DP1435
DP1435
    SDAPO(达普通讯)
    13W POE模块(隔离型)
DP1435 数据手册
PoE PD Module DP1435 DESCRIPTION 13W PD(Powered Device) Integrated Module (Isolation Type) FEATURES  IEEE802.3af compliant.  Low cost.  Support PoE applications in both of Fast / Gigabit Ethernet environments.  Support wide input voltage range  Thermal cut off.  Short circuit protection.  Over current protection  Programmable Classification (Default:Class 0)  High DC/DC converting efficiency.  Less external component one output decoupling capacitor.  Isolation level 1.5KVrms.  Enhanced surge protection  Internal build in 2 channel bridge rectifiers 37Vdc to 57Vdc. Product List Part Number DP1435-12V Nominal Maximum Nominal Input Output Voltage / Current Output Power Voltage 12Vdc / 1.1 1.1A 13W @ 25°C 48Vdc www.sdapo.com PoE PD Module DP1435 PIN ASSIGNMENT Pin # Name Description 1 VA1 2 VA2 3 VB1 4 VB2 RX Input (1). This input pin is used in conjunction with VA2 and connects to the centre tap of the transformer connected to pins 1 & 2 of the RJ45 connector (RX) - it is not polarity sensitive. TX Input (2). This input pin is used in conjunction with VA1 and connects to the centre tap of the transformer connected to pins 3 & 6 of the RJ45 connector (TX) - it is not polarity sensitive. Direct Input (1). This input pin is used in conjunction with VB2 and connects to pin 4 & 5 of the RJ45 connector - it is not polarity sensitive. Direct Input (2). This input pin is used in conjunction with VB1 and connects to pin 7 & 8 of the RJ45 connector - it is not polarity sensitive. 5 GND DC Return. This pin is the return path for the +VDC output. 6 VOUT DC Output. This pin provides the regulated output from the DC/DC converter. Package www.sdapo.com PoE PD Module Typical Application www.sdapo.com DP1435 PoE PD Module DP1435 ELECTRICAL SPECIFICATIONS No Item Specification 1 Input Voltage 37~57V 2 Output Voltage 12V Typ. DP1435-12V 5.15V Typ. DP1435-5V 3 Output Current (Vin=56V) Comment 1ATyp. 1.2A Max. DP1435-12V 2ATyp. 2.5A Max. DP1435-5V 4 Line Regulation 1% 5 Load Regulation 1% 6 Ripple & Noise 200mVp-p max. DP1435-12V 200mVp-p max. DP1435-5V 87% max. DP1435-12V 84% max. DP1435-5V 7 8 Efficiency Switching Frequency 340 KHz DP1435-12V 250 KHz DP1435-5V 9 Input to Output Isolation 1.5 KV 10 Type of DC/DC Converter Flyback Type 11 Operating Temperature -40 ~ +85 ℃ DP1435-12V -40 ~ +85 ℃ DP1435-5V www.sdapo.com
DP1435
物料型号:DP1435
器件简介: - DP1435是一款符合IEEE802.3af标准的13W PoE PD集成模块,适用于快速以太网和千兆以太网环境。 - 支持37Vdc至57Vdc的宽输入电压范围。 - 具有热切断、短路保护、过流保护等安全特性。 - 具有可编程分类(默认为Class 0)和高DC/DC转换效率。 - 封装级别为1.5KVrms,增强了浪涌保护。
引脚分配: - VA1和VA2:接收输入,与RJ45连接器的中心抽头相连。 - VB1和VB2:直接输入,与RJ45连接器的4、5、7、8引脚相连。 - GND:直流返回路径。 - VOUT:直流输出,提供DC/DC转换器的稳定输出。
参数特性: - 输入电压:37~57V。 - 输出电压:12V或5.15V(型号不同)。 - 输出电流:1A典型值,最大1.2A(DP1435-12V)或2A典型值,最大2.5A(DP1435-5V)。 - 线路调节:1%。 - 负载调节:1%。 - 纹波和噪声:最大200mVp-p。 - 效率:最大87%(DP1435-12V)或84%(DP1435-5V)。 - 开关频率:340 KHz(DP1435-12V)或250KHz(DP1435-5V)。 - 输入到输出隔离:1.5KV。 - DC/DC转换器类型:Flyback Type。 - 工作温度:-40 ~ +85°C。
功能详解应用信息: - 适用于10/100 Base-T和10/100/1000 Base-T以太网接口。 - 可使用外部LC滤波器以降低纹波和噪声。
封装信息: - 尺寸为35.6mm x 12.5mm,引脚间距为2.54mm。
DP1435 价格&库存
很抱歉,暂时无法提供与“DP1435”相匹配的价格&库存,您可以联系我们找货
