PL2303GC
PL2303GC
    PROLIFIC(旺玖)
    SSOP-28
    PL2303G4ZJG8P2 PL2303GC USB转全功能UART IC带GPIO
PL2303GC 数据手册
USB to Full UART IC with GPIO Product Data Sheet PL2303GC PL2303GC USB to Full UART IC with GPIO Single-chip USB to Asynchronous Serial Data Interface USB Interface UART Interface  Fully Compliant with USB 2.0 specification (Full-Speed Mode).  Supports Serial UART Interface: o RS232, RS422, RS485  USB-IF certified (USB logo compliant) with TID 40001838. o Flexible baud rate support up to 12Mbps  UHCI/OHCI (USB 1.1), EHCI (USB 2.0), xHCI (USB 3.1) Host Controller Compatible. o Odd, Even, Mark, Space, None parity mode  Provides royalty-free USB to Virtual Com Port (VCP) drivers for Windows, Mac, Linux, and Android. o Hardware Flow Control (CTS/RTS and/or DSR/DTR)  Highly integrated USB 1.1 FS Transceiver. Integrated termination resistors and pull-up resistor to reduce PCB external components. o Configurable Remote Wakeup Pin  Supports 256-byte OTPROM (One-Time Programmable ROM) for USB device descriptors and GPIO custom configuration. OTPROM can be programmed directly through USB port. o 5, 6, 7 or 8 data bits o One, one and a half, or two stop bits o Software Flow Control (XON/XOFF)  1024-byte bi-directional data FIFO buffers (768-byte receive/256-byte transmit) for faster data throughput. Configurable in OTPROM.  Configurable Transmit and Receive LED pins(*1) .  Suspend Pin control for RS232 transceiver.  UART inverted signal configurable option.  Each IC has unique ID (for Serial Number).  Supports bus-power, self-power and high-power USB device configuration.  Supports Windows USB Selective Suspend (Remote Wakeup enabled).  Supports VBUS input detect function to attach USB host after VBUS is detected.  Supports 3.3V VBUS voltage operation. Battery Charger Detection  Supports Battery Charger (BC1.2) Detection to enable fast charging of batteries(*1). Miscellaneous  Integrated self-generated precise clock generator. External crystal is optional.  Integrated Power-on-Reset (POR) circuit. GPIO Interface   Versatile GPIO functions and routing logic provides easy to use multi-I/O functions.  Low operating power and USB suspend current.  Configurable I/O pin output driving strength.  Wide I/O voltage range (1.8V/2.5V/3.3V/5V).  Total 16 General Purpose I/O (GPIO) pins can be used after configured.  -40oC to 85oC Operating Temperature.  Optional Clock Output to external MCU(*1). *1 Configurable pins shared with UART pins. Integrated 5V to 3.3V LDO that can support 80mA for external components.  28-pin SSOP and 24-pin UQFN IC package (RoHS compliant and Pb-free Green Compound).  Pin-compatible with PL2303HXD chip (SSOP28). Prolific Technology Inc. © 2018-2020 Prolific Inc. All rights reserved. 7F, No.48, Sec. 3, Nan Kang Rd., Nan Kang, Taipei 115, Taiwan Proprietary and Confidential Tel:+886-2-2654-6363; Fax:886-2-22654-6161 Website:http://www.prolific.com.tw/ USB to Full UART IC with GPIO Product Data Sheet PL2303GC REVISION HISTORY Revision  Description To change ordering information from version G3 to G4. Added driver support Windows Server 2019.  Added PL2303GR information  Added Chip Marking information  Del PL2303GL UDFN8 package information.  Added θjc information and modify Output Driving  1.0.3 1.0.2 1.0.1 1.0.0 Strength.  Formal release Date 2020/4/27 2020/2/13 2019/5/3 2018/12/11 Prolific Technology Inc. © 2018-2020 Prolific Inc. All rights reserved. 7F, No.48, Sec. 3, Nan Kang Rd., Nan Kang, Taipei 115, Taiwan Proprietary and Confidential Tel:+886-2-2654-6363; Fax:886-2-22654-6161 Website:http://www.prolific.com.tw/ USB to Full UART IC with GPIO Product Data Sheet 1. 2. PL2303GC Product Applications  Single-chip upgrade solution for Legacy RS232 devices to USB interface  USB to RS232/RS422/RS485 interface converters/cables/dongles/adapters  MCU-based devices to USB host interface  Point-of-Sale (POS) Terminals/Printers/Pole Displays  USB Barcode/Smart Card Readers  PC I/O Docking Station/Port Replicators  Healthcare/Medical USB Interface Data Transfer Cable  Serial-over-IP Wireless Solution  Cellular/PDA USB Interface Data Transfer Cable  GPS/Navigation USB Interface  Industrial / Instrumentation / Automation Control USB Interface  USB Modem / Wireless / Zigbee USB Interface  Set-Top Box (STB) / Home Gateway USB Interface  Battery Charger Detection for high-current and quick charging of batteries. Royalty-Free Driver Support  Windows 10, 8, 7, Vista, XP, (Microsoft Certified WHQL Drivers) - Windows Update Driver installation available in Windows 7 and above (32/64-bit) 3.  Windows Server 2003, 2008, 2008 R2, 2012, 2016, 2019  Windows Embedded Industry, Point-of-Service (WEPOS), and POSReady  Windows Embedded Compact, Windows Embedded CE, Windows CE  Mac OS X  Linux OS  Android 3.2 and above Ordering Information Chip Product Name Package Type Ordering Part Number MPQ PL2303G4ZJG7P2 48pcs / tube PL2303G4ZJG8P2 2000pcs / reel PL2303G4FIG7P2 490pcs / tray PL2303G4FIG8P2 4000pcs / reel 28-pin SSOP PL2303GC 24-pin UQFN Prolific Technology Inc. © 2018-2020 Prolific Inc. All rights reserved. 7F, No.48, Sec. 3, Nan Kang Rd., Nan Kang, Taipei 115, Taiwan Proprietary and Confidential Tel:+886-2-2654-6363; Fax:886-2-22654-6161 Website:http://www.prolific.com.tw/ USB to Full UART IC with GPIO Product Data Sheet 4. PL2303GC Block Diagram USBDP BC 1.2 Detection USBDM USB 1.1 Transceiver PLL 3.3V LDO & POR VIN 3V3OUT XO (optional) Clock Generator DPLL Serial Interface Engine (SIE) Power Management XI (optional) Control Endpoint Command Sequencer OTPROM Bulk Out Endpoint Bulk In Endpoint Outbound FIFO Buffer Inbound FIFO Buffer Interrupt In Endpoint Event Generator Mux/Demux External EEPROM (optional) UART Controller Descriptor ROM IO Functions Control Registers IO Routing Logic I2C EEPROM Controller GPB0 GPB1 GPB2 GPB3 GPB4 GPB5 GPB6 TXEN RS232/422/485 Interface (or configurable GPIO) Figure 4-1 PL2303GC Block Diagram Prolific Technology Inc. © 2018-2020 Prolific Inc. All rights reserved. 7F, No.48, Sec. 3, Nan Kang Rd., Nan Kang, Taipei 115, Taiwan Proprietary and Confidential Tel:+886-2-2654-6363; Fax:886-2-22654-6161 Website:http://www.prolific.com.tw/ USB to Full UART IC with GPIO Product Data Sheet 5. PL2303GC USB Logo Certification The PL2303GC IC has been certified by the USB-IF organization with TID 40001838 to be fully compliant with the USB 2.0 specification. Prolific Technology Inc. © 2018-2020 Prolific Inc. All rights reserved. 7F, No.48, Sec. 3, Nan Kang Rd., Nan Kang, Taipei 115, Taiwan Proprietary and Confidential Tel:+886-2-2654-6363; Fax:886-2-22654-6161 Website:http://www.prolific.com.tw/ Product Data Sheet PL2303GC Table of Contents 1. Product Applications .............................................................................................3 2. Royalty-Free Driver Support .................................................................................3 3. Ordering Information .............................................................................................3 4. Block Diagram........................................................................................................4 5. USB Logo Certification..........................................................................................5 6. Overview ............................................................................................................... 11 6.1 7. 8. PL2303 G-Series USB to Serial Family Product Table ............................................. 12 Pin Diagram and Description .............................................................................. 13 7.1 SSOP28 Pin Diagram .............................................................................................. 13 7.2 UQFN24 Pin Diagram .............................................................................................. 14 7.3 Pin Out Description .................................................................................................. 15 7.4 GPIO Multi-Function Options ................................................................................... 17 Functional Description ........................................................................................ 19 8.1 BC 1.2 Detection ..................................................................................................... 