WS72551EA-5/TR
WS72551EA-5/TR
    WILLSEMI(韦尔)
    SOT23-5
    零温漂运算放大器
WS72551EA-5/TR 数据手册
WS72551/2 WS72551/WS72552 Zero-Drift, Single-Supply, Rail-to-Rail Input/Output Operational Amplifiers Http//:www.willsemi.com Descriptions This family of amplifiers has ultra low offset, drift, and bias current. The WS72551 and WS72552 are SOT23-5L SOP-8L MSOP-8L single and dual amplifiers featuring rail-to-rail input and output swings respectively. All are guaranteed to operate from 2.5V to 5V with a single supply. OUT 1 V- 2 +IN 3 5 V+ 4 -IN +IN 1 V- 2 -IN 3 5 V+ 4 OUT The WS72551/WS72552 provides the benefits previously found only in expensive auto-zeroing or SOT23-5L SOT23-5L chopper-stabilized amplifiers. These new zero-drift (WS72551EA-5/TR) (WS72551E-5/TR) amplifiers combine low cost with high accuracy. No external capacitors are required. With an offset voltage of only 3μV and drift of 0.008 NC 1 8 NC OUTA 1 -IN 2 7 V+ -INA 2 +IN 3 6 OUT V- 4 5 NC μV/°C, the WS72551/WS72552 are perfectly suited +INA 3 V- 4 A B 8 V+ 7 OUTB 6 -INB 5 +INB for applications in which error sources cannot be tolerated. Temperature, position and pressure SOP-8L/MSOP-8L sensors, medical equipment, and strain gauge SOP-8L/MSOP-8L Pin configuration (Top view) amplifiers benefit greatly from nearly zero drift over their operating temperature range. The rail-to-rail input and output swings provided by the WS72551/WS72552 make both high-side and low-side sensing easy. 2551 GAYW 2551 GEYW WLSI 2551 GSYW SOT23-5L SOT23-5L SOP-8L 2551 GMYW WLSI 2552 GSYW 2552 GMYW MSOP-8L SOP-8L MSOP-8L The WS72551/WS72552 are specified for the extended industrial/automotive temperature range (-40°C to +125°C). The WS72551 single amplifier is available in 8-lead MSOP, 8-lead narrow SOIC and 5-lead SOT23-5L packages. The WS72552 dual amplifier is available in 8-lead MSOP and 8-lead narrow SOIC surface mount packages. Will Semiconductor Ltd. 1 Mar, 2020 - Rev. 1.1 WS72551/2 Applications Marking  Temperature sensors 2551 = Device code  Pressure sensors 2552 = Device code  Precision current sensing GA = Special code  Strain gauge amplifiers GE = Special code  Medical instrumentation GS = Special code  Thermocouple amplifiers GM = Special code Y = Year code W = Week code Features  Low offset voltage : 14 μV(MAX)  Input offset drift : 0.008 μV/°C  Overload recovery time : 150 μs  Low supply current : 240 μA/OpAmp  High gain, CMRR, PSRR : 130 dB  Ultralow input bias current : 10 pA  Order information Device Package Shipping WS72551S-8/TR SOP-8L 4000/Reel &Tape WS72551M-8/TR MSOP-8L 4000/Reel &Tape No external capacitors required WS72551EA-5/TR SOT23-5L 3000/Reel &Tape  5 V/2.5 V single-supply operation WS72551E-5/TR SOT23-5L 3000/Reel &Tape  Rail-to-rail input and output swing WS72552S-8/TR SOP-8L 4000/Reel &Tape WS72552M-8/TR MSOP-8L 4000/Reel &Tape Will Semiconductor Ltd. 2 Mar, 2020 - Rev. 1.1 WS72551/2 Pin Descriptions WS72551S-8/TR and WS72551M-8/TR WS72551EA-5/TR