S-1324A30-M5T1U
S-1324A30-M5T1U
    ABLIC(艾普凌科)
    SOT23-5
    IC REG LINEAR 3.0V 200MA SOT-23-
S-1324A30-M5T1U 数据手册
S-1324 Series www.ablic.com © ABLIC Inc., 2017-2022 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR Rev.1.1_00 The S-1324 Series, developed by using the CMOS technology, is a positive voltage regulator IC which has low noise and low dropout voltage. Output noise is as low as 17 μVrms typ., and a ceramic capacitor of 1.0 μF or more can be used as the input and output capacitors. It also has high-accuracy output voltage of ±1.0%.  Features • Output voltage: • Input voltage: • Output voltage accuracy: • Dropout voltage: • Current consumption: • Output current: • Input capacitor: • Output capacitor: • Output noise: • Ripple rejection: • Built-in overcurrent protection circuit: • Built-in thermal shutdown circuit: • Built-in ON / OFF circuit: • Operation temperature range: • Lead-free (Sn 100%), halogen-free 1.0 V to 3.5 V, selectable in 0.05 V step. 1.5 V to 5.5 V ±1.0% (1.0 V to 1.45 V output product: ±15 mV) 170 mV typ. (2.8 V output product, at IOUT = 100 mA) During operation: 7 μA typ., 12 μA max. During power-off: 0.01 μA typ., 0.1 μA max. Possible to output 100 mA (at 1.0 V ≤ VOUT(S) < 1.2 V, VIN ≥ VOUT(S) + 1.0 V)*1 Possible to output 200 mA (at VOUT(S) ≥ 1.2 V, VIN ≥ VOUT(S) + 1.0 V)*1 A ceramic capacitor can be used. (1.0 μF or more) A ceramic capacitor can be used. (1.0 μF or more) 17 μVrms typ. (at BW = 10 Hz to 100 kHz) 65 dB typ.(at f = 1.0 kHz) Limits overcurrent of output transistor Detection temperature 150°C typ. Ensures long battery life Discharge shunt function "available" / "unavailable" is selectable. Pull-down function "available" / "unavailable" is selectable. Ta = −40°C to +85°C *1. Please make sure that the loss of the IC will not exceed the power dissipation when the output current is large.  Applications • Constant-voltage power supply for communication module and home electric appliance with communication function • Constant-voltage power supply for portable communication device, digital camera, and digital audio player • Constant-voltage power supply for battery-powered device • Constant-voltage power supply for home electric appliance  Packages • SOT-23-5 • SC-82AB • HSNT-4(1010) 1 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00  Block Diagrams 1. S-1324 Series A type *1 VOUT VIN Overcurrent protection circuit Function ON / OFF logic Discharge shunt function Constant current source pull-down Status Active "H" Available Available Thermal shutdown circuit Reference voltage circuit ON / OFF     ON / OFF circuit *1 VSS *1. Parasitic diode Figure 1 2. S-1324 Series B type *1 VOUT VIN Overcurrent protection circuit Thermal shutdown circuit Reference voltage circuit ON / OFF     ON / OFF circuit *1 VSS *1. Parasitic diode Figure 2 2 Function ON / OFF logic Discharge shunt function Constant current source pull-down Status Active "H" Available Unavailable 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00 3. S-1324 Series C type *1 VOUT VIN Overcurrent protection circuit Function ON / OFF logic Discharge shunt function Constant current source pull-down Status Active "H" Unavailable Available Thermal shutdown circuit Reference voltage circuit ON / OFF + − + − ON / OFF circuit VSS *1. Parasitic diode Figure 3 4. S-1324 Series D type *1 VOUT VIN Overcurrent protection circuit Function ON / OFF logic Discharge shunt function Constant current source pull-down Status Active "H" Unavailable Unavailable Thermal shutdown circuit Reference voltage circuit ON / OFF + − + − ON / OFF circuit VSS *1. Parasitic diode Figure 4 3 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00  Product Name Structure Users can select the product type, output voltage, and package type for the S-1324 Series. Refer to "1. Product name" regarding the contents of product name, "2. Function list of product type" regarding the product type, "3. Packages" regarding the package drawings, "4. Product name list" regarding details of the product name. 1. Product name S-1324 x xx - xxxx U Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications M5T1: SOT-23-5, Tape N4T1: SC-82AB, Tape A4T2: HSNT-4(1010), Tape *1 Output voltage*2 10 to 35 (e.g., when the output voltage is 1.0 V, it is expressed as 10.) Product type*3 A to D *1. Refer to the tape drawing. *2. If you request the product which has 0.05 V step, contact our sales office. *3. Refer to "2. Function list of product type" and "3. ON / OFF pin" in " Operation". 2. Function list of product type Product Type A ON / OFF Logic Active "H" Table 1 Discharge Shunt Function Constant Current Source Pull-down Available Available B Active "H" Available Unavailable C D Active "H" Active "H" Unavailable Unavailable Available Unavailable 3. Packages Table 2 Package Drawing Codes Package Name 4 Dimension Tape Reel Land SOT-23-5 MP005-A-P-SD MP005-A-R-SD − SC-82AB NP004-A-P-SD NP004-A-R-SD − HSNT-4(1010) PL004-A-P-SD MP005-A-C-SD NP004-A-C-SD NP004-A-C-S1 PL004-A-C-SD PL004-A-R-SD PL004-A-L-SD 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00 4. Product name list 4. 