19 8.2 USB 1.1 FS Transceiver .......................................................................................... 19 8.3 LDO Regulator......................................................................................................... 19 8.4 Clock Generator ...................................................................................................... 19 8.5 USB FS SIE ............................................................................................................. 19 8.6 Power Management................................................................................................. 20 8.7 Control Endpoint ...................................................................................................... 20 8.8 Bulk Out Endpoint.................................................................................................... 20 8.9 Bulk In Endpoint ...................................................................................................... 20 8.10 Interrupt In Endpoint ................................................................................................ 20 8.11 Command Sequencer .............................................................................................. 20 8.12 Outbound FIFO........................................................................................................ 20 8.13 Inbound FIFO .......................................................................................................... 21 8.14 Event Generator ...................................................................................................... 21 8.15 Internal OTPROM .................................................................................................... 21 8.16 Mux/Demux ............................................................................................................. 21 8.17 Descriptor ROM ....................................................................................................... 21 8.18 UART Control .......................................................................................................... 21 Release: Apr. 27, 20 - 6 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 8.19 Control Registers ..................................................................................................... 21 8.20 IO Functions ............................................................................................................ 22 8.21 I/O Routing Logic ..................................................................................................... 22 8.22 I2C EEPROM Controller .......................................................................................... 22 9. Chip Function Configuration .............................................................................. 23 9.1 USB Data Configuration .......................................................................................... 23 9.2 UART Configuration................................................................................................. 25 9.3 GPIO (GPA) Configuration....................................................................................... 26 9.4 GPIO (GPB) Configuration....................................................................................... 28 9.5 Miscellaneous (MISC) Configuration ........................................................................ 30 10. Design Application Examples ............................................................................. 31 10.1 USB Bus Powered Design ....................................................................................... 31 10.2 Self Powered Design ............................................................................................... 31 10.3 Chip Reset Control .................................................................................................. 33 10.4 I/O Power Supply to PL2303GC .............................................................................. 34 10.5 USB to RS232 Cable Design ................................................................................... 35 10.6 USB to RS485/RS422 ............................................................................................. 36 10.7 Battery Charging Support ........................................................................................ 37 10.8 External I2C EEPROM Support ............................................................................... 39 11. DC & Temperature Characteristics ..................................................................... 40 11.1 Absolute Maximum Ratings ..................................................................................... 40 11.2 DC Characteristics ................................................................................................... 40 11.2.1 Operating Voltage and Suspend Current .................................................................. 40 11.2.2 I/O Pins ...................................................................................................................... 40 11.3 Temperature Characteristics.................................................................................... 41 11.4 Baud Rate Characteristics ....................................................................................... 41 12. Outline Diagram ................................................................................................... 42 12.1 Chip Marking information .......................................................................................... 42 12.2 SSOP28 Package.................................................................................................... 42 12.3 UQFN24 Package ................................................................................................... 44 13. Packing Information ............................................................................................ 45 13.1 Carrier Tape (SSOP-28) .......................................................................................... 45 13.2 Carrier Tape (UQFN24) ........................................................................................... 46 Release: Apr. 27, 20 - 7 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 13.3 Reel Dimension ....................................................................................................... 47 13.4 Tube Packing ........................................................................................................... 48 Release: Apr. 27, 20 - 8 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC List of Figures Figure 4-1 PL2303GC Block Diagram ......................................................................................... 4 Figure 7-1 PL2303GC Pin Diagram (SSOP28) ......................................................................... 13 Figure 7-2 PL2303GC Pin Diagram (UQFN24) ......................................................................... 14 Figure 10-1 USB Bus Powered Design Example ...................................................................... 31 Figure 10-2a USB Self Powered Design Example 1.................................................................. 32 Figure 10-2b USB Self Powered Design Example 2.................................................................. 32 Figure 10-3a Chip Reset Control Application ............................................................................ 33 Figure 10-3b Chip Power Reset Timing Diagram ...................................................................... 33 Figure 10-4a IO Power Supply .................................................................................................. 34 Figure 10-4b VDD_IO Voltage Supply....................................................................................... 34 Figure 10-5 USB to RS232 Design Example ............................................................................. 35 Figure 10-6 USB to RS485/422 Design Example ...................................................................... 36 Figure 10-7a Battery Charging Design Example #1 .................................................................. 