Sunlord
Specifications for Multi-layer Chip Ceramic Inductors
Page 1 of 9
SPECIFICATIONS
Customer
Product Name
Sunlord Part Number
SDCL0603Q-02B01 Series
Customer Part Number
New Released,
Revised]
SPEC No.:SDCL03130000
Rev.
Effective Date
Changed Contents
Change reasons
Approved By
01
New release
Hai Guo
【This SPEC is total 9 pages including specifications and appendix. 】
【RoHS Compliant Parts】
Approved By
Checked By
Issued By
Shenzhen Sunlord Electronics Co., Ltd.
Address: Sunlord Industrial Park, Dafuyuan Industrial Zone, Baoan, Shenzhen, China
518110
Tel: 0086-755-82400574
Fax: 0086-755-82269029
E-Mail: sunlord@sunlordinc.com
【For Customer approval Only】
Qualification Status:
Full
Approved By
Comments:
Verified By
Date:
Restricted
Rejected
Re-checked By
Checked By
Sunlord
1.
Page 2 of 9
Scope
This specification applies to SDCL0603Q-02B01 series of multi-layer ceramic chip inductors.
2.
Product Description and Identification (Part Number)
1)
Description
2)
Product Identification (Part Number)
SDCL
0603
Q
XXX
02
B01
①
②
③
④
⑤
⑥
⑦
⑧
Type
①
SDCL
0603 [0201]
Applications and Characteristics Code
③
Q
Inductance Tolerance
B、C、S
±0.1、±0.2、±0.3nH
G、H、J
±2%、±3%、±5%
Nominal Inductance
Example
Nominal Value
3N9
3.9nH
10N
10nH
Packing
⑥
Serial Code
⑦
0.6 X 0.3
④
High Q type
⑤
External Dimensions (L X W) (mm)
②
Ceramic Chip Inductor
T
02
Tape Carrier Package
Internal Code
⑧
B01
3.
Electrical Characteristics
Please refer to Appendix A (Page 8-9).
4.
1)
Operating and storage temperature range (individual chip without packing): -55℃~ +125℃,
2)
Storage temperature range (packaging conditions): -10℃~+40℃ and RH 70% (Max.)
Shape and Dimensions
1)
Dimensions and recommended PCB pattern for reflow soldering: See Fig.4-1, Fig.4-2 and Table 4-1.
2)
Structure: See Fig. 4-3 and Fig. 4-4.
Mark
Solder-resist
Chip inductor
C
Land pattern
B
A B
Fig. 4-2
Fig. 4-1
Unit: mm [inch]
[Table 4-1]
Type
L
W
T
a
0603
0.6±0.05
0.3±0.05
0.3±0.05
0.12±0.05
[0201]
[.024±.002]
[.012±.002]
[.012±.002]
[.005±.002]
W
④-2
②
③
Fig. 4-3
④
0.2~0.3
0.25~0.35
0.25~0.35
① Ceramic for SDCL Series
Ceramic
Sn
①
C
② Internal electrode (Ag)
T
a
B
Structure of
Electro-plating
T
L
a
A
③ Pull out electrode( Ag)
④-1 Terminal electrode: Inside (Ag)
Ni
④-2 Outside (Electro-plating Ni-Sn)
④-1
Ag
Fig. 4-4
Sunlord
3)
Page 3 of 9
Material Information: See Table 4-2
[Table 4-2]
Code
Part Name
Material Name
①
Ceramic Body
Ceramic Powder
②
Inner Coils
Silver Paste
Pull-out Electrode (Ag)
③
4)
④-1
Terminal Electrode: Inside Ag
④-2
Electro-Plating: Ni/Sn plating
Silver Paste
Termination Silver Composition
Plating Chemicals
Soldering Notice: The surface with the mark should be on the top side when soldering, but it is not necessary to identify the mark's direction
towards left or right.
5.
Test and Measurement Procedures
5.1 Test Conditions
Unless otherwise specified, the standard atmospheric conditions for measurement/test as:
a.
Ambient Temperature: 20±15℃
b.
Relative Humidity: 65±20%
c.
