SMBJ8.0CA
SMBJ8.0CA
    FTR(乔光电子)
    SMB(DO-214AA)
    双向TVS 8V截止 峰值浪涌电流:44.2A
SMBJ8.0CA 数据手册
SMBJ Series Transient Voltage Suppressors (TVS) Data Sheet Features ■ ■ ■ ■ ■ ■ ■ ■ Glass passivated junction Low zener impedance Excellent clamping capability 600W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle):0.01% Fast response time Typical IR less than 1μA above 11V. Plastic package has underwriters laboratory flammability 94V-0 Meets MSL level 1, per J-STD-020. Mechanical Data ■ ■ ■ ■ Case: JEDEC DO-214AAMoulded plastic Terminal:solderplated, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode except bi-directional models Mounting Position: Any Applications ■ I/O interface ■ AC/DC power supply ■ Low frequency signal transmission line (RS232, RS485, etc.) Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Rating Symbol Value Units Peak pulse power dissipation at 10/1000μs waveform (Note1, Fig.1) PPPM Minimum 600 Watts Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table Amps PM(AV) 5.0 Watts IFSM 100 Amps TJ,TSTG -55 to +150 ℃ Typical thermal resistance junction to lead RθJL 20 ℃/W Typical thermal resistance junction to ambient RθJA 100 ℃/W Steady state power dissipation at TL=75℃ (Fig.4) Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note2) Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2. 2. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. Revision:10-May-18 1/6 www.ftrqg.com SMBJ Series Dimensions (DO-214AA/SMB) Millimeters Inches Symbol D1 D L H d T1 T Min. Max. Min. Max. L 4.06 4.75 0.160 0.187 D 3.30 3.94 0.130 0.155 D1 1.95 2.20 0.077 0.086 T 5.18 5.59 0.204 0.220 T1 0.76 1.52 0.030 0.060 d - 0.203 - 0.008 H 1.99 2.61 0.078 0.103 Electrical Characteristics (TA=25℃) Part Number Unidirectional Bidirectional Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current UNI BI VRWM(V) VBR(V) IT(mA) Maximum Clamping Voltage@ IPP VC(V) Peak Pulse Current Reverse Leakage @VRWM IPP(A) IR(μA) SMBJ5.0A SMBJ5.0CA KE AE 5.0 6.4~7.0 10 9.2 65.2 800 SMBJ6.0A SMBJ6.0CA KG AG 6.0 6.7~7.4 10 10.3 58.3 800 SMBJ6.5A SMBJ6.5CA KK AK 6.5 7.2~8.0 10 11.2 53.57 500 SMBJ7.0A SMBJ7.0CA KM AM 7.0 7.8~8.6 10 12.0 50.0 200 SMBJ7.5A SMBJ7.5CA KP AP 7.5 8.3~9.2 1 12.9 46.5 100 SMBJ8.0A SMBJ8.0CA KR AR 8.0 8.9~9.8 1 13.6 44.1 50 SMBJ8.5A SMBJ8.5CA KT AT 8.5 9.4~10.4 1 14.4 41.7 10 SMBJ9.0A SMBJ9.0CA KV AV 9.0 10.0~11.0 1 15.4 39.0 5 SMBJ10A SMBJ10CA KX AX 10.0 11.1~12.3 1 17.0 35.3 5 SMBJ11A SMBJ11CA KZ AZ 11.0 12.2~13.5 1 18.2 33.0 1 SMBJ12A SMBJ12CA LE BE 12.0 13.3~14.7 1 19.9 30.2 1 SMBJ13A SMBJ13CA LG BG 13.0 14.4~15.9 1 21.5 28.0 1 SMBJ14A SMBJ14CA LK BK 14.0 15.6~17.2 1 23.2 25.9 1 SMBJ15A SMBJ15CA LM BM 15.0 16.7~18.5 1 24.4 24.6 1 SMBJ16A SMBJ16CA LP BP 16.0 17.8~19.7 1 26.0 23.1 1 SMBJ17A SMBJ17CA LR BR 17.0 18.9~20.9 1 27.6 21.8 1 SMBJ18A SMBJ18CA LT BT 18.0 20.0~22.1 1 29.2 20.6 1 SMBJ19A SMBJ19CA LW BW 19.0 21.1~23.3 1 30.8 19.5 1 SMBJ20A SMBJ20CA LV BV 20.0 22.2~24.5 1 32.4 18.6 1 SMBJ22A SMBJ22CA LX BX 22.0 24.4~26.9 1 35.5 16.9 1 SMBJ24A SMBJ24CA LZ BZ 24.0 26.7~29.5 1 38.9 15.5 1 SMBJ26A SMBJ26CA ME CE 26.0 28.9~31.9 1 42.1 14.3 1 Revision:10-May-18 2/6 www.ftrqg.com SMBJ Series Electrical Characteristics (TA=25℃) Part Number Unidirectional Bidirectional Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT UNI BI VRWM(V) VBR(V) IT(mA) Maximum Clamping Voltage@ IPP VC(V) Test Current Peak Pulse Current Reverse Leakage @VRWM IPP(A) IR(μA) SMBJ28A SMBJ28CA MG CG 28.0 