WS72551E-5/TR WS72552S-8/TR and WS72552M-8/TR Will Semiconductor Ltd. Pin Number Symbol 1 NC 2 -IN Inverting input 3 +IN Non-inverting input 4 V- 5 NC 6 OUT 7 V+ 8 NC Pin Number Symbol 1 OUT 2 V- 3 +IN Non-inverting input 4 -IN Inverting input 5 V+ Positive supply Pin Number Symbol 1 +IN 2 V- Negative supply 3 -IN Inverting input 4 OUT 5 V+ Pin Number Symbol 1 OUTA 2 -INA Inverting input 3 +INA Non-inverting input 4 V- 5 +INB Non-inverting input 6 -INB Inverting input 7 OUTB 8 V+ 3 Descriptions Negative supply Output Positive supply Descriptions Output Negative supply Descriptions Non-inverting input Output Positive supply Descriptions Output Negative supply Output Positive supply Mar, 2020 - Rev. 1.1 WS72551/2 Absolute Maximum Ratings (1) Parameter Rating Unit 6 V GND-0.2V to Vs+0.2 V Differential Input Voltage ±5.0 V ESD (Human Body Model) 7000 V Supply Voltage (2) Input Voltage Output Short-Circuit Duration to GND Indefinite / ° C Storage Temperature Range -65 to +150 Junction Temperature Range -65 to +150 ° 300 ° -40 to +125 ° Lead Temperature Range(Soldering, 60 sec) Operating Temperature Range C C C Note: 1. Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are only stress ratings, and functional operation of the device at these or any other conditions beyond those indicated under recommended operating conditions are not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. 2. All voltage values, except differential voltage are with respect to network terminal. ESD, Electrostatic Discharge Protection Symbol HBM Parameter Human Body Model ESD Condition MIL-STD-883H Method 3015.8 Minimum level Unit ±7000 V JEDEC-EIA/JESD22-A114A MM CDM Machine Model ESD JEDEC-EIA/JESD22-A115 ±300 V Charged Device Model ESD JEDEC-EIA/JESD22-C101E ±2000 V Will Semiconductor Ltd. 4 Mar, 2020 - Rev. 1.1 WS72551/2 Electronics Characteristics VS = 5 V, VCM = 2.5 V, Vo = 2.5 V, TA = 25°C, unless otherwise noted. Symbol VOS Parameter Conditions Min. Offset Voltage Input Bias Current Common Mode Rejection Ratio ﹣40 C≤TA≤﹢125 C 0.5 nA 6 pA ﹣40 C≤TA≤﹢85 C 50 pA ﹣40 C≤TA≤﹢125 C 0.5 nA ° ° -0.1 VCM=-0.1 V to﹢5.1V Large Signal Voltage Gain 5.1 V 100 140 dB 100 145 dB ﹣40°C≤TA≤﹢125°C 135 dB 0.01 μV/°C VO=0.3V to 4.7V, AVO μV pA ° ° CMRR 14 50 ° Input Voltage Range 5 ﹣40 C≤TA≤﹢85 C Input Offset Current VCMR Unit pA ° ° IOS Max. 10 ° IB Typ. RL=10k △VOS/△T Offset Voltage Drift ﹣40 C≤TA≤﹢125 C VOH Output Voltage High RL =10k to GND 6 VOL Output Voltage Low RL =100k to V+ 4 mV ISC Output Short-Circuit Limit Current ±58 ±70 mA PSRR Power Supply Rejection Ratio 100 120 dB ISY Supply Current / Amplifier SR Slew Rate Tor ° ° VS = 2.7V to 5V VO=0V 265 ﹣40 C≤TA≤﹢125 C 10 mV μA 340 290 μA 1.2 V/s Overload Recovery Time 150 us GBP Gain-Bandwidth Product 1.8 MHz en p-p Voltage Noise 0.1Hz to 10Hz 1.8 VP-P en Voltage Noise Density f=1kHz 80 nV/√Hz ° RL=10k ° Note: 1. Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. 