BE2F5VB2
Bi-directional
1 Line ESD Protection
Description
The BE2F5VB2 is a bi-directional ESD protection
http//:www.szbetterwin.com
diode designed to protect sensitive electronic
components which are connected to low speed
data lines and control lines from over-stress caused
by ESD (Electrostatic Discharge), EFT (Electrical
Fast Transients) and Lightning. The BE2F5VB2
may be used to provide ESD protection up to
±30kV (contact and air discharge) according to
IEC61000-4-2, and withstand peak pulse current up
DFN1006-2L(Bottom View)
to 8A (8/20μs) according to IEC61000-4-5.
The
BE2F5VB2
is
available
in
DFN1006-2L
package. Standard products are Pb-free
and Halogen-free.
Features
◆ Working voltage: 5V
◆ DFN1006-2L Package
Circuit Diagram
◆ Transient protection for data lines to
IEC61000-4-2 (ESD) ±30kV (air),
±30kV (contact)
IEC61000-4-5 (Surge) 8A (8/20us)
IEC61000-4-4(EFT)40A(5/50ns)
◆ Low leakage current
◆ Low clamping voltage
◆ Solid-state silicon-avalanche technology
Marking(Top View)
Applications
◆ Personal digital assistants (PDA's)
◆ Notebooks, Desktops, and Servers
Order Information
◆ Cell phone Handsets and Accessories
Device
Package
◆ Portable Electronics
BE2F5VB2
DFN1006-2L
Shipping
10000/Tape&Reel
◆ Peripherals
Rev.1.0
1
www.szbetterwin.com
BE2F5VB2
Definitions of electrical characteristics
Symbol
Parameter
VRWM
Reverse Stand-off Voltage
IR
Reverse Leakage Current @ VRWM
VBR
Reverse Breakdown Voltage @ IT
IR
Reverse Breakdown Current
IPP
Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tP = 8/20μS )
PPK
90
W
Peak Pulse Currentr ( tP = 8/20μS )
Ipp
8
A
±30
kV
±30
kV
TL
260 (10 sec)
Operating Temperature
TOP
-55 to +125
Storage Temperature
TSTG
-55 to +150
ESD according to IEC61000-4-2 air discharge
VESD
ESD according to IEC61000-4-2 contact discharge
Lead Soldering Temperature
Electrical Characteristics (Ta=25℃, unless otherwise noted)
Parameter
Symbol
VRWM
IR
VRWM =5V
VBR
IT=1mA
Clamping
Voltage1)
Junction Capacitance
VCL
Cj
Conditions
Min.
Typ.
Max.
Units
5
V
100
nA
5.5
V
IPP=5A
tP = 8/20μs
8.5
9.5
V
IPP=8A
tP = 8/20μs
10
12
V
VR=0V f = 1MHz
14
pF
Notes:
1)Non-repetitive current pulse, according to IEC61000-4-5.
Rev.1.0
2
www.szbetterwin.com
BE2F5VB2
Typical Characteristics (Ta=25℃, unless otherwise noted)
Pulse Waveform (8/20us)
Pulse Derating Curve
ESD Clamping(8kV Contact Discharge )
Rev.1.0
3
www.szbetterwin.com
BE2F5VB2
Package Outline Dimensions (DFN1006-2L)
Dim
Inches
Millimeters
MIN
MAX
MIN
MAX
A
0.018
0.020
0.46
0.51
B
0.000
0.002
C
0.037
0.041
0.95
1.05
D
0.022
0.025
0.55
0.65
E
0.017
0.021
0.45
0.55
F
0.008
0.012
0.20
0.30
H
R
0.015Typ.
0.001
0.005
0.40Typ
0.05
0.15
Recommend Land Pattern (Unit: mm)
Note:
This recommended land pattern is for reference purpose only.
Rev.1.0
4
www.szbetterwin.com
BE2F5VB2
Load with information
Unit:mm
.1.0
5
www.szbetterwin.com
很抱歉,暂时无法提供与“BE2F5VB2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.12402
- 200+0.11797
- 600+0.11192
- 2000+0.10587
- 5000+0.09982
- 10000+0.09559
