1
目 录 CONTENTS
电容器
与介质分类
01
产品
结构
02
产品规格型号
命名规则
产品容量
范围
04-16
产品
尺寸
03
17
技术要求
和测试条件
18-27
产品
包装
28-32
MLCC
使用注意事项
33-38
电容器及介质分类
Types of Capacitor and Dielectric Material
多层片式陶瓷电容器产品目录
COG:此类介质材料的电容器为Ⅰ类电容器, 包括常规、中高压COG 产品。此类产品电性能
稳定,几乎不随 温度、电压和时间的变化而变化。适用于低损耗,稳定性要求高的电路中,
如滤波器、谐振器和计时电路中。
-------------------------------------------------------------------------------------------COG: The capacitor of this kind dielectric material is considered as ClassⅠcapacitor, including
general capacitor and high frequency COG capacitor。The electrical properties of COG capacitor
are the most stable one and have little change with temperature, voltage and time. They are
suited for applications where low-losses
and high-stability are required, such as filters,
oscillators, and timing circuits.
-------------------------------------------------------------------------------------------X7R、X5R、X6S、X7T:此类介质材料的电容器为Ⅱ类电容器,具有较高的介电常数,容量比
Ⅰ类电容器高,具有较稳定的温度特性,适用于容量范围广,稳定性要求不高的电路中,如隔
直、耦合、旁路、鉴频等电路中。
-------------------------------------------------------------------------------------------X7R、X5R、X6S、X7T:material is a kind of material has high dielectric constant. The capacitor made
of this kind material is considered as Class Ⅱ capacitor whose capacitance is higher than that of
class Ⅰ. These capacitors are classified as having a semi-stable temperature characteristic and
used over a wide temperature range, such in these kinds of circuits, DC-blocking, decoupling,
bypassing, frequency discriminating etc.
-------------------------------------------------------------------------------------------Y5V:此类介质材料的电容器为Ⅱ类电容器,是所有电容器中介电常数最大的电容器,但其容
量稳定性较差,对温度、电压等条件较敏感,适用于要求大容量,温度变化不大的电路中。
-------------------------------------------------------------------------------------------Y5V:The capacitor made of this kind of material is the highest dielectric constant of all ceramic
capacitors. They are used over a moderate temperature range in application where high
capacitance is required because of its unstable temperature coefficient, but where moderate
losses and capacitance changes can be tolerated. Its capacitance and dissipation factors are
sensible to measuring conditions, such as temperature and voltage, etc
1
产品结构
Product Frame
多层片式陶瓷电容器产品目录
产品结构
Product Frame
图示说明
1 ------------------------------------------ 陶瓷介质
2 -------------------------------------------- 内电极
3 -------------------------------------------- 外电极
4 ---------------------------------------------- 镍层
5 ---------------------------------------------- 锡层
2
产品规格型号命名规则
General Product Parts Numbering System
多层片式陶瓷电容器产品目录
产品规格型号命名规则
例 [example]
F
公司名
CC
产品别
0805
尺寸
F
温度特性
105
电容值
M
公差
500
额定电压
D
厚度
T
包装
S
特殊码
FCC0805F105M500DT
FOJAN
陶瓷电容器代号
Code of Ceramic Capacitor
规 格 Chip Size
Type=L×W
0402=1.00×0.50mm
1206=3.20×1.60mm
0201=0.60×0.30mm
0805=2.00×1.25mm
0603=1.60×0.80mm
1210=3.20×2.50mm
温度特性 Dielectrics
COG=N, X7R=B ,
电容值
X5R=X, Y5V=F,
X7T=T,
X6S=S
Capacitance
105=10×105 =1000,000pF 5 表示 105
Two significant digits followed by no. of zero
容量容差 Capacitance Tolerance
A= ±0.05pF B= ±0.1pF C= ±0.25pF
J= ±5.0%
K= ±10% M= ±20%
D= ±0.5pF
Z=-20/+80%
F= ±1.0%
G= ±2.0%
额定电压 Rated Voltage
6R3=6.3VDC
201=200VDC
100=10VDC 160=16VDC
250=25VDC
500=50VDC
101=100VDC
251=250VDC 501=500VDC 102=1000VDC 202=2000VDC
厚 度 Thickness
A:0.5±0.10mm B:0.60±0.10mm
F:1.25±0.20mm H:1.6 ±0.20mm
C:0.80±0.10mm
G:2.0 ±0.20mm
D:0.85±0.10mm
M:2.5 ±0.30mm
E:1.00±0.10mm
Z:0.3 ±0.03mm
包 装 Packing
B:袋散装 B: bulk packaging in a bag
T:编带 T:tape carrier packa
特殊码 Specific
S:防断裂
■ 产品的介质特性组别
材质
工作温度范围
C0G (N)
-55℃~+125℃
0±30ppm/℃
X7R (B)
-55℃~+125℃
±15%
X5R (X)
-55℃~+85℃
±15%
X7T (T)
-55℃~+125℃
+22/-33%
Y5V (F)
-30℃~+85℃
+22/-82%
X6S (S)
-55℃~+105℃
3
温度系数或温度特性
±22%
产品容量范围
Product Capacitance Range
多层片式陶瓷电容器产品目录
产品容量范围
■ 0201[0603]尺寸
尺寸
0201[0603]
系列
X5R (X)
型号
CP VDC
25
103
Z
223
Z
16
10
X6S (S)
6.3
25
16
10
X7T (T)
6.3
Z
Z
16
10
6.3
Z
Z
Z
Z
Z
Z
473
Z
683
Z
Z
Z
Z
Z
Z
104
Z
Z
Z
Z
Z
Z
224
4
Z
Z
Z
说明
容量容差:
X5R/X6S/X7T;K(±10%);M(±20%)
厚度:Z:0.30±0.03mm
以上容量仅供参考,具体容量取决于使用要求。
Tolerance:
X5R/X6S/X7T: K(±10%);M(±20%)
Thickness: Z:0.30±0.03mm ;
Above capacitance for reference only, actual cap. Range depends on the standard products.
