40N06
40N06
    UMW(友台)
    TO-252(DPAK)
40N06 数据手册
UMW R UMW 40N06 60V N-Channel Enhancement Mode Power MOSFET UMW 40N06 General Description The 40N06 uses advanced trench technology and design to provide excellent R DS(ON) wi th low gate charge. It can be used in a wide variety of applications. Features VDS = 60V,ID =40A RDS(ON),14mΩ(Typ) @ VGS =10V RDS(ON),16mΩ(Typ) @ VGS =4.5V Advanced Trench Technology Excellent RDS(ON) and Low Gate Charge Lead free product is acquired Application Load Switch PWM Application Power management Package Marking and Ordering Information Device Marking 40N06 Device Device Package Reel Size Tape width Quantity 40N06 TO-252 330mm 12mm 2500 Absolute Maximum Ratings(TA=25℃ unless otherwise noted) Parameter Symbol Value Unit Drain-Source Voltage VDS 60 V Gate-Source Voltage VGS ±20 V 50 A 33 A Drain Current-ContinuousNote3 TC=25℃ TC=100℃ ID Drain Current-Pulsed IDM 200 A Avalanche Energy EAS 64 mJ PD 105 W TSTG -55 to +150 ℃ TJ -55 to +150 ℃ Note1 Note4 Maximum Power Dissipation TC=25℃ Storage Temperature Range Operating Junction Temperature Range Thermal Resistance Parameter Symbol Min. Typ. Max Unit RθJC - - 1.4 ℃/W Thermal Resistance,Junction-to-Case www.umw-ic.com 1 友台半导体有限公司 UMW R UMW 40N06 Electrical Characteristics(TJ=25℃ unless otherwise noted) OFF CHARACTERISTICS Parameter Symbol Conditions Min. Typ. Max. Unit Drain-Source Breakdown Voltage BVDSS VGS=0V,IDS=250uA 60 - - V Zero Gate Voltage Drain Current IDSS VDS=60V,VGS=0V - - 1.0 uA Gate-Body Leakage IGSS VGS=±20V,VDS=0V - - ±100 nA Symbol Conditions Min. Typ. Max. Unit Gate Threshold Voltage VGS(TH) VDS=VGS,IDS=250uA 1.0 1.6 2.5 V Drain-Source On-State Resistance RDS(ON) VGS=10V,IDS=30A - 14 18 mΩ VGS=4.5V,IDS=20A - 16 22 mΩ Conditions Min. Typ. Max. Unit - 2928 - - 141 - - 120 - Min. Typ. Max. - 7.5 - - 6.0 - - 28.4 - - 5.5 - - 50 - - 6 - - 15 - ON CHARACTERISTICS Parameter DYNAMIC CHARACTERISTICS Parameter Symbol Input Capacitance CiSS Output Capacitance COSS Reverse Transfer Capacitance Crss VDS =25V, VGS = 0V, f=1MHz pF SWITCHING CHARACTERISTICS Parameter Turn-On Delay Time Rise Time Symbol Td(on) tr Turn-Off Delay Time Fall Time Conditions VGS=10V,VDs=30V, RGEN=1.8Ω Td(off) ID=25A tf Total Gate Charge at 10V Qg Gate to Source Gate Charge Qgs Gate to Drain“Miller”Charge Qgd VDS=30V,IDS=25A, VGS=10V Unit ns nC DRAIN-SOURCE DIODE CHARACTERISTICS AND MAXIMUM RATINGS Parameter Symbol Conditions Min. Typ. Max. Unit VSD VGS=0V,IDS=30A - - 1.2 V Reverse Recovery Time trr TJ=25℃,IF=25A - 29 - nS Reverse Recovery Charge Qrr di/dt=100A/us - 42 - nC Drain-Source Diode Forward Voltage Notes: 1: Repetitive rating, pulse width limited by maximum junction temperature. 2: Surface mounted on FR4 Board, t≤10sec. 3: Pulse width ≤ 300μs, duty cycle ≤ 2%. 4: EAS condition: L=0.5mH,VDD=10V,VG=10V,VGATE=20V,Start TJ=25℃. www.umw-ic.com 2 友台半导体有限公司 UMW R www.umw-ic.com UMW 40N06 3 友台半导体有限公司 UMW R www.umw-ic.com UMW 40N06 4 友台半导体有限公司 UMW R www.umw-ic.com UMW 40N06 5 友台半导体有限公司 UMW R www.umw-ic.com UMW 40N06 6 友台半导体有限公司
40N06 价格&库存
很抱歉,暂时无法提供与“40N06”相匹配的价格&库存,您可以联系我们找货
