RL10JTNR10
RL10JTNR10
    TA-I(大毅)
    100mΩ ±5%
RL10JTNR10 数据手册
Alloy Film Chip Resistors Low Resistance (Standard) Halogen-Free TA - I Document No TRL-XX0S002C Issued date 2022/02/23 Page. 1 / 10 1. Scope : This specification applies for the RL series of alloy film chip resistors made by TA-I. 2. Construction : Over Coat Conductor : (Lead-free ) Sn Plating Ni Plating Ceramic Substrate Resistive Element 3. Type Designation : RL 10 F TN Product Code RL : Chip Resistor Size Power Rating Tolerance Packaging R100 Nominal Resistance 04-0402(1005) 1/16W J- ±5% T-Paper Tape 3 Digits e.g.,5% 06-0603(1608) 1/8W G- ±2% E-Embossed Tape (E24) R10=0.1Ω 10-0805(2012) 1/4W F- ±1% N-Lead Free 4 Digits e.g.,1% 12-1206(3216) 1/2W (E96) R100=0.1Ω 13-1210(3226) 1/2W 20-2010(5025) 3/4W 25-2512(6432) 1W TA-I TECHNOLOGY CO., LTD TA - I Alloy Film Chip Resistors Low Resistance (Standard) Halogen-Free Document No TRL-XX0S002C Issued date 2022/02/23 Page. 2 / 10 4. Dimensions : UNIT: mm Type L W C d t RL04 1.00 -0.05 0.50 ±0.05 0.20 ±0.10 0.25 ±0.10 0.35 ±0.05 RL06 1.60 ±0.10 0.80 ±0.10 0.30 ±0.20 0.35 ±0.20 0.45 ±0.10 RL10 2.00 ±0.10 1.25 ±0.10 0.40 ±0.20 0.35 ±0.20 0.50 ±0.10 RL12 3.10 ±0.20 1.55 ±0.10 0.50 ±0.30 0.40 ±0.20 0.55 ±0.10 RL13 3.10 ±0.20 2.55 ±0.20 0.50 ±0.30 0.50 ±0.20 0.55 ±0.15 RL20 5.00 ±0.20 2.50 ±0.20 0.60 ±0.30 0.50 ±0.25 0.55 ±0.10 RL25 6.30 ±0.20 3.20 ±0.20 0.60 ±0.30 0.50 ±0.25 0.55 ±0.10 +0.10 5. Electrical characteristics : Feature Characteristics Power Ratings (W) RL04 RL06 RL10 RL12 RL13 RL20 RL25 1/16W 1/8W 1/4W 1/2W 1/2W 3/4W 100 ~ 910 Resistance Value (m) 100~500mΩ: ±300 501~910mΩ: ±200 o T.C.R ( ppm / C ) o ±200 1W Measurement Method JIS Code 3A / JIS Code 3D Refer to JIS C 5201-1-4.5 Refer to JIS C 5201-1-4.8 Operation Temperature Range( C) -55 ~ +155 Resistance Tolerance (%)  1%,  2%,  5% JIS C 5201-1-4.2.5 Insulation Resistance (M) Over 100 Refer to JIS C 5201-1-4.6 Maximum Working Voltage (V) (P*R) 1/2 Note : Except for the above standardized products, we also provide the customized products. TA-I TECHNOLOGY CO., LTD TA - I 5.1 Alloy Film Chip Resistors Low Resistance (Standard) Halogen-Free Document No TRL-XX0S002C Issued date 2022/02/23 Page. 3 / 10 Derating Curve : For resistors operated at ambient temperature over 70℃ , power rating shall be derated in accordance with figure 1. P Max Power ratio(%) Ambient Temp.