WF08Q5603BTL-C
WF08Q5603BTL-C
    WALSIN(华新科)
WF08Q5603BTL-C 数据手册
Approval Sheet WF25Q,WF20Q,WF10Q,WF12Q,WF08Q, WF06Q,WF04Q,WF02Q 1%, 0.5%, 0.25%, 0.1%, 0.05%, 0.01% TC50 High Precision Power Thin Film chip resistors (RoHS compliant 、Halogen Free) Size 2512, 2010, 1210, 1206, 0805, 0603, 0402, 0201 *Contents in this sheet are subject to change without prior notice. Page 1 of 10 ASC_WFxxQ_V18 SEP - 2017 Approval Sheet FEATURE 1. SMD metal film resistor 2. High reliability and stability of 0.5% and below per customer request 3. High performance of TCR: 50 ppm/C and below per customer request 4. Low current noise 5. RoHS compliant and lead free APPLICATION  Medical equipment  Measuring instrument  Communication device  Computer  Printer DESCRIPTION The resistors are constructed in a high grade ceramic body (aluminum oxide). Internal metal electrodes are added at each end and connected by a resistive layer that is applied to the top surface of the substrate. The composition of the resistive layer is adjusted to give the approximate resistance required and the value is trimmed to nominated value within tolerance which controlled by laser trimming of this resistive layer. The resistive layer is covered with a protective coat. Finally, the two external end terminations are added. For environmental soldering issue, the outer layer of these end terminations is a Lead-free solder . Fig 1. Construction of Chip-R WFxxQ Page 2 of 10 ASC_WFxxQ_V18 SEP - 2017 Approval Sheet QUICK REFERENCE DATA Item General Specification Series No. WF25Q WF20Q WF10Q WF12Q WF08Q WF06Q WF04Q WF02Q Size Code 2512 2010 1210 1206 0805 0603 0402 0201 (6432) (5025) (3225) (3216) (2012) (1608) (1005) (0603) 1.0%, 0.5%, 0.25%, 0.1%, 0.05%, 0.01% Resistance Tolerance Resistance Range 10 ~ 1.5M 10 ~ 1.5M 10 ~ 1M 4.7 ~ 1M 4.7 ~ 1M 1.0%, 0.5%, 4.7 ~ 680K 10 ~ 100K 27 ~ 22K 50 ppm/C TCR Max. Dissipation at Tamb=70C 1W 3/4W 2/5W 1/4W 1/8W 1/10W 1/10W 1/20W Max. Operation Voltage 200V 200V 200V 200V 150V 75V 50V 15V Max. Overload Voltage 400V 400V 400V 400V 300V 150V 100V 30V Operation Temperature - 55~ +155’C Note : 1. This is the maximum voltage that may be continuously supplied to the resistor element, see “IEC publication 60115-8” 2. Max. Operation Voltage : So called RCWV (Rated Continuous Working Voltage) is determined by  RCWV Rated Power  Resistance Value or Max. RCWV listed above, whichever is lower. DIMENSIONS:(unit:mm) Type WF25Q WF20Q WF10Q WF12Q WF08Q WF06Q WF04Q WF02Q L 6.35  0.10 5.00  0.10 3.10  0.10 3.05  0.15 2.00  0.10 1.55  0.10 1.00  0.10 0.6  0.03 W 3.20  0.15 2.50  0.15 2.60  0.15 1.55  0.15 1.25  0.10 0.80  0.10 0.50  0.05 0.3  0.03 A 0.60  0.20 0.60  0.20 0.50  0.20 0.40  0.20 0.25  0.20 0.25  0.15 0.15  0.10 0.10  0.05 B 0.90  0.25 0.60  0.25 0.50  0.20 0.40  0.20 0.40  0.20 0.30  0.15 0.25  0.10 0.15  0.05 t 0.55  0.10 0.55  0.10 0.55  0.10 0.55  0.15 0.50  0.15 0.45  0.15 0.30  0.05 0.23  0.03 Protective coat t End termination B Resistive layer A Ceramic Substrate W T 1001 1001 L Page 3 of 10 ASC_WFxxQ_V18 SEP - 2017 Approval Sheet MARKING  3-digits marking for 0603 size WFxxQ has same marking rule as WRxx ±1%. Nominal resistance Description 1.E-24 series As 0603 WR06X 5%. 