Current Sensing Resistors
RLM Series
( Halogen-Free )
Document No
TRLM-120S030A
Issued date
2012/12/13
page
1/6
1. Scope:
This specification applied to the products of current sensing resistor of metal foil for Lead-Free RLM series
manufactured by TA-I TECHNOLOGY CO., LTD.
2. Type Designation:
RLM
Item
12
Series
No
F
Resistance
tolerance
T
Packaging
C
Power Rating
12:1206
F:±1%
T: Paper Tape
(3216)
G:±2%
S=1/2W
J:±5%
C=1W
A=1/4W
M
Metal
M=MnCu
R001
Resistance
e.g:
R001=1mΩ
3. Construction and Dimension :
3.1 Construction:
Over-Coat
Ni / Sn
Plating
Metal Alloy Plate
3.2 Dimension:
UNIT: mm
Style
L
W
RLM12 3.2±0.20 1.6±0.20
C
t
1.1 ± 0.30
(R=1mΩ)
0.75 ± 0.20
(R=1mΩ)
0.5 ± 0.30
(2mΩ≦R≦30mΩ)
0.6 ± 0.20
(2mΩ≦R≦30mΩ)
Material
Strip: Alloy
Over Coating : molding
Compound UL-94 grade
Tel:0755-29796190 Fax:0755-29796149 Email:sales@jepsun.com Http://www.jepsun.com
RLM Series
( Halogen-Free )
Document No
TRLM-120S030A
Issued date
2012/12/13
page
2/6
4. Features:
Type
RLM12
Power Rating
Resistance Value
Operation Temperature Range
Temperature Coefficient of Resistance
Tolerance
Insulation Resistance
Maximum Working Voltage(V)
1/4W & 1/2W & 1W
1~30mΩ
-55℃~+170℃
±200ppm/℃
R=1mΩ
±100ppm/℃
2mΩ≦R≦10mΩ
±75ppm/℃
R>10mΩ
±1%、±2%、±5%
Over 100MΩ
(P*R)1/2
Note*:1 Watts with total solder pad and trace size of 300mm
2
5. Reliability Tests:
Test Items
Resistance
Load Life
Short Time Overload
Moisture no Load
Temperature cycle
Resistance to Soldering Heat
Solderability
High Temperature Exposure
Low Temperature Storage
Substrate Bending
Reference
standard
IEC60115-1 4.8
JIS C 5201-1 4.8
Condition of Test
+25℃ ~ +125℃
Test Limits
Refer 4.0
IEC60115-1 4.25.1
JIS C 5201-1 4.25.1
1000hours at rated
power, 70℃, 1.5hours < ±1%
“ON”, 0.5hour “OFF”
IEC60115-1 4.13
JIS C 5201-1 4.13
5 X rated power for 5s < ±1%
IEC60115-1 4.24.2.1a)
85℃, 85%RH, 1000hrs < ±0.5%
JIS C 5201-1 4.24.2.1a)
-55℃ & +155℃,
IEC60115-1 4.19
< ±0.5%
300cycle, 15min per
JIS C 5201-1 4.19
extreme condition
IEC60115-1 4.18
260±5℃ for20±1 sec < ±0.5%
JIS C 5201-1 4.18
At least 95% of surface area
IEC60115-1 4.17
245±5℃, 2±0.5sec
of electrode shall be
JIS C 5201-1 4.17
covered with new solder
IEC60115-1 4.23.2
170℃, 1000hrs
< ±1%
JIS C 5201-1 4.23.2
EC60115-1 4.23.4
-55℃, 1000hrs
100 MΩ
JIS C 5201-1 4.6
RLM Series
( Halogen-Free )
Document No
TRLM-120S030A
Issued date
2012/12/13
page
3/6
Power Ratio (%)
5.1Derating Curve
100
-55
70
170
Ambient Temperature (℃)
5.2 Rated Voltage
The rated voltage is calculated by the following formula:
V: Rated Voltage (V)
V PR
P: Rated Power (W)
R: Resistance Value (Ω)
6. Recommended Solder Pad Dimension
L
b
a
Cu Trace
Sensing Trace
Resistance Range
(Ω)
a
b
L
0.001
1.8
2.3
1.0
0.002~0.030
1.8
1.7
1.6
Unit: mm
Document No
TRLM-120S030A
Issued date
2012/12/13
page
4/6
RLM Series
( Halogen-Free )
7. Number of Package:
5000 Pieces / package
8. Label:
Date Code
Series
Resistance
QTY: 5000 PCS
T019C0071H
LOT NO:
R010 FTC
1019
RLM12FTC
Tolerance
Package
Power Rating
Customer Label
9. Taping
Packing
Type
A
Paper Tape RLM12 2.0±0.15
B
W
F
E
P1
P2
P0
D0
T
3.6±0.2
8.0.±0.2
3.5±0.05
1.75±0.1
4.0±0.1
2.0±0.05
4.0±0.1
ψ1.5
(+0.1/-0)
0.84±0.1
RLM Series
( Halogen-Free )
Document No
TRLM-120S030A
Issued date
2012/12/13
page
5/6
10. Reel Specification
Series
RLM12
ψA
ψB
178±2.0
60.0±1.0
ψC
13.0±1.0
W
T
9.0±1.0
11.5±1.0
11. Peeling Strength of Top Cover Tape
Test Condition: 0.1 to 0.7 N at a peel-off speed of 300 mm / min.
Pull
300 mm/min
Top cover tape
10 ~15∘
standard: 0.1 ~ 0.7 N
Carrier tape
12. Storage Conditions:
Temperature: 5℃~35℃,Humidity:40%~75%
13. Shelf Life:
2 years from manufacturing date.
RLM Series
( Halogen-Free )
Document No
TRLM-120S030A
Issued date
2012/12/13
page
6/6
14. Recommend IR – Reflow profile: (solder: Sn96.5 / Ag3 / Cu0.5)
5
℃ , 5 sec
Pre–heat zone : 150 to 180 ℃, 90±30 sec
Soldering zone : 230℃ or higher , 30±10 sec
Peak : 250
15. ECN
Engineering Change Notice: The customer will be informed with ECN if there is significant
modification on the characteristics and materials described in approval sheet.
很抱歉,暂时无法提供与“RLM12FTAMR015”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.23242
- 200+0.18285
- 600+0.15531