4
Z
产品容量范围
多层片式陶瓷电容器产品目录
■ 0402[1005]尺寸
尺寸
系列
型号
0402[1005]
COG
(N)
X7R (B)
X6S (S)
X5R (X)
X7T (T)
Y5V (F)
5
5
1
6
1
3
5
5
1
6
1
3
5
5
1
6
1
3
5
5
1
6
1
3
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
181
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
201
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
221
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
271
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
331
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
391
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
471
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
561
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
681
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
821
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
102
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
152
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
182
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
222
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
272
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
332
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
472
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
CP VDC
5
5
0R5
A
A
1R0
A
A
2R0
A
A
3R0
A
A
4R0
A
A
5R0
A
A
6R0
A
A
7R0
8R0
9R0
A
A
A
A
A
A
100
A
A
120
A
A
150
A
A
180
A
A
200
A
A
220
A
A
270
A
A
300
A
A
330
A
A
390
A
A
470
A
A
560
A
A
680
A
A
820
A
A
101
A
121
A
151
5
5
5
1
6
1
3
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
产品容量范围
多层片式陶瓷电容器产品目录
562
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
103
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
153
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
183
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
223
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
273
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
333
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
393
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
473
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
563
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
683
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
104
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
A
184
A
A
A
A
A
A
A
A
A
A
A
224
A
A
A
A
A
A
A
A
A
154
A
A
274
A
A
A
A
A
A
334
A
A
A
A
A
A
474
A
A
A
A
A
A
684
A
A
A
A
A
105
A
A
A
A
A
说明
容量容差:
COG(0.5pF~4.9pF): B/C;COG(5.0pF~9.9pF): D;COG(≥10pF): F(±1%), G(±2%), J(±5%),
X7R/X5R/X6S/X7T: J(±5.0%);K(±10%);M(±20%) ;
Y5V: M(±20%);Z(-20,+80%)
厚度:A:0.50±0. 10mm;
Tolerance:
COG(0.5pF~4.9pF): COG(5.0pF~9.9pF): D;COG(≥10pF): F(±1%), G(±2%), J(±5%)
Thickness: A:0.50±0.10mm ;
6
产品容量范围
多层片式陶瓷电容器产品目录
■ 0603[1608]尺寸
尺寸
0603[1608]
系列
COG (N)
型号
CP VDC
0R5
1R0
2R0
3R0
4R0
5R0
6R0
7R0
8R0
9R0
100
120
150
180
200
220
270
300
330
390
470
560
680
820
101
121
151
181
201
221
271
331
391
471
561
681
821
102
152
182
222
272
332
X7R (B)
X6S (S)
X5R (X)
X7T (T)
Y5V (F)