37 Figure 10-7b Battery Charging Design Example #2 .................................................................. 38 Figure 10-8 External I2C EEPROM Design Example ................................................................ 39 Figure 12-1 PL2303GC Outline Diagram (SSOP28) ................................................................. 43 Figure 12-2 PL2303GC Outline Diagram (UQFN24) 4 x 4 mm .................................................. 44 Figure 13-1a SSOP28 Carrier Tape .......................................................................................... 45 Figure 13-1b IC Reel Placements ............................................................................................. 45 Figure 13-2 UQFN24 Carrier Tape ............................................................................................ 46 Figure 13-3 Reel Dimension ..................................................................................................... 47 Figure 13-4 Tube Packing Dimension ....................................................................................... 48 Release: Apr. 27, 20 - 9 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC List of Tables Table 7-1: USB Data Interface Pins .......................................................................................... 15 Table 7-2: UART (Serial Port) Interface Pins............................................................................. 15 Table 7-3: Configurable GPIO Pins – Group A (Shared with Serial Port Pins)........................... 15 Table 7-4: Configurable GPIO Pins – Group B .......................................................................... 16 Table 7-5: Power and Ground Pins ........................................................................................... 16 Table 7-6: Miscellaneous Pins .................................................................................................. 16 Table 7-7: Configurable GPIO Multi-Function Pins .................................................................... 17 Table 7-8: GPIO Multi-Function Option Descriptions ................................................................. 17 Table 9-1 USB Descriptor Configuration ................................................................................... 23 Table 9-2 UART Startup Configuration...................................................................................... 25 Table 9-3 GPIO (GPA Group) Configuration ............................................................................. 26 Table 9-4 GPIO (GPB Group) Configuration ............................................................................. 28 Table 9-5 Miscellaneous Configuration ..................................................................................... 30 Table 11-1 Absolute Maximum Ratings..................................................................................... 40 Table 11-2a Operating Voltage and Suspend Current ............................................................... 40 Table 11-2b I/O Pins ................................................................................................................. 40 Table 11-3 Temperature Characteristics ................................................................................... 41 Table 11-4 Baud Rate Characteristics....................................................................................... 41 Table 12-1 Package Dimension ................................................................................................ 42 Table 13-1 Reel Part Number Information ................................................................................. 47 Release: Apr. 27, 20 - 10 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 6. Overview The new PL2303GC chip is one of the latest G-Series IC product added to the popular PL2303 USB to Serial (UART) Bridge Controller family, replacing the PL2303HXD mainstream chip. It provides an advanced full-featured single-chip bridge solution for connecting a full-duplex UART asynchronous serial interface device to any Universal Serial Bus (USB) capable host. The PL2303GC provides highly compatible USB drivers to simulate the traditional COM port (via virtual COM Port) on most operating systems allowing existing serial UART applications based on legacy COM port to easily migrate and be made USB ready. The new PL2303GC is pin-to-pin compatible with the popular PL2303HXD chip (SSOP28). It also integrates an internal precise clock generator (no external crystal required), USB 1.1 transceiver, Serial Interface Engine (SIE), LDO voltage regulator, power-on- reset (POR), FIFO data buffers, and OTPROM. The PL2303GC added several new features and enhancements:  Integrated termination resistors and pull-up resistor to reduce PCB external components.  New USB drivers for different OS platforms with faster performance and advanced features.  Precise baud rate generator (up to 12Mbps).  OTPROM can be programmed directly through USB (no high voltage generator required).  Larger TX/RX FIFO data buffers (1024-byte).  Up to 16 configurable GPIO pins.  Versatile GPIO functions and routing logic (TX/RX LED, VBUS_DET, USB_CFG, CLK_OUT, etc.).  Supports 3.3V VBUS voltage operation.  Wide I/O voltage range (1.8V/2.5V/3.3V/5V).  Configurable I/O pin output driving strength.  UART inverted signal configurable option.  Unique USB Serial Number for each IC.  Supports Battery Charger (BC1.2) Detection to enable fast charging of batteries. The PL2303GC is designed to support a wide-range of serial application domain including mobile, embedded, industrial, consumer, healthcare, navigation, and wearable solutions in mind. It provides a small footprint that could easily fit in to any connectors and handheld devices. With very small power consumption in either operating or suspend mode, the PL2303GC is perfect for bus powered operation with plenty of power left for the attached devices. Flexible signal level requirement on the RS232-like serial port side also allows the PL2303GC to connect directly to any 5V~1.8V range devices. The PL2303GC is available in two small footprint Pb-free (RoHS compliant) green compound packages: 28-pin SSOP and 24-pin UQFN packages. Release: Apr. 27, 20 - 11 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 6.1 PL2303 G-Series USB to Serial Family Product Table Prolific’s new PL2303 G-series USB to Serial family product line offers a variety of new advanced features for USB serial interface product design. The PL2303 G-series are redesigned to provide accurate and flexible baud rate support as well as plenty of I/O functions that can be easily configured in OTPROM memory. PL2303 G-Series USB to Serial (UART) Family Product Line Product PL2303GC PL2303GS PL2303GE PL2303GT PL2303GL PL2303GR USB to Full UART (Integrated Clock) USB to Full UART (Integrated Clock) USB to Full UART (High ESD Protection) USB to RS232 (Internal RS232 Transceiver) USB to Basic UART (Low-Pin Count) USB to RS485 (Internal RS485 Transceiver) SSOP28 UQFN24 SSOP16 SSOP28 SSOP28 SOP8 SSOP28 UART Interface RS232 RS422/RS485 RS232 RS422/RS485 RS232 RS422/RS485 RS232 Only RS232 (TX-RX Only) RS485 Only Max. Data Rates 12Mbps 12Mbps 12Mbps 1Mbps 115200bps 10Mbps Dedicated GPIO Pins 6 0 6 4 0 4 9 9 9 0 0 0 Clocking Internal1 Internal Internal1 Internal Internal Internal OTPROM2 USB Data + Configurable GPIO Function USB Data + Configurable GPIO Function USB Data + Configurable GPIO Function USB Data + Configurable GPIO Function USB Data USB Data External EEPROM Option YES3 YES3 YES3 YES3 NO NO Android OS Support YES YES YES YES YES YES 768-byte (RX) 256-byte (TX) 768-byte (RX) 256-byte (TX) 768-byte (RX) 256-byte (TX) 768-byte (RX) 256-byte (TX) 768-byte (RX) 256-byte (TX) 768-byte (RX) 256-byte (TX) YES YES YES No No No I/O Voltage Range I/O levels from 1.8V to 5V I/O levels from 1.8V to 5V I/O levels from 1.8V to 5V 3.3V I/O levels from 1.8V to 5V 3.3V Pin Compatible PL2303HXD (SSOP28 only) New design PL2303EA PL2303RA PL2303SA New design Description Packages Shared GPIO (with UART pins) Configurable Data Buffer4 Battery Charger Detection Option 1 – Also supports external crystal clock source to bypass internal clock. 