125 °C for 1000h. The change of the resistance value should be within ± (0.25%+0. 05Ω) for resistors with tight tolerance and within ± (1%+0. 05Ω) for resistors with normal tolerance and tiny size as compared with the value before the load. (9)Accidental Overload Test IEC 60115-1, 4.26: 4 times RCWV or 2 times the maximum working voltage whichever is lower for 1 Minute. No evidence of flaming or arcing. (10) Component solvent resistance IEC 60115-1, 4.29: Isopropyl alcohol; 50 °C; method 2. No visible damage. (11) Solvent resistance of marking IEC 60115-1, 4.30: Isopropyl alcohol; 50 °C; method 1, toothbrush. Marking legible; no visible damage www.thunder-resistor.com sales@thunder-resistor.com 7 of 9 (12) Resistance to Solvent IEC 60115-1, 4.30: IPA for 5±0.5 Min. with ultrasonic. Marking legible; no visible deterioration occurred. (13) Flammability IEC 60115-1, 4.35: IEC 60695-11-5 (1), needle flame test; 10 s. No burning after 30 seconds. (14) Damp heat, steady state, accelerated IEC 60115-1, 4.37: (85 ± 2)°C, (85 ± 5)% RH; U = 0.3 x RCWV or U = 0.3 x Umax or 100V whichever is lower for 1000 hours. The change of the resistance value should be within ±(0.25%+0.05Ω) for resistors with tight tolerance and within ±(1%+0. 05Ω) for resistors with normal tolerance and tiny size as compared with the value before the load. (15) Electrostatic discharge (Human Body Model) IEC 60115-1, 4.38: IEC 61340-3-1 (1); 3 pos. + 3 neg. discharges. RJM72P0102: 1.5kV; RJM73P0204: 2kV; RJM74P0207: 3kV; RJM16M0207: 3 kV; RJM17M0411: 4kV; RJM18M0617: 6kV The change of the resistance value should be within ±(0.50%+0. 05Ω) as compared with the value before the load. www.thunder-resistor.com sales@thunder-resistor.com 8 of 9 Disclaimer All products, product specifications and data are subject to change without notice to improve reliability, function or design or otherwise. Thunder Precision Resistors makes no warranty, representation or guarantee regarding the suitability of the products for any particular purpose or the continuing production of any product to the maximum extent permitted by applicable law. www.thunder-resistor.com sales@thunder-resistor.com 9 of 9
RJM73P0204F2T1005 价格&库存
很抱歉,暂时无法提供与“RJM73P0204F2T1005”相匹配的价格&库存,您可以联系我们找货
