RLM10FTSMR009
RLM10FTSMR009
    TA-I(大毅)
    9mΩ ±1% 500mW
RLM10FTSMR009 数据手册
Lead-Free Current Sensing Resistors RLM Series ( Halogen-Free ) Document No TRLM-100S005D Issued date 2017/12/21 page 1/6 1. Scope: This specification applied to the products of Lead-Free current sensing resistor of metal foil for Lead-Free RLM series manufactured by TA-I TECHNOLOGY CO.,LTD. 2. Type Designation: RLM Item 10 Series No. 10:0805(2012) F Resistance tolerance T Packaging S Power Rating F:±1% T: Paper B=1/8W M Metal M=MnCu R003 Resistance e.g : G:±2% A=1/4W R003=3mΩ J:±5% S=1/2W R020=20mΩ 3. Construction and Dimension : 3.1 Construction: Over-Coat Matte Sn Metal Alloy Plate 3.2 Dimension: (R=1.5) (3≦R≦20) (R=2) unit: mm Style L W C t 0.65±0.2 (1<R≦2) RLM10 2.0±0.1 1.25±0.1 0.4±0.2 (3≦R≦20) Material Strip: Alloy 0.6 ±0.20 Over Coating:molding Compound UL-94V-0 grade TA-I TECHNOLOGY CO., LTD Lead-Free Current Sensing Resistors RLM Series ( Halogen-Free ) Document No TRLM-100S005D Issued date 2017/12/21 page 2/6 4. Features: Type RLM10 1/8W、1/4W、1/2W 1.5~20 mΩ -55℃~+170℃ Power Rating Resistance Value Operation Temperature Range ±50ppm/℃ Temperature Coefficient of Resistance ±1%、±2%、±5% Over 100MΩ (P*R)1/2 Tolerance Insulation Resistance Maximum Working Voltage(V) 5. Reliability Tests : Test Items Temperature Coefficient of Resistance Load Life Short Time Overload Moisture no Load Reference standard IEC60115-1 4.8 JIS C 5201-1 4.8 IEC60115-1 4.25.1 JIS C 5201-1 4.25.1 Condition of Test +25℃ ~ +125℃ Test Limits Refer 4.0 1000hours at rated power, 70 ℃, 1.5hours “ON”, 0.5hour < ±1% “OFF” IEC60115-1 4.13 JIS C 5201-1 4.13 5 X rated power for 5s < ±0.5% IEC60115-1 4.24.2.1a) JIS C 5201-1 4.24.2.1a) 85℃, 85%RH, 1000hrs < ±1% Temperature cycle IEC60115-1 4.19 JIS C 5201-1 4.19 -55℃ & +155℃, 300cycle, < ±1% 15min per extreme condition Resistance to Soldering Heat IEC60115-1 4.18 JIS C 5201-1 4.18 260±5℃ for10±1 sec < ±0.5% Solderability IEC60115-1 4.17 JIS C 5201-1 4.17 245±5℃, 2±0.5sec At least 95% of surface area of electrode shall be covered with new solder High Temperature Exposure IEC60115-1 4.23.2 JIS C 5201-1 4.23.2 170℃, 1000hrs < ±1% Low Temperature Storage EC60115-1 4.23.4 JIS C 5201-1 4.23.4 -55℃, 1000hrs 100 MΩ TA-I TECHNOLOGY CO., LTD Lead-Free Current Sensing Resistors RLM Series ( Halogen-Free ) Document No TRLM-100S005D Issued date 2017/12/21 page 3/6 Power Ratio (%) 5.1Derating Curve 100 -55 70 170 Ambient Temperature (℃) 5.2 Rated Current The rated current is calculated by the following formula: I= 𝐏 ÷ 𝐑 I:Rated Current(A) P:Rated Power(W) R:Resistance Value(Ω) 6. Recommended Solder Pad Dimension Resistance Range (Ω) a b L 0.0015~0.002 1.4 1.15 0.7 0.003~0.020 1.4 1.15 1. Unit: mm TA-I TECHNOLOGY CO., LTD Document No TRLM-100S005D Issued date 2017/12/21 page 4/6 Lead-Free Current Sensing Resistors RLM Series ( Halogen-Free ) 7. Number of Package: 5000 Pieces / package 8. Label: Date Code QTY: 5000 PCS T019C0071H LOT NO: Series Resistance MR003 FTS 0308 RLM10FTS Tolerance Package Power Rating 9. Taping Packing Type Paper Tape RLM10 A B W F E P1 P2 P0 D0 1.6±0.15 2.4±0.2 8.0±0.2 3.5±0.05 1.75±0.1 4.0±0.1 2.0±0.1 4.0±0.1 Φ 1.5 +0.1 T 0.84±0.1 -0 Unit:mm TA-I TECHNOLOGY CO., LTD Lead-Free Current Sensing Resistors RLM Series ( Halogen-Free ) Document No TRLM-100S005D Issued date 2017/12/21 page 5/6 10. Reel Specification Series RLM 10 ψA ψB 178.0 ±2.0 60.0 ±1.0 ψC W 13.0 ±1.0 9.0 ±1.0 T 11.4 ±1.0 Unit: mm 11. Peeling Strength of Top Cover Tape Peel – off force of paper and blister tape is in accordance with “JIS ” that is , 0.1 to 0.7 N at a peel-off speed of 300 mm / minute. pull 300 mm/min top cover tape 10 ~15∘ standard: 0.1 ~ 0.7 N carrier tape 12. Storage Conditions: Temperature: 5℃~35℃,Humidity:40%~75% 13. Shelf Life: 2 years from manufacturing date. TA-I TECHNOLOGY CO., LTD Document No TRLM-100S005D Issued date 2017/12/21 page 6/6 Lead-Free Current Sensing Resistors RLM Series ( Halogen-Free ) 14. Recommend IR – Reflow profile : (solder : Sn96.5 / Ag3 / Cu0.5) Peak : 260 5 ℃ , 10±1 sec 5 Pre – heat Zone : 150 to 180 ℃, 90±30 sec Soldering Zone : 230℃ or higher , 30±10 sec Iron Solder:350±10℃ , 3+1/-0 sec 15. ECN Engineering Change Notice: The customer will be informed with ECN if there is significant modification on the characteristics and materials described in Approval Sheet. 16. Manufacturing Country & City : TA-I TECHNOLOGY CO., LTD. ( Taiwan– Tao Yuan ) Tel: (+886) 3-3246169 Fax : (+886) 3-3246167 Associated companies : (1)TA-I TECHNOLOGY ( SU ZHOU ) CO., LTD. ( China – Su Zhou) Tel :(+86) 512-63457879 Fax : (+86) 512-63457869 (2) TA-I TECHNOLOGY ELECTRONIC (DONGGUAN ) CO., LTD. ( China –Dongguan ) Tel : (+86) 769-8339-4790〜3 Fax : (+86) 769-8339-4794 (3) TAI OHM ELECTRONICS ( M ) SDN. BHD. ( Malaysia –Penang ) Tel : 604- 3900480 Fax : 604-3901481 (4) P.T.TAI ELECTRONICS Indonesia ( Indonesia – Jakarta ) Tel : 62-21-89830123 Fax : 62-21-89830703 TA-I TECHNOLOGY CO., LTD
RLM10FTSMR009 价格&库存
很抱歉,暂时无法提供与“RLM10FTSMR009”相匹配的价格&库存,您可以联系我们找货
