RMS06JT154
RMS06JT154
    TA-I(大毅)
    厚膜电阻 150KΩ ±5% 100MW
RMS06JT154 数据手册
Anti-Sulfurated Thick Film Chip Resistors ( RMS series standard ) Halogen-Free AEC-Q200 qualified Document No. TRMS-XX0S001J Revise Date 2016/06/14 page number 1/13 1. Scope : This specification applies for the RMS series of Anti-Sulfurated thick film chip resistors made by TA-I. 2. Construction: Over Coat (Color : Black) Conductor Sn Plating Resistive Element Ni Plating Ceramic Substrate 3. Type Designation: RMS 10 J Product Code Size Tolerance RMS : Anti-Sulfurated T Packaging Power Rating 103 Nominal Resistance Chip Resistor 02-0201(0603) 1/20W J-±5% T-Paper Tape 04-0402(1005) 1/16W G-±2% E-Embossed Tape 06-0603(1608) 1/10W F-±1% 10-0805(2012) 1/8W D-0.5% 12-1206(3216) 1/4W 13-1210(3226) 1/3W 20-2010(5025) 1/2W 3 digits, e.g.,: (E-24) 103 = 10kΩ 0 = 0Ω 4 digits, e.g., : Special L : 06 – 2mm pitch (E-96) 1540 = 154Ω 43R2 = 43.2Ω paper Tape 25-2512(6432) 1 W TA-I TECHNOLOGY CO., LTD Anti-Sulfurated Thick Film Chip Resistors Document No. TRMS-XX0S001J ( RMS series standard ) Halogen-Free AEC-Q200 qualified Revise Date 2016/06/14 page number 2/13 4. Dimensions : UNIT: mm Type L W C d t RMS02 0.6 ±0.03 0.3 ±0.03 0.1 ±0.05 0.15 ±0.05 0.23 ±0.03 0.50±0.05 0.20±0.10 0.25±0.10 0.32±0.05 0.80±0.10 0.30±0.20 0.30 +0.1 RMS04 1.00 RMS06 1.60±0.10 RMS10 2.00±0.10 1.25±0.10 0.40±0.20 0.40±0.20 0.50±0.10 RMS12 3.10±0.10 1.55±0.10 0.50±0.30 0.40±0.20 0.55±0.10 RMS13 3.10±0.10 2.55±0.10 0.50±0.30 0.40±0.20 0.60±0.10 RMS20 5.00±0.15 2.50±0.15 0.60±0.30 0.50±0.25 0.60±0.10 RMS25 6.30±0.20 3.20±0.20 0.60±0.30 0.50±0.25 0.60±0.10 -0.05 +0.2 0.45±0.10 -0.1 TA-I TECHNOLOGY CO., LTD Anti-Sulfurated Thick Film Chip Resistors Document No. TRMS-XX0S001J ( RMS series standard ) Halogen-Free AEC-Q200 qualified Revise Date 2016/06/14 page number 3/13 5. Ratings & Characteristics : Resistance Range(Ω) Power Max. Max. Rating Rating Working Over- Load Voltage at 70℃ Voltage Voltage Type RMS02 1/20W Refer 5.2 T.C.R (PPM/℃) ±200 25V 50V Refer 5.2 ±200 50V F(±1%) E-96&E-24 G(±2%) E-24 J(±5%) E-24 100Ω-10KΩ 10Ω-3MΩ 10Ω-3MΩ 10Ω-10MΩ 1-9.1Ω 1-9.1Ω 1-9.1Ω 10Ω≦R
RMS06JT154
物料型号:文档描述了TA-I公司生产的RMS系列抗硫化厚膜芯片电阻器,包括多种型号,如RMS02、RMS04、RMS06等。
器件简介:这些电阻器是无卤素、符合AEC-Q200标准的抗硫化厚膜芯片电阻器,具有不同的功率等级和公差。
引脚分配:文档中没有明确提到引脚分配,但通常这类电阻器是无引脚的表面贴装元件。
参数特性:包括功率等级、额定电压、最大工作电压、最大过载电压、温度系数等。例如,RMS02型号的功率等级为1/20W,额定电压为50V,最大过载电压为+600V至-200V。
功能详解:文档详细介绍了电阻器的构造,包括覆层、导体、锡镀层、电阻元件、镍镀层和陶瓷基板。
应用信息:这些电阻器适用于需要抗硫化性能的汽车电子等领域。
封装信息:提供了不同型号的尺寸信息,如长度(L)、宽度(W)、引脚间距(C)、孔径(d)和厚度(t)。
RMS06JT154 价格&库存
很抱歉,暂时无法提供与“RMS06JT154”相匹配的价格&库存,您可以联系我们找货
RMS06JT154
    • 100+0.01340
    • 1000+0.01016
    • 5000+0.00843
    库存:1430