2. A heat sink may be required to keep the junction temperature below the absolute maximum rating when the output is shorted indefinitely. 3. Thermal resistance varies with the amount of PC board metal connected to the package. The specified values are for short traces connected to the leads. Will Semiconductor Ltd. 5 Mar, 2020 - Rev. 1.1 WS72551/2 Electronics Characteristics VS = 2.5 V, VCM = 1.25 V, Vo = 1.25 V, TA = 25°C, unless otherwise noted. Symbol VOS Parameter Conditions Min. Offset Voltage Input Bias Current Unit 3 14 μV pA ﹣40 C≤TA≤﹢85 C 40 pA ﹣40 C≤TA≤﹢125 C 0.2 nA 4 pA ° ° ° Input Offset Current IOS Max. 4 ° IB Typ. WS72552 ﹣40 C≤TA≤﹢85 C 40 pA WS72552 ﹣40 C≤TA≤﹢125 C 0.2 nA ° ° ° ° VCMR Input Voltage Range -0.1 CMRR Common Mode Rejection Ratio AVO Large Signal Voltage Gain △VOS/△T Offset Voltage Drift ﹣40°C≤TA≤﹢125°C VOH Output Voltage High VOL Output Voltage Low ISC Output Short-Circuit Limit Current PSRR Power Supply Rejection Ratio ISY Supply Current / Amplifier SR Slew Rate VCM=0 V to﹢2.5V 100 2.6 V 140 dB ﹣40 C≤TA≤﹢125 C ° ° VO=0.3V to 2.2V, dB 100 140 dB 0.008 μV/°C RL =10k to GND 10 mV RL =10k to V﹢ 10 mV ±20 mA 120 dB RL=10k VS = 2.7V to 5V 100 VO=0V 235 ﹣40 C≤TA≤﹢125 C μA 300 260 μA 1.2 V/s Overload Recovery Time 160 us GBP Gain-Bandwidth Product 1.7 MHz en p-p Voltage Noise 0Hz to 10Hz 1.8 VP-P en Voltage Noise Density f=1kHz 80 nV/√Hz ° RL=10k ° Note: 4. Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. 5. A heat sink may be required to keep the junction temperature below the absolute maximum rating when the output is shorted indefinitely. 6. Thermal resistance varies with the amount of PC board metal connected to the package. The specified values are for short traces connected to the leads. Will Semiconductor Ltd. 6 Mar, 2020 - Rev. 1.1 WS72551/2 Typical Characteristics TA=25°C, VCC=5V, RL=10K, CL=100pF, unless otherwise noted. Large-Signal Step Response, 2V Step 0.08 1.5 0.06 1.0 VIN & VOUT (V) VIN & VOUT (V) Small-Signal Step Response, 100mV Step 0.04 0.02 0.00 -0.02 -0.04 -0.06 0 5 10 15 0.0 -0.5 -1.0 VOUT VIN -0.08 -5 0.5 VOUT VIN -1.5 -5 20 0 5 Time (μs) 10 15 20 Time (μs) Open-Loop Gain and Phase Cload vs. Phase Margin 80 GAIN=20000 RLOAD=100K Gain Phase 120 Gain and Phase 100 70 80 60 40 50 40 30 20 20 0 10 -20 100 1000 10000 100000 Gain=10 60 Phase Margin 140 0 1000000 2000 4000 6000 8000 Frequency(Hz) Cload(pF) Phase Margin vs. Cload Input Offset Voltage vs. Temperature Iq vs. Supply Voltage -5.0 300 VS+=2.5V VS-=-2.5V 290 Quiescent Current (uA) -5.5 VOS (μV) -6.0 -6.5 -7.0 -7.5 -8.0 -8.5 -9.0 -50 10000 280 270 260 250 240 230 220 210 -25 0 25 50 75 100 200 1.00 125 Temperature( C) VOS vs. Temperature Will Semiconductor Ltd. 1.25 1.50 1.75 2.00 2.25 2.50 2.75 3.00 Supply voltage(V) Quiescent Current vs. Supply Voltage o 7 Mar, 2020 - Rev. 1.1 WS72551/2 Typical Characteristics (continued) TA=25°C, VCC=5V, RL=10K, CL=100pF, unless otherwise noted. Over Shoot Voltage, CLOAD=47nF, Over Shoot Voltage, CLOAD=47nF, RLOAD=10kΩ, Gain=+1 