Air Pressure: 86 KPa to 106 KPa
If any doubt on the results, measurements/tests should be made within the following limits:
a.
Ambient Temperature: 20±2℃
b.
Relative Humidity: 65±5%
c.
Air Pressure: 86KPa to 106 KPa
5.2 Visual Examination
a.
Inspection Equipment: 60 X magnifier
5.3 Electrical Test
5.3.1 DC Resistance (DCR)
a.
Refer to Appendix A.
b.
Test equipment (Analyzer): High Accuracy Milliohmmeter-HP4338B or equivalent.
5.3.2 Inductance (L)
a.
b.
Test equipment: High Accuracy RF Impedance /Material Analyzer-E4991A+16197A or equivalent.
c.
Test signal: -20dBm or 50mV
d.
Test frequency refers to Appendix A.
e.
Short bar residual inductance=0.43nH
5.3.3 Q Factor (Q)
a.
b.
c.
d.
5.3.4 Self-Resonant Frequency (SRF)
a.
b. Test equipment: Agilent 8719ES or equivalent.
c.
Test signal: -20 dBm or 50 mV
5.3.5 Rated Current
a.
b.
Test equipment (see Fig. 5.3.5-1): Electric Power, Electric current meter, Thermometer.
c.
Measurement method (see Fig. 5.3.5-1):
1. Set test current to be 0 mA.
2. Measure initial temperature of chip surface.
3. Gradually increase voltage and measure chip temperature for corresponding current.
d.
Definition of Rated Current(Ir): Ir is direct electric current as chip surface temperature rose just 20℃
against chip initial surface temperature(Ta) (see Fig. 5.3.5-2).
Thermometer
Temperature(℃)
Electric Power
Electric Current
Meter
Chip
R
+20
Ta
Rated current
Fig. 5.3.5-1
Fig. 5.3.5-2
Ir (mA)
Sunlord
Page 4 of 9
5.4 Reliability Test
Items
Requirements
Test Methods and Remarks
5.4.1
No removal or split of the termination or other
Terminal
defects shall occur.
Strength
①
Solder the inductor to the testing jig (glass epoxy board shown
in Fig. 5.4.1-1) using leadfree solder. Then apply a force in the
direction of the arrow.
Chip
F
Mounting Pad
②
2N force for SDCL0603Q-02B01 series.
③
Keep time: 10±1s
④
Speed: 1.0mm/s.
①
Solder the inductor to the test jig (glass epoxy board shown in
Glass Epoxy Board
Fig.5.4.1-1
5.4.2
Resistance
No visible mechanical damage.
to
Fig. 5.4.2-1) Using a leadfree solder. Then apply a force in the
Unit: mm [inch]
Flexure
Type
a
0603[0201]
0.25
direction shown Fig. 5.4.2-2.
b
c
②
Flexure: 2mm.
0.8
0.3
③
Pressurizing Speed: 0.5mm/sec.
④
Keep time: 30 sec.
Φ4.5
b
R230
Flexure
40
c
a
①
Vibration
②
Inductance change: Within ±10%.
③
Q factor change: Within ±20%.
Cu pad
45[1.772]
45[1.772]
100
Fig. 5.4.2-1
5.4.3
10
Fig. 5.4.2-2
①
shown in Fig. 5.4.3-1) using leadfree solder.
②
The inductor shall be subjected to a simple harmonic motion
having total amplitude of 1.5mm, the frequency being varied
Solder mask
uniformly between the approximate limits of 10 and 55 Hz.
③
The frequency range from 10 to 55 Hz and return to 10 Hz shall
be traversed in approximately 1 minute. This motion shall be
applied for a period of 2 hours in each 3mutually perpendicular
directions (total of 6 hours).
Glass Epoxy Board
Fig. 5.4.3-1
5.4.4 Dropping
①
Drop chip inductor 10 times on a concrete floor from a height of 100
②
cm.
③
5.4.5
Inductance change should be within ±10% of
Temperature range: SDCL0603Q-02B01: -55℃ to +125℃,
Temperature
initial value measuring at 20℃.
