US3DCG
US3DCG
    SK(時科)
    SMC(DO-214AB)
    耐压:200V 电流:3A 反向恢复时间:50NS
US3DCG 数据手册
US3ACG THRU US3MCG Surface Mount Ultrafast Recovery Rectifier PINNING Reverse Voltage – 50V~1000 V Forward Current – 3.0 A PIN FEATURES • For surface mounted applications • Low profile package • Glass Passivated Chip Junction • Easy to pick and place • High efficiency • Lead free in comply with EU RoHS 2011/65/EU directives DESCRIPTION 1 Cathode 2 Anode 2 1 Top View Marking Code: US3A~US3M Simplified outline SMC symbol MECHANICAL DATA • Case: SMC • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 0.22g / 0.0077oz Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols US3ACG US3BCG US3DCG US3GCG US3JCG Parameter US3KCG US3MCG Units Maximum Repetitive Peak Reverse Voltage V RRM 50 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current I F(AV) 3 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load I FSM 90 A Maximum Instantaneous Forward Voltage at 3 A VF Maximum DC Reverse Current T a = 25 °C at Rated DC Blocking Voltage T a =125 °C Maximum Reverse Recovery Time (1) Typical Thermal Resistance (2) Operating and Storage Temperature Range 1.0 1.68 5 100 IR t rr V μA 75 50 ns RθJA RθJC 45 15 °C/W T j , T stg -55 ~ +150 °C (1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A . (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. REV.08 1.3 1 of 3 US3ACG THRU US3MCG Fig.2 Typical Reverse Characteristics Instaneous Reverse Current(μ A) Average Forward Current (A) Fig.1 Maximum Average Forward Current Rating 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 100 T J =125°C 10 1.0 T J =25°C 0.1 00 Case Temperature (°C) Peak Forward Surage Current (A) Instaneous Forward Current (A) T J =25°C 1.0 US3ACG ~US3DCG US3GCG 0.1 US3JCG ~US3MCG 0.01 0.001 0 0.5 1.0 1.5 2.0 60 80 100 120 140 120 100 80 60 40 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 2.5 10 Number of Cycles Instaneous Forward Voltage (V) REV.08 40 Fig.4 Maximum Non-Repetitive Peak Forward Surage Current Fig.3 Typical Forward Characteristics 10 20 percent of Rated Peak Reverse Voltage (%) 2 of 3 100 US3ACG THRU US3MCG PACKAGE OUTLINE SMC Plastic surface mounted package; 2 leads E A A1 A C b D L E1 VM A SMC mechanical data A E D E1 A1 C L b max 2.62 7.0 6.2 8.0 0.21 0.31 1.6 3.25 min 2.00 6.5 5.6 7.6 0.05 0.15 0.9 2.75 max 103 276 244 315 8.3 12 63 128 min 79 256 220 299 2.0 5.9 35 108 UNIT mm mil Marking The recommended mounting pad size 3.8 (150) 4.1 (160) 4.3 (170) 4.1 (160) mm Unit : (mil) REV.08 3 of 3 Type number Marking code US3ACG US3A US3BCG US3B US3DCG US3D US3GCG US3G US3JCG US3J US3KCG US3K US3MCG US3M
US3DCG 价格&库存
很抱歉,暂时无法提供与“US3DCG”相匹配的价格&库存,您可以联系我们找货
US3DCG
    • 3000+0.17600
    库存:9000
    US3DCG
    库存:1804
