TAI-TECH
KBM01-230400059
High Current Ferrite Chip Bead(Lead Free)
1.Features
P2.
HCB2012KF-400T30
Halogen
1. Monolithic inorganic material construction.
Halogen-free
2. Closed magnetic circuit avoids crosstalk.
3. Suitable for reflow soldering.
4. Shapes and dimensions follow E.I.A. spec.
5. Available in various sizes.
6. Excellent solder ability and heat resistance.
7. High reliability.
8. 100% Lead(Pb) & Halogen-Free and RoHS compliant.
9. Low DC resistance structure of electrode to prevent wasteful electric power consumption.
10. Operating Temperature:-55~+125℃(Including self-temperature rise)
2.Dimensions
Chip Size
A
2.00±0.20
B
1.25±0.20
C
0.85±0.20
D
0.50±0.30
Units: mm
3.Part Numbering
HCB
2012
KF
A
B
C
A: Series
B: Dimension
C: Material
D: Impedance
E: Packaging
F: Rated Current
400
T
30
D
E
F
LxW
Lead Free Material
400=40Ω
T=Taping and Reel, B=Bulk(Bags)
30=3000 mA
4.Specification
Impedance (Ω)
Test Frequency
(Hz)
DC Resistance
(Ω) max.
Rated Current
(mA) max.
HCB2012KF-400T30
40±25%
60mV/100M
0.04
3000
Rated current: based on temperature rise test
In compliance with EIA 595
Impedance-Frequency Characteristics
HCB2012KF-400T30
80
IMPEDANCE(Ohm)
Tai-Tech
Part Number
60
Z
40
X
R
10
100
FREQUENCY(MHz)
www.tai-tech.com.tw
1000
TAI-TECH
KBM01-230400059
P3.
5. Reliability and Test Condition
Item
Series No.
Performance
FCB
FCM
HCB
Test Condition
GHB
FCA
-55~+125℃
-55~+125℃
(on board)
Transportation
Storage Temperature
--For long storage conditions, please see the
Application Notice
Agilent4291
Agilent E4991
Impedance (Z)
Agilent4287
Refer to standard electrical characteristics list
Agilent16192
DC Resistance
Agilent 4338
Rated Current
DC Power Supply
Over Rated Current requirements, there will be
some risk
Temperature Rise Test
Rated Current < 1A ∆T 20℃Max
Rated Current ≧ 1A ∆T 40℃Max
Life test
Appearance: no damage.
Impedance: within±15%of initial value.
RDC:within ±15% of initial value and shall not exceed the specification value
Load Humidity
Thermal shock
Vibration
Bending
1. Applied the allowed DC current.
2. Temperature measured by digital surface
thermometer.
Preconditioning: Run through reflow for 3
times.( IPC/JEDEC J-STD-020E Classification
Reflow Profiles)
Temperature: 125±2℃
Applied current: rated current.
Duration: 1000±12hrs.
Measured at room temperature after placing
for 24±2 hrs.
Reflow Profiles)
Humidity: 85±2%R.H.
Temperature: 85±2℃.
Duration:1000hrsMin.Bead:with100%ratedcurr
ent , Inductance: with 10% rated current
for 24±2 hrs.
Reflow Profiles)
Condition for 1 cycle
Step1: -55±2℃
30±5 min.
Step2: 125±2℃
≦0.5min
Step3: 125±2℃
30±5min.
Number of cycles: 500
for 24±2 hrs.
Appearance:No damage.
Impedance:within±15% of initial value
Reflow Profiles)
Oscillation Frequency: 10Hz ~ 2KHz ~ 10Hz
for 20 minutes
Equipment: Vibration checker
Total Amplitude:10g
Testing Time : 12 hours(20 minutes, 12 cycles
each of 3 orientations)。
Impedance:within±10% of initial value
Shall be mounted on a FR4 substrate of the
following dimensions:
>=0805inch(2012mm):40x100x1.2mm
=0805inch(2012mm):1.2mm
0805inch(2012mm):1kg
很抱歉,暂时无法提供与“HCB2012KF-400T30”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+0.04040
- 1000+0.03132
- 4000+0.02636