1 S-1324 Series A type ON / OFF logic: Discharge shunt function: Active "H" Available Constant current source pull-down: Available Table 3 Output Voltage 1.2 V ± 15 mV 1.8 V ± 1.0% 2.5 V ± 1.0% 3.3 V ± 1.0% SOT-23-5 S-1324A12-M5T1U S-1324A18-M5T1U S-1324A25-M5T1U S-1324A33-M5T1U SC-82AB S-1324A12-N4T1U S-1324A18-N4T1U S-1324A25-N4T1U S-1324A33-N4T1U HSNT-4(1010) S-1324A12-A4T2U S-1324A18-A4T2U S-1324A25-A4T2U S-1324A33-A4T2U Remark Please contact our sales representatives for products other than the above. 4. 2 S-1324 Series B type ON / OFF logic: Discharge shunt function: Active "H" Available Constant current source pull-down: Unavailable Table 4 Output Voltage 1.2 V ± 15 mV 1.8 V ± 1.0% 2.5 V ± 1.0% 3.3 V ± 1.0% SOT-23-5 S-1324B12-M5T1U S-1324B18-M5T1U S-1324B25-M5T1U S-1324B33-M5T1U SC-82AB S-1324B12-N4T1U S-1324B18-N4T1U S-1324B25-N4T1U S-1324B33-N4T1U HSNT-4(1010) S-1324B12-A4T2U S-1324B18-A4T2U S-1324B25-A4T2U S-1324B33-A4T2U Remark Please contact our sales representatives for products other than the above. 4. 3 S-1324 Series C type ON / OFF logic: Discharge shunt function: Active "H" Unavailable Constant current source pull-down: Available Table 5 Output Voltage 1.2 V ± 15 mV 1.8 V ± 1.0% 2.5 V ± 1.0% 3.3 V ± 1.0% SOT-23-5 S-1324C12-M5T1U S-1324C18-M5T1U S-1324C25-M5T1U S-1324C33-M5T1U SC-82AB S-1324C12-N4T1U S-1324C18-N4T1U S-1324C25-N4T1U S-1324C33-N4T1U HSNT-4(1010) S-1324C12-A4T2U S-1324C18-A4T2U S-1324C25-A4T2U S-1324C33-A4T2U Remark Please contact our sales representatives for products other than the above. 4. 4 S-1324 Series D type ON / OFF logic: Discharge shunt function: Active "H" Unavailable Constant current source pull-down: Unavailable Table 6 Output Voltage 1.2 V ± 15 mV 1.8 V ± 1.0% 2.5 V ± 1.0% 3.3 V ± 1.0% SOT-23-5 S-1324D12-M5T1U S-1324D18-M5T1U S-1324D25-M5T1U S-1324D33-M5T1U SC-82AB S-1324D12-N4T1U S-1324D18-N4T1U S-1324D25-N4T1U S-1324D33-N4T1U HSNT-4(1010) S-1324D12-A4T2U S-1324D18-A4T2U S-1324D25-A4T2U S-1324D33-A4T2U Remark Please contact our sales representatives for products other than the above. 5 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00  Pin Configurations 1. SOT-23-5 Top view 5 4 1 2 3 Pin No. 1 2 3 4 5 Table 7 Symbol VIN VSS ON / OFF NC*1 VOUT Description Input voltage pin GND pin ON / OFF pin No connection Output voltage pin Figure 5 *1. The NC pin is electrically open. The NC pin can be connected to the VIN pin or the VSS pin. 2. SC-82AB Top view 4 1 Pin No. 3 1 2 3 4 2 Table 8 Symbol ON / OFF VSS VOUT VIN Description ON / OFF pin GND pin Output voltage pin Input voltage pin Figure 6 3. HSNT-4(1010) Table 9 Top view 1 2 4 3 Bottom view 4 3 Pin No. 1 2 3 4 Symbol VOUT VSS ON / OFF VIN Description Output voltage pin GND pin ON / OFF pin Input voltage pin 1 2 *1 Figure 7 *1. Connect the heatsink of backside at shadowed area to the board, and set electric potential GND. However, do not use it as the function of electrode. 6 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00  Absolute Maximum Ratings Table 10 (Ta = +25°C unless otherwise specified) Item Symbol Absolute Maximum Rating Unit VSS − 0.3 to VSS + 6.0 VIN V Input voltage VSS − 0.3 to VSS + 6.0 VON / OFF V VSS − 0.3 to VIN + 0.3 Output voltage VOUT V Output current IOUT 240 mA −40 to +85 °C Operation ambient temperature Topr −40 to +125 °C Storage temperature Tstg Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions.  Thermal Resistance Value Item Symbol Table 11 Condition Board A Board B Board C SOT-23-5 Board D Board E Board A Board B Junction-to-ambient thermal resistance*1 θJA SC-82AB Board C Board D Board E Board A Board B HSNT-4(1010) Board C Board D Board E *1. Test environment: compliance with JEDEC STANDARD JESD51-2A Min. − − − − − − − − − − − − − − − Typ. 192 160 − − − 236 204 − − − 378 317 − − − Max. − − − − − − − − − − − − − − − Unit °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W Remark Refer to " Power Dissipation" and "Test Board" for details. 7 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00  Electrical Characteristics Table 12 Item Symbol Condition Output voltage*1 VOUT(E) VIN = VOUT(S) + 1.0 V, IOUT = 30 mA Output current*2 IOUT VIN ≥ VOUT(S) + 1.0 V Dropout voltage*3 Vdrop IOUT = 100 mA Line regulation Load regulation Output voltage temperature coefficient*4 ΔVOUT1 ΔVIN • VOUT ΔVOUT2 ΔVOUT VOUT(S) + 0.5 V ≤ VIN ≤ 5.5 V, IOUT = 1 μA VOUT(S) + 0.5 V ≤ VIN ≤ 5.5 V, IOUT = 30 mA VIN = VOUT(S) + 1.0 V, 1 μA ≤ IOUT ≤ 100 mA VIN = VOUT(S) + 1.0 V, 100 μA ≤ IOUT ≤ 200 mA 1.0 V ≤ VOUT(S) < 1.5 V 1.5 V ≤ VOUT(S) ≤ 3.5 V 1.0 V ≤ VOUT(S) < 1.2 V 1.2 V ≤ VOUT(S) ≤ 3.5 V 1.0 V ≤ VOUT(S) < 1.1 V 1.1 V ≤ VOUT(S) < 1.2 V 1.2 V ≤ VOUT(S) < 1.3 V 1.3 V ≤ VOUT(S) < 1.4 V 1.4 V ≤ VOUT(S) < 1.5 V 1.5 V ≤ VOUT(S) < 1.7 V 1.7 V ≤ VOUT(S) < 1.8 V 1.8 V ≤ VOUT(S) < 2.0 V 2.0 V ≤ VOUT(S) < 2.5 V 2.5 V ≤ VOUT(S) < 2.8 V 2.8 V ≤ VOUT(S) < 3.0 V 3.0 V ≤ VOUT(S) ≤ 3.5 V (Ta = +25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit VOUT(S) VOUT(S) VOUT(S) V 1 − 0.015 + 0.015 VOUT(S) VOUT(S) V V 1 × 0.99 OUT(S) × 1.01 *5 100 − − mA 3 200*5 − − mA 3 1.00 − − V 1 0.90 − − V 1 0.80 − − V 1 0.70 − − V 1 0.60 − − V 1 0.50 − − V 1 0.30 0.31 0.68 V 1 0.20 0.27 0.58 V 1 − 0.23 0.49 V 1 − 0.18 0.38 V 1 − 0.17 0.33 V 1 − 0.16 0.32 V 1 1.0 V ≤ VOUT(S) ≤ 3.5 V − 0.05 0.2 %/V 1 1.0 V ≤ VOUT(S) ≤ 3.5 V − 0.05 0.2 %/V 1 1.0 V ≤ VOUT(S) ≤ 3.5 V − 20 40 mV 1 1.0 V ≤ VOUT(S) ≤ 3.5 V − 40 80 mV 1 ΔTa • VOUT VIN = VOUT(S) + 