2 2 1 5 2 2 2 1 5 2 1 1 6 5 2 1 1 6 5 2 1 1 6 2 1 1 6 4 5 2 1 1
5 0 0 0 5 5 0 0 0 5 6 0 · 0 5 6 0 · 0 5 6 0 · 5 6 0 ·
0 5 6 0
3
3
3
3
0 0 0
0 0 0
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
472
C C C C C C C C C C C
C C C C C C C C C C C C C C C C
562
682
103
C C C C C C C C C
153
C C C C C C C C C
183
C C C C C C C C C
223
C C C C C C C C C
273
C C C C C C C C
7
产品容量范围
多层片式陶瓷电容器产品目录
333
C C C C C C C C
393
C C C C C C C C
473
C C C C C C C C
563
C C C C C C C C
683
C C C C C C C C
C C C C C C C C
154
C C C C C C C C
184
C C C C C C C C
224
C C C C C C C C
274
C C C C C C C C
334
C C C C C C C C
474
C C C C C C C C
104
C
684
C C C C
C C
C C
C C C C
C C C C
C C C
105
C C C C
C C
C C
C C C C
C C C C
C C C
225
C C C
C
C C
C C C
C C C
C C
475
C C
C C
C C
C C
C
106
C
C
C
C
说明
容量容差:
X7R/X5R/X6S/X7T: J(±5.0%);K(±10%);M(±20%);
厚度:C:0.80±0.1mm (0.80±0.2mm ) ;
Tolerance:
COG(0.5pF~4.9pF): B/C; COG(5.0pF~9.9pF): D;COG(≥10pF): F(±1%), G(±2%), J(±5%)
Thickness: C:0.80±0.1mm(0.80±0.2mm ) ;
8
产品容量范围
多层片式陶瓷电容器产品目录
■ 0805[2012]尺寸
尺寸
0805[2012]
系列
COG (N)
型号
X7R (B)
CP VDC
2
5
0R5
1R0
2R0
3R0
4R0
5R0
6R0
7R0
8R0
9R0
100
120
150
180
200
220
270
300
330
390
470
560
680
820
101
121
151
181
201
221
271
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
331
B
B B B B
391
B
B B B B
471
B
B B B B
561
B
B B B B
681
B
B B B B
821
B
B B B B
102
B
B B B B
X5R (X)
X6S(S)
X7T (T)
Y5V (F)
1 5 2 1 2 1 5 2 1 1 6 5 2 1 1 6 5 2 1 1 6 2 1 1 6 4 5 2 1 1 6
0 0 5 6 5 0 0 5 6 0 · 0 5 6 0 · 0 5 6 0 · 5 6 0 ·
0 5 6 0 ·
3
3
3
3
3
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
D
D
D
F
D
F
D
F
D
F
D
F
D
F
D
F
B
B
B
B
B
D
D
D
F
D
F
D
F
D
F
D
F
D
F
D
F
D
D
B
D
B
D
B
D
B
D
B
D
B
D
B
D
D
D
B
D
B
D
B
D
B
D
B
D
B
D
B
D
D
D
B
D
B
D
B
D
B
D
B
D
B
D
B
D
D
D
B
D
B
D
B
D
B
D
B
D
B
D
B
D
D
D
B
D
B
D
B
D
B
D
B
D
B
D
B
D
D
D
B
D
B
D
B
D
B
D
B
D
B
D
B
D
D
D
B
D
B
D
B
D
B
D
B
D
B
D
B
D
9
D
D
B
D
B
D
B
D
B
D
B
D
B
D
B
D
D
D
B
D
B
D
B
D
B
D
B
D
B
D
B
D
D
D
B
D
B
D
B
D
B
D
B
D
B
D
B
D
D
D
B
D
B
D
B
D
B
D
B
D
B
D
B
D
D
D
B
D
B
D
B
D
B
D
B
D
B
D
B
D
D
D
B
D
B
D
B
D
B
D
B
D
B
D
B
D
D
D
B
D
B
D
B
D
B
D
B
D
B
D
B
D
D
D
B
D
B
D
B
D
B
D
B
D
B
D
B
D
D
D
B
D
B
D
B
D
B
D
B
D
B
D
B
D
D
D
B
D
B
D
B
D
B
D
B
D
B
D
B
D
D
D
B
D
B
D
B
D
B
D
B
D
B
D
B
D
D
D
B
D
B
D
B
D
B
D
B
D
B
D
B
D
D
D
B
D
B
D
B
D
B
D
B
D
B
D
B
/ D D D D D
D
产品容量范围
多层片式陶瓷电容器产品目录
152
182
222
272
332
472
562
682
103
B
D
B B B B /
F
D
B B B B /
F
D
B B B B /
F
D
B B B /
F
D
D D /
F
D
D D /
F
D
D D /
F
D
D /
F
D
F
153
F
183
F
223
F
273
F
333
F
393
F
473
F
563
683
104
D
F
D
F
D
F
D
F
D
F
D
F
D
F
D
F
D
F
D
F
D
F
D
F
D
F
D
F
D
F
D
F
D
F
D
F
D
F
D D D D D D D D D D D D D D D D D D D D D D D D D
154
184
D
D
F
D
F
D
F
D
F
224
274
334
474
D D D D D
D
D D D D /
F
D
D D D D /
F
D
D D D D /
F
D D
D
/ / D D /
F F
F
D D D D D
D
D D D D /
F
D
D D D D /
F
D
D D D D /
F
D D
D
/ / D D /
F F
F
10
D D D D D
D
D D D D /
F
D
D D D D /
F
D
D D D D /
F
D D
D
/ / D D /
