X4612WV-04I-C40D28-E60 数据手册
Test Report
Client Name:
No.:
SZXPC23001911609
Date:
Aug 23, 2023
Page 1 of 5
GUANGDONG XKB HOLDING CO.LTD
Client Address: BUILDING 1, NO.36 XINZHOU MIDDLE STREET, LIN VILLAGE, TANGXIA TOWN,
DONGGUAN CITY, GUANGDONG PROVINCE
Sample Name:
Gold plating
The above sample(s) and information were provided by the client.
----------------------------------------------------------------------------------------------------------------------------- ---------------SGS Job No.:
SZPC2308005157
Sample Receiving Date:
Aug 15, 2023
Testing Period:
Aug 15, 2023 ~ Aug 23, 2023
Test Requested:
Select test(s) as requested by the client.
Test Method(s):
Please refer to next page(s).
Test Result(s):
Test Requirement
EU RoHS Directive (EU) 2015/863 amending Annex II to Directive
2011/65/EU- Lead, Mercury, Cadmium and Hexavalent chromium
Signed for and on behalf of
SGS-CSTC Standards Technical Services Co., Ltd. Shenzhen Branch
Ford Shi
Approved Signatory
Conclusion
Pass
Test Report
No.:
SZXPC23001911609
Date:
Aug 23, 2023
Page 2 of 5
Test Result(s):
Test Part Description:
SN ID
Sample No.
SGS Sample ID
SN1
005
SZX23-0019116-0001.C005
Remarks:
(1) 1 mg/kg = 1 ppm = 0.0001%
(2) MDL = Method Detection Limit
(3) ND = Not Detected (< MDL)
(4) “-“ = Not Regulated
Description
Silvery metal
EU RoHS Directive (EU) 2015/863 amending Annex II to Directive 2011/65/EU- Lead, Mercury,
Test Method:
With reference to IEC 62321-4:2013+AMD1:2017, IEC 62321-5:2013 and IEC 62321-71:2015, analysis was performed by ICP-OES and UV-Vis .
Test Item(s)
Cadmium(Cd)
Lead(Pb)
Mercury(Hg)
Hexavalent Chromium (Cr(VI)) ▼
Limit
100
1000
1000
Unit(s)
mg/kg
mg/kg
mg/kg
µg/cm²
MDL
2
2
2
0.10
005
ND
42
ND
ND
Notes:
(1) The maximum permissible limit is quoted from RoHS Directive (EU) 2015/863.
(2) IEC 62321 series is equivalent to EN 62321 series.
(3) ▼ = a. The sample is positive for Cr(VI) if the Cr(VI)concentration is greater than 0.13 μg/cm2. The sample
coating is considered to contain Cr(VI)
b. The sample is negative for Cr(VI) if Cr(VI) is ND (concentration less than 0.10 μg/cm2). The coating is
considered a non-Cr(VI) based coating
c. The result between 0.10 μg/cm2 and 0.13 μg/cm2 is considered to be inconclusive-unavoidable coating
variations may influence the determination.
Information on storage conditions and production date of the tested sample is unavailable and thus Cr(VI) results
represent status of the sample at the time of testing.
Unless otherwise stated, the decision rule for conformity reporting is based on Binary Statement for Simple
Acceptance Rule (w=0) stated in ILAC-G8:09/2019.
Test Report
No.:
Date:
SZXPC23001911609
Aug 23, 2023
Elements Testing Flow Chart
These samples were dissolved totally by pre-conditioning method according to below flow chart.
Sample Preparation
Sample Measurement
Acid digestion with
microwave/ hotplate
Filtration
Solution
Residue
1) Alkali Fusion / Dry
Ashing
2) Acid to dissolve
ICP-OES/AAS
DATA
Page 3 of 5
Test Report
No.:
SZXPC23001911609
Date:
Aug 23, 2023
Hexavalent Chromium (Cr(VI)) Testing Flow Chart
Sample Preparation
Sample Measurement
Nonmetallic
material
ABS/PC/PVC
Metallic
material
Others
Boiling water
extraction
Digesting at
150~160°C
Dissolving by
ultrasonication
Digesting at
60°C by
ultrasonication
Separating to
get aqueous
phase
Adding 1,5diphenylcarba
zide for color
development
UV-Vis
pH adjustment
DATA
Adding 1,5diphenylcarbazide for
color development
UV-Vis
DATA
Page 4 of 5
Test Report
No.:
SZXPC23001911609
Date:
Aug 23, 2023
Sample Photo:
SGS authenticate the photo on original report only
*** End of Report ***
Page 5 of 5
X4612WV-04I-C40D28-E60 价格&库存
很抱歉,暂时无法提供与“X4612WV-04I-C40D28-E60”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.27900
- 100+0.26100
- 500+0.24300
- 2000+0.21600
- 5000+0.20700
- 10000+0.20160
- 国内价格
- 10+0.43154
- 100+0.34279
- 300+0.29847
- 1000+0.25414
- 5000+0.22757
- 10000+0.21433
