TAI-TECH
KBM01-230900129 P2.
High Current Ferrite Chip Bead(Lead Free)
1.Features
HCB2012KF-SERIES
Halogen
1. Monolithic inorganic material construction.
Halogen-free
2. Closed magnetic circuit avoids crosstalk.
3. Suitable for reflow soldering.
4. Shapes and dimensions follow E.I.A. spec.
5. Available in various sizes.
6. Excellent solder ability and heat resistance.
7. High reliability.
8. 100% Lead(Pb) & Halogen-Free and RoHS compliant.
9. Low DC resistance structure of electrode to prevent wasteful electric power consumption.
10. Operating Temperature: -55~+125℃(Including self-temperature rise)
2.Dimensions
Chip Size
A
2.00±0.20
B
1.25±0.20
C
0.85±0.20
D
0.50±0.30
Units: mm
3.Part Numbering
HCB
2012
KF
A
B
C
A: Series
B: Dimension
C: Material
D: Impedance
E: Packaging
F: Rated Current
301
T
10
D
E
F
LxW
Lead Free Material
301=300Ω
T=Taping and Reel, B=Bulk(Bags)
10=1000mA
4.Specification
Tai-Tech
Part Number
Impedance (Ω)
Test Frequency
(MHz)
DC Resistance
(Ω) max.
Rated Current
(mA) max.
HCB2012KF-070T50
7±25%
100
0.02
5000
HCB2012KF-100T60
10±25%
100
0.01
6000
4000
HCB2012KF-190T40
19±25%
100
0.03
HCB2012KF-220T60
22±25%
100
0.01
6000
6000
HCB2012KF-300T60
30±25%
100
0.01
HCB2012KF-400T50
40±25%
100
0.02
5000
6000
HCB2012KF-600T60
60±25%
100
0.02
HCB2012KF-700T30
70±25%
100
0.04
3000
HCB2012KF-700T40
70±25%
100
0.03
4000
6000
HCB2012KF-800T60
80±25%
100
0.01
HCB2012KF-101T50
100±25%
100
0.02
5000
5000
HCB2012KF-121T50
120±25%
100
0.02
HCB2012KF-221T20
220±25%
100
0.10
2000
100
0.20
1000
HCB2012KF-301T10
300±25%
www.tai-tech.com.tw
TAI-TECH
Tai-Tech
Part Number
KBM01-230900129 P3.
Impedance (Ω)
Test Frequency
(MHz)
DC Resistance
(Ω) max.
Rated Current
(mA) max.
HCB2012KF-301T40
300±25%
100
0.03
4000
HCB2012KF-331T25
330±25%
100
0.05
2500
3000
3000
HCB2012KF-331T30
330±25%
100
0.04
HCB2012KF-401T30
400±25%
100
0.04
www.tai-tech.com.tw
TAI-TECH
KBM01-230900129 P4.
5. Reliability and Test Condition
Item
Series No.
Performance
FCB
FCM
HCB
Test Condition
GHB
FCA
-55~+125℃
-55~+125℃
(on board)
Transportation
Storage Temperature
--For long storage conditions, please see the
Application Notice
Agilent4291
Agilent E4991
Impedance (Z)
Agilent4287
Refer to standard electrical characteristics list
Agilent16192
DC Resistance
Agilent 4338
Rated Current
DC Power Supply
Over Rated Current requirements, there will be
some risk
Temperature Rise Test
Rated Current < 1A ΔT 20℃Max
Rated Current ≧ 1A ΔT 40℃Max
Life test
Appearance: no damage.
Impedance: within±15%of initial value.
RDC:within ±15% of initial value and shall not exceed the specification value
Load Humidity
Thermal shock
Vibration
Bending
1. Applied the allowed DC current.
2. Temperature measured by digital surface
thermometer.
Preconditioning: Run through reflow for 3
times.( IPC/JEDEC J-STD-020E Classification
Reflow Profiles)
Temperature: 125±2℃
Applied current: rated current.
Duration: 1000±12hrs.
Measured at room temperature after placing
for 24±2 hrs.
Reflow Profiles)
Humidity: 85±2%R.H.
Temperature: 85±2℃.
Duration:1000hrsMin.Bead:with100%ratedcurr
ent , Inductance: with 10% rated current
for 24±2 hrs.
Reflow Profiles)
Condition for 1 cycle
Step1: -55±2℃
30±5 min.
Step2: 125±2℃
≦0.5min
Step3: 125±2℃
30±5min.
Number of cycles: 500
for 24±2 hrs.
Appearance:No damage.
Impedance:within±15% of initial value
Reflow Profiles)
Oscillation Frequency: 10Hz ~ 2KHz ~ 10Hz
for 20 minutes
Equipment: Vibration checker
Total Amplitude:10g
Testing Time : 12 hours(20 minutes, 12 cycles
each of 3 orientations)。
Impedance:within±10% of initial value
Shall be mounted on a FR4 substrate of the
following dimensions:
>=0805inch(2012mm):40x100x1.2mm
=0805inch(2012mm):1.2mm
0805inch(2012mm):1kg
很抱歉,暂时无法提供与“HCB2012KF-100T60”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+0.04817
- 1000+0.03737
- 4000+0.03143