F F
F
D D D D D
D
D D D D /
F
D
D D D D /
F
D
D D D D /
F
D D
D
/ / D D /
F F
F
D D D D
D D D D
D D D D
D D D D
D D
/ / D D
F F
产品容量范围
多层片式陶瓷电容器产品目录
D D D
D
/ / / D D D /
F F F
F
D D
D
F / / D D F /
F F
F
F F F F
F
684
105
225
475
F
106
D
D D
D
/ D D D / / D D D /
F
F F
F
D
D D
D
/ D D F / / D D D /
F
F F
F
F F F
F F F F
F
D
/ D D
F
D
/ D D
F
F F F
F
F F
F F
F
F F
F
F
F
F
F F
F F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F F
F
F
226
476
F
D
D
/ D D D /
F
F
D
D
/ D D F /
F
F
F F F
F
F
F
F
说明
容量容差:
COG(0.5pF~4.9pF): B/C;COG(5.0pF~9.9pF): D;COG(≥10pF): F(±1%), G(±2%), J(±5%),K(±10%)
X7R/X5R/X6S/X7T: J(±5.0%);K(±10%);M(±20%);Y5V: M(±20%);Z(-20,+80%)
厚度:
B:0.60±0.1mm
、D:0.85±0.1mm、F:1.25±0.2mm;
Tolerance:
Thickness: B:0.60±0.1mm、D:0.85±0.1mm、F:1.25±0.2mm;
11
F
F
F
F
F
产品容量范围
多层片式陶瓷电容器产品目录
■ 1206[3216]尺寸
尺寸
1206[3216]
系列
COG (N)
型
X7R (B)
X6S (S)
X5R (X)
X7T (T)
Y5V (F)
号
CP VDC
0R5
1R0
2R0
3R0
4R0
5R0
6R0
7R0
8R0
9R0
100
120
150
180
200
220
270
300
330
390
470
560
2
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
E
F
D
E
F
D
E
F
D
E
F
D
E
F
D
E
F
D
E
1 6 5 2 1 5 2 1 2 1 6 5 2 1 5 2 1 1 6 5 2 1 1 6 5 2 1 1 6 2 1 1 6 4 5 2 1 1 6
0 3 0 5 0 0 5 6 0 0 3 0 5 0 0 5 6 0 · 0 5 6 0 · 0 5 6 0 · 5 6 0 ·
0 5 6 0 ·
0 0 0 0 0
0 0 0 0 0 0
3
3
3
3
3
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D D D D D D D D
D D D D D D D D
D D D D D D D D
D D D D D D D D
D D D D D D D D
D D D D D D D D
D D D D D D D D
12
产品容量范围
多层片式陶瓷电容器产品目录
680
820
101
121
151
181
201
221
271
331
391
471
561
681
821
102
152
182
222
272
332
472
562
682
103
153
183
223
273
333
393
473
563
F
D
E
F
D
E
F
D
E
F
D
E
F
D D D D D D D D
D D D D D D D D
D
/ D D D D D D D F F F F F
E
D
E
D
E
D
E
D
E
D
E
D
E
D
E
D
E
D
E
D D D D D D D F F F F F D D D D D D D D D D D D D D D D D D D D D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
F
D
D
D
D
D
D
D
D
D
D
D
D
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
13
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
产品容量范围
多层片式陶瓷电容器产品目录
683
104
154
184
224
274
334
474
F D D
F D D
D D
D D
D D
D D
D D
F F
F F
H H
F F
H H
F
H
F
684
105
205
225
475
D
D
D
D
D
D
D
F
D
D
D
D
D
D
D
F
F
F F F F /
H
F
F F F F /
H
D
D
D
D
D
D
D
F
D
D
D
D
D
D
D
F
F
F F F F /
H
F
F F F F /
H
D
D
D
D
D
D
D
F
D
D
D
D
D
D
D
F
F
F F F F /
H
F
F F F F /
H
D
D
D
D
D
D
D
F
E E E
E E E
E E E
E E E
F
H
H
106
226
D
D
D
D
D
D
D
F
F
H
H
H
H
D
D
D
D
D
D
D
F
F
H
H
H
H
H
H
476
D
D
D
D
D
D
D
F
F
H
H
H
H
H
H
H
H
F
H
H
D
D
D
D
D
D
D
F
F
H
H
H
H
D
D
D
D
D
D
D
F
F
H
H
H
H
H
H
D
D
D
D
D
D
D
F
F
H
H
H
H
H
H
H
H
F
H
H
D
D
D
D
D
D
D
F
F
H
H
H
H
D
D
D
D
D
D
D
F
F
H
H
H
H
H
H
D
D
D
D
D
D
D
F
F
H
H
H
H
H
H
H
H
D
D
D
D
D
D
D
F
F
F F F F /
H
F
F F F F /
H
F
H
H
D
D
D
D
D
D
D
F
F
H
H
H
H
D
D
D
D
D
D
D
F
F
H
H
H
H
H
H
D
D
D
D
D
D
D
F
F
H
H
H
H
H
H
H
H
容量容差:
D:0.85±0.1mm 、E:1.00±0.1mm 、F:1.25±0.2mm 、H:1.60±0.2mm 、1.60±0.3*mm;
Tolerance:
COG(0.5pF~4.9pF): C ;COG(5.0pF~9.9pF): D;COG(≥10pF): F(±1%), G(±2%), J(±5%)
