LT8711EH-C
LT8711EH-C
    LONTIUM(龙迅)
    QFN64
    视频接口处理芯片 QFN64
LT8711EH-C 数据手册
      LT8711EH‐C ADVANCE INFORMATION – CONFIDENTIAL AND PROPRIETARY                      LT8711EH-C --- Product Brief Type-C/DP1.2 to HDMI2.0 Converter Features  Programmable transmitter swing and pre-emphasis  USB Type-C  5V tolerance DDC/HPD I/Os  Downstream receiver sensing  Compliant with VESA DisplayPort Alt Mode on USB  Miscellaneous  DP receiver to HDMI transmitter bypass to support Type-C Standard V1.0 HDMI Alt Mode  Compliant with USB Power Delivery Specification R2.0,  Internal or external oscillator V1.0  Compatible with USB Type-C Cable and Connector  Integrated microprocessor  Embedded SPI flash for firmware and HDCP keys Specification R1.2  Built-in dual CC controllers for charger and normal  GPIOs for VBUS/VCONN/AUX and other system controls communication  Compliant with HDMI 1.4b Alt Mode on USB Type-C  Integrated 100/400kHz I2C slave  Firmware update through SPI, AUX or I2C interface Specification V1.0  DP1.2 Receiver  Low power consumption  Compliant with VESA DP1.2  Power supply: 3.3V for I/O and 1.2V for core  Support 1.62/2.7/5.4Gbps  ESD 4kV HBM  Support 1/2/4 lanes  Temperature Range: -40°C to +85°C  Support SSC  64-pin QFN 7.5*7.5 package  1Mbps AUX channel Description  Compliant with HDCP1.3  Adaptive receiver equalization for PCB, cable and HDMI2.0 converter, designed to connect a USB Type-C connector losses  Support lane The LT8711EH-C is a high performance Type-C/DP1.2 to swap(arbitrarily) and polarity source or a DP1.2 source to an HDMI2.0 sink. The LT8711EH-C integrates a DP1.2 compliant receiver, inversion(independent) and an HDMI2.0 compliant transmitter. Also, two CC  Receiver PHY is HDMI signal compatible controllers are included for CC communication to  HDMI2.0 Transmitter  Compliant with HDMI2.0, HDMI1.4 and DVI1.0 implement DP Alt Mode and power delivery function, one  Compliant with HDCP2.2 and HDCP1.4 for upstream Type-C port and another for downstream  Data rate up to 6Gbps port.  Support UHD 4k@60Hz(RGB and YCbCr 4:4:4) The device is capable of automatic operation which is  Support TMDS scrambling for EMI/RFI reduction enabled by an integrated microprocessor that uses an  Support SCDC(Status and Control Data Channel) embedded SPI flash for firmware storage. System control  AC-couple capable is also available through the use of a dedicated  Support channel swap(arbitrarily) and polarity configuration I2C slave interface. inversion(independent) Lontium Semiconductor Corporation        www.lontiumsemi.com  LT8711EH‐C Product Brief – Rev 1.3                                      1        LT8711EH‐C ADVANCE INFORMATION – CONFIDENTIAL AND PROPRIETARY                      Applications  Docking Station  Dongle Figure 1. Application Diagram Ordering Information    Part Number Operating Temperature Range Package Packing Method LT8711EH-C −40°C to +85°C QFN64 (7.5*7.5) Tray     Lontium Semiconductor Corporation        www.lontiumsemi.com  LT8711EH‐C Product Brief – Rev 1.3                                      2        LT8711EH‐C ADVANCE INFORMATION – CONFIDENTIAL AND PROPRIETARY                      Copyright © 2016-2018 Lontium Semiconductor Corporation, All rights reserved. Lontium Semiconductor Proprietary & Confidential This document and the information it contains belong to Lontium Semiconductor. Any review, use, dissemination, distribution or copying of this document or its information outside the scope of a signed agreement with Lontium is strictly prohibited. LONTIUM DISCLAIMS ALL WARRANTIES, EXPRESSED OR IMPLIED, INCLUDING THOSE OF NONINFRINGEMENT, MERCHANTABILITY, TITLE AND FITNESS FOR A PARTICULAR PURPOSE. CUSTOMERS EXPRESSLY ASSUME THEIR OWN RISH IN RELYING ON THIS DOCUMENT. LONTIUM PRODUCTS ARE NOT DESIGNED OR INTENDED FOR USE IN LIFE SUPPORT APPLIANCES, DEVICES OR SYSTEMS WHERE A MALFUNCTION OF A LONTIUM DEVICE COULD RESULT IN A PERSONAL INJURY OR LOSS OF LIFE. Lontium assumes no responsibility for any errors in this document, and makes no commitment to update the information contained herein. Lontium reserves the right to change or discontinue this document and the products it describes at any time, without notice. Other than as set forth in a separate, signed, written agreement, Lontium grants the user of this document no right, title or interest in the document, the information it contains or the intellectual property in embodies. Trademarks Lontium™ 龙迅™ and ClearEdge™ is a registered trademark of Lontium Semiconductor. All Other brand names, product names, trademarks, and registered trademarks contained herein are the property of their respective owners. Visit our corporate web page at: www.lontiumsemi.com Technical support: support@lontium.com Sales: sales@lontium.com     Lontium Semiconductor Corporation        www.lontiumsemi.com  LT8711EH‐C Product Brief – Rev 1.3                                      3
LT8711EH-C 价格&库存
很抱歉,暂时无法提供与“LT8711EH-C”相匹配的价格&库存,您可以联系我们找货