(℃) Figure 1 6. Reliability Test : NTest Item Reference standard Condition of Test Test Limits Temperature Coefficient of Resistance IEC60115-1-4.8 JIS-C5201-1-4.8 -55 ~ +125℃ Refer to paragraph 5 Short Time Overload IEC60115-1-4.13 JIS-C5201-1-4.13 2.5 X rated voltage, 5s 1%: (1%+0.005  ) 2%,5%: (3%+0.005  ) Remark: 0402(2%+0.005  ) Load Life IEC60115-1-4.25.1 1000 hours at rated power , JIS-C5201-1-4.25.1 70℃, 1.5hours “ON “, 0.5hour “OFF” 1%: (1%+0.001  ) 2%,5%: (3%+0.001  ) Remark: 0402(3%+0.005  ) Load Life with Humidity IEC60115-1-4.24 JIS-C5201-1-4.24 1000 hours at rated power , 40  2℃, 90~95% RH 1.5hours “ON “, 0.5hour “OFF” 1%: (1%+0.001  ) 2%,5%: (3%+0.001  ) Remark: 0402(3%+0.005  ) Rapid Change of Temperature IEC60115-1-4.19 JIS-C5201-1-4.19 -55℃ (30 min. ) / +155 ℃(30 min.) 5 cycles  1%+0.005  Resistance to Soldering Heat IEC60115-1-4.18 JIS-C5201-1-4.18 270  5℃ solder , 10  1 sec dwell .  1%+0.005  Solderability IEC60115-1-4.17 JIS-C5201-1-4.17 245±5℃ solder, 2±0.5 sec dwell. Solder : Sn96.5 / Ag3.0 / Cu0.5 At least 95% of surface area of electrode shall be covered with new solder. Robustness of Termination (Bending Strength) IEC60115-1-4.33 JIS-C5201-1-4.33 3mm deflection 2mm deflection (RL20,25)  1%+0.005Ω Resistance to Dry Heat IEC60115-1-4.23.2 155  5℃ for 96  4hrs JIS-C5201-1-4.23.2 1%:  (1%+0.005  ) 2%,5%: (2%+0.005  ) MSL Level: 1 Note* :RCWV : Rated continuous working voltage . TA-I TECHNOLOGY CO., LTD Alloy Film Chip Resistors Low Resistance (Standard) Halogen-Free TA - I Document No TRL-XX0S002C Issued date 2022/02/23 Page. 4 / 10 7. Marking : 7.1 Type : 0805, 1206, 1210, 2010, 2512 7.1.1 E96: 1% Resistance value is expressed by 4 digits, the first “R” means decimal point and the other digits represent for the normal resistance inΩ. e.g., R100 =100 mΩ 7.1.2 E24: 2%,5% Resistance value is expressed by 3 digits, the first “R” means decimal point and the other digits represent for the normal resistance inΩ. e.g., R10 =100 mΩ 7.2 Type : 0603 7.2.1 E96: 1% When the marking space is too small in such small-sized resistors as RL06, the marking can not made by 4 digits and may be made by two digits combined with one English capital. Significant figures of nominal resistance Symbol 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 E96 100 102 105 107 110 113 115 118 121 124 127 130 133 137 140 143 147 150 154 158 162 165 169 174 Symbol 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 E96 178 182 187 191 196 200 205 210 215 221 226 232 237 243 249 255 261 267 274 280 287 294 301 309 Symbol 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 E96 316 324 332 340 348 357 365 374 383 392 402 412 422 432 442 453 464 475 487 499 511 523 536 549 Symbol 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 E96 562 576 590 604 619 634 649 665 681 698 715 732 750 768 787 806 825 845 866 887 909 931 953 976 Symbol for multipliers Symbol multipliers A 0 10 B 1 10 e.g., C 2 10 D 3 10 E 4 10 F 5 10 G 6 10 H 7 10 X -1 10 Y -2 10 Z -3 10 -3 01Z =100 ×10 =100 mΩ Notes : When the resistance value is not in the list of E96 , 3 digitals with underline in E-24 series is