VDR4032K471G2
VDR4032K471G2
    VDRSAS(嵩隆)
    SMD
    775V 60J
VDR4032K471G2 数据手册
VDR HUIZHOU SHI SONGLONG LISHANG ELECTRONICS CO.,LTD ---------------------------------------------------------------------------------------------------------------------------------------------------------------- VDR-4032 SMD Disc Varistors FEATURES ■ Improved component design in a compact case ■ High surge current capability ■ Superior performance at high temperature ■ SMD mountable disk varistors, suitable for lead-free reflow / wave soldering APPLICATIONS ■ Power supplies for telecommunication systems ■ Protection for LED circuits ■ Protection for consumer, industrial equipment ■ Protection for automotive electronics APPLICABLE STANDARDS ■ UL1449 TYPE5 E525940 ■ TUV B115439 002 IEC61051-1, -2, -2-2, IEC60950-1Annex Q IEC 62368-1:2018/G.8.1 ■ IEC61000-4-5 ■ GB/T10193-1997 GB/T10194-1997/GB8898 GB4943.1 CQCNO:22001333056 TYPE CODE DESIGNATION ==================================================================================================== HUIZHOU SHI SONGLONG LISHANG ELECTRONICS CO.,LTD 1/9 TEL:0752-3728085 /FAX:0752-3728399 VDR HUIZHOU SHI SONGLONG LISHANG ELECTRONICS CO.,LTD ---------------------------------------------------------------------------------------------------------------------------------------------------------------- General parameters Parameter name Parameter value UNIT working temperature -55 — +125 ℃ Storage temperature -55 — +125 ℃ Withstand voltage ≥2.5 KVRMS Insulation resistance ≥100 MΩ Structure and size (UNIT:mm) size Varistor voltage range (V) 4032 V1ma=201—681 V1ma=751—821 L W 11.0±0.3 8.2±0.3 H 4.8±0.3 5.5±0.3 Welding size (UNIT:mm) SIZE A B C L 4032 3.5 2.8 6.5 12.1 ==================================================================================================== HUIZHOU SHI SONGLONG LISHANG ELECTRONICS CO.,LTD 2/9 TEL:0752-3728085 /FAX:0752-3728399 VDR HUIZHOU SHI SONGLONG LISHANG ELECTRONICS CO.,LTD ---------------------------------------------------------------------------------------------------------------------------------------------------------------- Electrical characteristics (Standard) Varistor voltage Model (@1mA DC) V1mA (V) Maximum Clamping Voltage VAC (V) VDC (V) Maximum Allowable Voltage (8/20μs) Vp Ip (V) (A) Typical Max Surge Energy 8/20μs (10/1000μs) Rated Powe Capacitance (Reference) @1KHZ I max W max P (A) (J) (W) C(pF) 4032K201 200(180-220) 130 170 340 25 2500 25.0 0.4 500 4032K221 220(198-242) 140 180 360 25 2500 27.0 0.4 450 4032K241 240(216-264) 150 200 395 25 2500 30.0 0.4 420 4032K271 270(243-297) 175 225 455 25 2500 35.0 0.4 370 4032K301 300(270-330) 195 250 500 25 2500 40.0 0.4 330 4032K331 330(297-363) 210 275 550 25 2500 42.0 0.4 300 4032K361 360(324-396) 230 300 595 25 2500 45.0 0.4 280 4032K391 390(351-429) 250 320 650 25 2500 50.0 0.4 260 4032K431 430(387-473) 275 350 710 25 2500 55.0 0.4 230 4032K471 470(423-517) 300 385 775 25 2500 60.0 0.4 210 4032K511 510(459-561) 320 410 845 25 2500 67.0 0.4 200 4032K561 560(504-616) 350 450 930 25 2500 69.0 0.4 180 4032K621 620(558-682) 395 510 1020 25 2500 70.0 0.4 160 4032K681 680(612-748) 420 560 1120 25 2500 72.0 0.4 150 4032K751 750(675-825) 460 615 1235 25 2500 75.0 0.4 130 ==================================================================================================== HUIZHOU SHI SONGLONG LISHANG ELECTRONICS CO.,LTD 3/9 TEL:0752-3728085 /FAX:0752-3728399 VDR HUIZHOU SHI SONGLONG LISHANG ELECTRONICS CO.,LTD ---------------------------------------------------------------------------------------------------------------------------------------------------------------- Electrical characteristics (High energy) Varistor voltage Model (@1mA DC) V1mA (V) Maximum Clamping Voltage VDC VAC (V) (V) Maximum Allowable Voltage (8/20μs) Vp Ip (V) (A) Typical Max Surge Energy 8/20μs (10/1000μs) Rated Powe Capacitance (Reference) @1KHZ I max W max P (A) (J) (W) C(pF) 4032K201-H 200(180-220) 130 170 340 25 3500 35 0.4 500 4032K221-H 220(198-242) 140 180 360 25 3500 39 0.4 450 4032K241-H 240(216-264) 150 200 395 25 3500 42 0.4 420 4032K271-H 270(243-297) 175 225 455 25 3500 49 0.4 370 4032K301-H 300(270-330) 195 250 500 25 3500 54 0.4 330 4032K331-H 330(297-363) 210 275 550 25 3500 58 0.4 300 4032K361-H 360(324-396) 230 300 595 25 3500 65 0.4 280 4032K391-H 390(351-429) 250 320 650 25 3500 70 