Reference temperature: +20℃
5.4.6
①
①
Solder temperture:240±2℃
Solderability
②
Wetting shall exceed 75% coverage.
②
Duration: 3 sec.
③
Solder: Sn/3.0Ag/0.5Cu.
④
Flux: 25% Resin and 75% ethanol in weight.
5.4.7
①
①
Solder temperature: 260±3℃
Resistance to
②
②
Duration: 5 sec.
Soldering Heat
③
③
④
④
⑤
The chip shall be stabilized at normal condition for 1~2 hours
before measuring.
Sunlord
5.4.8
①
No mechanical damage.
Thermal Shock
②
③
①
30 min.
125℃
Temperature, Time: (See Fig. 5.4.8-1)
SDCL0603Q-02B01: -55℃for 30±3 min→125℃ for 30±3min,
30 min.
②
Transforming interval: Max. 20 sec.
③
Tested cycle: 100 cycles.
④
before measuring.
Ambient
Temperature
-55℃
Page 5 of 9
30 min.
Fig. 5.4.8-1
20sec. (max.)
5.4.9 Resistance
①
①
Temperature: -55±2℃,
to Low
②
②
Duration: 1000
Temperature
③
③
+24
hours.
before measuring.
5.4.10 Resistance
①
①
Temperature: 125±2℃,
to High
②
②
Duration: 1000
Temperature
③
③
5.4.11
①
①
Temperature: 60±2℃
②
②
Humidity: 90% to 95% RH.
③
③
Duration: 1000
④
+24
hours.
before measuring.
Damp Heat
(Steady States)
+24
hours.
before measuring.
5.4.12
①
①
Temperature: 60±2℃
Loading Under
②
②
Damp Heat
③
③
Duration: 1000
④
Applied current: Rated current.
⑤
+24
hours.
before measuring.
5.4.13 Loading at
①
①
High Temperature
②
②
Duration: 1000
(Life Test)
③
③
④
+24
hours.
before measuring.
6.
Packaging and Storage
6.1 Packaging
Tape Carrier Packaging:
Packaging code: T
a.
Tape carrier packaging are specified in attached figure Fig.6.1-1~3
b.
Tape carrier packaging quantity please see the following table:
Type
(1)
0603[0201]
Thickness (mm)
0.3±0.05
Tape
Paper Tape
Quantity
15K
Taping Drawings (Unit: mm)
.6.1-1
Sunlord
Page 6 of 9
(2) Taping Dimensions (Unit: mm)
Paper Tape
Chip Cavity
Sprocket Hole Φ1.5 (+0.1,0)
1.75±0.1
B
8.0±0.3
3.5±0.05
A
A
B
P
T max
0603[0201]
0.4±0.1
0.7±0.1
2.0±0.05
0.55
T
4.0±0.1
P
2.0±0.05
Type
Fig. 6.1-2
Direction of Feed
(3) Reel Dimensions (Unit: mm)
4.3±0.2mm
8.4+1.5/-0.0mm
C
4.0±0.1mm
2.45±0.2mm
5.0±0.1mm
58±2.0mm
13.5±0.2mm
3.0±0.1mm
max<14.4mm
178±2.0mm
Fig. 6.1-3
6.2 Storage
a.
The solderability of the external electrode may be deteriorated if packages are stored where they are exposed to high humidity. Package must be
stored at 40℃ or less and 70% RH or less.
b.
The solderability of the external electrode may be deteriorated if packages are stored where they are exposed to dust of harmful gas (e.g. HCl,
sulfurous gas of H2S).
c.
d.
Packaging material may be deformed if package are stored where they are exposed to heat of direct sunlight.
Solderability specified in Clause 5.4.6 shall be guaranteed for 6 months from the date of delivery on condition that they are stored at the
environment specified in Clause 3. For those parts, which passed more than 6 months shall be checked solder-ability before use.
7. Recommended Soldering Technologies
7.1 Reflow Profile
Preheat condition: 150 ~200℃/60~120sec.
Allowed time above 217℃: 60~90sec.
Max temp: 260℃
Max time at max temp: 10sec.