Thickness: D:0.85±0. 1mm、E:1.00±0. 1mm、F:1.25±0.2mm、H:1.60±0.2mm、1.60±0.3*mm;
14
D
D
D
D
D
D
D
F
D
D
D
D
D
D
D
F
D
D
D
D
D
D
D
F
F F F F
F F F F
E E E E
说明
厚度:
D
D
D
D
D
D
D
F
F F F F
F F F F
F F F
F F
H H
产品容量范围
多层片式陶瓷电容器产品目录
■ 1210[3225]尺寸
尺
寸
1210[3225]
系
列
COG (N)
型
X7R (B)
X6S (S)
X5R (X)
X7T (T)
Y5V (F)
号
CP
VDC
100
120
150
180
200
220
270
300
330
390
470
560
680
820
101
121
151
181
201
221
271
331
391
471
561
681
821
102
152
182
222
272
332
472
2
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
F
F
F
F
F
1 5 2 1 5 2 1 6 5 2 1 5 2 1 1 6 5 2 1 1 6 5 2 1 1 6 2 1 1 6 4 5 2 1 1 6
0 0 5 0 0 0 0 3 0 5 0 0 5 6 0 · 0 5 6 0 · 0 5 6 0 · 5 6 0 ·
0 5 6 0 ·
0 0 0 0
0 0 0 0 0 0
3
3
3
3
3
D
D
D
D
D
D
D
D
D
D
F
F
F
F
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
F
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
D
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F
F F F F F
562
F F F F F
682
F F F F F
103
F F F F F
153
F F F F F
223
H H F F
333
H H F F
473
G G F F
563
F F
683
F F
104
F F
154
H H
15
产品容量范围
多层片式陶瓷电容器产品目录
224
G H
334
G
394
G
474
G G G G G G G G G G G G G G G G G G G G G G G G G G
684
H H H H H H H H H H H H H H H H H H H H H H H H H H
105
225
H
H
H
H
H
/ H H H
/ H H H
/ H H H
/ H H H
/ H H H
G
G
G
G
G
M G M M
M G M M
M G M M
M G M M
M G M M
475
106
226
M M M
M M M
M M M
M M M
M M M
476
M M
M M
M M
M M
M M
107
M
M
M
M
M
说明
容量容差:
COG(≥10pF): F(±1%), G(±2%), J(±5%),K(±10%);
X7R/X5R/X6S/X7T:J(±5.0%);K(±10%);M(± 20%);
厚度:
D:0.85±0.1mm 、F:1.25±0.2mm 、H:1.60±0.2mm 、G:2.00±0.20mm 、M:2.50±0.30mm;
Tolerance:
COG(≥10pF): F(±1%), G(±2%), J(±5%);
Thickness: D:0.85±0.1mm 、F:1.25±0.2mm 、H:1.60±0.2mm 、G:2.00±0.20mm 、M:2.50±0.30mm;
16
产品尺寸
Dimensions
多层片式陶瓷电容器产品目录
产品尺寸
Dimensions
规格: 0201 、0402 、0603 、0805 、1206 、1210。
Chip Size:0201,0402,0603,0805, 1206 and 1210
规格
L
W
Type
(mm)
(mm)
e
(mm)
g min
T
(mm)
(mm)
0201
0.60±0.03
0.30±0.03
0. 1~0.2
0.2
0.30±0. 03
0402
1.00±0. 10
0.50±0. 10
0. 15~0.3
0.4
0.50±0. 10
0603
1.60±0. 10
0.80±0. 10
0.2~0.6
0.5
0.80±0. 10
0603*1 1.60±0.20*1 0.80±0.20*1 0.2~0.6
0.5
0.80±0.20*1
0.2~0.7
0.7
0.60±0. 10
0.85±0. 10
1.25±0.20
0805*1 2.00±0.20*1 1.25±0.20*1 0.2~0.7
0.7
0.60±0. 10
0.85±0. 10
1.25±0.20
2.00±0. 10
0805
1.25±0. 10
1206
3.20±0.20
0.3~0.8
1.6
0.85±0. 10
1.00±0. 10
1.25±0.20
1.60±0.20
1206*1
3.20±0.30*1 1.60±0.30*1 0.3~0.8
1.6
0.85±0. 10
1.00±0. 10
1.25±0.20
1.60±0.30*1
1210
3.20±0.30
0.3~0.8
1.6
0.85±0. 10
1.25±0.20
1.60±0.20
2.00±0.20
2.50±0.30
1210*1
3.20±0.40*1 2.5±0.30*1
0.3~0.8
1.6
0.85±0. 10
1.25±0.20
1.60±0.20
2.00±0.20
2.50±0.30
*1
1.60±0.20
2.5±0.20
标识该规格型号标识为 1uF 及以上规格产品尺寸。
17
技术要求和测试条件
Specification and Test Condition
多层片式陶瓷电容器产品目录
技术要求和测试条件
■ 外观 Appearance
类型 Dielectrics
COG/X7R/X5R/Y
5V
/X7T/X6S
技术要求 Specification
测试条件 Testing Condition
1/10L<L≤1/8L, 1/10W<W≤1/8W,
1/10T<t≤1/8T(I、W 、T 任意一项不符 合,均判定不合格)
(I、W 、T None is acceptable ,All judged unqualified)
目视检查
Visual inspection.