RF=2kΩ, Gain=-1 0.15 0.08 VIN & VOUT (V) VIN & VOUT (V) 0.06 0.10 0.05 0.00 -0.05 0.00 0.09 0.18 0.02 0.00 -0.02 -0.04 -0.06 VOUT VIN -0.10 -0.09 0.04 VOUT VIN -0.08 -0.09 0.27 0.00 0.09 Time (μs) Iq vs. Temperature 60 over shoot and Under shoot(%) 340 Quiescent Current (uA) 0.27 Over/under shoot vs. Cload 360 320 300 280 260 VS+=2.5V VS-=-2.5V 240 220 200 -50 0.18 Time (μs) -25 0 25 50 75 100 Gain=+1 Over shoot Under shoot 50 40 30 20 10 0 100 125 o Temperature( C) Quiescent Current vs. Temperature 1000 10000 Cload(pf) over shoot and Under shoot(%) vs. Cload PSRR vs. Frequency Over/under shoot vs. Cload 30 over shoot and Under shoot(%) 120 PSRR (dB) 100 80 60 40 20 0 1 10 100 1k 10k 100k 1M 15 10 5 0 200 400 600 800 1000 Cload(pf) over shoot and Under shoot(%) vs. Cload Frequency (Hz) Will Semiconductor Ltd. 20 0 10M Gain=-1 Over shoot Under shoot 25 8 Mar, 2020 - Rev. 1.1 WS72551/2 Typical Characteristics (continued) TA=25°C, VCC=5V, RL=10K, CL=100pF, unless otherwise noted. THD+N vs. Vin F=20KHz THD+N vs. Frequency -60 -20 -40 -50 -70 THD+N(dB) -30 THD+N(dB) -65 VS+=2.5V VS-=-2.5V RLOAD=100k CLOAD=100p f=20KHz Gain=1 -60 -75 VS+=2.5V VS-=-2.5V RLOAD=100K CLOAD=100P VIN+=2VPP Gain=+1 -80 -85 -90 -70 -95 -80 -90 0.0 -100 10 0.5 1.0 1.5 2.0 2.5 3.0 3.5 100 1000 10000 Frequency(Hz) THD+Noise vs. Frequency 4.0 VIN+ (Vpp) THD+N VS. VIN+ Input Offset Voltage Distribution(VS+=2.5V) Input Offset Voltage Distribution(VS+=5V) THD+Noise vs. Vin+, Gain=+1, f=1kHz, THD+Noise vs. Vin+, Gain=100, f=20kHz, RLOAD=100kΩ, CLOAD=100pF RLOAD=100kΩ, CLOAD=100pF -20 -20 VS+=2.5V VS-=-2.5V RLOAD=100k CLOAD=100p f=1KHz Gain=1 THD+N(dB) -40 -50 -60 -40 -70 -50 -60 -70 -80 -80 -90 -100 0.0 VS+=2.5V VS-=-2.5V RLOAD=100k CLOAD=100p f=20KHz Gain=1 -30 THD+N(dB) -30 0.5 1.0 1.5 2.0 2.5 3.0 3.5 -90 0.0 4.0 VIN+ (Vpp) THD+N VS. VIN+ Will Semiconductor Ltd. 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 VIN+ (Vpp) THD+N VS. VIN+ 9 Mar, 2020 - Rev. 1.1 WS72551/2 Typical Characteristics (continued) TA=25°C, VCC=5V, RL=10K, CL=100pF, unless otherwise noted. THD+Noise vs. Frequency, Gain=+1, Crosstalk, (WS72552 only) Vin+=2Vpp RLOAD=100kΩ, CLOAD=100pF -40 -20 VS+=2.5V VS-=-2.5V RLOAD=100k CLOAD=100p f=20KHz Gain=1 THD+N(dB) -40 -50 -50 Crosstalk (dB) -30 -60 -70 -80 -90 0.0 -60 -70 -80 -90 -100 0.5 1.0 1.5 2.0 2.5 3.0 3.5 -110 10 4.0 VIN+ (Vpp) THD+N VS. VIN+ Will Semiconductor Ltd. 100 1k 10k 100k Frequency (Hz) 10 Mar, 2020 - Rev. 1.1 WS72551/2 PACKAGE OUTLINE DIMENSIONS SOP-8L D E E1 L c θ e SIDE VIEW A1 TOP VIEW A A2 b SIDE VIEW Dimensions In Millimeters (mm) Symbol Min. Typ. Max. A 1.35 1.55 1.75 A1 0.05 0.15 0.25 A2 1.25 1.40 1.65 b 0.33 - 0.51 c 0.15 - 0.26 D 4.70 4.90 5.10 E 3.70 3.90 4.10 E1 5.80 6.00 6.20 e 1.27BSC L 0.40 - 1.27 θ 0° - 8° Will Semiconductor Ltd. 11 Mar, 2020 - Rev. 1.1 WS72551/2 TAPE AND REEL INFORMATION SOP-8L Reel Dimensions RD Reel Dimensions Tape Dimensions W P1 Quadrant Assignments For PIN1 Orientation