31.1~34.4 1 45.4 13.3 1 SMBJ30A SMBJ30CA MK CK 30.0 33.3~36.8 1 48.4 12.4 1 SMBJ33A SMBJ33CA MM CM 33.0 36.7~40.6 1 53.3 11.3 1 SMBJ36A SMBJ36CA MP CP 36.0 40.0~44.2 1 58.1 10.4 1 SMBJ40A SMBJ40CA MR CR 40.0 44.4~49.1 1 64.5 9.3 1 SMBJ43A SMBJ43CA MT CT 43.0 47.8~52.8 1 69.4 8.7 1 SMBJ45A SMBJ45CA MV CV 45.0 50.0~55.3 1 72.7 8.3 1 SMBJ48A SMBJ48CA MX CX 48.0 53.3~58.9 1 77.4 7.8 1 SMBJ51A SMBJ51CA MZ CZ 51.0 56.7~62.7 1 82.4 7.3 1 SMBJ54A SMBJ54CA NE DE 54.0 60.0~66.3 1 87.1 6.9 1 SMBJ58A SMBJ58CA NG DG 58.0 64.4~71.2 1 93.6 6.5 1 SMBJ60A SMBJ60CA NK DK 60.0 66.7~73.7 1 96.8 6.2 1 SMBJ64A SMBJ64CA NM DM 64.0 71.1~78.6 1 103.0 5.9 1 SMBJ70A SMBJ70CA NP DP 70.0 77.8~86.0 1 113.0 5.3 1 SMBJ75A SMBJ75CA NR DR 75.0 83.3~92.1 1 121.0 5.0 1 SMBJ78A SMBJ78CA NT DT 78.0 86.7~95.8 1 126.0 4.8 1 SMBJ80A SMBJ80CA NW DW 80.0 88.8~97.6 1 129.6 4.6 1 SMBJ85A SMBJ85CA NV DV 85.0 94.4~104 1 137.0 4.4 1 SMBJ90A SMBJ90CA NX DX 90.0 100~111 1 146.0 4.1 1 SMBJ100A SMBJ100CA NZ DZ 100.0 111~123 1 162.0 3.7 1 SMBJ110A SMBJ110CA PE FE 110.0 122~135 1 177.0 3.4 1 SMBJ120A SMBJ120CA PG FG 120.0 133~147 1 193.0 3.2 1 SMBJ130A SMBJ130CA PK FK 130.0 144~159 1 209.0 2.9 1 SMBJ140A SMBJ140CA PL FL 140.0 155~171 1 227.0 2.7 1 SMBJ150A SMBJ150CA PM FM 150.0 167~185 1 243.0 2.5 1 SMBJ160A SMBJ160CA PP FP 160.0 178~197 1 259.0 2.3 1 SMBJ170A SMBJ170CA PR FR 170.0 189~209 1 275.0 2.2 1 SMBJ180A SMBJ180CA PT FT 180.0 200~220 1 291.0 2.1 1 SMBJ190A SMBJ190CA PU FU 190.0 211~232 1 308.0 2.0 1 SMBJ200A SMBJ200CA PV FV 200.0 224~247 1 324.0 1.9 1 SMBJ220A SMBJ220CA PX FX 220.0 246~272 1 356.0 1.7 1 SMBJ250A SMBJ250CA PZ FZ 250.0 279~309 1 405.0 1.5 1 SMBJ300A SMBJ300CA QE GE 300.0 335~371 1 486.0 1.3 1 SMBJ350A SMBJ350CA QG GG 350.0 391~432 1 567.0 1.1 1 SMBJ400A SMBJ400CA QK GK 400.0 447~494 1 648.0 0.9 1 SMBJ440A SMBJ440CA QM FM 440.0 492~543 1 713.0 0.9 1 Notes: For bidirectional type having VRWM of 10V and less, the IR limit is double. Revision:10-May-18 3/6 www.ftrqg.com SMBJ Series Recommended Soldering Conditions Reflow Soldering Critical Zone TL to TP tP TP Ramp-up TL tL Temperature TS max TS min Ramp-down tS Preheat 25 t 25 to Peak Time Recommended Conditions Profile Feature Pb-Free Assembly Average ramp-up rate (TLto TP) 3℃/second max. Preheat -Temperature Min (TS min) -Temperature Max (TS max) -Time (min to max)( tS) 150℃ 200℃ 60-180 seconds TS maxto TL -Ramp-up Rate 3℃/second max. Time maintained above: -Temperature (TL) -Time (tL) 217℃ 60-150 seconds Peak Temperature (TP) 260℃ Time within 5℃ of actual PeakTemperature (tP) Ramp-down Rate 6℃/second max. Time 25℃ to Peak Temperature Revision:10-May-18 20-40 seconds 8 minutes max. 4/6 www.ftrqg.com SMBJ Series Partnumber code SMBJ 18 CA FTR XXXX Bidirectional XX (A:Uni-directional) VRWM Voltage FTR logo Date Code Marking Code Series Code Ratings and Characteristic Curves (T A=25℃ unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve Figure 4. Steady State Power Dissipation Derating Figure 3. Pulse Waveform Revision:10-May-18 Curve 5/6 www.ftrqg.com SMBJ Series Packaging Tape P0 Symbol Dimension (mm) W 12.00±0.10 P0 4.00±0.10 P1 8.00±0.10 P2 2.00±0.10 D0 Φ1.55±0.10 D1 Φ1.5±0.10 E 1.75±0.10 F 5.50±0.10 A0 A0 3.80±0.1 SECTION A-A B0 5.40±0.1 K0 2.45±0.1 T 0.25±0.1 D5 Φ330.0±2.0 D6 Φ13.5±0.5 H 2.5±1.0 W2 16.0±2.0 P1 P2 D0 B T E F W B0 D1 A A K0 B SECTION B-B Reel Quantity: 3000PCS Revision:10-May-18 6/6 www.ftrqg.com
SMBJ8.0CA 价格&库存
很抱歉,暂时无法提供与“SMBJ8.0CA”相匹配的价格&库存,您可以联系我们找货
