SS12 THRU SS120
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 20 to 200 V
Forward Current - 1.0 A
1
2
SMAF
FEATURES
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
∠ALL ROUND
C
A
∠ALL ROUND
D
g
g
pad
e
E
MECHANICAL DATA
• Case: SMAF
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 27mg / 0 . 00095oz
E
A
V M
A
pad
HE
Top View
mm
mil
Bottom View
A
C
D
E
e
g
HE
max
1.2
0.20
3.7
2.7
1.6
1.2
4.9
UNIT
min
0.9
0.12
3.3
2.4
1.3
0.8
4.4
max
47
7.9
146
106
63
47
193
min
35
4.7
130
94
51
31
173
7°
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Symbols
SS12
SS14
Maximum Repetitive Peak Reverse Voltage
V RRM
60
80
Maximum RMS voltage
V RMS
14
28
42
Maximum DC Blocking Voltage
V DC
60
Maximum Average Forward Rectified Current
I F(AV)
1.0
A
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
30
A
Parameter
Max Instantaneous Forward Voltage at 1 A
Maximum DC Reverse Current
T a = 25°C
at Rated DC Reverse Voltage
T a =100°C
Typical Junction Capacitance (1)
Typical Thermal Resistance (2)
Operating Junction Temperature Range
Storage Temperature Range
VF
SS16
0.55
SS112
SS115
SS120
100
120
150
200
V
56
70
84
105
140
V
80
100
120
150
200
V
SS110
SS18
0.70
0.3
10
IR
110
Cj
Units
0.85
0.90
V
0.2
5
0.1
2
mA
80
pF
°C/W
RθJA
95
Tj
-55 ~ +125
°C
T stg
-55 ~ +150
°C
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
SS12 THRU SS120
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
Average Forward Current (A)
1.2
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
10 4
10 3
T J =100°C
10 2
T J =75°C
10 1
T J =25°C
10 0
Case Temperature (°C)
40
60
80
100
Fig.4 Typical Junction Capacitance
500
Junction Capacitance ( pF)
1.0
SS12F/SS14F
SS16F/SS18F
SS110F/SS112F
SS115F/SS120F
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
T J =25°C
200
100
50
SS12F/SS14F
SS16F-SS120F
10
1.8
1
0.1
100
10
Instaneous Forward Voltage (V)
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
Fig.3 Typical Forward Characteristic
Peak Forward Surage Current (A)
Percent of Rated Peak Reverse Voltage(%)
50
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles at 60Hz
1000
100
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
The recommended mounting pad size
2.2
(86)
1.6
(63)
1.8
(71)
1.6
(63)
mm
Unit :
(mil)
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“SS14”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.09730
- 500+0.07893
- 3000+0.06659
- 6000+0.06046
- 24000+0.05512
- 51000+0.05220