1.0 V, IOUT = 30 mA, −40°C ≤ Ta ≤ +85°C − ±130 − ppm/°C 1 ISS1 VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, no load − 7 12 μA 2 − 0.01 0.1 μA 2 1.5 − 5.5 V − 1.0 − − V 4 − − 0.25 V 4 −0.1 − 0.1 μA 4 0.05 0.1 0.2 μA 4 −0.1 − 0.1 μA 4 − 65 − dB 5 − 65 − dB 5 − 17 − μVrms 6 − − 19 50 − − μVrms mA 6 3 Current consumption during operation Current consumption during poweroff Input voltage ISS2 VIN = VOUT(S) + 1.0 V, ON / OFF pin = OFF, no load VIN ON / OFF pin input voltage "H" VSH ON / OFF pin input voltage "L" VSL ON / OFF pin input current "H" ISH Output noise eN Short-circuit current Thermal shutdown detection temperature Thermal shutdown release temperature Ishort − VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ, determined by VOUT output level VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ, determined by VOUT output level B / D type (without constant current source pull-down) VIN = 5.5 V, VON / OFF = 5.5 V A / C type (with constant current source pull-down) VIN = 5.5 V, VON / OFF = 0 V VIN = VOUT(S) + 1.0 V, IOUT = 1 mA f = 1.0 kHz, IOUT = 30 mA ΔVrip = 0.5 Vrms VIN = VOUT(S) + 1.0 V, IOUT = 1 mA CL = 1 μF, IOUT = 30 mA BW = 10 Hz to 100 kHz VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, VOUT = 0 V TSD Junction temperature − 150 − °C − TSR Junction temperature − 120 − °C − RLOW VOUT = 0.1 V, VIN = 5.5 V − 35 − Ω 3 ON / OFF pin input current "L" ISL Ripple rejection RR Discharge shunt resistance during power-off 8 A / B type (with discharge shunt function) Rev.1.1_00 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series *1. VOUT(S): Set output voltage VOUT(E): Actual output voltage The output voltage when VIN = VOUT(S) + 1.0 V, IOUT = 30 mA *2. The output current at which the output voltage becomes 95% of VOUT(E) after gradually increasing the output current. *3. Vdrop = VIN1 − (VOUT3 × 0.98) VIN1 is the input voltage at which the output voltage becomes 98% of VOUT3 after gradually decreasing the input voltage. VOUT3 is the output voltage when VIN = VOUT(S) + 1.0 V, and IOUT = 100 mA. *4. A change in the temperature of the output voltage [mV/°C] is calculated using the following equation. ΔVOUT ΔVOUT [mV/°C]*1 = VOUT(S) [V]*2 × ΔTa•VOUT [ppm/°C]*3 ÷ 1000 ΔTa *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient *5. Due to limitation of the power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation when the output current is large. This specification is guaranteed by design. 9 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00  Test Circuits VIN + VOUT ON / OFF VSS V A + Set to ON Figure 8 Test Circuit 1 + A VIN VOUT ON / OFF VSS Set to VIN or GND Figure 9 Test Circuit 2 VIN VOUT ON / OFF A V + VSS Set to VIN or GND Figure 10 Test Circuit 3 VIN + A VOUT ON / OFF V + VSS RL Figure 11 Test Circuit 4 VIN VOUT ON / OFF V VSS Set to ON Figure 12 Test Circuit 5 10 + RL 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00 VOUT VIN ON / OFF V + VSS RL Set to ON Figure 13 Test Circuit 6  Standard Circuit Input Output VOUT VIN CIN *1 ON / OFF VSS Single GND *1. *2. CL *2 GND CIN is a capacitor for stabilizing the input. CL is a capacitor for stabilizing the output. Figure 14 Caution The above connection diagram and constant will not guarantee successful operation. Perform thorough evaluation including the temperature characteristics with an actual application to set the constant.  Condition of Application Input capacitor (CIN): Output capacitor (CL): A ceramic capacitor with capacitance of 1.0 μF or more is recommended. A ceramic capacitor with capacitance of 1.0 μF or more is recommended. Caution Generally, in a voltage regulator, an oscillation may occur depending on the selection of the external parts. Perform thorough evaluation including the temperature characteristics with an actual application using the above capacitors to confirm no oscillation occurs.  Selection of Input Capacitor (CIN) and Output Capacitor (CL) The S-1324 Series requires CL between the VOUT pin and the VSS pin for phase compensation. The operation is stabilized by a ceramic capacitor with capacitance of 1.0 μF or more. When using an OS capacitor, a tantalum capacitor or an aluminum electrolytic capacitor, the capacitance also must be 1.0 μF or more. However, an oscillation may occur depending on the equivalent series resistance (ESR). Moreover, the S-1324 Series requires CIN between the VIN pin and the VSS pin for a stable operation. Generally, an oscillation may occur when a voltage regulator is used under the conditon that the impedance of the power supply is high. Note that the output voltage transient characteristics vary depending on the capacitance of CIN and CL and the value of ESR. Caution Perform thorough evaluation including the temperature characteristics with an actual application to select CIN and CL. 11 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00  Explanation of Terms 1. Low dropout voltage regulator This is a voltage regulator which made dropout voltage small by its built-in low on-resistance output transistor. 