TAI-TECH
KBM01-180900409 P2.
High Current Ferrite Chip Bead(Lead Free)
HCB2012KF-471T20
1.Features
1. Monolithic inorganic material construction.
2. Closed magnetic circuit avoids crosstalk.
Halogen
3. Suitable for reflow soldering.
4. Shapes and dimensions follow E.I.A. spec.
Halogen-free
5. Available in various sizes.
6. Excellent solder ability and heat resistance.
7. High reliability.
8. 100% Lead(Pb) & Halogen-Free and RoHS compliant.
9. Low DC resistance structure of electrode to prevent wasteful electric power consumption.
Pb
Pb-free
2.Dimensions
Chip Size
A
2.00±0.20
B
1.25±0.20
C
0.85±0.20
D
0.50±0.30
Units: mm
3.Part Numbering
HCB
2012
KF
A
B
C
A: Series
B: Dimension
C: Material
D: Impedance
E: Packaging
F: Rated Current
471
T
D
E
F
LxW
Lead Free Material
471=470Ω
T=Taping and Reel, B=Bulk(Bags)
20=2000 mA
4.Specification
Tai-Tech
Part Number
Impedance (Ω)
HCB2012KF-471T20
DC Resistance
(Ω) max.
Rated Current
(mA) max.
60mV/100M
0.10
2000
470±25%
Rated current: based on temperature rise test
In compliance with EIA 595
Impedance-Frequency Characteristics
HCB2012KF-471T20
800
IMPEDANCE(Ohm)
Test Frequency
(Hz)
600
Z
400
200
X
R
10
100
FREQUENCY(MHz)
www.tai-tech.com.tw
1000
TAI-TECH
KBM01-180900409 P3.
5. Reliability and Test Condition
Item
Series No.
Operating Temperature
Performance
FCB
FCM
HCB
Test Condition
GHB
FCA
-55~+125℃
(Including self-temperature rise)
-55~+125℃
(on board)
Transportation
Storage Temperature
For long storage conditions, please see the
Application Notice
Agilent4291
Agilent E4991
Impedance (Z)
Agilent4287
Refer to standard electrical characteristics list
Agilent16192
DC Resistance
Agilent 4338
Rated Current
DC Power Supply
Over Rated Current requirements, there will be
some risk
Temperature Rise Test
1. Applied the allowed DC current.
2. Temperature measured by digital surface
thermometer.
Rated Current < 1A ΔT 20℃Max
Rated Current ≧ 1A ΔT 40℃Max
Life test
Appearance: no damage.
Impedance: within±15%of initial value.
Inductance: within±10%of initial value.
Q:Shall not exceed the specification value.
RDC:within ±15% of initial value and shall not exceed the specification value
Load Humidity
Thermal shock
Preconditioning: Run through IR reflow for 2
times.( IPC/JEDEC J-STD-020D Classification
Reflow Profiles)
Temperature: 125±2℃
Applied current: rated current.
Duration: 1000±12hrs.
Measured at room temperature after placing
for 24±2 hrs.
Reflow Profiles)
Humidity: 85±2%R.H.
Temperature: 85±2℃.
Duration: 1000hrs Min. with 100% rated
current.
for 24±2 hrs.
Reflow Profiles)
Condition for 1 cycle
Step1: -55±2℃
30±5 min.
Step2: 25±2℃
≦0.5min
Step3: +125±2℃
30±5min.
Number of cycles: 500
for 24±2 hrs.
Appearance:No damage.
Impedance:within±15% of initial value
Inductance:within±10% of initial value
Reflow Profiles)
Oscillation Frequency: 10~2K~10Hz for 20
minutes
Equipment: Vibration checker
Total Amplitude:1.52mm±10%
Testing Time : 12 hours(20 minutes, 12 cycles
each of 3 orientations)。
Bending
Impedance:within±10% of initial value
Shall be mounted on a FR4 substrate of the
following dimensions:
>=0805inch(2012mm):40x100x1.2mm
=0805inch(2012mm):1.2mm
0805inch(2012mm):1kg
很抱歉,暂时无法提供与“HCB2012KF-471T20”相匹配的价格&库存,您可以联系我们找货
