To-220-35W-100R-5%
To-220-35W-100R-5%
    MILLIOHM(毫欧)
    TO-220
    100Ω ±5% 35W
To-220-35W-100R-5% 数据手册
TO-220 系列号 大功率电阻系列规格书 修订日期 2022-02-18 版本号 Ho-A2 TO-220(20W) ■Features ■Construction -20 Watts at 25°C case temperature heat sink mounted -TO-220 style power package -Molded case for protection and easy to mount -Electrically isolated case -Non-Inductive design ■Applications -Switching Power Supplies -Snubbers Circuits -Automated Machine Controller -RF Power Amplifiers. -Low Energy Pulse Loading -UPS -Voltage Regulation  Copper Lead  Radiator Fin  Alumina Substrate  Molding  Resistor Layer ■Dimensions W H H1 B B1 D D1 10.16 15.23 2.9 13.5 Max 1.26 0.78 ±0.25 ±0.3 ±0.25 ±0.8 4 ±0.1 ±0.08 型號 PRT20 (Unit: mm) L C T T1 H2 P 3.83 5.08 4.6 1.3 6.25 0.51 2.27 ±0.3 ±0.25 ±0.2 ±0.1 ±0.35 ±0.15 ±0.25 ■Part Numbering T0 产品类别 大功率电阻 220 封装 220 20W 功率 20W 120R 5% ±50PPM 阻值 精度 温度系数 R100: 0.1Ω 0100: 10Ω 4700: 470Ω D=±0.5% 1001: 1000Ω 1002: 10000Ω F=±1% J=±5% K: ±10% D: ±50 E: ±100 F: ±200 G: ±300 -:未设定 地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A 栋 8 楼 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn P1 系列号 大功率电阻系列规格书 TO-220 修订日期 2022-02-16 版本号 Ho-A2 TO-220(20W) ■Electrical Characteristics Specifications Resistance Range ±0.5% TCR (PPM/°C) ±1% ±5% - >0.1Ω - 1Ω - - >1Ω - 3Ω ±100、±200 ±100、±200 ±100、±200 >3Ω - 10Ω >10Ω - 10KΩ      ±10% - 0.05Ω - 0.1Ω ±50 ±100 ±200 ±100 ±200 ±50 ±100 ±200 ±100 ±200 ±50 ±100 ±200 ■Derating Curve ±100 ±200 ±50 ±100 ±200 Operating Voltage: 350V max. Dielectric Strength: 1800VAC Insulation Resistance: 10GΩ min. Working Temperature Range: -65°C to +150°C Resistance Value< 1Ω is available ■ Environmental Characteristics Test Item Requirement Test Method Temperature Coefficient of Resistance (T.C.R.) As Spec. Referenced to 25°C, ∆R taken at +105°C Short Time Overload ∆R±0.3% 2 times rated power with applied voltage not to exceed 1.5 times Maximum continuous operating voltage for 5 seconds Load Life ∆R±1.0% 2,000 hours at rated power Damp Heat with Load ∆R±0.5% 40±2°C, 90~95% R.H. Max. working voltage for 1000 hrs with 1.5 hrs “ON” and 0.5 hrs “OFF” Solderability 90% min. coverage 245±5°C for 3 seconds Thermal Shock ∆R±0.3% -65°C~150°C, 100 cycles Terminal Strength ∆R±0.2% (Pull Test) 2.4N Vibration, High Frequency ∆R±0.2% 20g peak Lead Material: Tinned Copper Without a Heat Sink When in Free Air at 25°C, the TR20 is Rated for 2.25W The Case Temperature is to be used for the Definition of the Applied Power Limit The Case Temperature Measurement must be made with a Thermocouple Contacting the Center of the Component mounted on the Designed Heat Sink.  