2 – OTPROM allows setting the USB data descriptors. Also allows setting of multi-function GPIO options. 3 – External EEPROM (when enabled in OTPROM) will override OTPROM settings. 4 – TX/RX data buffers are configurable in OTPROM (PL2303GC, PL2303GS, and PL2303GE); or by driver customization. Release: Apr. 27, 20 - 12 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 7. 7.1 Pin Diagram and Description SSOP28 Pin Diagram Figure 7-1 PL2303GC Pin Diagram (SSOP28) Release: Apr. 27, 20 - 13 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 7.2 UQFN24 Pin Diagram Figure 7-2 PL2303GC Pin Diagram (UQFN24) Release: Apr. 27, 20 - 14 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 7.3 Pin Out Description Table 7-1: USB Data Interface Pins SSOP28 UQFN24 Pin No. Pin No. DP 15 10 I/O USB Port Data Plus (D+) Signal. DM 16 11 I/O USB Port Data Minus (D-) Signal. Pin Name Type Description Table 7-2: UART (Serial Port) Interface Pins SSOP28 UQFN24 Pin No. Pin No. TXD 1 21 Output Serial Port: Transmitted Data Output DTR_N 2 22 Output Serial Port: Data Terminal Ready Control Output RTS_N 3 23 Output Serial Port: Request To Send Control Output RXD 5 1 Input RI_N 6 2 Input DSR_N 9 4 Input Serial Port: Data Set Ready Control Input DCD_N 10 5 Input Serial Port: Data Carrier Detect Control Input CTS_N 11 6 Input Serial Port: Clear To Send Control Input Pin Name Type Description Serial Port: Received Data Input Serial Port: Ring Indicator (Remote Wakeup) Control Input Table 7-3: Configurable GPIO Pins – Group A (Shared with Serial Port Pins) SSOP28 UQFN24 Pin No. Pin No. GPA0 1 21 I/O GPA1 5 1 I/O GPA2 3 23 I/O GPA3 11 6 I/O GPA4 2 22 I/O GPA5 9 4 I/O GPA6 10 5 I/O GPA7 6 2 I/O Pin Name Release: Apr. 27, 20 Type Description Configurable GPIO Pin. (see Section 7.4) Factory default is TXD serial port output pin. Configurable GPIO Pin. (see Section 7.4) Factory default is RXD serial port input pin. Configurable GPIO Pin. (see Section 7.4) Factory default is RTS_N serial port output pin. Configurable GPIO Pin. (see Section 7.4) Factory default is CTS_N serial port input pin. Configurable GPIO Pin. (see Section 7.4) Factory default is DTR_N serial port output pin. Configurable GPIO Pin. (see Section 7.4) Factory default is DSR_N serial port input pin. Configurable GPIO Pin. (see Section 7.4) Factory default is DCD_N serial port input pin. Configurable GPIO Pin. (see Section 7.4) Factory default is RI_N serial port input pin. - 15 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC Table 7-4: Configurable GPIO Pins – Group B SSOP28 UQFN24 Pin No. Pin No. GPB0 22 15 I/O Configurable GPIO Pin. (see Section 7.4) GPB1 23 16 I/O Configurable GPIO Pin. (see Section 7.4) GPB2 14 9 I/O Configurable GPIO Pin. (see Section 7.4) GPB3 13 8 I/O Configurable GPIO Pin. (see Section 7.4) GPB4 24 17 I/O Configurable GPIO Pin. (see Section 7.4) GPB5 25 18 I/O Configurable GPIO Pin. (see Section 7.4) GPB6 12 7 I/O GPB7 8 3 I/O Pin Name Type Description Configurable GPIO Pin. (see Section 7.4) Factory default is SUSP_N output pin. Configurable GPIO Pin. (see Section 7.4) Factory default is TXEN output pin NOTE: All GPB pins are default Input mode (except GPB6). Table 7-5: Power and Ground Pins SSOP28 UQFN24 Pin No. Pin No. VDD_IO 4 24 Power VO_33 17 12 Power GND 18 VIN 20 Pin Name Exposed Pad 14 Type Power Power Description +1.8V to +5V I/O signal power input pin. Note: VDD_IO voltage should not larger than VIN voltage. +3.3V output power from integrated LDO regulator. For self-powered design, supply +3.3V to this pin. Ground USB port VBUS input power supply. For self-powered design, supply +3.3V to this pin. Table 7-6: Miscellaneous Pins Pin Name SSOP28 UQFN24 Pin No. Pin No. 12 7 SUSP_N Type Output Description Active low Shutdown control pin. Can be used to shutdown external RS232 transceiver. Active low Reset pin. Can be used by external device RESET_N 19 13 Input to reset the PL2303GC. NOTE: This pin has internal pull-high. It can be pull up to VIN or VDD_IO. XI 27 19 Input XO 28 20 Output NC 7, 21, 26 - NC Release: Apr. 27, 20 Optional. 12MHz crystal oscillator input. If not used, leave pin floating. Optional. 12MHz crystal oscillator output. If not used, leave pin floating. No internal connection. Leave floating. - 16 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 7.4 GPIO Multi-Function Options The PL2303GC chip (SSOP28 package) provides a total of 16 configurable GPIO (General Purpose I/O) pins. The pins are grouped into GPA and GPB set of pins. The table below shows the possible functions that can be configured for each GPIO pin. These special functions can be easily configured in the OTPROM of the PL2303GC or to an external I2C EEPROM using the Prolific OTPROM/EEPROM software tool. When these pins are configured as standard GPIO pins, customers can refer to the Prolific GPIO SDK (software development kit) to develop software to control the GPIO pins for customer application desired functions. Table 7-7: Configurable GPIO Multi-Function Pins SSOP28 UQFN24 Factory Pin No. Pin No. Default GPA0 1 21 TXD GPA1 5 1 RXD GPA2 3 23 RTS TX_LED CLK_OUT SUSP_N USB_CFG TXEN GPA3 11 6 CTS RX_LED TRX_LED WAKEUP VBUS_DET BC_DET GPA4 2 22 DTR TX_LED CLK_OUT USB_CFG EE_SDA GPA5 9 4 DSR RX_LED TRX_LED BC_SUSP_N EE_SCL GPA6 10 5 DCD VBUS_DET BC_DET TXEN GPA7 6 2 RI (WAKEUP) GPB0 22 15 GPIO Input Pin TX_LED CLK_OUT GPB1 23 16 GPIO Input Pin RX_LED TRX_LED GPB2 14 9 GPIO Input Pin VBUS_DET EE_SDA GPB3 13 8 GPIO Input Pin USB_CFG EE_SCL GPB4 24 17 GPIO Input Pin CLK_OUT BC_SUSP_N GPB5 25 18 GPIO Input Pin BC_DET GPB6 12 7 SUSP_N USB_CFG GPB7 8 3 TXEN Pin GPIO Input GPIO Configurable Options (using OTPROM Tool) WAKEUP CLK_OUT Table 7-8: GPIO Multi-Function Option Descriptions SSOP28 UQFN24 GPIO Pins GPIO Pins GPA2 (Pin 3) GPA2 (Pin 3) GPA4 (Pin 2) GPA4 (Pin 2) GPB0 (Pin 22) GPB0 (Pin 22) GPA3 (Pin 11) GPA3 (Pin 11) GPA5 (Pin 9) GPA5 (Pin 9) GPB1 (Pin 23) GPB1 (Pin 23) GPIO Function TX_LED RX_LED Release: Apr. 27, 20 Type Description Output Serial Port: TXD Access LED. Output Serial Port: RXD Access LED. - 17 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC TRX_LED VBUS_DET USB_CFG TXEN SUSP_N WAKEUP BC_DET BC_SUSP_N CLK_OUT EE_SDA EE_SCL GPA3 (Pin 11) GPA3 (Pin 11) GPA5 (Pin 9) GPA5 (Pin 9) GPB1 (Pin 23) GPB1 (Pin 23) GPA3 (Pin 11) GPA3 (Pin 11) GPA6 (Pin 10) GPA6 (Pin 10) GPB2 (Pin 14) GPB2 (Pin 14) GPA2 (Pin 3) GPA2 (Pin 3) GPA4 (Pin 2) GPA4 (Pin 2) GPB3 (Pin 13) GPB3 (Pin 13) GPB6 (Pin 12) GPB6 (Pin 12) GPA2 (Pin 3) GPA2 (Pin 3) GPA6 (Pin 10) GPA6 (Pin 10) GPB7 (Pin 8) GPB7 (Pin 8) Output Input When this pin is set to VBUS_DET mode, the device will not attach to USB until VBUS_DET input pin goes to high level. There must be only one pin configured as VBUS_DET pin. Output When device is attached to USB port and configured by USB host, this USB_CFG pin will output to high level. This pin can be used to enable system function after USB is configured. Output Transmit Data Enable Pin can be used to enable RS485/RS422 transceiver when data is being transmitted. Output Active low Shutdown control pin. This pin has two options to choose. One is to indicate chip suspend state by USB bus state. The other option (factory default) is to indicate chip un-configured state and chip suspend state. These two options can be configured in OTPROM or EEPROM. Input The remote wakeup function is to wake up chip from suspended state when this pin toggle in suspend state. There must be only one pin configured as WAKEUP pin. The factory default is RI (GPA7) pin. Output Battery Charge Detect pin. This active high pin indicates BC 1.2 DCP/CDP is detected. Output This pin has same function as SUSP_N except this pin will be forced inactive in chip suspend state when BC 1.2 DCP/CDP is detected. GPA2 (Pin 3) GPA2 (Pin 3) GPB6 (Pin 12) GPB6 (Pin 12) GPA3 (Pin 11) GPA3 (Pin 11) GPA7 (Pin 6) GPA7 (Pin 2) GPB6 (Pin 12) GPB6 (Pin 12) GPA3 (Pin 11) GPA3 (Pin 11) GPA6 (Pin 10) GPA6 (Pin 10) GPB5 (Pin 25) GPB5 (Pin 25) GPA5 (Pin 9) GPA5 (Pin 9) GPB4 (Pin 24) GPB4 (Pin 24) GPA2 (Pin 3) GPA2 (Pin 3) GPA4 (Pin 2) GPA4 (Pin 2) GPB0 (Pin 22) GPB0 (Pin 22) GPB4 (Pin 24) GPB4 (Pin 24) GPB6 (Pin 12) GPB6 (Pin 12) GPA4 (Pin 2) GPA4 (Pin 2) Input/ GPB2 (Pin 14) GPB2 (Pin 14) Output Output This pin can generate clock output up to 12MHz. Clock rates can be