used as mark . e.g., 0603 : 120mΩ, 1% Marking is 012 TA-I TECHNOLOGY CO., LTD Alloy Film Chip Resistors Low Resistance (Standard) Halogen-Free TA - I 7.2.2 Document No TRL-XX0S002C Issued date 2022/02/23 Page. 5 / 10 E24: 2%,5% Resistance value is expressed by 3 digits, the first “0” means decimal point and the other digits represent for the normal resistance inΩ. e.g., 010 =100 mΩ 7.2 Type: 0402 RL04 : No Marking 8. Taping & Reel : 8.1 Taping Dimensions : 8.1.1 4 mm pitch paper UNIT: mm Packing Type A RL06 1.1 ±0.1 Paper Tape B 1.9 ±0.1 W F E P1 P2 P0 D0 T 0.64 ±0.1 +0.1 8.0±0.2 3.5±0.05 1.75±0.1 4.0±0.1 2.0±0.05 4.0±0.1 φ1.5 RL12 2.0 ±0.15 3.6 ±0.2 -0 0.84 ±0.1 RL10 1.6 ±0.15 2.4 ±0.2 RL13 2.8 ±0.20 3.6 ±0.2 TA-I TECHNOLOGY CO., LTD Alloy Film Chip Resistors Low Resistance (Standard) Halogen-Free TA - I 8.1.2 Document No TRL-XX0S002C Issued date 2022/02/23 Page. 6 / 10 2 mm pitch paper : Packing Type A B W F E P1 P2 P0 D0 T +0.1 RL04 0.7±0.05 1.2±0.05 8.0 ±0.2 3.5±0.05 1.75±0.1 2.0 ±0.1 2.0 ±0.1 4.0 ±0.1 ψ1.5 0.45 ±0.1 -0 +0.1 Paper Tape RL06 1.1 ±0.1 1.9 ±0.1 8.0 ±0.2 3.5±0.05 1.75±0.1 4.0 ±0.1 2.0 ±0.1 4.0 ±0.1 ψ1.5 0.64 ±0.1 -0 8.1.3 4 mm pitch Emboss : Packing Type RL20 A B 2.8 ±0.2 5.3 ±0.2 Emboss RL25 3.6 ±0.2 W F E P1 P2 12.0±0.2 5.5±0.05 1.75±0.1 4.0±0.1 2.0±0.05 6.9 ±0.2 P0 D0 T +0.1 4.0±0.05 ψ1.5 0.85 ±0.15 -0 Paper Tape Type Size RL RL RL RL RL RL RL 04 06 10 12 13 20 25 4 mm pitch 2 mm pitch 178mm/R 178mm/R 10000 10000 5000 5000 5000 5000 Emboss Plastic Tape 4 mm pitch 4000 4000 TA-I TECHNOLOGY CO., LTD TA - I Alloy Film Chip Resistors Low Resistance (Standard) Halogen-Free Document No TRL-XX0S002C Issued date 2022/02/23 Page. 7 / 10 8.2 Reel Specifications : UNIT: mm ψA Series ψB ψC RL 04/ 06/ 10/ 12/ 13 178 ± 2.0 60.0 ± 1.0 RL 20 / 25 W T 9.0 ±1.0 11.5 ± 1.0 13.0 ± 1.0 15.5 ±1.0 13.0 ± 1.0 8.3 Peel – off force : Peel – off force of paper and blister tape is in accordance with “JIS-C5202 ” that is , 0.1 to 0.7 N at a peel-off speed of 300 mm / minute. Pull top cover tape carrier tape 300 mm/min 10 ~ 15° standard: 0.1 ~ 0.7 N TA-I TECHNOLOGY CO., LTD TA - I Alloy Film Chip Resistors Low Resistance (Standard) Halogen-Free Document No TRL-XX0S002C Issued date 2022/02/23 Page. 8 / 10 9. Label : 9.1 Manufacture Label : Date Code Lot No: Type QTY: 5000 PCS R10 T5486A001K 9.2 Resistance Tolerance 1548 J RL10JT Customer Label: ( By customer request ) : Lead-Free Products TA-I TECH Product Spec. Customer No: LEAD FREE 0805 5%(T) 0.1Ω 105A702723 RL10JTNR10 Date 04. 05. 