In Tape Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 User Direction of Feed RD Reel Dimension 7inch 13inch W Overall width of the carrier tape 8mm 12mm P1 Pitch between successive cavity centers 2mm 4mm 8mm Pin1 Pin1 Quadrant Q1 Q2 Q3 Will Semiconductor Ltd. 12 Q4 Mar, 2020 - Rev. 1.1 WS72551/2 PACKAGE OUTLINE DIMENSIONS MSOP-8L D e c E E1 L b θ TOP VIEW A A2 A1 SIDE VIEW SIDE VIEW Symbol Dimensions In Millimeters (mm) Min. Typ. Max. A - - 1.10 A1 0.02 - 0.15 A2 0.75 0.80 0.95 b 0.25 - 0.38 c 0.09 - 0.23 D 2.90 3.00 3.10 E 4.75 4.90 5.05 E1 2.90 3.00 3.10 e 0.65 BSC L 0.40 - 0.80 θ 0° - 6° Will Semiconductor Ltd. 13 Mar, 2020 - Rev. 1.1 WS72551/2 TAPE AND REEL INFORMATION MSOP-8L Reel Dimensions RD Reel Dimensions Tape Dimensions W P1 Quadrant Assignments For PIN1 Orientation In Tape Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 User Direction of Feed RD Reel Dimension 7inch 13inch W Overall width of the carrier tape 8mm 12mm P1 Pitch between successive cavity centers 2mm 4mm 8mm Pin1 Pin1 Quadrant Q1 Q2 Q3 Will Semiconductor Ltd. 14 Q4 Mar, 2020 - Rev. 1.1 WS72551/2 PACKAGE OUTLINE DIMENSIONS SOT23-5L (WS72551EA-5/TR) D θ b K L1 L M E E1 (Ⅰ) (Ⅱ) c e e1 A A1 SIDE VIEW A2 TOP VIEW SIDE VIEW Symbol Dimensions in Millimeters Min. Typ. Max. A - - 1.45 A1 0.00 - 0.15 A2 0.90 1.10 1.30 b 0.30 0.40 0.50 c 0.10 - 0.21 D 2.72 2.92 3.12 E 2.60 2.80 3.00 E1 1.40 1.60 1.80 e 0.95 BSC e1 1.90 BSC L 0.30 0.45 0.60 M 0.10 0.15 0.25 K 0.00 - 0.25 θ 0° - 8° Will Semiconductor Ltd. 15 Mar, 2020 - Rev. 1.1 WS72551/2 TAPE AND REEL INFORMATION SOT23-5L (WS72551EA-5/TR) Reel Dimensions RD Reel Dimensions Tape Dimensions W P1 Quadrant Assignments For PIN1 Orientation In Tape Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 RD Reel Dimension W Overall width of the carrier tape P1 Pitch between successive cavity centers Pin1 Pin1 Quadrant Will Semiconductor Ltd. User Direction of Feed 7inch 13inch 1 8mm 12mm 16mm 2mm 4mm 8mm Q1 Q2 Q3 16 Q4 Mar, 2020 - Rev. 1.1 WS72551/2 PACKAGE OUTLINE DIMENSIONS SOT23-5L (WS72551E-5/TR) D θ b K L1 L M E E1 (Ⅰ) (Ⅱ) c e e1 A A1 SIDE VIEW A2 TOP VIEW SIDE VIEW Symbol Dimensions in Millimeters Min. Typ. Max. A - - 1.25 A1 0.00 - 0.15 A2 1.00 1.10 1.20 b 0.36 - 0.45 c 0.14 - 0.20 D 2.826 2.926 3.026 E 2.60 2.80 3.00 E1 1.526 1.626 1.726 e 0.90 0.95 1.00 e1 1.80 1.90 2.00 L 0.30 0.40 0.60 M 0.10 0.15 0.25 K 0.00 - 0.25 θ 0° - 8° Will Semiconductor Ltd. 17 Mar, 2020 - Rev. 1.1 WS72551/2 TAPE AND REEL INFORMATION SOT23-5L (WS72551E-5/TR) Reel Dimensions RD Reel Dimensions Tape Dimensions W P1 Quadrant Assignments For PIN1 Orientation In Tape Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 RD Reel Dimension W Overall width of the carrier tape P1 Pitch between successive cavity centers Pin1 Pin1 Quadrant Will Semiconductor Ltd. User Direction of Feed 7inch 13inch 1 8mm 12mm 16mm 2mm 4mm 8mm Q1 Q2 Q3 18 Q4 Mar, 2020 - Rev. 1.1
WS72551EA-5/TR 价格&库存
很抱歉,暂时无法提供与“WS72551EA-5/TR”相匹配的价格&库存,您可以联系我们找货
