ES8J
ES8J
    LGE(鲁光)
    SMC(DO-214AB)
    耐压:600V 电流:8A 反向恢复时间:35NS
ES8J 数据手册
ES8A THRU ES8J 8.0AMPS Surface Mount Super Fast Rectifiers SMC/DO-214AB FEATURES        Plastic package has Underwrites Laboratory Flammability Classification 94V-0 Metal-Silicon Junction For surface mount applications Guard ring for over voltage protection High forward surge current capability Super Low forward voltage High temperature soldering guaranteed: 260℃/10 seconds at terminals MECHANICAL DATA       Case: Transfer molded plastic Epoxy: UL94V-O rate flame retardant Polarity: Color band denotes cathode end Lead: Plated axial lead, solderable per MIL-STD-750 method 2026 Dimensions in inches and (millimeters) Mounting position: Surface Mounted Weight: 0.007 ounce, 0.25 grams MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS    Ratings at 25OC ambient temperature unless otherwise specified Single Phase, half wave, 60Hz, resistive or inductive load For capacitive load derate current by 20% SYMBOLS ES8A ES8B ES8C ES8D ES8E ES8G ES8H ES8J UNIT Maximum Repetitive Peak Reverse Voltage VRRM 50 100 150 200 300 400 500 600 Volts Maximum RMS Voltage VRMS 35 70 105 140 210 280 350 420 Volts Maximum DC Blocking Voltage VDC 50 100 150 200 300 400 500 600 Volts Maximum Average Forward Rectified Current I(AV) 8.0 Amp Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load IFSM 125 Amps Maximum Instantaneous Forward Voltage at 5.0A VF Maximum DC Reverse Current at rated DC Blocking Voltage TA = 25℃ 0.95 1.3 10 IR TA = 125℃ 350 1.7 Volts uA Maximum Reverse Recovery Time(1) Trr 35 ns Typical Junction Capacitance at VR=4V,f=1MHZ CJ 90 pF RθJA/ RθJC 75/20 ℃/W Typical Thermal Resistance (2) Operating Temperature Range Storage Temperature Range TJ -55 to +150 ℃ TSTG -55 to +150 ℃ Notes: (1)Measured with IF=0.5A,IR=1A,In=0.25A (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. Revision:20181018-P1 ht t p : // www.lgesem i .c o m mail:lge@lgesemi.com ES8A THRU ES8J 8.0AMPS Surface Mount Super Fast Rectifiers RATINGS AND CHARACTERISTIC CURVES t rr 10 ohm Noninductive 50 ohm Noninductive +0.5 D.U.T + PULSE GENERATOR Note 2 25Vdc approx 0 - -0.25 1 ohm NonInductive OSCILLOSCOPE Note 1 -1.0 Note:1.Rise Time = 7ns, max. Input Impedance = 1megohm,22pF. 2. Ries Time =10ns, max. Source Impedance = 50 ohms. 10ns/div Set time Base for 10ns/div Fig.3 Typical Reverse Characteristics 11.2 300 9.6 100 I R - Reverse Current (μA) Average Forward Current (A) Fig.2 Maximum Average Forward Current Rating 8.0 6.4 4.8 3.2 1.6 Single phase half-wave 60 Hz resistive or inductive load T J =125°C 10 T J =75°C 1.0 T J =25°C 0.1 0.0 25 50 75 100 125 150 0 175 20 40 Case Temperature (°C) Junction Capacitance (pF) Instaneous Forward Current (A) T J =25°C 10 ES8A~ES8D ES8E-ES8G ES8H-ES8J 0.1 0.01 0.5 1.0 1.5 100 Fig.5 Typical Junction Capacitance 100 0 80 % of PIV.VOLTS Fig.4 Typical Forward Characteristics 1.0 60 2.0 2.5 T J =25°C 100 10 T J=25°C f = 1.0MHz V sig = 50mV p-p 1 0.1 Instaneous Forward Voltage (V) 1.0 10 100 Reverse Voltage (V) Peak Forward Surage Current (A) Fig.6 Maximum Non-Repetitive Peak Forward Surage Current 126 105 84 63 42 21 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles Revision:20181018-P2 ht t p : // www.lgesem i .c o m mail:lge@lgesemi.com
很抱歉,暂时无法提供与“ES8J”相匹配的价格&库存,您可以联系我们找货
