FCR1206LT240R
FCR1206LT240R
    SEI
    RES 240 OHM 15% 1/4W 1206
FCR1206LT240R 数据手册
FCR Series Stackpole Electronics, Inc. Trimmable Thick Film Chip Resistor Resistive Product Solutions Features: • • • • • YAG laser user-trimmable in circuit Available in a variety of pre-trim tolerance ranges TCR of ± 200 ppm/ºC RoHS compliant and halogen free REACH compliant Electrical Specifications Maximum Working Power Rating (W) @ 70ºC 0.063 0.1 0.125 0.25 0.33 0.75 1 Type/Code FCR0402 FCR0603 FCR0805 FCR1206 FCR1210 FCR2010 FCR2512 Voltage (V) 50 50 100 200 200 200 200 (1) Maximum Overload Voltage (V) 100 100 200 400 400 400 400 TCR (ppm/ºC) Ohmic Range (Ω) ± 200 10 - 1M (1) Lesser of√ P*R or maximum working voltage. Mechanical Specifications Type/Code FCR0402 FCR0603 FCR0805 FCR1206 FCR1210 FCR2010 FCR2512 L Body Length 0.039 ± 0.002 1.00 ± 0.05 0.063 ± 0.006 1.60 ± 0.15 0.079 ± 0.008 2.00 ± 0.20 0.126 ± 0.010 3.20 ± 0.20 0.126 ± 0.008 3.20 ± 0.20 0.197 ± 0.006 5.00 ± 0.15 0.248 ± 0.008 6.30 ± 0.20 W Body Width 0.020 ± 0.002 0.50 ± 0.05 0.031 ± 0.006 0.80 ± 0.15 0.049 ± 0.004 1.25 ± 0.10 0.063 ± 0.010 1.60 ± 0.15 0.098 ± 0.008 2.50 ± 0.20 0.098 ± 0.006 2.50 ± 0.15 0.126 ± 0.008 3.20 ± 0.20 H Body Height 0.014 ± 0.002 0.35 ± 0.05 0.018 ± 0.004 0.45 ± 0.10 0.020 ± 0.004 0.50 ± 0.10 0.024 ± 0.004 0.60 ± 0.10 0.024 ± 0.004 0.60 ± 0.10 0.024 ± 0.004 0.60 ± 0.10 0.024 ± 0.004 0.60 ± 0.10 a Top Termination 0.008 ± 0.004 0.20 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.016 ± 0.008 0.40 ± 0.20 0.020 ± 0.010 0.50 ± 0.25 0.020 ± 0.010 0.50 ± 0.25 0.024 ± 0.010 0.60 ± 0.25 0.028 ± 0.008 0.70 ± 0.20 b Bottom Termination 0.010 ± 0.004 0.25 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.016 ± 0.008 0.40 ± 0.20 0.020 ± 0.012 0.50 ± 0.30 0.020 ± 0.008 0.50 ± 0.20 0.024 ± 0.010 0.60 ± 0.25 0.028 ± 0.008 0.70 ± 0.20 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm Performance Characteristics Test Test Results (JIS C 5202) Load Life in Moisture Temperature Cycle Load Life Resistance to Solder Heat Terminal Adhesion Short Time Overload Operating Temperature Range: -55ºC to +125ºC Rev Date: 11/18/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. ± 3% ± 1% ± 3% ± 1% ± 1% ± 2% 1 www.seielect.com marketing@seielect.com FCR Series Stackpole Electronics, Inc. Trimmable Thick Film Chip Resistor Resistive Product Solutions Power Derating Curve: Trimming Ration Curve: Recommended Solder Profile This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board density, geometry, packages used, etc., especially those cells labeled with “*”. 100% Matte Tin / RoHS Compliant Terminations Soldering iron recommended temperatures: 330°C to 350°C with minimum duration. Maximum number of reflow cycles: 3. Wave Soldering Description Maximum Recommended Preheat Time 80 seconds 70 seconds Temperature Diff. 140°C 120°C Solder Temp. 260°C 250°C Dwell Time at Max 10 seconds 5 seconds Ramp DN (°C/sec) N/A N/A Temperature Diff. = Difference between final preheat stage and soldering stage. Minimum 60 seconds 100°C 240°C * N/A Convection IR Reflow Description Maximum Recommended Minimum Ramp Up (°C/sec) Dwell Time > 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec * 60 seconds * 10 seconds * Rev Date: 11/18/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com FCR Series Stackpole Electronics, Inc. Trimmable Thick Film Chip Resistor Resistive Product Solutions Recommended Lead Free Resistor Reflow Profile RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description Package / Termination Type Trimmable Thick Film SMD Surface Mount Chip Resistor Note (1): RoHS Compliant by means of exemption 7c-I. FCR Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) YES(1) 100% Matte Sn over Ni Jan-04 04/01 “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Rev Date: 11/18/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com FCR Series Stackpole Electronics, Inc. Trimmable Thick Film Chip Resistor Resistive Product Solutions Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order F C Product Series FCR Trimmable R Size Code W 0402 0.063 0603 0.1 0805 0.125 1206 0.25 1210 0.33 2010 0.75 2512 1 0 8 0 Tolerance Code Tol Value K ±10 L ±15 M ±20 N ±30 E24 S 0 ~ -5% U 0 ~ -10% V 0 ~ -20% W 0 ~ -30% Rev Date: 11/18/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 Code K Packaging Description 7" Reel - Paper Tape T 7" Reel - Plastic Tape 4 T 4 Size 0402 0603, 0805 1206, 1210 2010, 2512 7 K 0 Resistance Value Quantity 10000 5000 4000 Four characters with the multiplier used as the decimal holder. 10 ohm = 10R0 10 Kohm = 10K0 1 Mohm = 1M00 www.seielect.com marketing@seielect.com
FCR1206LT240R 价格&库存
很抱歉,暂时无法提供与“FCR1206LT240R”相匹配的价格&库存,您可以联系我们找货
