SK52B THRU SK510B
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Reverse Voltage - 20 to 100 Volts
Forward Current - 5.0 Amperes
FEATURES
DO-214AA
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
260 C/10 seconds at terminals
0.155(3.94)
0.130(3.30)
0.087 (2.20)
0.071 (1.80)
0.180(4.57)
0.160(4.06)
0.012(0.305)
0.006(0.152)
MECHANICAL DATA
0.096(2.44)
0.084(2.13)
0.060(1.52)
0.030(0.76)
0.008(0.203)MAX.
0.220(5.59)
0.200(5.08)
Case: JEDEC DO-214AA molded plastic body
Terminals: leads solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.003 ounce, 0.093 grams
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
SYMBOLS SK52B SK53B SK54B SK55B SK56B SK58B SK510B
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL(see fig.1)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load
Maximum instantaneous forward voltage at 5.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
VRRM
VRMS
VDC
21
30
40
28
40
50
35
50
60
42
60
80
56
80
100
70
100
UNITS
V
V
V
I(AV)
5.0
A
IFSM
100.0
A
VF
0.55
IR
CJ
RθJA
TJ,
TSTG
0.70
0.5
0.1
mA
10
200
68.0
-55 to +125
V
-55 to +150
-55 to +150
pF
C/W
C
C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
DN:S06G19A0
STAR SEA
FIG. 1- FORWARD CURRENT DERATING CURVE
5.0
P.C.B mounted on
0.2*0.2"(5.0*5.0mm)
copper pad areas
4.0
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
3.0
2.0
SK52B-SK54B
SK55B-SK510B
1.0
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
RATINGS AND CHARACTERISTIC CURVES SK52B THRU SK510B
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
100
80
60
40
8.3ms SINGLE HALF SINE-WAVE
1
10
LEAD TEMPERATURE, C
INSTANTANEOUS FORWARD
CURRENT,AMPERES
TJ=25 C
10.0
1
SK52B-SK54B
SK55B-SK56B
SK58B-SK510B
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
50
0.1
100
10
TJ=100 C
1
TJ=75 C
0.1
0.01
TJ=25 C
0.001
0.4
0.6
0.8
1.0
1.2
1.4
INSTANTANEOUS FORWARD VOLEAGE,
VOLTS
JUNCTION CAPACITANCE, pF
FIG. 5-TYPICAL JUNCTION CAPACITANCE
2000
1000
TJ=25 C
100
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
1.6
TRANSIENT THERMAL IMPEDANCE,
C/W
0.01
100
NUMBER OF CYCLES AT 60 Hz
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
10
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
DN:S06G19A0
100
t,PULSE DURATION,sec.
STAR SEA
很抱歉,暂时无法提供与“SK54”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.52602
- 50+0.42442
- 600+0.33551
- 1200+0.33048
- 3000+0.30500
- 国内价格
- 20+1.09620
- 100+0.65390
- 800+0.45770
- 3000+0.32690
- 6000+0.31060
- 30000+0.28770
- 国内价格
- 1+0.63910
- 200+0.41140
- 1500+0.35750
- 3000+0.31680
- 国内价格
- 5+0.57970
- 50+0.46773
- 150+0.41174
- 500+0.36975
- 3000+0.33612
- 6000+0.31931