Solder paste: Sn/3.0Ag/0.5Cu
Allowed Reflow time: 2x max
[Note: The reflow profile in the above table is only for
217℃
the customer's specific board design, solder paste and
Max Ramp Up Rate=3℃/sec.
Max Ramp Down Rate=6℃/sec.
60~90sec.
200℃
150℃
60~120sec.
qualification and is not meant to specify board assembly
profiles. Actual board assembly profiles must be based on
Peak 260℃ max
260℃
25℃
Time 25℃ to Peak =8 min max
process, and should not exceed the parameters as the
Reflow profile shows.]
7.2 Iron Soldering Profile
3sec. Max.
Iron soldering power: Max. 30W
350℃
Pre-heating: 150℃/60sec.
Soldering Tip temperature: 350℃ Max.
Soldering Iron
Soldering time: 3sec. Max.
Power: max. 30W
Max.1 times for iron soldering
[Note: Take care not to apply the tip of
the soldering iron to the terminal electrodes.]
Diameter of Soldering
Tc ℃
Iron 1.0mm max.
Sunlord
8.
Supplier Information
a) Supplier:
b)
Manufacturer:
c)
Manufacturing Address:
Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110
Page 7 of 9
Sunlord
Page 8 of 9
Appendix A: Electrical Characteristics (SDCL0603Q-02B01 Series of Inductors)
Part Number
SDCL0603Q0N6□T02B01
L
Q
(nH)
Min.
0.6
13
L, Q Test.
S.R.F
Q (Typ.) @Freq. (GHz)
Freq
(MHz)
(MHz)
0.5
0.8
1.8
2.0
2.4
Min
500
>24
>32
>54
>57
>65
10000
DCR
Ir (mA)
(Ω) Max.
Max.
0.06
Thickness
(mm)
[inch]
600
0.3±0.05
[.012±.002]
SDCL0603Q0N7□T02B01
0.7
13
500
>24
>32
>54
>57
>65
10000
0.06
550
SDCL0603Q0N8□T02B01
0.8
13
500
>24
>32
>54
>57
>65
10000
0.07
550
SDCL0603Q0N9□T02B01
0.9
13
500
>24
>32
>54
>57
>65
10000
0.07
550
SDCL0603Q1N0□T02B01
1.0
13
500
24
32
54
57
65
10000
0.08
520
SDCL0603Q1N1□T02B01
1.1
13
500
19
26
45
47
55
10000
0.11
440
SDCL0603Q1N2□T02B01
1.2
13
500
19
25
43
44
52
10000
0.12
420
SDCL0603Q1N3□T02B01
1.3
13
500
19
25
40
42
47
10000
0.12
420
SDCL0603Q1N4□T02B01
1.4
13
500
19
24
39
41
47
10000
0.11
440
SDCL0603Q1N5□T02B01
1.5
13
500
19
24
39
41
46
10000
0.12
420
SDCL0603Q1N6□T02B01
1.6
13
500
19
24
39
41
46
10000
0.13
410
SDCL0603Q1N7□T02B01
1.7
13
500
19
24
39
41
46
10000
0.15
380
SDCL0603Q1N8□T02B01
1.8
13
500
19
24
39
41
46
10000
0.15
380
SDCL0603Q1N9□T02B01
1.9
13
500
18
24
38
40
45
10000
0.18
350
SDCL0603Q2N0□T02B01
2.0
13
500
17
24
38
39
44
10000
0.23
300
SDCL0603Q2N1□T02B01
2.1
13
500
17
24
37
39
44
10000
0.24
300
SDCL0603Q2N2□T02B01
2.2
13
500
17
24
38
40
43
10000
0.25
290
SDCL0603Q2N3□T02B01
2.3
13
500
17
24
37
39
43
10000
0.20
330
SDCL0603Q2N4□T02B01
2.4
13
500
17
