PSBD1DF60V1H
PSBD1DF60V1H
    PRISEMI(上海芯导电子)
    SMF(SOD-123FL)
    60V 1A
PSBD1DF60V1H 数据手册
PSBD1DF20V1H THRW PSBD1DF200V1H Switching Diode Feature  Surface Mount Schottky Barrier Rectifier Rectifiers  Reverse Voltage 20 to 200 V  Forward Current 1.0 A 2 1 SOD123-FL  Maximum Ratings and Electrical characteristics per line@25℃( unless otherwise specified) Single  phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 % Parameter Symbols 20V1H 40V1H 60V1H 80V1H 100V1H 120V1H 150V1H 200V1H Units Maximum Repetitive Peak Reverse Voltage VRRM 20 40 60 80 100 120 150 200 V Maximum RMS voltage VRMS 14 28 42 56 80 100 105 140 V Maximum DC Blocking Voltage VDC 20 40 60 80 100 120 150 200 V Maximum Average Forward Rectified Current IF(AV) at Ta = 65 ℃ 1 A Peak Forward Surge Current 8.3 ms Single Half IFSM 40 30 A Sine Wave Superimposed on Rated Load (JEDEC Method) Maximum Instantaneous Forward Voltage at VF 0.55 0.70 0.85 0.90 0.3 0.2 0.1 10 5 2 V 1A Maximum DC Reverse Current Ta = 25 ℃ at Rated DC Blocking Voltage Ta =125 ℃ ) Typical Junction Capacitance 1 ) IR Cj mA 110 80 pF Typical Thermal Resistance 2 RθJA 115 ℃/W Operating and Storage Temperature Range Tj,Tstg -55~+150 ℃     1)Measured at 1 MHz and applied reverse voltage of 4 V D.C 2)Thermal resistance from junction to ambient at 0.375" (9.5 mm) lead length, P.C.B. mounted Rev.06.2 1 www.prisemi.com Switching Diode Rev.06.2 PSBD1DF20V1H THRW PSBD1DF200V1H 2 www.prisemi.com Switching Diode PSBD1DF20V1H THRW PSBD1DF200V1H Product dimension (SOD-123FL) Unit:mm Rev.06.2 3 www.prisemi.com Switching Diode Rev.06.2 PSBD1DF20V1H THRW PSBD1DF200V1H 4 www.prisemi.com Switching Diode PSBD1DF20V1H THRW PSBD1DF200V1H Marking information Device Marking PSBD1DF20V1H S12 PSBD1DF40V1H 14A Ordering information Device Package Reel Shipping PSBD1DFXXV1H SOD-123FL (Pb-Free) 7" 3000 / Tape & Reel Rev.06.2 5 www.prisemi.com Switching Diode PSBD1DF20V1H THRW PSBD1DF200V1H IMPORTANT NOTICE and are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi reserves the right to make changes without further notice to any products herein. Prisemi makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Prisemi assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. “Typical” parameters which may be provided in Prisemi data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. Prisemi does not convey any license under its patent rights nor the rights of others. The products listed in this document are designed to be used with ordinary electronic equipment or devices, Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. Website: http://www.prisemi.com For additional information, please contact your local Sales Representative. ©Copyright 2009, Prisemi Electronics is a registered trademark of Prisemi Electronics. All rights are reserved. Rev.06.2 6 www.prisemi.com
PSBD1DF60V1H 价格&库存
很抱歉,暂时无法提供与“PSBD1DF60V1H”相匹配的价格&库存,您可以联系我们找货
PSBD1DF60V1H
  • 1+0.22880
  • 200+0.14630
  • 1500+0.12760
  • 3000+0.11330
库存:2950