0.4 260 4032K431-H 430(387-473) 275 350 710 25 3500 80 0.4 230 4032K471-H 470(423-517) 300 385 775 25 3500 85 0.4 210 4032K511-H 510(459-561) 320 410 845 25 3500 90 0.4 200 4032K561-H 560(504-616) 350 450 930 25 3500 92 0.4 180 4032K621-H 620(558-682) 395 510 1020 25 3500 95 0.4 160 4032K681-H 680(612-748) 420 560 1120 25 3500 98 0.4 150 4032K751-H 750(675-825) 460 615 1235 25 3500 100 0.4 130 ==================================================================================================== HUIZHOU SHI SONGLONG LISHANG ELECTRONICS CO.,LTD 4/9 TEL:0752-3728085 /FAX:0752-3728399 VDR HUIZHOU SHI SONGLONG LISHANG ELECTRONICS CO.,LTD ---------------------------------------------------------------------------------------------------------------------------------------------------------------- Electrical characteristics (Combined wave) Varistor voltage Model (@1mA DC) V1mA (V) Maximum Clamping Voltage VAC (V) VDC (V) Maximum Allowable Voltage (8/20μs) Surge Vp I max 3500A Ip (V) (A) 4KV/2KA 1.2/50+8/20 Typical Energy (10/1000μs) Rated Powe μs (times) Capacitance (Reference) @1KHZ W max P 8/2μs(1time) (J) (W) C(pF) 4032K201-EC 200(180-220) 130 170 340 25 40 25.0 0.4 500 4032K221-EC 220(198-242) 140 180 360 25 40 27.0 0.4 450 4032K241-EC 240(216-264) 150 200 395 25 40 30.0 0.4 420 4032K271-EC 270(243-297) 175 225 455 25 40 35.0 0.4 370 4032K301-EC 300(270-330) 195 250 500 25 40 40.0 0.4 330 4032K331-EC 330(297-363) 210 275 550 25 40 42.0 0.4 300 4032K361-EC 360(324-396) 230 300 595 25 40 45.0 0.4 280 4032K391-EC 390(351-429) 250 320 650 25 40 50.0 0.4 260 4032K431-EC 430(387-473) 275 350 710 25 40 55.0 0.4 230 4032K471-EC 470(423-517) 300 385 775 25 40 60.0 0.4 210 4032K511-EC 510(459-561) 320 410 845 25 40 67.0 0.4 200 4032K561-EC 560(504-616) 350 450 930 25 40 69.0 0.4 180 4032K621-EC 620(558-682) 395 510 1020 25 40 70.0 0.4 160 4032K681-EC 680(612-748) 420 560 1120 25 40 72.0 0.4 150 4032K751-EC 750(675-825) 460 615 1235 25 40 75.0 0.4 130 SOLDERING GUIDELINES The usage of mild, non-activated fluxes for soldering is recommended, as well as proper cleaning of the PCB. The components are suitable for reflow soldering per JEDEC J-STD-020C. - Wave soldering ==================================================================================================== HUIZHOU SHI SONGLONG LISHANG ELECTRONICS CO.,LTD 5/9 TEL:0752-3728085 /FAX:0752-3728399 VDR HUIZHOU SHI SONGLONG LISHANG ELECTRONICS CO.,LTD ---------------------------------------------------------------------------------------------------------------------------------------------------------------- ==================================================================================================== HUIZHOU SHI SONGLONG LISHANG ELECTRONICS CO.,LTD 6/9 TEL:0752-3728085 /FAX:0752-3728399 VDR HUIZHOU SHI SONGLONG LISHANG ELECTRONICS CO.,LTD ---------------------------------------------------------------------------------------------------------------------------------------------------------------- V/I CHARACTERISTICS V-I VDR 4032K201 – 4032K471(H/EC) VDR 4032K511 – 4032K821(H/EC) VDR 4032K201 – 4032K471(H/EC) VDR 4032K511 – 4032K751(H/EC) ==================================================================================================== HUIZHOU SHI SONGLONG LISHANG ELECTRONICS CO.,LTD 7/9 TEL:0752-3728085 /FAX:0752-3728399 VDR HUIZHOU SHI SONGLONG LISHANG ELECTRONICS CO.,LTD ---------------------------------------------------------------------------------------------------------------------------------------------------------------- Packing Tape packing method description 24mm tape size ==================================================================================================== HUIZHOU SHI SONGLONG LISHANG ELECTRONICS CO.,LTD 8/9 TEL:0752-3728085 /FAX:0752-3728399 VDR HUIZHOU SHI SONGLONG LISHANG ELECTRONICS CO.,LTD ---------------------------------------------------------------------------------------------------------------------------------------------------------------- 15 inch rubber disc size ==================================================================================================== HUIZHOU SHI SONGLONG LISHANG ELECTRONICS CO.,LTD 9/9 TEL:0752-3728085 /FAX:0752-3728399
VDR4032K471G2 价格&库存
很抱歉,暂时无法提供与“VDR4032K471G2”相匹配的价格&库存,您可以联系我们找货
VDR4032K471G2
    • 5+0.57327
    • 50+0.45922
    • 150+0.40220
    库存:501
