UMW
R
AO4419
30V P-Channel MOSFET
D
General Description
The AO4419 combines advanced trench MOSFET
technology with a low resistance package to provide
extremely low RDS(ON). This device is ideal for load switch
and battery protection applications.
G
S
Product Summary
VDS
ID (at VGS=-10V)
-30V
-9.7A
RDS(ON) (at VGS=-10V)
< 20mΩ
RDS(ON) (at VGS = -4.5V)
< 35mΩ
1
2
3
4
S
S
S
G
D
D
D
D
8
7
6
5
SOP-8
Absolute Maximum Ratings TA=25°C unless otherwise noted
Symbol
Parameter
VDS
Drain-Source Voltage
Gate-Source Voltage
VGS
TA=25°C
Continuous Drain
Current
Pulsed Drain Current
C
Units
V
±20
V
-9.7
ID
TA=70°C
Maximum
-30
A
-7.8
IDM
-70
Avalanche Current C
IAS, IAR
-27
A
Avalanche energy L=0.1mH C
TA=25°C
EAS, EAR
36
mJ
Power Dissipation B
Junction and Storage Temperature Range
Thermal Characteristics
Parameter
Maximum Junction-to-Ambient A
Maximum Junction-to-Ambient A D
Maximum Junction-to-Lead
www.umw-ic.com
3.1
PD
TA=70°C
TJ, TSTG
Steady-State
Steady-State
°C
-55 to 150
Typ
31
59
16
Symbol
t ≤ 10s
W
2
RθJA
RθJL
1
Max
40
75
24
Units
°C/W
°C/W
°C/W
UTD Semiconductor Co.,Limited
UMW
R
AO4419
Electrical Characteristics (TJ=25°C unless otherwise noted)
Parameter
Symbol
STATIC PARAMETERS
BVDSS
Drain-Source Breakdown Voltage
IDSS
Zero Gate Voltage Drain Current
IGSS
Gate-Body leakage current
Conditions
Min
ID=-250µA, VGS=0V
-30
Typ
Max
Units
V
VDS=-30V, VGS=0V
-1
TJ=55°C
-5
VDS=0V, VGS= ±20V
µA
±100
nA
-2.5
V
VGS(th)
Gate Threshold Voltage
VDS=VGS ID=-250µA
-1.5
ID(ON)
On state drain current
VGS=-10V, VDS=-5V
-70
RDS(ON)
Static Drain-Source On-Resistance
gFS
Forward Transconductance
VSD
Diode Forward Voltage
IS=-1A,VGS=0V
IS
Maximum Body-Diode Continuous Current
-4
A
ISM
Pulsed Body-Diode CurrentC
-70
A
VGS=-10V, ID=-9.7A
Output Capacitance
Crss
Reverse Transfer Capacitance
Rg
Gate resistance
A
16.5
mΩ
VGS=-4.5V, ID=-7A
26
35
mΩ
VDS=-5V, ID=-9.7A
27
-1
V
-0.75
DYNAMIC PARAMETERS
Ciss
Input Capacitance
Coss
-2.0
VGS=0V, VDS=-15V, f=1MHz
VGS=0V, VDS=0V, f=1MHz
2
S
1040
pF
180
pF
125
pF
4
6
Ω
SWITCHING PARAMETERS
Qg(10V) Total Gate Charge
19
nC
Qg(4.5V) Total Gate Charge
9.6
nC
VGS=-10V, VDS=-15V, ID=-9.7A
Qgs
Gate Source Charge
3.6
nC
Qgd
Gate Drain Charge
4.6
nC
tD(on)
Turn-On DelayTime
10
ns
tr
Turn-On Rise Time
5.5
ns
tD(off)
Turn-Off DelayTime
26
ns
tf
Turn-Off Fall Time
9
ns
11.5
ns
nC
VGS=-10V, VDS=-15V, RL=1.5Ω,
RGEN=3Ω
IF=-9.7A, dI/dt=500A/µs
trr
Body Diode Reverse Recovery Time
Qrr
Body Diode Reverse Recovery Charge IF=-9.7A, dI/dt=500A/µs
25
A. The value of RθJA is measured with the device mounted on 1in2 FR-4 board with 2oz. Copper, in a still air environment with TA =25°C. The
value in any given application depends on the user's specific board design.
B. The power dissipation PD is based on TJ(MAX)=150°C, using ≤ 10s junction-to-ambient thermal resistance.
C. Repetitive rating, pulse width limited by junction temperature TJ(MAX)=150°C. Ratings are based on low frequency and duty cycles to keep
initialTJ=25°C.
D. The RθJA is the sum of the thermal impedence from junction to lead RθJL and lead to ambient.
E. The static characteristics in Figures 1 to 6 are obtained using
很抱歉,暂时无法提供与“AO4419(UMW)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.53212
- 50+0.41948
- 150+0.36310
- 500+0.32087
- 3000+0.28707
- 6000+0.27011