2.E-96 series The 1st two digit codes are referring to the CODE on the table, the 3rd code is the index of resistance value : Y=10-2,X=10-1,A=100,B=101,C=102,D=103,E=104,F=105 EX : 17.8Ω=25X,178Ω=25A,1K78 =25B 17K8=25C, 178K=25D, 1M78=25E 3. Remark There is no marking for the items are not under E-24 and E-96 series CODE R_value CODE R_value R_value CODE R_value CODE R_value CODE R_value CODE R_value 01 100 13 133 25 178 37 237 49 316 61 422 73 562 85 750 02 102 14 137 26 182 38 243 50 324 62 432 74 576 86 768 03 105 15 140 27 187 39 249 51 332 63 442 75 590 87 787 04 107 16 143 28 191 40 255 52 340 64 453 76 604 88 806 05 110 17 147 29 196 41 261 53 348 65 464 77 619 89 825 06 113 18 150 30 200 42 267 54 357 66 475 78 634 90 845 07 115 19 154 31 205 43 274 55 365 67 487 79 649 91 866 08 118 20 158 32 210 44 280 56 374 68 499 80 665 92 887 09 121 21 162 33 215 45 287 57 383 69 511 81 681 93 909 10 124 22 165 34 221 46 294 58 392 70 523 82 698 94 931 11 127 23 169 35 226 47 301 59 402 71 536 83 715 95 953 12 130 24 174 36 232 48 309 60 412 72 549 84 732 96 976  CODE R_Value CODE 4-digits marking for 2512, 2010, 1210, 1206, 0805 size For E24+E96, each resistor is marked with a four digits code on the protective coating to designate the nominal resistance value. For values below 976 the R is used as a digit. For values of 100 or greater, the first 3 digits are significant, the fourth digit indicates the number of multiple to follow. Example  RESISTANCE 100 6800 47000 4-digits marking 1000 6801 4702 No marking code for 0402 and 0201 size FUNCTIONAL DESCRIPTION Product characterization Standard values of nominal resistance are taken from the E192 & E24 series for resistors with a tolerance of 1.0%, 0.5%, 0.25%, 0.1%. The values of the E24/E192 series are in accordance with “IEC publication 60063”. Page 4 of 10 ASC_WFxxQ_V18 SEP - 2017 Approval Sheet DERATING The power that the resistor can dissipate depends on the operating temperature; see Fig.2 MOUNTING Due to their rectangular shapes and small tolerances, Surface Mountable Resistors are suitable for handling by automatic placement systems. Chip placement can be on ceramic substrates and printed-circuit boards (PCBs). Electrical connection to the circuit is by individual soldering condition. The end terminations guarantee a reliable contact. Page 5 of 10 ASC_WFxxQ_V18 SEP - 2017 Approval Sheet SOLDERING CONDITION The robust construction of chip resistors allows them to be completely immersed in a solder bath of 260C for 10 seconds. Therefore, it is possible to mount Surface Mount Resistors on one side of a PCB and other discrete components on the reverse (mixed PCBs). Surface Mount Resistors are tested for solderability at 235C during 2 seconds within lead-free solder bath. The test condition for no leaching is 260C for 30 seconds. Typical examples of soldering profile and condition that provide reliable joints without any damage are given in Fig 3. and Table 1. Fig. 3 Infrared soldering profile for Chip Resistors Table 1. Infrared soldering condition for Chip Resistors Temperature Condition Exposure Time Average ramp-up rate (217C to 260C) Less than 3C/second Between 150 and 200C Between 60-120 seconds > 217C Between 60-150 seconds Peak Temperature 260ºC +0/-5C Time within 245C Min. 30 seconds Ramp-down rate (Peak to 217C) Less than 6C/second Time from 25C to Peak No greater than 480 seconds Page 6 of 10 ASC_WFxxQ_V18 SEP - 2017 Approval Sheet CATALOGUE NUMBERS The resistors have a catalogue number starting with. WF06 Q xxxx B Size code Type code Resistance code Tolerance Packaging code Termination code WF25: 2512 Q: TCR = 50 ppm R is first code followed by T : 0.01% T : Reeled L = lead free WF20: 2010 & High power 3 significant digits. A : 0.05% A : 7” Reel 15k pcs WF10: 1210 100 =1000 B : 0.10% WF12: 1206 37.4K =3742 C : 0.25% WF08: 0805 D : 0.50% WF06: 0603 F : 1.00% T L WF04: 0402 WF02: 0201 1. Reeled tape packaging: 8mm width paper taping. 