configured in OTPROM/EEPROM or customized driver. Note: Only one GPIO pin can be configured as CLK_OUT function. GPA5 (Pin 9) GPA5 (Pin 9) Input/ GPB3 (Pin 13) GPB3 (Pin 13) Output Release: Apr. 27, 20 Serial Port: TXD and RXD Access LED. - 18 / 49 - External I2C EEPROM interface serial data signal. External I2C EEPROM interface serial clock signal. Rev.1.0.3 Product Data Sheet PL2303GC 8. Functional Description This section details the functional block diagram description of the PL2303GC. 8.1 BC 1.2 Detection This function is used to detect VBUS power supply capability of USB host port and provides charging control to battery charging IC. This function is enabled in OTPROM by setting GPIO pin to BC_DET option. This pin will indicate if BC 1.2 DCP/CDP is detected when device is attached to the USB port. The external battery charging IC uses the USB_CFG and SUSP_N signal pins to control its charging current support or the BC_DET signal pin to enable fast charging current mode. 8.2 USB 1.1 FS Transceiver The USB Transceiver provides the USB full-speed electrical signal requirements and USB physical interface (DP/DM). This block also includes one precise internal oscillator for PLL. The PLL provides the clock to other logic functions. This block also includes the internal USB series termination resistors on the USB data lines and pull-up resistor for the DP signal. 8.3 LDO Regulator This block is the 5V to 3.3V LDO regulator to power and drive the USB transceiver. It also includes 3.3V brownout detection output signals that will be used by digital circuit to reset the chip. The LDO 5V to 3.3V can supply 100mA for chip internal and external components. 8.4 Clock Generator The clock generator module generates the 48MHz and 12MHz reference clock signals for internal chip logic. The internal clocks will be stopped while in suspend state. 8.5 USB FS SIE The USB Full-Speed Serial Interface Engine (SIE) block performs the processing of USB DP/DM signals. It translates the internal parallel data to serial data and outputs to USB FS transceiver to generate external USB DP/DM signals timing. It also translates external USB DP/DM signals pass through USB FS transceiver to parallel data for internal circuit. This block supports USB packet decoding and encoding. It also generates and check packet CRC, bit stuffing, SYNC and EOP frame signal. The DPLL module will use the internal 48MHz clock to synchronize external DP/DM transitions to generate 12MHz clock for USB interface related circuit. Release: Apr. 27, 20 - 19 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 8.6 Power Management This module will monitor the USB attachment and DP/DM signals state to create reset state, running state, suspend state, wakeup state, etc. 8.7 Control Endpoint The Control Endpoint module handles control endpoint packet transfer protocols such as SETUP packet, DATA packet and return status packet. 8.8 Bulk Out Endpoint The Bulk Out Endpoint module handles bulk-out endpoint packet transfer protocols such as DATA packet and return status packet. It also transfers USB host bulk-out data to chip outbound FIFO. 8.9 Bulk In Endpoint The Bulk In Endpoint module handles bulk-in endpoint packet transfer protocols such as DATA packet and return status packet. It also transfers data inside the chip inbound FIFO to USB host through bulk-in DATA packet. 8.10 Interrupt In Endpoint The Interrupt In Endpoint module handles interrupt-in endpoint packet transfer protocols such as DATA packet and return status packet. It transfers interrupt data generated inside the chip to USB host through interrupt-in DATA packet. 8.11 Command Sequencer This module handles the USB standard requests and vendor requests. It dispatches control signals to relative peripheral modules and gather information from peripheral modules. When it received USB standard request commands, it may check ROM data or data latched from OTP and return them to USB host. When vendor requests are received, it dispatches to peripherals to set or get something. 8.12 Outbound FIFO This buffer receives data from Bulk Out Endpoint and provides data to peripheral modules. It handles read and write pointers and calculate full and empty conditions. There are also near empty threshold check to notify peripheral module that FIFO is going to empty. Release: Apr. 27, 20 - 20 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 8.13 Inbound FIFO This buffer receives data from peripheral modules and provides data to Bulk In Endpoint. It handles read and write pointers and calculate full and empty conditions. There are also near full threshold check to notify peripheral module that FIFO is going to full. 8.14 Event Generator This module provides interrupt data to Interrupt In Endpoint. This module senses interrupt event toggle from UART peripheral and GPIO module. 8.15 Internal OTPROM The OTPROM (One-Time Programming Read-Only Memory) is used to store chip function settings, GPIO pin function setting and USB descriptor related data. A one-time programming user area of the memory is available to allow customization of settings. The user area of the PL2303GC OTPROM can now be easily programmed using the Prolific OTPROM software through USB port without any additional voltage converter requirement. Refer to Section 9.0 for more information on the OTPROM configuration settings. 8.16 Mux/Demux This module is designed to pass data between FIFO and UART peripheral module. 8.17 Descriptor ROM This block contains the USB descriptor data for returning to USB host. 8.18 UART Control The UART Control module handles the data transfer according to RS232 format and interface. Full set flow control is implemented including RTS/CTS, DTR/DSR and software flow control. Flow control circuit will check FIFO near full or near empty status to activate flow control signals. This module includes a precise baud rate generator that can generate baud rates up to 12Mbps. The baud rate is set from USB command. 8.19 Control Registers The Control Registers module contains the chip control registers read and set, and initially loads from OTPROM. USB host will use USB vendor command to read and write control registers to set chip function. Release: Apr. 27, 20 - 21 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 8.20 IO Functions The IO Functions block implements generic GPIO function and many configurable I/O functions such as TX access LED and RX access LED features, clock output features, and others (see Section 7.4). 8.21 I/O Routing Logic The PL2303GC has many versatile I/O functions. Each GPIO pin is provided with multiple functions that can be configured in the OTPROM. This module multiplexes I/O functions to different chip I/O pins. It also handles I/O pin polarity, open-drain, pull-up/pull-down, and I/O pin drive capability functions. 8.22 I2C EEPROM Controller The I2C EEPROM Controller provides an optional alternative solution to the OTPROM that allows an external I2C EEPROM to be attached through GPIO pins 2 and 9 (GPA4/GPA5); or pins 14 and 13 (GPB2/GPB3) for the SDA and SCL interface. Using the PL2303G OTPROM/EEPROM Writer program, customer can also write the chip function settings, GPIO pin function settings, and USB descriptor related data to external I2C EEPROM. The advantage of using an external EEPROM is that it can be written several times. The Prolific OTPROM/EEPROM software works by plugging the device through USB port without any additional voltage converter requirement. Refer to Section 9.0 for more information on the OTPROM/EEPROM configuration settings. Release: Apr. 27, 20 - 22 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 9. Chip Function Configuration The default configuration descriptors are stored in the chip internal memory which will be loaded during power-on reset or USB bus reset whenever OTPROM is empty. Several of the USB and configuration descriptors could be modified and programmed one-time into the chip’s OTPROM using the PL2303GC OTPROM/EEPROM Writer utility program. These descriptors include Vendor ID, Product ID, Serial Number, Product String, UART settings, GPIO configurations, and other configuration descriptors. The PL2303GC chip also provides an option to use an external I2C EEPROM to write the configurations several times. 