U233-091N-4BLPC17-11 数据手册
2.40 [0.095]
0.82 [0.032]
0.20 [0.008]
12.80 [0.504]
1.50 [0.059]
SIGNAL NAME DESCRIPTION
1
2
3
D+
MATING
SEQUENCE
VBUS
POWER
SECOND
D-
USB 2.0
DIFFERENTIAL PAIR
THIRD
4
GND
GROUND FOR POWER RETURN
SECOND
5
StdA_SSRX-
SUPERSPEED RECEIVER
DIFFERENTIAL PAIR
LAST
6
StdA_SSRX+
7
GND_DRAIN
GROUND FOR SIGNAL RETURN
8
StdA_SSTX-
9
SUPERSPEED TRANSMITTER
DIFFERENTIAL PAIR
StdA_SSTX+
Shell
Shield
CONNECTOR METAL SHELL
P:1
0.80 [0.031]
11.60 [0.457]
11.50 [0.453]
Pin #
2.00 [0.079]
13.10 [0.516]
5.70 [0.224]
5.72 [0.225]
FRIST
P:3
5.10 [0.201]
4.00 [0.157]
2.00 [0.079]
1.00 [0.039]
9*0.70 [0.028]
6.00 [0.236]
8*1.00=8.00 [0.315]
7.00 [0.276]
12.50 [0.492]
4*2.00=8.00 [0.315]
4.50 [0.177]
2.00 [0.079]
6.00 [0.236]
2.50 [0.098]
3.00 [0.118]
1.80 [0.071]
5.90 [0.232]
Material
Housing Material: LCP, UL94V-0, blue
Contact Terminal: Brass
Metallic Shell:Spcc
Plating
Underplating: Nickel
Contact Plating: 1µ" Gold
Solder Tail: 100µ" Min. Tin
Metallic Shell: Nickel
9.00 [0.354]
9.30 [0.366]
1.50 [0.059]
U233-09XN-XBLPC17-X 1
1:Au 1U"
5:Au 15U"
6:Au 30U"
1:SPCC
P:1 P:3
T:TIN
N:NICKEL
Electrical
Voltage Rating: 100 V AC
Current Rating: 0.25A (Signal pins 2,3,5,6,7,8,9) 1.8A (Power
Pins 1,4)
Contact Resistance: 30mΩ Max.
Insulation resistance: 1000MΩ Min.
Dielectric withstanding voltage: 100V AC/Minute
Mechanical
Durability: 1500 cycles
Mating Force: 35N (3.57Kgf) Max
Unmating Force: 10N (1.02Kgf) Min. initial, 8N min after test
Environmental and Processing
Operating Temperature: -40°C to +85°C
B:BLACK W:WHITE BL:BLUE
1:PBT
2:PA6T
3:PA9T
4:LCP
X
X
X
MARK
DATE
DESCRIPTION
REVISIONS
www.xk-dg.cn
www.helloxkb.com
REVISED
APPROVED
ANGLAR
L≤4
4
U233-091N-4BLPC17-11 价格&库存
很抱歉,暂时无法提供与“U233-091N-4BLPC17-11”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.68070
- 50+1.34720
- 200+1.16450
- 500+0.88760
- 国内价格
- 5+1.50012
- 50+1.20248
- 200+1.03940
- 500+0.79218
- 2500+0.72832
- 5000+0.69003
