SHLDP-20V-S-1(B)
SHLDP-20V-S-1(B)
    JST
    P=1mm
    2X10P 1MM
SHLDP-20V-S-1(B) 数据手册
SHLD CONNECTOR Emboss Emboss Tape Tape 1.0 mm pitch/Disconnectable Crimp style connectors SHLD CONNECTOR Specifications • Current rating: 1.0 A AC/DC (AWG #28) • Voltage rating: 50 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 30 mΩ max. After environmental tests/ 40 mΩ max. • Insulation resistance: 100 MΩ min. • Withstanding voltage: 500 VAC/minute Developed for PDP, LCD or small electronics equipment. This is a dual-row small crimp type connector with a secure locking system or without-designed for different applications. The PC board layout is compatible with that of existing SHD connector, which allows for replacement of the above existing connector. Secure housing lock structure (for locking type) Prevent deformation of contacts A contact lock structure Strong structure against external force ® Standards ® ® ® PC board layout and Assembly layout ® 0.6 0.9±0.1 Side entry type 0.85±0.1 1 4.6 0.6 ±0.1 Connector outline 1.8 ±0.1 4.1 0.85 ±0.1 0.9 1.6 4.2 (7.3) 7.2 1.8±0.1 4 0.5 Circuit No.1 (9.05) 6.7 5.4 Circuit No.1 5.4 1.6 1±0.1 6.6 (5.8) 5.6 Top entry type Recognized E60389 (6.15) ● ● ● ● * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. 1.25±0.1 VHコネクタ表1 Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ± 0.1 mm for all centers. The dimensions above should serve as a guideline. Contact JST for details. Contact Applicable wire mm2 AWG # Model No. SSHL-003GA1-P0.2 0.5 2 0.032~0.08 4.75 0.8 0.4~0.8 41,000 Material and Finish 2.35 Phosphor bronze, nickel-undercoated, Mating part; gold-plated, Crimping part; gold-plated 0.8 0.4 RoHS2 compliance Contact Crimping machine Crimp applicator SSHL-003GA1-P0.2 AP-K2N 1 Insulation O.D. (mm) Q'ty/reel 32~28 MKS-L-10-3 Applicator Dies Crimp applicator with dies MK/SSH/L-003-02 APLMK SSHL002-02 Note: Contact JST for fully automatic crimping applicator. VHコネクタ表1 SHLD CONNECTOR Housing No. of circuits B A 20 1 30 40 Polarity rib Circuit No.1 mark 4.6 C 9.0 11.4 13.0 3,500 14.0 16.4 18.0 2,500 19.0 21.4 23.0 2,000 24.0 26.4 28.0 1,500 Material and Finish PBT, UL94V-0, natural (white) With secure lock type No. of circuits With secure lock type 20 B 30 40 1 Model No. SHLDP-20V-S-1(B) SHLDP-30V-S-1(B) SHLDP-40V-S-1(B) SHLDP-50V-S-1(B) 2.6 50 5.7 6 Polarity rib Dimensions (mm) B C Q'ty/bag 14.7 15.7 3,000 14.0 19.7 20.7 2,000 19.0 24.7 25.7 1,500 24.0 29.7 30.7 1,200 9.0 PBT, UL94V-0, natural (white) RoHS2 compliance 4.6 VHコネクタ表1 5.4 C A Material and Finish N-1 Circuit No.1 mark Q'ty/bag RoHS2 compliance 5.4 A Dimensions (mm) B C SHLD CONNECTOR VHコネクタ表1 N-1 A SHLDP-20V-S(B) SHLDP-30V-S(B) SHLDP-40V-S(B) SHLDP-50V-S(B) 5.7 2.6 50 Model No. Shrouded header No. of circuits Top entry type 20 30 4.05 40 0.2 1.5 1 A 50 Model Top entry type BM20B-SHLDS-G-TFT BM30B-SHLDS-G-TFT BM40B-SHLDS-G-TFT BM50B-SHLDS-G-TFT No. Side entry type SM20B-SHLDS-G-TF SM30B-SHLDS-G-TF SM40B-SHLDS-G-TF SM50B-SHLDS-G-TF Dimensions (mm) Q'ty/reel A B Top type Side type 9.0 13.0 1,400 1,000 14.0 18.0 1,400 1,000 19.0 23.0 1,400 1,000 24.0 28.0 1,400 1,000 Material and Finish 0.8 5 Contact: Phosphor bronze, nickel-undercoated, gold-plated Wafer: PA, UL94V-0, natural (ivory) Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment) B RoHS2 compliance This product displays (LF)(SN) on a label. Side entry type 5.45 Circuit No.1 0.2 1 A B 1.45 0.75 0.55 1.5 5.4 2
SHLDP-20V-S-1(B) 价格&库存
很抱歉,暂时无法提供与“SHLDP-20V-S-1(B)”相匹配的价格&库存,您可以联系我们找货
SHLDP-20V-S-1(B)
    • 1+2.060331+0.26668
    • 100+1.80716100+0.23391
    • 300+1.44922300+0.18758
    • 500+1.37065500+0.17741
    • 1000+1.318261000+0.17063
    • 4000+1.274614000+0.16498
    库存:4
    SHLDP-20V-S-1(B)
      • 1+1.957311+0.25335
      • 100+1.71680100+0.22222
      • 300+1.37676300+0.17821
      • 500+1.30211500+0.16854
      • 1000+1.252351000+0.16210
      • 4000+1.210884000+0.15674
      • 5000+1.210885000+0.15674
      库存:1356
      SHLDP-20V-S-1(B)
        • 1+2.610331+0.33787
        • 10+2.3135110+0.29945
        • 50+1.7809650+0.23052
        • 100+1.42303100+0.18419
        • 500+1.35318500+0.17515
        • 1000+1.292071000+0.16724
        • 2000+1.265882000+0.16385
        库存:306
        SHLDP-20V-S-1(B)
          • 1+1.98337
          库存:4
          SHLDP-20V-S-1(B)
            库存:2781
            SHLDP-20V-S-1(B)
              • 10+0.85792
              库存:39