5,000pcs/reel for WF10Q, WF12Q, WF08Q, WF06Q; 10,000pcs/reel for WF04Q; 15,000pcs/real for WF02Q. 2. Reeled tape packaging: 12mm width paper taping 4,000pcs/reel for WF25Q, WF20Q. Page 7 of 10 ASC_WFxxQ_V18 SEP - 2017 Approval Sheet TEST AND REQUIREMENTS(JIS C 5201-1 : 1998) REQUIREMENT TEST PROCEDURE Resistor DC resistance DC resistance values measured Within the specified tolerance Clause 4.5 Temperature Coefficient of Resistance(T.C. R) Clause 4.8 Natural resistance change per change in degree Refer to centigrade. “ QUICK REFERENCE DATA “ R 2  R1 6  10 (ppm/C) R 1  t 2  t1  R1 : Resistance at reference temperature R2 : Resistance at test temperature t1 : 20°C+5°C-1°C t2 : 125°C+5°C-1°C Short time overload (S.T.O.L) Clause 4.13 Resistance to soldering heat(R.S.H) IEC 60068-258:2004 Solderability IEC 60068-258:2004 Temperature cycling Clause 4.19 Endurance Clause 4.25 Humidity Clause 4.24 Permanent resistance change after a 5second R/R max. ±(0.2%+0.05) application of a voltage 2.5 times RCWV or the maximum overload voltage specified in the above list, whichever is less. Un-mounted chips completely immersed for no visible damage 10±1second in a SAC solder bath at 260℃±5ºC  R/R max. ±(0.25%+0.05) Un-mounted chips completely immersed for 2±0.5 good tinning (>95% covered) second in a SAC solder bath at 235℃±5℃ no visible damage 30 minutes at -55C3C, 2~3 minutes at no visible damage 20°C+5°C-1°C, 30 minutes at +155C3C, 2~3 R/R max. ±(0.5%+0.05) minutes at 20°C+5°C-1°C, total 5 continuous cycles 70±2ºC, 1000 hours, loaded with Vmax,1.5 hours on and 0.5 hours off RCWV or R/R max. (0.5%+0.05) 1000 hours, at rated continuous working voltage in R/R max. (0.5%+0.05) humidity chamber controller at 40C2C and 90~95% relative humidity, 1.5hours on and 0.5 hours off Clause 4.33 Resistors mounted on a 90mm glass epoxy resin R/R max. ±(0.1%+0.05) PCB(FR4); bending : 3 mm, once for 10 seconds. Adhesion Pressurizing force: 5N, Test time: 10±1sec. Bending strength Clause 4.32 Page 8 of 10 ASC_WFxxQ_V18 No remarkable damage or removal of the terminations. SEP - 2017 Approval Sheet PACKAGING Paper Tape specifications (unit :mm) Series No. Tape A B W F E WF25 Plastic 6.90±0.20 3.60±0.20 12.00±0.30 5.50±0.10 1.75±0.10 WF20 Plastic 5.50±0.20 2.80±0.20 12.00±0.30 5.50±0.10 1.75±0.10 WF10 Paper 3.60±0.20 3.00±0.20 8.00±0.30 3.50±0.20 1.75±0.10 WF12 Paper 3.60±0.20 2.00±0.20 8.00±0.30 3.50±0.20 1.75±0.10 WF08 Paper 2.40±0.20 1.65±0.20 8.00±0.30 3.50±0.20 1.75±0.10 WF06 Paper 1.90±0.20 1.10±0.20 8.00±0.30 3.50±0.20 1.75±0.10 WF04 Paper 1.20±0.10 0.70±0.10 8.00±0.30 3.50±0.05 1.75±0.10 WF02 Paper 0.67±0.05 0.37±0.05 8.00±0.30 3.50±0.05 1.75±0.10 Series No. P1 P0 D T WF25 4.00±0.10 4.00±0.10  1 . 50  0 .1  0 .0 Max 1.2 WF20 4.00±0.10 4.00±0.10  1 . 50  0 .1  0 .0 Max 1.2 WF10 4.00±0.10 4.00±0.10  1 . 50  0 .1  0 .0 Max. 1.0 WF12 4.00±0.10 4.00±0.10  1 . 50  0 .1  0 .0 Max. 1.0 WF08 4.00±0.10 4.00±0.10  1 . 50  0 .1  0 .0 Max. 1.0 WF06 4.00±0.10 4.00±0.10  1 . 50  0 .1  0 .0 0.65±0.05 WF04 2.00±0.10 4.00±0.10  1 . 50  0 .1  0 .0 0.40±0.05 WF02 2.00±0.05 4.00±0.05  1 . 50  0 .1  0 .0 0.45±0.05 Page 9 of 10 ASC_WFxxQ_V18 SEP - 2017 Approval Sheet Reel dimensions B C A D WF25Q , WF20Q Symbol A B C D (unit : mm) 178.0±2.0 60.0±1.0 13.0±0.2 14.0±0.5 WF12Q , WF10Q , WF08Q , WF06Q , WF04Q Symbol A B C D (unit : mm) 178.0±2.0 60.0±1.0 13.0±0.2 9.0±0.5 Symbol A B C D 13.0±0.2  9  0 .0 WF02Q (unit : mm)  180  0 .0 1 .5  60  0 .0  1 .5  1 .0 Taping quantity - Chip resistors 4,000 pcs per reel ( WF25Q, WF20Q ) - Chip resistors 5,000 pcs per reel ( WF10Q, WF12Q, WF08Q, WF06Q ) - Chip resistors 10,000 pcs per reel ( WF04Q ) - Chip resistors 15.000 pcs per reel ( WF02Q ) Page 10 of 10 ASC_WFxxQ_V18 SEP - 2017
WF08Q5603BTL-C 价格&库存
很抱歉,暂时无法提供与“WF08Q5603BTL-C”相匹配的价格&库存,您可以联系我们找货
WF08Q5603BTL-C
    • 10+0.29668
    • 100+0.24441
    • 300+0.21827
    库存:29
