HCB160806ZF-260T60
HCB160806ZF-260T60
    TAI-TECH(台庆)
    商规
HCB160806ZF-260T60 数据手册
TAI-TECH KBM01-221100437 High Current Ferrite Chip Bead(Lead Free) 1.Features P2. HCB160806ZF-260T60 Halogen 1. Monolithic inorganic material construction. Halogen-free 2. Closed magnetic circuit avoids crosstalk. 3. Suitable for reflow soldering. 4. Shapes and dimensions follow E.I.A. spec. 5. Available in various sizes. 6. Excellent solder ability and heat resistance. 7. High reliability. 8.100% Lead(Pb) & Halogen-Free and RoHS compliant. 9. Low DC resistance structure of electrode to prevent wasteful electric power consumption. 10. Operating Temperature: -55~+125℃(Including self-temperature rise) 2.Dimensions Chip Size A 1.60±0.15 B 0.80±0.15 C 0.60±0.15 D 0.30±0.20 Units: mm 3.Part Numbering HCB 160806 ZF A B A: Series B: Dimension C: Material D: Impedance E: Packaging F: Rated Current 260 T 60 C D E F Lead Free Material 260=26Ω T=Taping and Reel, B=Bulk(Bags) 60=6000mA 4.Specification ● Impedance (Ω) Test Frequency (Hz) DC Resistance (Ω) max. Rated Current (mA) max. HCB160806ZF-260T60 26±25% 60mV/100M 0.01 6000 Rated current: based on temperature rise test In compliance with EIA 595 „ Impedance-Frequency Characteristics HCB160806ZF-260T60 HCB1606ZF-260T60 40 IMPEDANCE(Ohm) ● Tai-Tech Part Number 30 Z 20 10 X R 0 1 10 100 1000 FREQUENCY(MHz) www.tai-tech.com.tw 10000 TAI-TECH KBM01-221100437 P3. 5. Reliability and Test Condition Item Series No. Operating Temperature Performance FCB FCM HCB Test Condition GHB FCA -55~+125℃ (Including self-temperature rise) -55~+125℃ (on board) Transportation Storage Temperature --For long storage conditions, please see the Application Notice Agilent4291 Agilent E4991 Impedance (Z) Agilent4287 Refer to standard electrical characteristics list Agilent16192 DC Resistance Agilent 4338 Rated Current DC Power Supply Over Rated Current requirements, there will be some risk Temperature Rise Test Rated Current < 1A ∆T 20℃Max Rated Current ≧ 1A ∆T 40℃Max Life test Appearance: no damage. Impedance: within±15%of initial value. RDC:within ±15% of initial value and shall not exceed the specification value Load Humidity Appearance: no damage. Thermal shock Vibration Bending Impedance: within±15%of initial value. RDC:within ±15% of initial value and shall not exceed the specification value 1. Applied the allowed DC current. 2. Temperature measured by digital surface thermometer. Preconditioning: Run through IR reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles) Temperature: 125±2℃ Applied current: rated current. Duration: 1000±12hrs. Measured at room temperature after placing for 24±2 hrs. Preconditioning: Run through IR reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles) Humidity: 85±2%R.H. Temperature: 85±2℃. Duration:1000hrsMin.Bead:with100%ratedcurr ent , Inductance: with 10% rated current Measured at room temperature after placing for 24±2 hrs.. Preconditioning: Run through IR reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles) Condition for 1 cycle Step1: -55±2℃ 30±5 min. Step2: 125±2℃ ≦0.5min Step3: 125±2℃ 30±5min. Number of cycles: 500 Measured at room temperature after placing for 24±2 hrs. Appearance:No damage. Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Preconditioning: Run through IR reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles) Oscillation Frequency: 10Hz ~ 2KHz ~ 10Hz for 20 minutes Equipment: Vibration checker Total Amplitude:10g Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 Appearance:No damage. Impedance:within±10% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Shall be mounted on a FR4 substrate of the following dimensions: >=0805inch(2012mm):40x100x1.2mm =0805inch(2012mm):1.2mm 0805inch(2012mm):1kg
HCB160806ZF-260T60 价格&库存
很抱歉,暂时无法提供与“HCB160806ZF-260T60”相匹配的价格&库存,您可以联系我们找货
HCB160806ZF-260T60
    • 100+0.03338
    • 1000+0.02614
    • 4000+0.02128
    库存:3601
