承
认
SPECIFICATION FOR
书
APPROVAL
客户名称:Customer
货
HC-49SSMD 石英晶体谐振器
名:Description
客户料号:
Part No
物料编号:
Code No
49SAT25000201030JY
25.000MHz
频
率:Frequency
日
期:Date
备
注:RoHS compliance with Directive (EU) 2015/863
2020-06-09
制作(Prepare by)
检查(Check by)
批准(Approve by)
江丹娜
甘瑛
张刚
客户批准
Approve by customer
批准日期
Approval date
Add:广东省深圳市华发北路桑达工业区桑达雅苑 7P
7 P Sangda Yayuan Huafa North Road, Futian District, Shenzhen, Guangdong
Tel:
86-755-83048260
86-755-83048290
Fax: 86-755-83048280
www.jghcorp.com
ShenZhen JingGuangHua Electronics Co.,Ltd.
1、 Specifications
1
规格型号 Holder Type
HC-49SSMD
2
标称频率 Nominal Frequency
25.000MHz
3
振动模式 Mode of Oscillation
基频
4
调整频差 Frequency Tolerance at 25℃
±10ppm
5
温度频差 Temperature Frequency Stability
±30ppm
6
工作温度 Operating Temperature Range
-40~85℃
7
贮存温度 Storage Temperature Range
-40~90℃
8
负载电容 Load Capacitance
9
静电容
Shunt capacitance
≤7 pF
10
等效电阻 Equivalent Series Resistance
30Ω Max
11
激励功率 Drive Level
12
绝缘阻抗 Insulation Resistance
20pF
10uW
500MΩ min./DC100V
2、Frequency stability over temperature range (AT cut)
Temperature
Range
Frequency Stability
±30PPM
±50PPM
-40℃~+85℃
-40℃~+125℃
0℃~+50℃
±3PPM
±5PPM
±7.5PPM
±10PPM
-10℃~+60℃
-20℃~+70℃
-30℃~+70℃
www.jghcorp.com
±20PPM
±70PPM
3、Dimensions (unit:mm)
4、 Recommended Reflow profile
www.jghcorp.com
5、Reliability specifications
NO
Item
Condition
Free drop from 50cm height on a hard
1.
Drop Test
wooden board for 3 times. (Board is
thickness more than 30 mm.)
2.
Mechanical
Half sine wave, 1000G, 0.5mS, three
Shock
times for all 3 directions
Frequency range:10~55hz
3.
Vibration
Amplitude:1.52mm
Standard
Frequency change:
≤5ppm
Rr as specification
Frequency change:
≤5ppm
Rr as specification
Frequency change:
≤5ppm
Sweep time:1mintutes
perpendicular axes each test time:2Hrs
Rr as specification
Temperature:245℃±5℃
Immersing depth:0.5mm minimum
4.
Solderability
Immersion time:5±1sec.
90% exhibit tin ok
Flux:Rosin resin methyl alcohol
solvent(1:4)
5.
6.
7.
8.
9.
Resistance to
Test temperature:260℃±5℃
soldering heat
Test time :10±1sec.
High Temp
&Humidity
Low temperature
storage
High temperature
storage
≤10ppm
Rr as specification
Frequency change:
85±3℃& RH85%, 500±12 hours
≤10ppm
Rr as specification
Frequency change:
-40±3℃, 500±12 hours
≤10ppm
Rr as specification
Frequency change:
+85±3℃,500±12 hours
≤10ppm
Rr as specification
Temperature
-40±3℃/10min~+85±3℃/10min,
cycling
100cycles
www.jghcorp.com
Frequency change:
Frequency change:
≤10ppm
Rr as specification
6、Tape & Reel ( unit:mm )
www.jghcorp.com
7、Packing
1. 每 盘 数 量 Capacity of a plastic reel : 1000 PCS
2. 每内箱数量 Capacity per inner box : 1000 PCS (A reel inner)
3. 每大箱数量 Capacity per outer carton : 10000 PCS (10×inner box) .
www.jghcorp.com
很抱歉,暂时无法提供与“49SAT25000201030JY”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.70528
- 50+0.55753
- 150+0.48366
- 1000+0.42826
- 2000+0.38393
- 5000+0.36166