9.1 USB Data Configuration Table 9-1 USB Descriptor Configuration Descriptors Default Value Description This field allows writing the chip configuration settings either into the OTPROM or to an external EEPROM. OTPROM / External EEPROM Release: Apr. 27, 20  Use OTPROM – this option will write the new settings into the chip’s OTPROM. The OTPROM can only be written once. If the Space box denotes a 1, it means it can be written.  Enable Ext. EEPROM (GPA5:SCL, GPA4:SDA) – this option can be used if there is an external I2C EEPROM attached to pins GPA5 and GPA4 of PL2303GC. Settings will be written to the external Use OTPROM - 23 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC EEPROM and can be written several times.  Enable Ext. EEPROM (GPB3:SCL, GPB2:SDA) – this option can be used if there is an external I2C EEPROM attached to pins GPB3 and GPB2 of PL2303GC. Settings will be written to the external EEPROM and can be written several times. NOTE: PL2303GC chip can only allow a one-time switch from OTPROM to Ext EEPROM or vice-versa. USB unique Vendor ID of Company or Manufacturer. This ID is applied and registered from USB-IF. Vendor ID (VID) 067B (hex) Refer to this website for applying VID: http://www.usb.org/developers/vendor/ Product ID (PID) 23A3 (hex) USB Product ID assigned by Manufacturer. Release No. (BCD) 0100 (hex) This field reports the release number of the USB device chip. This item is not allowed to be modified. Device Power Mode Bus Powered (100mA) This field sets the USB device maximum power that can be drawn by the device from the USB host. Enter the value here if it is not 100mA or 500mA. Expressed in 2 mA units (i.e., 50 = 100 mA). Max Power 100mA USB Selective Suspend Enable Manufacturer String Prolific Technology Inc. Product String Serial Number This field sets the USB device if bus-powered or self-powered device. This field enables/disables the USB Selective Suspend function. When enabled, Windows OS will suspend the device when idle for few seconds (COM port not open). USB-Serial Controller Enable Unique Serial Number ID This field contains the product manufacturer string. This field when entered will be the device string displayed by Windows and other OS when device is first detected and before driver is loaded or driver not installed. After driver is loaded, Windows will show the product string written inside the driver INF file.  Disable Serial Number – this option will disable the Serial Number. Operating System will assign a random serial number for the device.  Enable Unique Serial Number ID – this default option enables the unique serial number pre-programmed inside the chip.  Custom Serial Number – this option allows the customer to set own product serial numbering: o Auto SN: allows to add prefix while the numbers auto increment after each write. o Fixed SN: this will write the same number. Device with serial number enabled allows the device to be assigned with the same COM port number even when plug to other USB ports of the same PC. NOTE: The total string length for the manufacturer + product + serial number string is up to 90 characters. Release: Apr. 27, 20 - 24 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 9.2 UART Configuration Table 9-2 UART Startup Configuration Functions Default Value Description LED Flash Fast This option sets the flashing speed of the access LED when configured using the TX_LED, RX_LED, TRX_LED GPIO pins. Fast 11.4Hz and slow 2.8Hz. UART Mode Full-duplex UART  Full-Duplex UART – this default setting allows simultaneous transmission of TX and RX lines.  Half-Duplex UART – this option only allows for one-way transmission at a time. When there is no data transmission, TXD will be tri-state. Disable This allows using the RXD pin as remote wakeup. The received data from RXD may be wrong while chip is waking up. Disable This option allows setting the software flow control (Xon/Xoff) during chip initial startup. In general, this option need not enabled because driver or software can control this option. Hardware Flow Control Disable This option allows setting the hardware flow control (RTS/CTS, DTR/DSR, Both) during chip initial startup. In general, this option need not enabled because driver or software can control this option. Buffer Size Configuration 256(TX) - 768(RX) Remote Wakeup (RXD) Software Flow Control Release: Apr. 27, 20 736(HW) - 384(LW) This sets the internal buffer size configuration for TX (downstream) and RX (upstream) as well as the high and low watermark threshold levels. - 25 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 9.3 GPIO (GPA) Configuration Also refer to Section 7.4 for the complete GPIO Multi-Function options description. Table 9-3 GPIO (GPA Group) Configuration GPIO Function Default Value Default I/O Description This field also allows setting the pin as a standard GPIO. GPA0 TXD Output  TXD (default)  GPIO (General Purpose I/O) This field also allows setting the pin as a standard GPIO. GPA1 RXD Input  RXD (default)  GPIO (General Purpose I/O) This field allows setting the pin as a standard GPIO or any of the following function: GPA2 RTS Output  RTS (default)  TX_LED  CLK_OUT (also refer to MISC folder)  SUSP_N (also refer to MISC folder)  USB_CFG  TXEN  GPIO (General Purpose I/O) 1 This field allows setting the pin as a standard GPIO or any of the following function: GPA3 Release: Apr. 27, 20 CTS Input - 26 / 49 -  CTS (default)  RX_LED  TRX_LED  WAKEUP Rev.1.0.3 Product Data Sheet PL2303GC  VBUS_DET (also refer to MISC folder)  BC_DET  GPIO (General Purpose I/O) This field allows setting the pin as a standard GPIO or any of the following function: GPA4 DTR Output  DTR (default)  TX_LED  CLK_OUT (also refer to MISC folder)  USB_CFG  EE_SDA  GPIO (General Purpose I/O) 1 This field allows setting the pin as a standard GPIO or any of the following function: GPA5 DSR Input  DSR (default)  RX_LED  TRX_LED  BC_SUSP_N  EE_SCL  GPIO (General Purpose I/O) This field allows setting the pin as a standard GPIO or any of the following function: GPA6 DCD Input  DCD (default)  VBUS_DET (also refer to MISC folder)  BC_DET  TXEN  GPIO (General Purpose I/O) This field also allows setting the pin as a standard GPIO. GPA7 RI (Wakeup)  RI (default) Input  GPIO (General Purpose I/O) Enable Open-Drain Disabled This field sets the selected I/O pin to open-drain output mode. This field enables the selected I/O pin weak pull-up. Enable-Pull Up Disabled NOTE: The weak pull-up resistor is pull-up to VDD_IO. When enabling pull-up for input pins, the input signal voltage should not be higher than the VDD_IO voltage. 1 Inverse Polarity Disabled Output Driving Strength 4mA This field inverts the selected I/O pin input and output signal polarity. This field sets the output driving strength of the selected pin. (4mA up to 8mA) @VDDIO3.3V Note: Only one GPIO pin can be configured as CLK_OUT function. Release: Apr. 27, 20 - 27 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 9.4 GPIO (GPB) Configuration Also refer to Section 7.4 for the complete GPIO Multi-Function options description. Table 9-4 GPIO (GPB Group) Configuration GPIO Function Default Value Default I/O Description This field allows setting the pin as a standard GPIO or any of the following function: GPB0 GPIO Input  GPIO (General Purpose I/O)  TX_LED  CLK_OUT (also refer to MISC folder) 1 This field allows setting the pin as a standard GPIO or any of the following function: GPB1 GPIO Input  GPIO (General Purpose I/O)  RX_LED  TRX_LED This field allows setting the pin as a standard GPIO or any of the following function: GPB2 GPIO Input  GPIO (General Purpose I/O)  VBUS_DET (also refer to MISC folder)  EE_SDA This field allows setting the pin as a standard GPIO or any of the following function: GPB3 Release: Apr. 27, 20 GPIO Input - 28 / 49 -  GPIO (General Purpose I/O)  USB_CFG  EE_SCL Rev.1.0.3 Product Data Sheet PL2303GC This field allows setting the pin as a standard GPIO or any of the following function: GPB4 GPB5 GPIO Input GPIO Input  GPIO (General Purpose I/O)  CLK_OUT (also refer to MISC folder)  BC_SUSP_N 1 This field allows setting the pin as a standard GPIO or any of the following function:  GPIO (General Purpose I/O)  BC_DET This field allows setting the pin as a standard GPIO or any of the following function: GPB6 GPB7 Enable Open-Drain SUSP_N Output GPIO Input Disabled  GPIO (General Purpose I/O)  USB_CFG  WAKEUP  CLK_OUT (also refer to MISC folder) 1 This field allows setting the pin as a standard GPIO or any of the following function:  GPIO (General Purpose I/O)  TXEN This field sets the selected I/O pin to open-drain output mode. This field enables the selected I/O pin weak pull-up. Enable-Pull Up Disabled NOTE: The weak pull-up resistor is pull-up to VDD_IO. When enabling pull-up for input pins, the input signal voltage should not be higher than the VDD_IO voltage. 