AO3401
AO3401
V(BR)DSS
30V
P-Channel Enhancement Mode Field Effect Transistor
RDS(ON)MAX
65mΩ@-10V
75mΩ@-4.5V
90mΩ@-2.5V
SOT-23 贴片塑封场效应管
SOT-23 Plastic-Encapsulate MOSFET
ID
-4.2A
SOT-23
特征 Features
High dense cell design for extremely low RDS(on).
Exceptional on-resistance and maximum DC current capability.
Load/Power Switching.
Interfacing Switching
机械数据 Mechanical Data
Marking
R1
3401
封装: SOT-23 封装 SOT-23 Small Outline Plastic Package.
环氧树脂 UL 易燃等级 Epoxy UL: 94V-0.
安装位置: 任意 Mounting Position: Any.
极限值和温度特性(TA = 25℃ 除非另有规定)
Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.)
参数 Parameters
符号 Symbol
数值 Value
单位 Unit
Drain-Source Voltage
VDS
-30
V
Gate-Source Voltage
VGS
V
±12
Continuous Drain Current
ID
-4.2
A
Power Dissipation
PD
350
mW
Junction Temperature
Tj
150
Storage Temperature
Tstg
-50-+150
Thermal Resistance From Junction to Ambient (note 2)
RθJA
357
℃/W
电特性 (TA = 25℃ 除非另有规定)
Electrical Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified).
参数
Parameter
符号
Symbols
测试条件
Test Condition
界限 Limits
Min
Typ
Max
单位
Unit
-1
±100
V
uA
nA
Off characteristics
Drain-Source Breakdown Voltage
Zero Gate Voltage Drain current
Gate-body Leakage
V(BR)DSS
IDSS
IGSS
VGS=0V, ID=-250uA
VDS=-24V, VGS=0V
VDS=±12V, VDS=0V
-30
On characteristics
Drain-Source On-Resistance
(note 1)
RDS(ON)
Forward trans conductance
Gate-Threshold voltage*
gfs
V GS (th)
VGS=-10V, ID=-4.2A
VGS=-4.5V, ID=-4A
VGS=-2.5V, ID=-1A
VDS=-5V, ID=-5A
VDS=VGS, ID=-250uA
7
-0.7
50
60
75
65
75
90
-0.9
-1.3
mΩ
S
V
Dynamic characteristics (note 2)
Input capacitance
Output capacitance
Reverse Transfer capacitance
Ciss
Coss
Crss
VDS=-15V, VGS=0V,f=1MHz
954
115
77
pF
Switching characteristics (note 2)
Turn-on Time
Rise time
Turn-off Time
Fall time
td(on)
tr
VGS=-10V, RL=3.6Ω,
VDS=-15V, RGEN=6Ω
td(off)
tf
Drain-source diode characteristics and maximum ratings
VSD
IS=-1A, VGS=0V
Diode forward voltage(note 1)
Notes: 1. Pulse Test: Pulse Width ≤300us, Duty Cycle≤2%.
2. These parameters have no way to verify.
0571-87006810
www.dowosemi.cn
6.3
3.2
38.2
12
ns
-1.0
V
1/3
AO3401
Typical characteristics
0571-87006810
www.dowosemi.cn
2/3
AO3401
SOT-23 PACKAGE OUTLINE Plastic surface mounted package
焊盘设计参考Precautions: PCB Design
Recommended land dimensions for SOT-23 diode. Electrode patterns for PCBs
0571-87006810
www.dowosemi.cn
3/3
很抱歉,暂时无法提供与“AO3401”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.63800
- 200+0.21230
- 1500+0.13310
- 3000+0.10538
- 国内价格
- 20+0.23652
- 200+0.18404
- 600+0.15488
- 3000+0.13835
- 9000+0.12323
- 21000+0.11502