2. Output voltage (VOUT) This voltage is output at an accuracy of ±1.0% or ±15 mV*2 when the input voltage, the output current and the temperature are in a certain condition*1. *1. *2. Differs depending on the product. When VOUT < 1.5 V: ±15 mV, when VOUT ≥1.5 V: ±1.0% Caution If the certain condition is not satisfied, the output voltage may exceed the accuracy range of ±1.0% or ±15 mV. Refer to Table 12 in " Electrical Characteristics" for details. ΔVOUT1  ΔVIN • VOUT  3. Line regulation  Indicates the dependency of the output voltage on the input voltage. That is, the values show how much the output voltage changes due to a change after fixing output current constant. 4. Load regulation (ΔVOUT2) Indicates the dependency of the output voltage against the output current. That is, the value shows how much the output voltage changes due to a change in the output current after fixing input voltage constant. 5. Dropout voltage (Vdrop) Indicates the difference between input voltage (VIN1) and the output voltage when the output voltage becomes 98% of the output voltage value (VOUT3) at VIN = VOUT(S) + 1.0 V after the input voltage (VIN) is decreased gradually. Vdrop = VIN1 − (VOUT3 × 0.98) 12 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00 ΔVOUT  ΔTa • VOUT  6. Output voltage temperature coefficient  The shaded area in Figure 15 is the range where VOUT varies in the operation temperature range when the output voltage temperature coefficient is ±130 ppm/°C. Example of VOUT = 3.0 V typ. product VOUT [V] +0.39 mV/°C VOUT(E)*1 −0.39 mV/°C −40 *1. +25 +85 Ta [°C] VOUT(E) is the value of the output voltage measured at Ta = +25°C. Figure 15 A change in the temperature of the output voltage [mV/°C] is calculated using the following equation. ΔVOUT ΔVOUT [mV/°C]*1 = VOUT(S) [V]*2 × ΔTa • VOUT [ppm/°C]*3 ÷ 1000 ΔTa *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient 13 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00  Operation 1. Basic operation Figure 16 shows the block diagram of the S-1324 Series to describe the basic operation. The error amplifier output voltage (Verror) is divided by the feedback resistors (Rs and Rf). In order to keep the feedback voltage (Vfb) equal to the reference voltage (Vref), the error amplifier outputs Verror. The preamplifier controls the output transistor to keep Verror equal to the output voltage (VOUT), and consequently, the regulator starts the operation that holds VOUT constant without the influence of the input voltage (VIN). VIN *1 Current supply Error amplifier Vref Verror + Preamplifier − − VOUT + Rf Vfb Reference voltage circuit Rs VSS *1. Parasitic diode Figure 16 2. Output transistor In the S-1324 Series, a low on-resistance P-channel MOS FET is used between the VIN pin and the VOUT pin as the output transistor. In order to hold VOUT constant, the on-resistance of the output transistor varies appropriately according to the output current (IOUT). Caution Since a parasitic diode exists between the VIN pin and the VOUT pin due to the structure of the transistor, the IC may be damaged by a reverse current if VOUT becomes higher than VIN. Therefore, be sure that VOUT does not exceed VIN + 0.3 V. 14 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00 3. ON / OFF pin The ON / OFF pin controls the internal circuit and the output transistor in order to start and stop the regulator. When the ON / OFF pin is set to OFF, the internal circuit stops operating and the output transistor between the VIN pin and the VOUT pin is turned off, reducing current consumption significantly. The internal equivalent circuit related to the ON / OFF pin is configured as shown in Figure 17 and Figure 18. Note that the current consumption increases when a voltage of VSL max.*1 to VIN − 0.3 V is applied to the ON / OFF pin. 3. 1 S-1324 Series A / C type The ON / OFF pin is internally pulled down to the VSS pin in the floating status, so the VOUT pin is pulled down to VSS. 3. 2 S-1324 Series B / D type The ON / OFF pin is not internally pulled down to the VSS pin, so do not use it in the floating status. When not using the ON / OFF pin, connect it to the VIN pin. Product Type ON / OFF Pin Table 13 Internal Circuit VOUT Pin Voltage Current Consumption A/B/C/D "H": ON Operate Constant value*2 ISS1*3 *4 A/B/C/D "L": OFF Stop Pulled down to VSS ISS2 *1. Refer to Table 12 in " Electrical Characteristics". *2. The constant value is output due to the regulating based on the set output voltage value. *3. Note that the IC's current consumption increases as much as current flows into the constant current of 0.1 μA typ. when the ON / OFF pin is connected to the VIN pin and the S-1324 Series A / C type is operating (refer to Figure 17). *4. The VOUT pin voltage of S-1324 Series A / B type is pulled down to VSS due to the discharge shunt circuit (RLOW = 35 Ω typ.) and a load. VIN VIN ON / OFF ON / OFF VSS Figure 17 S-1324 Series A / C type VSS Figure 18 S-1324 Series B / D type 15 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00 4. Discharge shunt function (S-1324 Series A / B type) The S-1324 Series A / B type has a built-in discharge shunt circuit to discharge the output capacitance. The output capacitance is discharged as follows so that the VOUT pin reaches the VSS level. (1) The ON / OFF pin is set to OFF level. (2) The output transistor is turned off. (3) The discharge shunt circuit is turned on. (4) The output capacitor discharges. Since the S-1324 Series C / D type