1 Inverse Polarity Disabled Output Driving Strength 4mA This field inverts the selected I/O pin input and output signal polarity. This field sets the output driving strength of the selected pin. (4mA up to 8mA) @VDDIO3.3V Note: Only one GPIO pin can be configured as CLK_OUT function. Release: Apr. 27, 20 - 29 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 9.5 Miscellaneous (MISC) Configuration This folder includes other miscellaneous chip configuration options including VBUS_DET, chip I/O suspend state, SUSP_N, USB chip suspend, and clock output frequency divider options. Table 9-5 Miscellaneous Configuration Functions Default Value Description Suspend Mode I/O State Keep I/O Driving State This option allows setting the I/O state when chip is in suspend mode. SUSP_N Pin Active when both USB not configured and USB suspend This option allows setting the SUSP_N pin behavior when USB is not configured and in suspend state. USB Chip Suspend Enabled This option can enable or disable the USB chip to suspend. This field sets the output clock divider value. Output Clock Divider 0xFF When value is 0, output clock pin will stay at low state. When value is 0xff, output clock pin will stay at high state. When other value, output clock rate is 24MHz / (1 + clock divider value). The default value can be kept as is and let customer driver or user tool through SDK to dynamic change the clock divider rate. Note: Only one GPIO pin can be configured as CLK_OUT function. Release: Apr. 27, 20 - 30 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 10. Design Application Examples This section illustrates conceptual design application examples using the PL2303GC. 10.1 USB Bus Powered Design The PL2303GC has a built-in 3.3V regulator. USB device power (pin VIN) can be supplied directly from USB VBUS pin. The capacitor behind the USB connector on VBUS is a defined requirement of USB specification. If the regulator output VO_33 needs to be maintained at 3.3V, VIN should be larger than 3.6V. It is also recommended to add capacitor at VO_33 pin, please refer to schematic. This built-in 3.3V regulator can supply 100mA in addition to providing chip operating power around 10mA. It is also possible to supply power to external components under the range limit. PL2303GC USB connector VIN VBUS Regulator DD+ VO_33 C1 GND C2 Figure 10-1 USB Bus Powered Design Example 10.2 Self Powered Design The PL2303GC can also use external power supply. There are two possible ways to use external power source. The first is to use system power source to connect to VIN, and the chip’s internal 3.3V regulator will generate the 3.3V power output VO_33 for chip operations and external components. Below Figure 10-2a shows this case. The second is to disable the internal regulator where the system should provide the same 3.3V voltage to VIN and VO_33. Under this condition, the chip will use this external 3.3V power as operating power source. See Figure 10-2b. For USB self-powered design, it is also recommended to enable the VBUS_DET GPIO input pin function because the PL2303GC DP pin will be pulled up after power on even if USB is not attached yet. USB specification states that a DP pull-up means to attach USB. If the VBUS_DET pin function is turned on and connected to VBUS pin, the chip will only pull-up the DP pin to USB bus when VBUS_DET is active. Release: Apr. 27, 20 - 31 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC To use self-powered design, USB power mode descriptor in the OTPROM or EEPROM of the PL2303GC chip should also be programmed to self-powered mode to match this kind of configuration. USB hosts can read the USB descriptor of the device to know if it is a self-powered device. Supply 3.3V to 5V PL2303GC USB connector VIN VBUS Regulator DD+ VO_33 GND VBUS_DET Figure 10-2a USB Self Powered Design Example 1 Supply 3.3V PL2303GC USB connector VIN VBUS Regulator DD+ VO_33 GND VBUS_DET Figure 10-2b USB Self Powered Design Example 2 Release: Apr. 27, 20 - 32 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 10.3 Chip Reset Control The PL2303GC has an internal power on reset circuit; therefore, external reset control circuit is optional. External reset control (RESET_N pin) can help system designs to make sure of chip operation start time. PL2303GC VIN Regulator VO_33 VDD_IO POR RESET_N Reset Gen Figure 10-3a Chip Reset Control Application The power ramp-up time shall keep below than 1ms as shown in diagram below. VIN 2.4V 0V 800us Figure 10-3b Chip Power Reset Timing Diagram Release: Apr. 27, 20 - 33 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 10.4 I/O Power Supply to PL2303GC The PL2303GC supports a wide range of I/O voltage. The simple way to supply IO voltage is to directly connect VDD_IO to VO_33 pin to provide 3.3V I/O voltage. Add capacitor to VDD_IO can help to reduce I/O noise. Please refer to schematic for the detailed capacitor value. PL2303GC USB connector VIN VBUS Regulator DVO_33 D+ GND C1 C2 VDD_IO Figure 10-4a IO Power Supply VDD_IO can also be supplied from other power source to provide different I/O voltage. All of the PL2303GC I/O pins, including UART signals, use the same VDD_IO voltage. The I/O pins does not support mixed I/O voltages. Unless open-drain option is enabled, the I/O connection between two chips shall use the same VDD_IO voltage. PL2303GC I/O pin also supports 5V tolerance which allows 5V input signal level in different VDD_IO voltage. {Note: VDD_IO voltage should not be larger than VIN voltage.} PL2303GC VIN TXD RX RXD TX Regulator VO_33 Supply IO Voltage VDD_IO VDD_IO Figure 10-4b VDD_IO Voltage Supply Release: Apr. 27, 20 - 34 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 10.5 USB to RS232 Cable Design The most common design application for the PL2303GC is the USB to RS232 converter cable or adapter shown in the diagram below. This design pairs the PL2303GC with an RS232 transceiver chip (ex. SIPEX SP213EHCA) to convert the PL2303GC TTL levels serial interface to RS232 level signals. The design below includes the use of the SUSP_N pin (SHTDN#) to power down the transceiver chip to sleep mode when in USB suspend mode. The default OTPROM supports this function directly and no need to program the OTP for special GPIO setting. Below diagram also shows an access LED example on how to make use of GPB0 and GPB1 pins which are configured as TX and RX access LED. RS232 PL2303GC Transceiver VDD_IO TXD T1IN VO_33 RXD R1OUT USB connector VBUS VIN D- DM D+ DP RTS_N T2IN CTS_N R2OUT DTR_N T3IN DSR_N R3OUT DCD_N R4OUT RI_N RTOUT GND C1 GND SHTDN# TX_LED/GPB0 VDD_IO RX_LED/GPB1 VDD_IO GPB2 GPB3 GPB4 GPB5 SUSP_N GPB7 Figure 10-5 USB to RS232 Design Example Release: Apr. 27, 20 - 35 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 10.6 USB to RS485/RS422 Another popular application for the PL2303GC is the USB to RS485/422 design. For RS485, the chip is paired with an RS485 transceiver chip to convert the serial interface of the PL2303GC to RS485 levels. RS485 transceivers are only enabled when data is being transmitted. Hence, it needs to use the TX_EN (transmit enable) GPB7 GPIO pin to connect to the RS485 transceiver output enable pin and enable this pin function using the OTPROM software. This application can also make use of the GPB0 and GPB1 pins configured as TX and RX access LED. RS485/RS422 Transceiver VDD_IO TXD DI VO_33 RXD RO RTS_N RE\ CTS_N DE USB connector VBUS VIN D- DM D+ DP DTR_N DSR_N GND DCD_N C1 RI_N GND TX_LED/GPB0 VDD_IO RX_LED/GPB1 VDD_IO GPB2 GPB3 GPB4 GPB5 SUSP_N TX_EN/GPB7 Figure 10-6 USB to RS485/422 Design Example Release: Apr. 27, 20 - 36 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 