21 Year Month 10. Recommended land patterns : Land pattern Type RL RL RL RL RL RL RL Size 04(1005 ) 06 (0603 ) 10 (0805 ) 12 (1206 ) 13 (1210 ) 20 (2010 ) 25 (2512 ) Dimension ( mm ) a b c 0.5~0.6 1.4~1.6 0.4~0.6 0.7~0.9 2.0~2.2 0.8~1.0 1.0~1.4 3.2~3.8 0.9~1.4 2.0~2.4 4.4~5.0 1.2~1.8 2.0~2.4 4.4~5.0 2.3~3.5 3.3~3.7 5.7~6.5 2.3~3.5 3.6~4.0 7.6~8.6 2.3~3.5 TA-I TECHNOLOGY CO., LTD TA - I Alloy Film Chip Resistors Low Resistance (Standard) Halogen-Free Document No TRL-XX0S002C Issued date 2022/02/23 Page. 9 / 10 11. Recommend IR – Reflow profile : ( Lead-Free solder : Sn96.5 / Ag3 / Cu0.5 ) Profile Feature Average ramp-up rate (Tsmax to Tp) Preheat - Temperature Min (Tsmin) - Temperature Max (Tsmax) - Time (Tsmin to Tsmax ) (ts) Time maintained above : - Temperature (TL) - Time (TL) Peak Temperature (Tp) Time within 0 ℃ of actual Peak 5 Temperature (tp)2 Ramp-down Rate Time 25℃ to Peak Temperature Lead (Pb )-Free Assembly 3℃ / second max. 150℃ 200℃ 60 -120 seconds 217℃ 60-150 seconds 260℃ 10 seconds 6℃/second max. 8mimutes max. Allowed Re-flow times : 3 times Remark : To avoid discoloration phenomena of chip on terminal electrodes, please use N2 Re-flow furnace . 12. Storage Conditions : Temperature: 5℃~35℃,Humidity:40%~75% 13. Shelf Life : 2 years from manufacturing date TA-I TECHNOLOGY CO., LTD TA - I Alloy Film Chip Resistors Low Resistance (Standard) Halogen-Free Document No TRL-XX0S002C Issued date 2022/02/23 Page. 10 / 10 14. ECN : Engineering Change Notice: The customer will be informed with ECN if there is significant modification on the characteristics and materials described in Approval Sheet. 15. Manufacturing Country & City : TA-I TECHNOLOGY CO., LTD. ( Taiwan– Tao Yuan ) Tel: 886-3-3246169 Fax : 886-3-3246167 Associated companies : (1) FORTUNE TASK RESISTOR FACTORY ( China – Dongguan ) Tel : 86-769-8339-4790〜3 Fax : 86-769-8339-4794 (2) TA-I TECHNOLOGY (DONGGUAN ) CO., LTD. ( China –Dongguan ) Tel : 86-769-8339-4790〜3 Fax : 86-769-8339-4794 (3) TA-I TECHNOLOGY ( SU ZHOU ) CO., LTD. ( China – Su Zhou) Tel :86- 512-63457879 Fax : 86-512-63457869 (4) TAI OHM ELECTRONICS ( M ) SDN. BHD. ( Malaysia – Penang ) Tel :604- 3900480 Fax : 604-3901481 (5) P.T.TAI ELECTRONICS Indonesia ( Indonesia – Jakarta ) Tel :62-21-89830123 Fax : 62-21-89830703 TA-I TECHNOLOGY CO., LTD
RL10JTNR10
物料型号:TA-I合金膜片电阻器,文档编号TRL-XX0S002C。
器件简介:这是一系列低电阻值的标准合金膜片电阻器,无卤素,符合环保要求。
引脚分配:文档中没有明确指出引脚分配,但提到了不同尺寸的电阻器,例如0402、0603、0805等。
参数特性: - 尺寸:提供了不同型号的尺寸数据,例如RL04、RL06、RL10等。 - 功率额定值:包括1/16W、1/8W、1/4W、1/2W、3/4W和1W。 - 电阻值:100 ~ 910 mΩ,具体值参照JIS C5201-1-4.5。 - 温度系数:100~500mΩ的电阻温度系数为±300 ppm/°C,501~910mΩ的为±200 ppm/°C。 - 工作温度范围:-55°C至+155°C。 - 电阻公差:±1%、±2%、±5%。
功能详解:文档提供了电阻器的可靠性测试信息,包括温度系数、短时过载、负载寿命、温度快速变化、焊接热抗力、可焊性、端头强度和干热抗力等测试。
应用信息:文档中没有明确提供应用信息,但根据其特性,这些电阻器适用于需要低电阻值和环保特性的电子设备中。
封装信息:提供了不同尺寸的封装信息,如0402、0603、0805等,以及它们的尺寸和公差。
RL10JTNR10 价格&库存
很抱歉,暂时无法提供与“RL10JTNR10”相匹配的价格&库存,您可以联系我们找货
RL10JTNR10
    • 50+0.13101
    • 500+0.10304
    • 1500+0.08748
    库存:182