■ 尺寸 Dimensions
类型 Dielectrics
COG/X7R/X5R/Y
5V/ X7T/X6S
技术要求 Specification
在要求的范围内
用千分尺
Using calipers on micrometer
Within the specified dimensions
■ 容量 Capacitance
类型 Dielectrics
COG
技术要求 Specification
在要求的容值容差范围内
1.0±0.2Vrms, 1MHz±10%
Within the specified tolerance
(C>1000pF,1.0±0.2Vrms,
1KHz±10% ,)
A:±0.05pF; B:±0.1pF; C:±0.25pF; D:±0.5pF; J: ±5%
X7R/X5R/X7T
/X6S
在要求的容值容差范围内
tolerance
J: ±5%;K: ±10%; M: ±20%
在要求的容值容差范围内
Y5V
1.0±0.2Vrms, 1KHz±10%
(Cp>10uF,0.5±0. 1Vrms,
120±24Hz)
120±24Hz)
M: ±20%; Z: -20%, +80%
备注:
测试温度:25℃±3℃,测试湿度:<70%RH. 针对二类介质规格需去老化处理,条件:电容器在 150℃热处理 1 小时,
放置 48h 后进行测量。
18
技术要求和测试条件
多层片式陶瓷电容器产品目录
■ 损耗 Dissipation Factor
类型
Dielectrics
测试条件 Testing
Condition
技术要求 Specification
1.0±0.2Vrms,
1MHz±10% ,25 ℃
Cp1000pF, 1.0±0.2Vrms,
1K Hz±10%)
Cp≥30pF, Q≥1000
0201
≤25v
≤25v
0402
>25v
≤25v
0603
>25v
X7R/X5R/X7T
/X6S
≤25v
0805
>25v
≤25v
1206
>25v
1210
≤25v
UR
DF
UR≥50v
C≤0.22 ㎌
≤10.0%
C≤0.47 ㎌
≤7.0%
C>0.47 ㎌
≤10.0%
C≤0.1 ㎌
≤7.0%
C>0.1 ㎌
≤10.0%
C≤0.47 ㎌
≤7.0%
C>0.47 ㎌
≤10.0%
C≤0.1 ㎌
≤5.0%
0.1 ㎌<C≤0.22 ㎌
≤7.0%
C>0.22 ㎌
≤10.0%
C≤1 ㎌
≤7.0%
C>1 ㎌
≤10.0%
C≤0.47 ㎌
≤7.0%
C>0.47 ㎌
≤10.0%
C<2.2 ㎌
≤7.0%
2.2 ㎌≤C<47 ㎌
≤10.0%
C>1 ㎌
≤7.0%
1 ㎌≤C<47 ㎌
≤10.0%
C<2.2 ㎌
≤7.0%
2.2 ㎌≤C<47 ㎌
≤10.0%
( Cp > 10uF,0.5±0.1Vrms,
120±24Hz)
备注
DF≤7.0%
683>0402≥473,474>0603≥104
DF≤7.0%
UR=25v
Y5V
DF≤9.0%
105>0805≥334,475>1206≥684
1.0±0.2Vrms, 1KHz±10%,
106>1210≥105
(Cp > 10uF,0.5 ± 0.1Vrms,
0402≥683, 0603≥474 0805≥105
120±24Hz)
1206≥475, 1210≥106
25 ℃ , 预 处 理 后 48hrs 。
at
DF≤9.0%
UR=16v
DF≤12.5%
UR=10v
DF≤12.5%
UR=6.3v
DF≤15.0%
0402≥224, 0603≥225, 0805≥335
25 ℃ ,48hrs
after
annealing
1206≥106,1210≥226, 1812≥476
备注: 测试温度: 25℃±3℃,测试湿度: <70%RH. 针对二类介质规格需去老化处理,条件: 电容器在 150℃热处
理 1 小时,放置 48h 后进行测量。
19
技术要求和测试条件
多层片式陶瓷电容器产品目录
■ 绝缘电阻 Insulation Resistance
类型 Dielectrics
技术要求 Specification
UR≤50V ,大于 10 GΩ 或 100Ω·F /CR(大于其中较小的数
COG/X7R/
X5R/Y5V/X7T/X6S
值)
UR≤50V
,More than 10 GΩ or 100Ω·F /CR, whichever
is smaller.