10.7 Battery Charging Support The PL2303GC supports USB battery charging specification (BC1.2) where in battery charging controller can use signals from PL2303GC to control the charging current. An example of charging control concept is shown in below diagram. LTC4053 USB connector VBUS CHRG# ACPR# D- VCC D+ FAULT# SHDN# TIMER PROG GND BAT GND NTC BC_DET/GPB5 USB_CFG/GPB6 BC_SUSP_N/GPB4 VIN PL2303GC Figure 10-7a Battery Charging Design Example #1 This concept diagram uses the GPB5 GPIO pin configured as BC_DET (battery charge detect pin) signal and this pin need to set to inverse polarity and open-drain mode. GPB6 GPIO pin is configured as USB_CFG and is also set to inverse polarity and open-drain mode. GPB4 GPIO pin is configured as BC_SUSP_N function and connected to shutdown signal of charging controller. All above signals can achieve charging conditions as below table. Charging Condition Charging Current (max) BC_SUSP_N USB_CFG BC_DET Suspend 2.5mA 0 x x Un-configured 100mA 1 1 1 Operation 500mA 1 0 1 Fast Charging 1500mA 1 1 0 Release: Apr. 27, 20 - 37 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC Below is another example of charging controller support concept. MAX8856 USB connector VBUS DD+ GND BAT SYS BAT SYS IN SETI VL GND THM EN1# CHG# EN2# POK# GATE I=1A, R=16.8k USB_CFG/GPB3 SUSP_N/GPB6 VIN PL2303GC Figure 10-7b Battery Charging Design Example #2 The above concept diagram uses GPB3 pin as USB_CFG and set to normal polarity and push-pull I/O mode as default. GPB6 pin is configured as SUSP_N and set to inverse polarity and push-pull IO mode. The SUSP_N option is also set active during USB bus suspend state only, and not when USB is not configured. This concept diagram can achieve charging conditions as below table. Charging Condition Charging Current (max) SUSP_N USB_CFG Suspend 2.5mA 1 1 Un-configured 100mA 0 0 Operation 500mA 0 1 Fast Charging 1000mA 1 0 Release: Apr. 27, 20 - 38 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 10.8 External I2C EEPROM Support The PL2303GC can also support an external I2C EEPROM to override the OTPROM settings. To use an external EEPROM, it needs to program the OTPROM to enable the external I2C EEPROM support. There are two options, one is to use the GPB2 pin as I2C SDA and the GPB3 pin as I2C SCL; the other option is to use GPA4(DTR_N) pin as I2C SDA and GPA5(DSR_N) pin as I2C SCL. 1k 1k 24C02 VDD USB connector VDD_IO GPA4/GPB2 SDA- VO_33 GPA5/GPB3 SCL GND VBUS VIN D- DM D+ DP GND C1 GND Figure 10-8 External I2C EEPROM Design Example There is signature field in external EEPROM space. When this field content is valid, the PL2303GC will load the external EEPROM contents and override the settings defined in the OTPROM. Detailed information can be checked with OTPROM and EEPROM software programming tool. The supported external I2C EEPROM size is 256 bytes. Release: Apr. 27, 20 - 39 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 11. DC & Temperature Characteristics 11.1 Absolute Maximum Ratings Table 11-1 Absolute Maximum Ratings Items Ratings Power Supply Voltage – VIN -0.3 to 6.0 V Input Voltage of VDD_IO -0.3 to VIN+0.3 V Input Voltage of I/O pins with 5V Tolerance I/O -0.3 to 6.0 V Storage Temperature -40 to 150 oC Thermal Resistance (θjc) 19 oC/W (UQFN24) Thermal Resistance (θjc) 31 oC/W (SSOP28) Note: Permanent device damage may occur if the absolute maximum ratings are exceeded. These are stress rating only, and functional operation should be restricted to within the conditions. Exposure to absolute maximum rating conditions for extended periods may affect the device’s reliability. 11.2 DC Characteristics 11.2.1 Operating Voltage and Suspend Current Table 11-2a Operating Voltage and Suspend Current Parameter Power Supply Voltage Range Power Supply for I/O Pins Output Voltage of Regulator Operating Current(1) (Power Consumption) Suspend Current Symbol Min Typ Max Unit VIN 2.8 5 5.5 V VDD_IO 1.8 3.3 VIN+0.3 V VO_33 2.97 3.3 3.63 V IDD - 9.5 15 mA ISUS - 250 450 A Note: (1) – No device connected. 11.2.2 I/O Pins Table 11-2b I/O Pins Parameter Symbol Min Typ Max Unit Low VIL -- -- 0.4 V High VIH 0.7* VDD_IO -- -- V Low VOL -- -- 0.4 V High VOH 0.7*VDD_IO -- -- V Input Voltage (CMOS) Output Voltage Release: Apr. 27, 20 - 40 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 11.3 Temperature Characteristics Table 11-3 Temperature Characteristics Parameter Symbol Min Typ Max Unit Operating Temperature (ambient) -- -40 -- 85 o Junction Operation Temperature TJ -40 25 125 o C C 11.4 Baud Rate Characteristics Table 11-4 Baud Rate Characteristics Parameter Symbol Min Typ Max Unit Baud rate @ VDD_IO = 5V -- 1 -- 12M bps Baud rate @ VDD_IO = 3.3V -- 1 -- 12M bps Baud rate @ VDD_IO = 1.8V -- 1 -- 6M bps Release: Apr. 27, 20 - 41 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 12. Outline Diagram 12.1 Chip Marking information Figure 12-1 Chip Part Number Information (SSOP) Table 12-2 Chip Marking Information Line Marking First Line PL2303GC Description Chip Product Name G Green packing material Second Line YY Last two digits of the manufacturing year (GYYWWXX) WW Week number of the manufacturing year XX Chip Version Third Line XXXXXXXXX Manufacturing LOT code Example: “G19361A” – means Green packing + Year 2019 + Week no. 36 + 1A chip version. 12.2 SSOP28 Package Table 12-1 Package Dimension Symbol Millimeter Min Nom Inch Max Min 0.38 0.009 Nom Max b 0.22 0.015 E 7.40 7.80 8.20 0.291 0.307 0.323 E1 5.00 5.30 5.60 0.197 0.209 0.220 L 0.55 0.75 0.95 0.021 0.030 0.037 R1 0.09 D 9.9 0.402 0.413 0.004 10.2 A 10.5 0.390 2.0 0.079 e 0.65 0.0256 L1 1.25 0.050 A1 0.05 A2 1.65 Release: Apr. 27, 20 0.020 1.75 1.85 - 42 / 49 - 0.065 0.069 0.073 Rev.1.0.3 Product Data Sheet PL2303GC Figure 12-1 PL2303GC Outline Diagram (SSOP28) Release: Apr. 27, 20 - 43 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 12.3 UQFN24 Package Figure 12-2 PL2303GC Outline Diagram (UQFN24) 4 x 4 mm Release: Apr. 27, 20 - 44 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 13. Packing Information 13.1 Carrier Tape (SSOP-28) Figure 13-1a SSOP28 Carrier Tape Notes:  10 sprocket hole pitch cumulative tolerance 0.2  Camber not to exceed 1mm in 100mm.  Material: Black Polystyrene.  Ao and Bo measured on a plane 0.3mm above the bottom of the pocket.  Ko measured from a plane on the inside bottom of the pocket to the top surface of the carrier.  Pocket position relative to sprocket hole measured as true position of pocket, not pocket hole.  IC quantity per one reel: 2,000 pieces (MOQ) Figure 13-1b IC Reel Placements Release: Apr. 27, 20 - 45 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 13.2 Carrier Tape (UQFN24) Figure 13-2 UQFN24 Carrier Tape Release: Apr. 27, 20 - 46 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 13.3 Reel Dimension Figure 13-3 Reel Dimension Table 13-1 Reel Part Number Information Package Part Number Normal Hub W1 +0.3mm Width -0.2mm W2 Max UQFN24 RD33008SW-T + RD33004SW-T 12mm 12.8mm 18.2mm SSOP28 RD33008SW-T + RD33008SW-T 16mm 16.8mm 22.2mm Release: Apr. 27, 20 - 47 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC 13.4 Tube Packing Figure 13-4 Tube Packing Dimension Release: Apr. 27, 20 - 48 / 49 - Rev.1.0.3 Product Data Sheet PL2303GC Disclaimer All the information in this document is subject to change without prior notice. Prolific Technology Inc. does not make any representations or any warranties (implied or otherwise) regarding the accuracy and completeness of this document and shall in no event be liable for any loss of profit or any other commercial damage, including but not limited to special, incidental, consequential, or other damages. Trademarks The Prolific logo is a registered trademark of Prolific Technology Inc. All brand names and product names used in this document are trademarks or registered trademarks of their respective holders. Copyrights Copyright © 2018 – 2020 Prolific Technology Inc. All rights reserved. No part of this document may be reproduced or transmitted in any form by any means without the express written permission of Prolific Technology Inc. Release: Apr. 27, 20 - 49 / 49 - Rev.1.0.3
PL2303GC 价格&库存
很抱歉,暂时无法提供与“PL2303GC”相匹配的价格&库存,您可以联系我们找货
PL2303GC
  • 10+8.01735
  • 100+7.89305
库存:100
PL2303GC
库存:1309