does not have a discharge shunt circuit, the VOUT pin is set to VSS level through constant current load between the VOUT pin and the VSS pin. The S-1324 Series A / B type allows the VOUT pin to reach the VSS level rapidly due to the discharge shunt circuit. Output transistor: OFF S-1324 Series *1 VOUT VIN Discharge shunt circuit : ON *1 ON / OFF ON / OFF circuit Output capacitor (CL) ON / OFF Pin: OFF Current flow GND VSS *1. Parasitic diode Figure 19 5. Constant current source pull-down (S-1324 Series A / C type) The ON / OFF pin is internally pulled down to the VSS pin in the floating status, so the VOUT pin is set to the VSS level. Note that the IC's current consumption increases as much as current flows into the constant current of 0.1 μA typ. when the ON / OFF pin is connected to the VIN pin and the S-1324 Series A / C type is operating. 16 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00 6. Overcurrent protection circuit The S-1324 Series has a built-in overcurrent protection circuit to limit the overcurrent of the output transistor. When the VOUT pin is shorted with the VSS pin, that is, at the time of the output short-circuit, the output current is limited to 50 mA typ. due to the overcurrent protection circuit operation. The S-1324 Series restarts regulating when the output transistor is released from the overcurrent status. Caution This overcurrent protection circuit does not work as for thermal protection. For example, when the output transistor keeps the overcurrent status long at the time of output short-circuit or due to other reasons, pay attention to the conditions of the input voltage and the load current so as not to exceed the power dissipation. 7. Thermal shutdown circuit The S-1324 Series has a built-in thermal shutdown circuit to limit overheating. When the junction temperature increases to 150°C typ., the thermal shutdown circuit becomes the detection status, and the regulating is stopped. When the junction temperature decreases to 120°C typ., the thermal shutdown circuit becomes the release status, and the regulator is restarted. If the thermal shutdown circuit becomes the detection status due to self-heating, the regulating is stopped and VOUT decreases. For this reason, the self-heating is limited and the temperature of the IC decreases. The thermal shutdown circuit becomes release status when the temperature of the IC decreases, and the regulating is restarted, thus the self-heating is generated again. Repeating this procedure makes the waveform of VOUT into a pulse-like form. This phenomenon continues unless decreasing either or both of the input voltage and the output current in order to reduce the internal power consumption, or decreasing the ambient temperature. Note that the product may suffer physical damage such as deterioration if the above phenomenon occurs continuously. Caution 1. When the heat radiation of the application is not in a good condition, the self-heating cannot be limited immediately, and the IC may suffer physical damage. Perform thorough evaluation including the temperature characteristics with an actual application to confirm no problems happen. 2. If a large load current flows during the restart process of regulating after the thermal shutdown circuit changes to the release status from the detection status, the thermal shutdown circuit becomes the detection status again due to self-heating, and a problem may happen in the restart of regulating. A large load current, for example, occurs when charging to the CL whose capacitance is large. Perform thorough evaluation including the temperature characteristics with an actual application to select CL. Table 14 Thermal Shutdown Circuit Release: 120°C typ.*1 Detection: 150°C typ.*1 VOUT Pin Voltage Constant value*2 Pulled down to VSS*3 *1. Junction temperature *2. The constant value is output due to the regulating based on the set output voltage value. *3. The VOUT pin voltage is pulled down to VSS due to the feedback resistors (Rs and Rf) and a load. 17 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00  Precautions • Generally, when a voltage regulator is used under the condition that the load current value is small (10 μA or less), the output voltage may increase due to the leakage current of an output transistor. • Generally, when a voltage regulator is used under the condition that the temperature is high, the output voltage may increase due to the leakage current of an output transistor. • Generally, when the ON / OFF pin is used under the condition of OFF, the output voltage may increase due to the leakage current of an output transistor. • Generally, when a voltage regulator is used under the condition that the impedance of the power supply is high, an oscillation may occur. Perform thorough evaluation including the temperature characteristics with an actual application to select CIN. • Generally, in a voltage regulator, an oscillation may occur depending on the selection of the external parts. The following use conditions are recommended in the S-1324 Series, however, perform thorough evaluation including the temperature characteristics with an actual application to select CIN and CL. Input capacitor (CIN): Output capacitor (CL): A ceramic capacitor with