UR≤50V
温度:25℃
Charge Time:60±5sec
Temperture:25℃
UR≤400V
COG/X7R/X7T/X6S
U 测=UR;
充电时间:60±5 秒
U 测=UR
UR>50V,大于4GΩ 或 100Ω·F/CR (大于其中较小的数值)
UR>400V U 测=400V;
UR>50V,More than 4 GΩ or 100Ω·F/CR , whichever is
充电时间:60±5 秒
smaller.
温度:25℃
Charge Time:60±5sec
Temperture:25℃
70%RH.
■ 耐电压 Dielectric Strength
类型Dielectrics
额定电压范围
耐电压性能测试方法Measuring Method
Rated voltage range
COG
X7R/X5R/Y5V/X7T/
X6S
UR≤50V
施加额定电压的 300%,5 秒,最大电流不超过50mA
Force 300%Rated voltage for 5second. Max..current should not
exceed 50 mA.
UR≤50V
施加额定电压的250%,5 秒,最大电流不超过50mA
Force 250%Rated voltage for 5second. Max..current should not
exceed 50 mA.
100V≤UR<500V
施加额定电压的200%,5 秒,最大电流不 超过50mA
Force 200%Rated voltage for 5second. Max..current should not
exceed 50 mA.
500V≤UR<1000V
COG/X7R/X7T
施加额定电压的 150%,5 秒,最大电流不 超过50mA
Force 150% Rated voltage for 5second. Max..current should not
exceed 50 mA.
1000V≤UR<2000V
Force 150%Rated voltage for 5second. Max..current should not
exceed 50 mA.
UR≥2000V
施加额定电压的 120%,5 秒,最大电流不 超过30mA
Force 120%Rated voltage for 5second. Max..current should not
exceed 30 mA.
技术要求和测试条件
多层片式陶瓷电容器产品目录
■ 静电容量温度特性 Temperature Coefficient of Capacitance
类型
Dielectrics
技术要求
Specification
测试条件
Testing Condition
按系列温度顺序测试电容容量
容量变化在±30ppm/℃以内
COG
容量漂移在±0.2%或±0.05p F 以内
Temperature coefficient within
±30ppm/℃;
Cp drift within ±0.2% or±0.05pF
Measure capacitance under follow table list temperature: 在 140~
150℃预处理 1 小时,放置24h 后进行测量。
步骤
COG,
STEP
X7R,X7T
25 ±2
25 ±2
25 ±2
25 ±2
-55±3
-55±3
-55±3
-30±3
1
2
X7R/X5R
X7T
X6S
3
容量变化在±15%以内
Capacitance change within
±15%
容量变化在+22%, -33%以内
+22%, -33%
容量变化在±22%以内
±22%
4
5
X6S
Y5V
Y5V
25 ±2
25 ±2
25 ±2
25 ±2
125±3
105±3
85±3
85±3
25 ±2
25 ±2
25 ±2
25 ±2
1) COG
容量漂移的计算方法为: 用步骤 3 测量的电容容值量除以在第
1 、3 和 5 步骤测量得到的误差的最大值和最小值的差。
温度系数的计算以第 3 步骤测量电容容量为参考。
The capacitance drift is calculated by dividing the differences
between the maximum and minimum measured values in the step
1,3 and 5.
The temperature coefficient is determined using the Capacitance
measured in step 3 as a reference.
2) X7R、X5R 、X7T 、X6S
容量变化在+22%, -82%以内
+22%, -82%
X5R
和 Y5V
与 25℃时的电容容量相比较,电容容量在温度范围内的变化在要求
的范围之内。
X7R
、X5R 、X7T 、X6S and Y5V
The ranges of capacitance change compared within the above 25℃
value over the temperature ranges shall be within the
specified ranges.
■ 附着力 Adhesion
类型 Dielectrics
技术要求 Specification
施加6N 的压力,并保持 10±1 秒
The pressurizing force shall be 6N (=600g*f) and the
duration of application shall be 10±1sec.
COG/X7R/X5R/
Y5V/X7T/X6S
端电极无松动,也无其它不良现象
No removal of the terminations or
other defect shall occur.
21
技术要求和测试条件
多层片式陶瓷电容器产品目录
■ 可焊性 Solder ability of Termination
类型 Dielectrics
技术要求 Specification
锡炉温度: 245±5℃
X7R/X5R/X7T
端电极挂锡面积不小于 95%,针孔或粗糙面积小于 5%
/X6S
95% min. coverage of both terminal electrodes and less
than 5% have pin holes or rough spots.
浸入时间:
2±1 秒
两侧端电极完全浸入焊锡炉
Solder temperature: 245±5℃
Dipping time: 2±1 seconds.