Thermal Grease should be Applied Properly      地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A 栋 8 楼 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn TO-220 系列号 大功率电阻系列规格书 修订日期 2022-01-21 版本号 Ho-A2 TO-220(30W) ■Features ■Construction -30 Watts at 25°C case temperature heat sink mounted -TO-220 style power package -Molded case for protection and easy to mount -Electrically isolated case -Non-Inductive design ■Applications -Switching Power Supplies -Snubbers Circuits -Automated Machine Controller -RF Power Amplifiers. -Low Energy Pulse Loading -UPS -Voltage Regulation  Copper Lead  Radiator Fin  Alumina Substrate  Molding  Resistor Layer ■Dimensions W H H1 B B1 D D1 10.16 15.23 2.9 13.5 Max 1.26 0.78 ±0.25 ±0.3 ±0.25 ±0.8 4 ±0.1 ±0.08 型號 PRT30 (Unit: mm) L C T T1 H2 P 3.83 5.08 4.6 1.3 6.25 0.51 2.27 ±0.3 ±0.25 ±0.2 ±0.1 ±0.35 ±0.15 ±0.25 ■Part Numbering T0 产品类别 大功率电阻 220 封装 220 30W 功率 30W 120R 5% ±50PPM 阻值 精度 温度系数 R100: 0.1Ω 0100: 10Ω 4700: 470Ω D=±0.5% 1001: 1000Ω 1002: 10000Ω F=±1% J=±5% K: ±10% D: ±50 E: ±100 F: ±200 G: ±300 -:未设定 地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A 栋 8 楼 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn P1 系列号 大功率电阻系列规格书 TO-220 修订日期 2022-02-18 版本号 Ho-A2 TO-220(30W) ■Electrical Characteristics Specifications Resistance Range ±0.5% ±10% 0.05Ω - 0.1Ω - - >0.1Ω - 1Ω - - >1Ω - 3Ω ±100、±200 ±100、±200 ±100、±200 >3Ω - 10Ω >10Ω - 10KΩ      TCR (PPM/°C) ±1% ±5% ■Derating Curve ±50 ±100 ±200 ±100 ±200 ±50 ±100 ±200 ±100 ±200 ±50 ±100 ±200 ±100 ±200 ±50 ±100 ±200 Operating Voltage: 350V max. Dielectric Strength: 1500VAC Insulation Resistance: 10GΩ m  in. Working Temperature Range: -65°C to +150°C Resistance Value < 1Ω is available ■Environmental Characteristics Item Requirement Test Method Temperature Coefficient of Resistance (T.C.R.) As Spec. Referenced to 25°C, ∆R taken at +105°C Short Time Overload ∆R±0.3% 2 times rated power with applied voltage not to exceed 1.5 times maximum continuous operating voltage for 5 seconds Load Life ∆R±1.0% 2,000 hours at rated power Damp Heat with Load ∆R±0.5% 40±2°C, 90~95% R.H. Max. working voltage for 1000 hrs with 1.5 hrs “ON” and 0.5 hrs “OFF” Solderability 90% min. coverage 245±5°C for 3 seconds Thermal Shock ∆R±0.3% -65°C~150°C, 100 cycles Terminal Strength ∆R±0.2% (Pull Test) 2.4N Vibration, High Frequency ∆R±0.2% 20g peak Lead Material: Tinned Copper Maximum Torque: 0.9 N-m When in Free Air at 25°C, the TR30 is Rated for 2.25W The Case Temperature is to be used for the Definition of the Applied Power Limit The Case Temperature Measurement must be made with a Thermocouple Contacting the Center of the Component mounted on the Designed Heat Sink.  Thermal Grease should be Applied Properly      地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A 栋 8 楼 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 系列号 大功率电阻系列规格书 TO-220 修订日期 2022-02-18 版本号 Ho-A2 TO-220(35W) ■Features ■Construction -35 Watts at 25°C case temperature heat sink mounted -TO-220 style power package -Molded case for protection and easy to mount -Electrically isolated case -Non-Inductive design ■Applications -Switching Power Supplies -Snubbers Circuits -Automated Machine Controller -RF Power Amplifiers. -Low Energy Pulse Loading -UPS -Voltage Regulation  Copper Lead  Radiator Fin  Alumina Substrate  Molding  Resistor Layer ■Dimensions W H 10.16 15.23 ±0.25 ±0.3 型號 PRT35 (Unit: mm) H1 L T C B1 2.9 13.5 Max 1.26 0.78 3.83 5.08 4.6 1.3 6.25 0.51 2.27 ±0.25 ±0.8 4 ±0.1 ±0.08 ±0.3 ±0.25 ±0.2 ±0.1 ±0.35 ±0.15 ±0.25 D D1 T1 H2 P ■Part Numbering T0 产品类别 大功率电阻 220 封装 220 P1 B 35W 功率 35W 120R 5% ±50PPM 阻值 精度 温度系数 R100: 0.1Ω 0100: 10Ω 4700: 470Ω D=±0.5% 1001: 1000Ω 1002: 10000Ω F=±1% J=±5% K: ±10% D: ±50 E: ±100 F: ±200 G: ±300 -:未设定 地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A 栋 8 楼 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 系列号 大功率电阻系列规格书 TO-220 修订日期 2022-01-21 版本号 Ho-A2 TO-220(35W) ■Electrical Characteristics Specifications Resistance Range ±0.5% - - >0.1Ω - 1Ω - - >1Ω - 3Ω ±100、±200 ±100、±200 ±100、±200 >10Ω - 10KΩ ±50 ±100 ±200 ±100 ±200 ±50 ±100 ±200 ±100 ±200 ±50 ±100 ±200 ■Derating Curve ±10% 0.05Ω - 0.1Ω >3Ω - 10Ω      TCR (PPM/°C) ±1% ±5% ±100 ±200 ±50 ±100 ±200 Operating Voltage: 350V Max. Dielectric Strength: 1800VAC Insulation Resistance: 10GΩ min. Working Temperature Range: -65°C to +150°C Resistance Value < 1Ω is available ■Environmental Characteristics Item Requirement Test Method Temperature Coefficient of Resistance (T.C.R.) As Spec. Referenced to 25°C, ∆R taken at +105°C Short Time Overload ∆R±0.3% 2 times rated power with applied voltage not to exceed 1.5 times maximum continuous operating voltage for 5 seconds Load Life ∆R±1.0% 2,000 hours at rated power Damp Heat with Load ∆R±0.5% 40±2°C, 90~95% R.H. Max. working voltage for 1000 hrs with 1.5 hrs “ON” and 0.5 hrs “OFF” Solderability 90% min. coverage 245±5°C for 3 seconds Thermal Shock ∆R±0.3% -65°C~150°C, 100 cycles Terminal Strength ∆R±0.2% (Pull Test) 2.4N Vibration, High Frequency ∆R±0.2% 20g peak Lead Material: Tinned Copper Maximum Torque: 0.9 N-m Without a Heat Sink, When in Free Air at 25°C, the TR35 is Rated for 2.50W The Case Temperature is to be used for the Definition of the Applied Power Limit The Case Temperature Measurement must be made with a Thermocouple Contacting the Center of the Component mounted on the Designed Heat Sink.  Thermal Grease should be Applied Properly.      地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A 栋 8 楼 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 系列号 大功率电阻系列规格书 TO-220 修订日期 2022-02-18 版本号 Ho-A2 TO-220(50W) ■Features ■Construction -50 Watts at 25°C case temperature heat sink mounted -TO-220 style power package -Molded case for protection and easy to mount -Electrically isolated case -Non-Inductive design ■Applications -Switching Power Supplies -Snubbers Circuits -Automated Machine Controller -RF Power Amplifiers. -Low Energy Pulse Loading -UPS -Voltage Regulation  Copper Lead  Radiator Fin  Alumina Substrate  Molding  Resistor Layer ■Dimensions W H 10.16 15.23 ±0.25 ±0.3 型號 PRT50 (Unit: mm) H1 L T C B1 2.9 13.5 Max 1.26 0.78 3.83 5.08 4.6 1.3 6.25 0.51 2.27 ±0.25 ±0.8 4 ±0.1 ±0.08 ±0.3 ±0.25 ±0.2 ±0.1 ±0.35 ±0.15 ±0.25 D D1 T1 H2 P ■Part Numbering T0 产品类别 大功率电阻 220 封装 220 P1 B 50W 功率 50W 120R 5% ±50PPM 阻值 精度 温度系数 R100: 0.1Ω 0100: 10Ω 4700: 470Ω D=±0.5% 1001: 1000Ω 1002: 10000Ω F=±1% J=±5% K: ±10% D: ±50 E: ±100 F: ±200 G: ±300 -:未设定 地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A 栋 8 楼 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 系列号 大功率电阻系列规格书 TO-220 修订日期 2022-02-18 版本号 Ho-A2 TO-220(50W) ■Electrical Characteristics Specifications Resistance Range ±0.5% ■Derating Curve ±10% 0.05Ω - 0.1Ω - - >0.1Ω - 1Ω - - >1Ω - 3Ω ±100、±200 ±100、±200 ±100、±200 >3Ω - 10Ω >10Ω - 10KΩ      TCR (PPM/°C) ±1% ±5% ±50 ±100 ±200 ±100 ±200 ±50 ±100 ±200 ±100 ±200 ±50 ±100 ±200 ±100 ±200 ±50 ±100 ±200 Operating Voltage: 350V Max. Dielectric Strength: 1800VAC Insulation Resistance: 10GΩ min. Working Temperature Range: -65°C to +150°C Resistance Value < 1Ω is available ■Environmental Characteristics Item Requirement Test Method Temperature Coefficient of Resistance (T.C.R.) As Spec. Referenced to 25°C, ∆R taken at +105°C Short Time Overload ∆R±0.3% 2 times rated power with applied voltage not to exceed 1.5 times maximum continuous operating voltage for 5 seconds Load Life ∆R±1.0% 2,000 hours at rated power Damp Heat with Load ∆R±0.5% 40±2°C, 90~95% R.H. Max. working voltage for 1000 hrs with 1.5 hrs “ON” and 0.5 hrs “OFF” Solderability 90% min. coverage 245±5°C for 3 seconds Thermal Shock ∆R±0.3% -65°C~150°C, 100 cycles Terminal Strength ∆R±0.2% (Pull Test) 2.4N Vibration, High Frequency ∆R±0.2% 20g peak Lead Material: Tinned Copper Maximum Torque: 0.9 N-m Without a Heat Sink, When in Free Air at 25°C, the TR50 is Rated for 3W. The Case Temperature is to be used for the Definition of the Applied Power Limit. The Case Temperature Measurement must be made with a Thermocouple Contacting the Center of the Component mounted on the Designed Heat Sink.  Thermal Grease should be Applied Properly.      地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A 栋 8 楼 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 系列号 TO-247大功率电阻系列规格书 TO-247 修订日期 2022-02-18 版本号 Ho-A2 TO-247(100W) ■Construction 1 Alumina Substrate 2 Resistor Layer 3 Lead 4 Molding ■Features ■Dimensions Type Weight (g) (1000pcs) TR100 3381 (15.49~16.01) (3.53~3.73) ■Applications -Gate Resistors in Power Supplies -Snubbers -Load and Dumping Resistors in CRT Monitors -Terminal Resistance in RF Power Amplifier -Voltage Regulation -Low Energy Pulse Loading -UPS 大功率电阻 - : No Specified 15R 1002: 10000Ω 247 100W 封装 功率 阻值 精度 D=±0.5% 100W R100: 0.1Ω 0100: 10Ω 4700: 470Ω 247 1001: 1000Ω 1002: 10000Ω 5% F=±1% J=±5% K: ±10% ±50PPM 温度系数 D: ±50 E: ±100 F: ±200 G: ±300 (13.21~15.75) (2.03~3.55) (9.9~10.42) ■Part Numbering 产品类别 (4.69~5.21) (3.45~3.81) (1.42~1.62) T0 (5.07~5.59) Unit: mm (20.44~20.96) -100 Watts at 25°C case temperature heat sink mounted -TO-247 style power package -Single M3 screw mounting to heat sink -Molded case for protection and easy to mount -Electrically isolated case -Non-Inductive design (0.55~1.07) (2.15~2.67) 系列号 TO-247大功率电阻系列规格书 TO-247 修订日期 2022-02-18 版本号 Ho-A2 TO-247(100W) ■Electrical Characteristics Specifications Resistance Range ±1% 0.05Ω - 1Ω >1Ω - 3Ω ±10% - - ±100 ±200 ±50 ±100 ±200 ±100 ±200 ±50 ±100 ±200 ■Derating Curve ±300 >3Ω - 10Ω >10Ω - 10KΩ     TCR (PPM/°°C) ±5% ±100 ±200 ±50 ±100 ±200 Operating Voltage: 350V Max. Dielectric Strength: 1800V AC Insulation Resistance: 10GΩ min. Working Temperature Range: -65°C to +175°C ■Environmental Characteristics Item Requirement Test Method Temperature Coefficient of Resistance (T.C.R.) As Spec. Referenced to 25°C, ∆R taken at +105°C Load Life ∆R±1.0% Rated power, 2,000 hours Solderability 90% min. coverage 245±5°C for 3 seconds Momentary Overload ∆R±0.5% 1.5 times rated power and V (dc) ≦ 1.5V Max. for 5 seconds Dielectric strength ∆R±0.15% 1800v AC, 60 seconds Moisture resistance ∆R±0.5% -10°C~+65°C, RH>90%, cycle 240 hours Thermal Shock ∆R±0.5% -65°C~150°C, 100 cycles Terminal Strength ∆R±0.2% (Pull Test) 2.4N Vibration, High Frequency ∆R±0.4% 20g peak Lead Material: Tinned Copper When in Free Air at 25°C, the TR100 is Rated for 3.5W The Case Temperature is to be used for the Definition of the Applied Power Limit The Case Temperature Measurement must be made with a Thermocouple Contacting the Center of the Component mounted on the Designed Heat Sink  Thermal Grease should be Applied Properly.     HoNP100 平面无感功率电阻 TO-247 封 装,厚膜和薄膜技术,符合AEC-Q200 认证功率可达 140W, 热阻 0.9℃/W, 极好的频率特性 使用厚膜和薄膜两种电阻技术的 TO-247封装功率电阻 HoNP100系 相比较厚膜电阻技术,薄膜电阻可以提供更好的温飘和精度。 列产品在10R-51KΩ的阻值范围内使用金属化薄膜电阻技术,不仅可以实现 高达140W的功率,而且可以提供50ppm的温飘和1% 的阻值精度。本系列 在0.02-510K Ω的阻值范围内也可以提供标准厚膜电阻技术。 规格和参数 系列 功率 阻值范围 阻值标准 温飘 可选精度 电阻技术 热阻 绝缘电压 频率特性 最大工作 电流 工作温度 并联电容 HoNP100H 140W 0.05-0.091 E12 ±250ppm ±5% 厚膜 0.9℃/W 2000VAC 25A -55~+155℃ HoNP100A 140W 0.1-9.9R E24 ±100ppm ±1%,±5% 厚膜 0.9℃/W 2000VAC 25A HoNP100C 140W 10-51K E24 ±50ppm ±1% 薄膜 0.9℃/W 2000VAC 25A 额定功率 (%) 3.55* 20.0 5.1 120 120 80 100 14.5 13nH HoNP100AJ1R50S 60 20 40 +175℃ 0 -50 0 50 100 150 20 0 200 0 法兰温度( ℃ ) 16.0 13nH 4.5pF 80 40 3.63 4.5pF -55~+155℃ 140 +25℃ 100 0.8 -55~+155℃ 160 60 10.9 13nH 温升 (℃) 140 20 40 60 80 功率 (W) 4.8 脉冲功率 (W) 引脚,铜镀锡 环氧模压, UL94-V0 铜导体 电阻, 镍铬或氧化钌 基板, 氧化铝 法兰,铜镀镍 HoNP100CF10R0S 100k 连续脉冲功率允许占空比 0.01 基于不同的阻值,负载,重复次数,工作温度, 寿命试验需要根据实际情况来确定 10k 串联电感 4.5pF 100 阻值 (Ohms) 1K 100 1350W 10 140W 10 10n 1 100n 1u 10u 100u 1m 10m 100m 脉冲宽度 (秒) 1 10 10k 100k 1M 10M 100M 频率 (Hz) 选型表 选型示例:HoNP100CF10R0S (RNP100C, ±50ppm/℃, 10R, ±1% 标准 品) o N P 140 1k 100 H 120 1 0 系列号 精度 HoNP100H HoNP100A HoNP100C F=±1% J=±5% 0 C F 1 阻值编码 R020=0.02R 10R0=10R 1001=1K 1003=100K 1R00=1R 1000=100R 1002=10K 5103=510K 0 R 0 定制编码 S=标准品 A-Z=识别码 S 1G 修改履历表: 序号 修改内容 修改日期 修改原因 1 修改20W、30W、35W、50W的外观 2022-01-13 更新 2 修改20W、30W、35W、50W的尺寸 2022-02-18 更新
To-220-35W-100R-5% 价格&库存
很抱歉,暂时无法提供与“To-220-35W-100R-5%”相匹配的价格&库存,您可以联系我们找货