capacitance of 1.0 μF or more is recommended. A ceramic capacitor with capacitance of 1.0 μF or more is recommended. • Generally, in a voltage regulator, the values of an overshoot and an undershoot in the output voltage vary depending on the variation factors of input voltage start-up, input voltage fluctuation and load fluctuation etc., or the capacitance of CIN or CL and the value of the equivalent series resistance (ESR), which may cause a problem to the stable operation. Perform thorough evaluation including the temperature characteristics with an actual application to select CIN and CL. • Generally, in a voltage regulator, an overshoot may occur in the output voltage momentarily if the input voltage steeply changes when the input voltage is started up, the soft-start operation is performed, the input voltage fluctuates etc. Perform thorough evaluation including the temperature characteristics with an actual application to confirm no problems happen. • Generally, in a voltage regulator, if the VOUT pin is steeply shorted with GND, a negative voltage exceeding the absolute maximum ratings may occur in the VOUT pin due to resonance phenomenon of the inductance and the capacitance including CL on the application. The resonance phenomenon is expected to be weakened by inserting a series resistor into the resonance path, and the negative voltage is expected to be limited by inserting a protection diode between the VOUT pin and the VSS pin. • If the input voltage is started up steeply under the condition that the capacitance of CL is large, the thermal shutdown circuit may be in the detection status by self-heating due to the charge current to CL. • Make sure of the conditions for the input voltage, output voltage and the load current so that the internal loss does not exceed the power dissipation. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • When considering the output current value that the IC is able to output, make sure of the output current value specified in Table 12 in " Electrical Characteristics" and footnote *5 of the table. • Wiring patterns on the application related to the VIN pin, the VOUT pin and the VSS pin should be designed so that the impedance is low. When mounting CIN between the VIN pin and the VSS pin and CL between the VOUT pin and the VSS pin, connect the capacitors as close as possible to the respective destination pins of the IC. • In the package equipped with heat sink of backside, mount the heat sink firmly. Since the heat radiation differs according to the condition of the application, perform thorough evaluation with an actual application to confirm no problems happen. • ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 18 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00  Characteristics (Typical Data) 1. Output voltage vs. Output current (When load current increases) (Ta = +25°C) 1. 2 VOUT = 2.5 V 1.2 3.0 1.0 2.5 0.8 2.0 0.6 VOUT [V] VOUT [V] 1. 1 VOUT = 1.0 V VIN = 3.0 V VIN = 2.0 V VIN = 1.8 V VIN = 1.5 V 0.4 0.2 0.0 0 100 200 300 IOUT [mA] 400 VIN = 3.0 V VIN = 3.3 V VIN = 3.5 V VIN = 4.5 V 1.5 1.0 0.5 0.0 500 0 100 200 300 IOUT [mA] 400 500 1. 3 VOUT = 3.5 V VOUT [V] 4.0 3.0 Remark VIN = 4.0 V VIN = 4.3 V VIN = 4.5 V VIN = 5.5 V 2.0 1.0 In determining the output current, attention should be paid to the following. 1. The minimum output current value and footnote *5 in Table 12 in " Electrical Characteristics" 2. The power dissipation 0.0 0 100 200 300 IOUT [mA] 400 500 2. Output voltage vs. Input voltage (Ta = +25°C) 2. 2 VOUT = 2.5 V 1.2 3.0 1.0 2.5 0.8 VOUT [V] VOUT [V] 2. 1 VOUT = 1.0 V IOUT = 1 mA IOUT = 30 mA IOUT = 50 mA IOUT = 100 mA 0.6 0.4 0.2 2.0 1.5 IOUT = 1 mA IOUT = 30 mA IOUT = 50 mA IOUT = 100 mA 1.0 0.5 0.0 0.0 0.5 1.0 1.5 2.0 VIN [V] 2.5 3.0 0.5 1.5 2.5 VIN [V] 3.5 4.5 2. 3 VOUT = 3.5 V VOUT [V] 4.0 3.0 2.0 IOUT = 1 mA IOUT = 30 mA IOUT = 50 mA IOUT = 100 mA 1.0 0.0 0.5 1.5 2.5 3.5 VIN [V] 4.5 5.5 19 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00 3. Dropout voltage vs. Output current 3. 1 VOUT = 1.0 V 0.6 0.6 Ta = +85°C Ta = +25°C Ta = −40°C 0.4 0.5 Vdrop [V] 0.5 Vdrop [V] 3. 2 VOUT = 2.5 V 0.3 0.2 0 20 40 60 IOUT [mA] 80 100 3. 3 VOUT = 3.5 V 0.6 0.5 Vdrop [V] 0.2 0.0 0.0 0.4 Ta = +85°C Ta = +25°C Ta = −40°C 0.3 0.2 0.1 0.0 0 50 100 IOUT [mA] 150 200 4. Dropout voltage vs. Set output voltage 1.0 IOUT = 200 mA IOUT = 100 mA IOUT = 30 mA IOUT = 1 mA 0.8 Vdrop [V] 0.3 0.1 0.1 0.6 0.4 0.2 0.0 1.0 20 Ta = +85°C Ta = +25°C Ta = −40°C 0.4 1.5 2.0 2.5 VOUT(S) [V] 3.0 3.5 0 50 100 IOUT [mA] 150 200 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00 5. Output voltage vs. Ambient temperature 5. 2 VOUT = 2.5 V 1.10 2.70 1.05 2.60 VOUT [V] VOUT [V] 5. 1 VOUT = 1.0 V 1.00 0.95 0.90 2.50 2.40 −40 −25 2.30 0 25 Ta [°C] 50 75 85 0 25 Ta [°C] 50 75 85 −40 −25 0 25 Ta [°C] 50 75 85 5. 3 VOUT = 3.5 V 3.80 VOUT [V] 3.70 3.60 3.50 3.40 3.30 3.20 −40 −25 6. Current consumption vs. Input voltage 6. 1 VOUT = 1.0 V 6. 2 VOUT = 2.5 V 10 10 8 Ta = +85°C 6 4 Ta = +25°C 2 Ta = −40°C ISS1 [μA] ISS1 [μA] 8 0 Ta = +85°C 6 4 Ta = +25°C 2 Ta = −40°C 0 0.0 1.0 2.0 3.0 4.0 VIN [V] 5.0 6.0 5.0 6.0 0.0 1.0 2.0 3.0 4.0 VIN [V] 5.0 6.0 6. 