23
36
38
42
10000
0.22
310
SDCL0603Q2N5□T02B01
2.5
13
500
17
23
35
36
40
9600
0.20
330
SDCL0603Q2N6□T02B01
2.6
13
500
17
22
34
35
39
9400
0.20
330
SDCL0603Q2N7□T02B01
2.7
13
500
17
22
34
35
39
9200
0.22
310
SDCL0603Q2N8□T02B01
2.8
13
500
17
22
34
35
39
8900
0.24
300
SDCL0603Q2N9□T02B01
2.9
13
500
17
22
34
35
39
8800
0.26
280
SDCL0603Q3N0□T02B01
3.0
13
500
17
22
34
35
39
8600
0.26
280
SDCL0603Q3N1□T02B01
3.1
13
500
17
22
34
35
39
8500
0.28
270
SDCL0603Q3N2□T02B01
3.2
13
500
17
22
33
35
39
8200
0.28
270
SDCL0603Q3N3□T02B01
3.3
13
500
18
23
34
36
40
8100
0.30
270
SDCL0603Q3N4□T02B01
3.4
13
500
17
23
33
35
39
8000
0.30
270
SDCL0603Q3N5□T02B01
3.5
13
500
17
23
33
35
39
7900
0.34
250
SDCL0603Q3N6□T02B01
3.6
13
500
16
23
33
35
39
7700
0.38
240
SDCL0603Q3N7□T02B01
3.7
13
500
16
23
33
35
38
7600
0.40
230
SDCL0603Q3N8□T02B01
3.8
13
500
16
22
33
35
38
7500
0.42
230
SDCL0603Q3N9□T02B01
3.9
13
500
16
22
33
35
38
7400
0.42
230
SDCL0603Q4N3□T02B01
4.3
13
500
16
21
32
34
37
6800
0.44
220
SDCL0603Q4N7□T02B01
4.7
13
500
16
22
33
35
38
6200
0.45
220
SDCL0603Q5N1□T02B01
5.1
13
500
17
22
34
36
38
5900
0.46
210
SDCL0603Q5N6□T02B01
5.6
13
500
16
21
33
34
37
5500
0.46
210
SDCL0603Q6N2□T02B01
6.2
13
500
18
23
34
35
37
5100
0.48
210
SDCL0603Q6N8□T02B01
6.8
13
500
17
22
32
33
35
5500
0.50
200
SDCL0603Q7N5□T02B01
7.5
13
500
16
21
31
33
34
4700
0.50
200
SDCL0603Q8N2□T02B01
8.2
13
500
16
21
31
32
34
4300
0.56
190
SDCL0603Q9N1□T02B01
9.1
13
500
16
31
32
4100
0.72
170
SDCL0603Q10N□T02B01
10
13
500
16
29
31
3800
0.80
160
SDCL0603Q12N□T02B01
12
13
500
16
28
28
3400
0.80
160
SDCL0603Q15N□T02B01
15
13
500
15
19
24
24
23
2600
0.85
160
SDCL0603Q18N□T02B01
18
13
500
15
19
23
24
22
2300
1.00
140
SDCL0603Q22N□T02B01
22
13
500
15
19
22
23
1.20
130
SDCL0603Q27N□T02B01
27
13
500
15
19
15
13
8
1800
1.60
120
SDCL0603Q33N□T02B01
33
11
300
14
15
8
5
1800
2.20
110
Sunlord
Page 9 of 9
SDCL0603Q39N□T02B01
39
11
300
14
15
6
1600
2.30
100
SDCL0603Q47N□T02B01
47
11
300
14
15
1500
2.60
100
SDCL0603Q56N□T02B01
56
11
300
13
13
1400
2.80
80
SDCL0603Q68N□T02B01
68
11
300
13
11
1200
3.20
80
SDCL0603Q82N□T02B01
82
10
300
12
10
1100
3.80
70
SDCL0603QR10□T02B01
100
10
300
12
10
1000
4.00
60
SDCL0603QR12□T02B01
120
9
300
12
8
1000
5.00
50
Note: □: Please specify the inductance tolerance. For L≤6.2nH, choose B=±0.1nH, C=±0.2nH or S=±0.3nH;For L>6.2nH, choose, H=±3%, J=±5%.or
K=±10%
SDCL0603Q5N1HT02B01 价格&库存
很抱歉,暂时无法提供与“SDCL0603Q5N1HT02B01”相匹配的价格&库存,您可以联系我们找货
