DF06S
DF06S
    SLKOR(萨科微)
    DF-S
    耐压:600V 电流:1A
DF06S 数据手册
DF005S-DF10S 1.0 A Single-Phase Glass Passivated Bridge Rectifiers Rectifier Reverse Voltage 50 to 1000V DFS _ Features The plastic material used carries Underwriters Laboratory flammability recognition 94V-0 Surge overload ratings to 30 amperes Ideal for printed circuit board application High temperature soldering guaranteed 260 C /5 seconds at 5 lbs (2.3kg) tension + ~ ~ 6.35 + 0.15 7.65 + 0.25 8.15 + 0.2 2.35 + 0.15 Mechanical Data 0.20 + 0.05 0.15 + 0.05 1.28 + 0.15 1.01 + 0.13 Case: Molded plastic Terminals: Plated leads solderable per MIL-STD-202, Method 208 Polarity: Marked on body Mounting Position: Any Weight:0.33 grams (approx) 5.1 + 0.1 10.4 Max. Dimensions in millimeters ( 1mm =0.0394" ) Maximum Ratings & Thermal Characteristics Rating at 25 C ambient temperature unless otherwise specified, Resistive or Inductive load, 60 Hz. For Capacitive load derate current by 20%. Parameter Symbol DF005S DF01S DF02S DF04S DF06S DF08S DF10S unit Maximum repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS bridge input voltage VRMS 35 70 140 280 420 560 700 V VDC 50 100 200 400 600 800 1000 V Maximum DC blocking voltage Maximum average forward rectified output current at TA=40 C IF(AV) 1.0 A Peak forward surge current single sine-wave superimposed on rated load (JEDEC Method) IFSM 30 A I t 10 A sec ReJA 110 C/W Cj 25.0 pF Rating for fusing ( t
DF06S 价格&库存
很抱歉,暂时无法提供与“DF06S”相匹配的价格&库存,您可以联系我们找货