3 VOUT = 3.5 V 10 ISS1 [μA] 8 Ta = +85°C 6 4 Ta = +25°C 2 Ta = −40°C 0 0.0 1.0 2.0 3.0 4.0 VIN [V] 21 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00 7. Current consumption vs. Ambient temperature 7. 1 VOUT = 1.0 V 7. 2 VOUT = 2.5 V 10 6 4 VIN = 2.0 V 2 0 VIN = 5.5 V 8 ISS1 [μA] 8 ISS1 [μA] 10 VIN = 5.5 V 6 4 VIN = 3.5 V 2 0 −40 −25 0 25 Ta [°C] 50 75 85 −40 −25 0 25 Ta [°C] 50 75 85 7. 3 VOUT = 3.5 V 10 VIN = 5.5 V ISS1 [μA] 8 6 4 VIN = 4.5 V 2 0 −40 −25 0 25 Ta [°C] 50 75 85 8. Current consumption vs. Output current 8. 1 VOUT = 1.0 V 8. 2 VOUT = 2.5 V 50 50 40 VIN = 2.0 V ISS1 [μA] ISS1 [μA] 40 30 20 10 VIN = 5.5 V 0 0 50 100 IOUT [mA] 150 200 8. 3 VOUT = 3.5 V 50 40 ISS1 [μA] 20 10 VIN = 5.5 V 0 VIN = 4.5 V 30 20 10 VIN = 5.5 V 0 0 22 VIN = 3.5 V 30 50 100 IOUT [mA] 150 200 0 50 100 IOUT [mA] 150 200 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00 9. Ripple rejection (Ta = +25°C) 9. 1 VOUT = 1.0 V 9. 2 VOUT = 2.5 V Ripple Rejection [dB] 100 Ripple Rejection [dB] VIN = 2.0 V, CL = 1.0 μF IOUT = 1 mA IOUT = 30 mA 80 60 40 IOUT = 100 mA 20 0 10 100 1k 10k 100k Frequency [Hz] VIN = 3.5 V, CL = 1.0 μF 100 IOUT = 1 mA IOUT = 30 mA 80 60 40 IOUT = 100 mA IOUT = 200 mA 20 0 10 1M 100 1k 10k 100k Frequency [Hz] 1M 9. 3 VOUT = 3.5 V VIN = 4.5 V, CL = 1.0 μF Ripple Rejection [dB] 100 IOUT = 1 mA IOUT = 30 mA 80 60 40 IOUT = 100 mA IOUT = 200 mA 20 0 10 100 1k 10k 100k Frequency [Hz] 1M 10. Output noise (Ta = +25°C) 10. 2 VOUT = 2.5 V VIN = 2.0 V, CL = 1.0 μF 10 Noise Density [μV/√Hz] Noise Density [μV/√Hz] 10. 1 VOUT = 1.0 V IOUT = 100 mA IOUT = 30 mA 1 0.1 0.01 IOUT = 1 mA 0.001 10 100 1k 10k 100k Frequency [Hz] 1M VIN = 3.5 V, CL = 1.0 μF 10 IOUT = 200 mA IOUT = 100 mA 1 0.1 IOUT = 30 mA IOUT = 1 mA 0.01 0.001 10 100 1k 10k 100k Frequency [Hz] 1M Noise Density [μV/√Hz] 10. 3 VOUT = 3.5 V VIN = 4.5 V, CL = 1.0 μF 10 IOUT = 200 mA IOUT = 100 mA 1 0.1 IOUT = 30 mA IOUT = 1 mA 0.01 0.001 10 100 1k 10k 100k Frequency [Hz] 1M 23 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00  Reference Data 1. Transient response characteristics when input (Ta = +25°C) 1. 1 VOUT = 1.0 V 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.0 VIN VOUT −50 0 50 100 150 200 250 300 t [μs] 1.5 1.4 1.3 1.2 1.1 1.0 0.9 0.8 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.0 VIN VOUT −50 0 50 VIN [V] VOUT [V] 1.5 1.4 1.3 1.2 1.1 1.0 0.9 0.8 IOUT = 100 mA, CL = 1.0 μF, VIN = 2.0 V ↔ 3.0 V, tr = tf = 5.0 μs VIN [V] VOUT [V] IOUT = 1 mA, CL = 1.0 μF, VIN = 2.0 V ↔ 3.0 V, tr = tf = 5.0 μs 100 150 200 250 300 t [μs] 1. 2 VOUT = 2.5 V 5.0 4.5 4.0 3.5 3.0 2.5 2.0 1.5 VIN VOUT −50 0 50 100 150 200 250 300 t [μs] 3.0 2.9 2.8 2.7 2.6 2.5 2.4 2.3 5.0 4.5 4.0 3.5 3.0 2.5 2.0 1.5 VIN VOUT −50 0 50 VIN [V] VOUT [V] 3.0 2.9 2.8 2.7 2.6 2.5 2.4 2.3 IOUT = 100 mA, CL = 1.0 μF, VIN = 3.5 V ↔ 4.5 V, tr = tf = 5.0 μs VIN [V] VOUT [V] IOUT = 1 mA, CL = 1.0 μF, VIN = 3.5 V ↔ 4.5 V, tr = tf = 5.0 μs 100 150 200 250 300 t [μs] 1. 3 VOUT = 3.5 V 24 6.0 5.5 5.0 4.5 4.0 3.5 3.0 2.5 VIN VOUT −50 0 50 100 150 200 250 300 t [μs] IOUT = 100 mA, CL = 1.0 μF, VIN = 4.5 V ↔ 5.5 V, tr = tf = 5.0 μs 4.0 6.0 3.9 5.5 3.8 5.0 VIN 3.7 4.5 3.6 4.0 VOUT 3.5 3.5 3.4 3.0 2.5 3.3 −50 0 50 100 150 200 250 300 t [μs] VIN [V] 4.0 3.9 3.8 3.7 3.6 3.5 3.4 3.3 VIN [V] VOUT [V] VOUT [V] IOUT = 1 mA, CL =1.0 μF, VIN = 4.5 V ↔ 5.5 V, tr = tf = 5.0 μs 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00 2. Transient response characteristics of load (Ta = +25°C) 2. 1 VOUT = 1.0 V 200 400 t [μs] 600 800 150 100 50 0 −50 −100 −150 −200 VIN = 2.0 V, CIN = CL = 1.0 μF, IOUT = 50 mA ↔ 100 mA, tr = tf = 1.0 μs 1.5 1.4 IOUT 1.3 1.2 1.1 1.0 VOUT 0.9 0.8 −200 0 200 400 t [μs] 600 800 150 100 50 0 −50 −100 −150 −200 IOUT [mA] 1.5 1.4 1.3 IOUT 1.2 1.1 VOUT 1.0 0.9 0.8 −200 0 IOUT [mA] VOUT [V] VOUT [V] VIN = 2.0 V, CIN = CL = 1.0 μF, IOUT = 1 mA ↔ 100 mA, tr = tf = 1.0 μs 2. 2 VOUT = 2.5 V 200 400 t [μs] 600 800 150 100 50 0 −50 −100 −150 −200 VIN = 3.5 V, CIN = CL = 1.0 μF, IOUT = 50 mA ↔ 100 mA, tr = tf = 1.0 μs 3.0 2.9 IOUT 2.8 2.7 2.6 2.5 VOUT 2.4 2.3 −200 0 200 400 t [μs] 600 800 150 100 50 0 −50 −100 −150 −200 IOUT [mA] 3.0 2.9 2.8 IOUT 2.7 2.6 VOUT 2.5 2.4 2.3 −200 0 IOUT [mA] VOUT [V] VOUT [V] VIN = 3.5 V, CIN = CL = 1.0 μF, IOUT = 1 mA ↔ 100 mA, tr = tf = 1.0 μs 2. 3 VOUT = 3.5 V 200 400 t [μs] 600 800 150 100 50 0 −50 −100 −150 −200 VIN = 4.5 V, CIN = CL = 1.0 μF, IOUT = 50 mA ↔ 100 mA, tr = tf = 1.0 μs 4.0 3.9 IOUT 3.8 3.7 3.6 3.5 VOUT 3.4 3.3 −200 0 200 400 t [μs] 600 800 150 100 50 0 −50 −100 −150 −200 IOUT [mA] 4.0 3.9 3.8 IOUT 3.7 3.6 3.5 VOUT 3.4 3.3 −200 0 IOUT [mA] VOUT [V] VOUT [V] VIN = 4.5 V, CIN = CL = 1.0 μF, IOUT = 1 mA ↔ 100 mA, tr = tf = 1.0 μs 25 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00 3. Transient response characteristics of ON / OFF pin (Ta = +25°C) 3. 1 VOUT = 1.0 V VOUT [V] 4.0 VON / OFF 3.0 2.0 5.0 4.0 4.0 2.0 0.0 VOUT 1.0 0.0 6.0 −50 0 50 100 t [μs] 150 200 −2.0 250 VON / OFF [V] VOUT [V] 5.0 VIN = 2.0 V, CIN = CL = 1.0 μF, IOUT = 100 mA, VON / OFF = 0 V → 2.0 V, tr = 1.0 μs −4.0 6.0 4.0 VON / OFF 3.0 2.0 0.0 VOUT 1.0 0.0 2.0 −50 0 50 100 t [μs] 150 200 −2.0 250 VON / OFF [V] VIN = 2.0 V, CIN = CL = 1.0 μF, IOUT = 1 mA, VON / OFF = 0 V → 2.0 V, tr = 1.0 μs −4.0 3. 