5ET-032H1
5ET-032H1
    HOLLY(好利来)
    插件,P=5.08mm
    一次性保险丝(熔断) 3.15A 300V
5ET-032H1 数据手册
5ET 8x8.5x4mm, RoHS Compliant & Pb-Free RADIAL LEAD MICROFUSE (TIME-LAG) 径向引线式保险丝管(慢断型) PATENT NO. 专利号 :ZL 200620053742.1 BREAKING CAPACITY / 分断能力: CURRENT RATING 额定电流 5ET-050H1/H/L 50mA 5ET-080H1/H/L 80mA 5ET-063H1/H/L Max. VOLTAGE DROP(mv) 最大电压降 550 63mA CCC H1 H SEMKO H SAFETY APPROVALS 安全认证 VDE H1 H cURus H1 H L BSI H PSE KC TÜV H1 H H 480 400 ● 5ET-0100H1/H/L 100mA 350 ● ● ● ● ● ● ● ● 5ET-0160H1/H/L 160mA 280 ● ● ● ● ● ● ● ● 5ET-0125H1/H/L 5ET-0200H1/H/L 5ET-0250H1/H/L 5ET-0315H1/H/L 5ET-0400H1/H/L 5ET-0500H1/H/L 5ET-0630H1/H/L 5ET-0800H1/H/L 5ET-010H1/H/L 5ET-013H1/H/L 5ET-016H1/H/L 125mA 300 200mA 260 250mA 240 315mA 220 400mA 200 500mA 190 630mA 180 800mA 160 1A 140 1.6A 120 1.25A 130 2A 100 5ET-032H1/H/L 3.15A 100 5ET-050H1/H/L 5A 5ET-020H1/H/L 5ET-025H1/H/L 2.5A 100 4A 100 5ET-063H1/H/L 6.3A 100 5ET-100H1/H/L 10A 5ET-040H1/H/L 5ET-080H1/H/L 100 8A 100 100 ● DENOTES FOR APPROVED H ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● H1 DENOTES FOR 300V ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 表示已取得安全认证 ● ● ● ● ● ● ● ● ● ● ● ● ● H1 代表 300V L DENOTES FOR 125V RATING 额定 2.75In 4In 10In PACKING/ 包装: 0.012907 0.019062 Dimensions/ 尺寸 : 散装规格:5ET-XXXHB TAPING SPECIFICATIONS / 编带规格 :5ET-XXXHA Unit 单位:mm MATERIALS: THERMOPLASTIC, UL94-V0 主体材料:阻燃塑料,UL94-V0 0.02623 0.04499 0.08755 0.1181 0.3206 0.5153 0.7761 1.631 2.329 5.145 6.619 12.23 22.03 43.08 50.05 73.53 128.3 190.0 309.5 305.7 439.2 Standards/ 标准:IEC 60127, GB 9364 Operating Temperature/ 工作温度:-55℃ ~125℃ Storaging Temperature/ 储存温度:-55℃ ~85℃ Resistance to soldering heat/ 耐焊接热性:260℃,10s Max. Solderability/ 可焊性:245℃ ±5℃ , 5s±0.5s 5ET AVERAGE I-T CHARACTERISTICS CURVE (FOR REFERENCE ONLY) 5ET 平均 I-T 曲线图 ( 仅供参考 ) L 代表 125V ELECTRICAL CHARACTERISTICS/ 电气特性 : 2.1In 0.006447 1000 H 代表 250V H DENOTES FOR 250V REFERENCE (A2.Sec.) (RoHS) 2 I T 参考值 Max. 最慢 Min. 最快 BLOWING TIME 熔断时间 ≥ 50mA, 且≤ 6.3A > 6.3A,且≤ 10A 400 ms 1 seconds 2 minutes 5 minutes Max. 最慢 10 seconds 20 seconds Max. 最慢 3 seconds 3 seconds Max. 最慢 150 ms 150 ms Min. 最快 Min. 最快 1. INNER BOX/ 内盒 : AMMO PACK 150 ms 20 ms 100 150 ms 20 ms TIME(s)/ 时间 ( 秒 ) PART NO. 目录编号 50mA 63mA 80mA 100mA 125mA 160mA 200mA 250mA 315mA 400mA 500mA 630mA 800mA 1A 1.25A 1.6A 2A 2.5A 3.15A 4A 5A 6.3A 8A 10A TECHNICAL PARAMETERS/ 技术参数 : CCC / SEMKO / VDE / BSI / KTL: 35A OR 10In 250V AC WHICHEVER IS GREATER VDE: 35A OR 10In 300V AC WHICHEVER IS GREATER(1A-6.3A) CCC: 35A OR 10In 300V AC WHICHEVER IS GREATER (100mA-6.3A) PSE: 100A 250V AC cURus: 50A 300V AC, 50A 125V DC (100mA-6.3A), 130A/200A 250V AC (0.315A-10A), 100A 400V (0.315A-10A) TÜV: 130A 250V AC (50mA-10A) 10 1 41 0.1 Unit 单位:mm 2. OUTER CARTON/ 外箱 : 10 INNER BOXES / CARTON CARTON SIZE / 尺寸:L440x W348 x H205(mm) 0.01 0.01 0.1 1 10 CURRENT(A)/ 电流 ( 安培 ) 100 www.hollyfuse.com 1000 19
5ET-032H1 价格&库存
很抱歉,暂时无法提供与“5ET-032H1”相匹配的价格&库存,您可以联系我们找货
5ET-032H1
  • 5+0.92513
  • 50+0.72814
  • 150+0.62964
  • 1000+0.55577
  • 2000+0.49670
  • 5000+0.46721