Completely soak both terminal
electrodes in solder
■ 耐焊性 Resistance to leaching
类型 Dielectrics
技术要求 Specification
预热: 120℃~ 150℃/60 秒
端电极挂锡面积不小于 95%,针孔或粗糙面积小于 5%,外
X7R/X5R/X7T
/X6S
观无开裂
No remarkable visual damage.
锡炉温度: 270±5℃
浸入时间:
10±1 秒
两侧端电极完全浸入焊锡炉
Solder temperature: 270±5℃
preheated: 120℃~ 150℃/60sec
Dipping time: 10±1 seconds.
■ 端电极结合强度 Bending
类型
Dielectrics
技术要求 Specification
无可见损伤;容量变化小于等于±5%或±
COG
0.5pF(取较大值)
No remarkable visual damage Cp change
within ±5.0% or ±0.5pF, whichever is larger.
X7R/X5R/X7T
/X6S
无可见损伤;
将片状电容器安装在测试夹具上,按图所示
方向以 1.0mm/s 的速率施加压力,弯曲 1mm。
Solder the capacitor on testing substrate and
put
it on testing stand. The middle part of substrate
shall successively be pressurized by
pressuring
rod at a rated of about 1.0mm/sec. Until the
deflection become means of the 1.0mm.)
容量变化小于等于±10%
No remarkable visual damage Cp change ≤
±10%
50 pressurizing
speeding:1.0mm/sec.
pressurize
无可见损伤;
Y5V
≤1
capacitance meter
容量变化小于等于 ±30%
±30%
22
技术要求和测试条件
多层片式陶瓷电容器产品目录
■ 耐焊接热 Resistance to Soldering Heat
类型
Dielectrics
技术要求 Specification
无明显可见损伤
容量变化在±2.5%或±0.25pF(取较大值)以内
DF 满足产品初始值的要求
COG
IR 满足产品初始值的要求
Cp change within ±2.5% or ±0.25pF,
焊接温度: 270±5℃
DF meets initial standard value.
预热: 120~ 150℃ 60 秒
IR meets initial standard value.
浸
入
在 室 温
时
间
下 放 置
10±1
24±2 (COG)
48±4(X7R 、 X5R、Y5V 、X7T 、X6S)
无明显可见损伤
时以后测量 试验后在标准条件下恢复
容量变化在±7.5%以内
*高介电常数电容器的初始值测量
/X6S
小
温下 放置 48±4 小时
IR 满足产品初始值的要求
测量初始值
Soldering temperature: 270±5℃
Preheating: 120~ 150℃ 60sec.
Dipping
time:
10±1
seconds.
Measurement
to
be
made
after
being
kept
at room
temperature
for
24±2
(COG)
or
48±4(X7R ,X5R, Y5V 、X7T 、X6S) hours.
Recovery
for
the
following
period
under
the standard condition after test.
*Initial measurement for high dielectric
constant
type
Perform a heat treatment at 140~ 150 ℃ for
1hr and let sit for 48±4hrs at room
temperature.
Perform the initial
measurement.
Cp change within ±7.5%
无明显可见损伤
容量变化在±20%以内
DF 满足产品初始值的要求
Y5V
或
在 140~ 150℃进行 1 小时的热处理后在室
DF 满足产品初始值的要求
X7R/X5R/X7T
秒
IR 满足产品初始值的要求
Cp change within ±20%
23
技术要求和测试条件
多层片式陶瓷电容器产品目录
■ 温度快速循环 Temperature Cycle
类型
Dielectrics
技术要求 Specification
无明显可见损伤
容量变化在±2.5%或 ±0.25pF (取较大值) 以
内
COG
Cp change within ±2.5% or ±0.25pF, whichever
is larger.
按下列步骤进行 5 次循环:
To perform 5 cycles of the stated
environment
步骤温度
Step Temperature
下限类别温度
+0/-3℃
25℃
上限类别温度
+3/-0℃
25℃
无明显可见损伤
X7R/X5R/X7T
/X6S
在室温下放置 48±4 (X7R, X5R, Y5V、X7T、
X6S) 小时以后测量
容量变化在±7.5%以内
*高介电常数电容器的初始值测量在 140~
150℃进行 1 小时的热处理后在室温下放置
48±4 小时测量初始值
Measurement to be made after being kept at
room temperature for 24±2hrs (COG) or
48±4hrs (X7R, X5R, Y5V、X7T、X6S) at
room temperature, then
measure.
constant type
for 1hr and let sit for 48±4hrs at room
temperature. Perform the initial
measurement.
无明显可见损伤
Y5V
容量变化在±20%以内
24
技术要求和测试条件
多层片式陶瓷电容器产品目录
类型
Dielectrics
技术要求 Specification
外观无明显可见损伤
容量变化在±5%或 ±0.5pF(取较大值) 以内
Cp