2 VOUT = 2.5 V VOUT [V] 4.0 VON / OFF 3.0 VOUT 2.0 0.0 5.0 4.0 4.0 2.0 0.0 −2.0 1.0 −50 0 50 100 t [μs] 150 200 250 VIN = 3.5 V, CIN = CL = 1.0 μF, IOUT = 100 mA, VON / OFF = 0 V → 3.5 V, tr = 1.0 μs 6.0 VON / OFF [V] VOUT [V] 5.0 −4.0 6.0 4.0 VON / OFF 3.0 VOUT 2.0 0.0 −2.0 1.0 0.0 2.0 −50 0 50 100 t [μs] 150 200 250 VON / OFF [V] VIN = 3.5 V, CIN = CL = 1.0 μF, IOUT = 1 mA, VON / OFF = 0 V → 3.5 V, tr = 1.0 μs −4.0 3. 3 VOUT = 3.5 V VON / OFF VOUT [V] 4.0 5.0 4.0 4.0 2.0 2.0 0.0 1.0 −2.0 0.0 26 VOUT 3.0 −50 0 50 100 t [μs] 150 200 250 VIN = 4.5 V, CIN = CL = 1.0 μF, IOUT = 100 mA, VON / OFF = 0 V → 4.5 V, tr = 1.0 μs 6.0 −4.0 VON / OFF [V] VOUT [V] 5.0 VON / OFF 6.0 4.0 VOUT 3.0 2.0 2.0 0.0 1.0 −2.0 0.0 −50 0 50 100 t [μs] 150 200 250 −4.0 VON / OFF [V] VIN = 4.5 V, CIN = CL = 1.0 μF, IOUT = 1 mA, VON / OFF = 0 V → 4.5 V, tr = 1.0 μs 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00 4. Output capacitance vs. Characteristics of discharge time (Ta = +25°C) tDSC [ms] VIN = VOUT + 1.0 V, IOUT = no load, VON / OFF = VOUT + 1.0 V → VSS, tf = 1.0 μs 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0.0 1 μs VON / OFF VOUT(S) = 1.0 V VOUT(S) = 2.5 V VOUT(S) = 3.5 V VSS tDSC VOUT 0 2 4 6 CL [μF] 8 10 12 VOUT × 10% VIN = VOUT + 1.0 V VON / OFF = VOUT + 1.0 V → VSS Figure 20 S-1324 Series A / B type (with discharge shunt function) Figure 21 Measurement Condition of Discharge Time 5. Example of equivalent series resistance vs. Output current characteristics (Ta = +25°C) CIN = CL = 1.0 μF 100 RESR [Ω] VIN VOUT CIN Stable ON / OFF 0 0.01 S-1324 Series VSS 200 CL *1 RESR IOUT [mA] *1. CL: TDK Corporation Figure 22 C3216X8R1E105K (1.0 μF) Figure 23 27 5.5 V INPUT, 200 mA, LOW NOISE VOLTAGE REGULATOR S-1324 Series Rev.1.1_00  Power Dissipation SOT-23-5 SC-82AB Tj = +125°C max. 0.8 B 0.6 A 0.4 0.2 0.0 0 25 50 75 100 125 150 175 Tj = +125°C max. 1.0 Power dissipation (PD) [W] Power dissipation (PD) [W] 1.0 0.8 0.6 B 0.4 A 0.2 0.0 0 25 Ambient temperature (Ta) [°C] Board A B C D E Board A B C D E HSNT-4(1010) Tj = +125°C max. Power dissipation (PD) [W] 0.8 0.6 0.4 B 0.2 A 0.0 0 25 50 75 100 125 150 Ambient temperature (Ta) [°C] Board A B C D E 28 Power Dissipation (PD) 0.26 W 0.32 W − − − 75 100 125 150 Ambient temperature (Ta) [°C] Power Dissipation (PD) 0.52 W 0.63 W − − − 1.0 50 175 Power Dissipation (PD) 0.42 W 0.49 W − − − 175 SOT-23-3/3S/5/6 Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - No. SOT23x-A-Board-SD-2.0 ABLIC Inc. SC-82AB Test Board (1) Board A IC Mount Area Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - No. SC82AB-A-Board-SD-1.0 ABLIC Inc. HSNT-4(1010) Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - No. HSNT4-B-Board-SD-1.0 ABLIC Inc. 2.9±0.2 1.9±0.2 4 5 1 2 0.16 3 +0.1 -0.06 0.95±0.1 0.4±0.1 No. MP005-A-P-SD-1.3 TITLE SOT235-A-PKG Dimensions No. MP005-A-P-SD-1.3 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) ø1.5 ø1.0 +0.1 -0 +0.2 -0 2.0±0.05 0.25±0.1 4.0±0.1 1.4±0.2 3.2±0.2 3 2 1 4 5 Feed direction No. MP005-A-C-SD-2.1 TITLE SOT235-A-Carrier Tape No. MP005-A-C-SD-2.1 ANGLE UNIT mm ABLIC Inc. +1.0 - 0.0 9.0 11.4±1.0 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP005-A-R-SD-2.0 TITLE SOT235-A-Reel No. MP005-A-R-SD-2.0 ANGLE QTY. UNIT mm ABLIC Inc. 3,000 2.0±0.2 1.3±0.2 4 3 0.05 0.3 +0.1 -0.05 0.16 2 1 0.4 +0.1 -0.06 +0.1 -0.05 No. NP004-A-P-SD-2.0 TITLE SC82AB-A-PKG Dimensions NP004-A-P-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. ø1.5 2.0±0.05 +0.1 -0 4.0±0.1 1.1±0.1 4.0±0.1 0.2±0.05 ø1.05±0.1 (0.7) 2.2±0.2 2 1 3 4 Feed direction No. NP004-A-C-SD-3.0 TITLE SC82AB-A-Carrier Tape No. NP004-A-C-SD-3.0 ANGLE UNIT mm ABLIC Inc. 1.1±0.1 4.0±0.1 2.0±0.1 ø1.5 +0.1 -0 4.0±0.1 0.2±0.05 ø1.05±0.1 2.3±0.15 2 1 3 4 Feed direction No. NP004-A-C-S1-2.0 TITLE SC82AB-A-Carrier Tape No. NP004-A-C-S1-2.0 ANGLE UNIT mm ABLIC Inc. +1.0 - 0.0 9.0 11.4±1.0 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. NP004-A-R-SD-2.0 TITLE SC82AB-A-Reel No. NP004-A-R-SD-2.0 QTY. ANGLE UNIT mm ABLIC Inc. 3,000 0.38±0.02 0.65 3 4 1 2 1.00±0.04 0.20±0.05 +0.05 0.08 -0.02 The heat sink of back side has different electric potential depending on the product. Confirm specifications of each product. Do not use it as the function of electrode. No. PL004-A-P-SD-1.1 TITLE HSNT-4-B-PKG Dimensions No. PL004-A-P-SD-1.1 ANGLE UNIT mm ABLIC Inc. 2.0±0.05 +0.1 ø1.5 -0 1.12±0.05 2 1 3 4 ø0.5 4.0±0.05 +0.1 -0 0.25±0.05 2.0±0.05 0.5±0.05 Feed direction No. PL004-A-C-SD-2.0 TITLE HSNT-4-B-C a r r i e r Tape No. PL004-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. 9.0 +1.0 - 0.0 11.4±1.0 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PL004-A-R-SD-2.0 HSNT-4-B-Reel TITLE PL004-A-R-SD-2.0 No. QTY. ANGLE UNIT mm ABLIC Inc. 10,000 Land Pattern 0.30min. 0.38~0.48 0.38~0.48 0.07 0.65±0.02 (1.02) Caution It is recommended to solder the heat sink to a board in order to ensure the heat radiation. PKG Metal Mask Pattern Aperture ratio Aperture ratio Caution Mask aperture ratio of the lead mounting part is 100%. Mask aperture ratio of the heat sink mounting part is 40%. Mask thickness: t0.10mm to 0.12 mm 100% 40% t0.10mm ~ 0.12 mm TITLE No. PL004-A-L-SD-2.0 HSNT-4-B -Land Recommendation PL004-A-L-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-1324A30-M5T1U 价格&库存
很抱歉,暂时无法提供与“S-1324A30-M5T1U”相匹配的价格&库存,您可以联系我们找货
S-1324A30-M5T1U
    • 1+2.03688
    • 200+0.81270
    • 500+0.78560
    • 1000+0.77220
