PESD5V0L1BA-ES
PESD5V0L1BA-ES
    ELECSUPER(静芯微)
    SOD-323
PESD5V0L1BA-ES 数据手册
PESD5V0L1BA Rev-1.1 www.elecsuper.com SuperESD - PESD5V0L1BA 1. Description The PESD5V0L1BA is Transient Voltage Suppressor that designed to protect components which are connected to data and transmission lines against electrostatic discharge (ESD), electrical fast transient (EFT), and lightning. All pins are rated to withstand 30kV ESD pulses using the IEC61000-4-2 air discharge method. 2. Features ⚫ IEC 61000-4-2 Level 4 ESD Protection ⚫ Working voltage: 5V - ±30kV Contact Discharge ⚫ Low leakage current - ±30kV Air Discharge ⚫ RoHS compliant ⚫ 250W Peak pulse Power (8/20us) ⚫ Protecting one bi-directional lines ⚫ Low clamping voltage ⚫ Junction capacitance: 30pF Typ. 3. Applications ⚫ Control & monitoring systems ⚫ Set-top box ⚫ Portable electronics ⚫ Communication systems ⚫ Servers, notebooks, and desktop PCs 4. Ordering Information Part Number Package Marking Material Packing PESD5V0L1BA SOD-323 |||||E6 Halogen free Tape & Reel Table-1 Copyright© ElecSuper Incorporated Quantity per reel 3,000 PCS Flammability Rating Reel Size UL 94V-0 7 inches Ordering information Contact Us 1 / 7 PESD5V0L1BA Rev-1.1 www.elecsuper.com 5. Pin Configuration and Functions Pin Name Description 1 IO1 Connect to IO 2 IO2 Outline Circuit Diagram 1 E6 Connect to IO Table-2 2 Pin configuration 6. Specification 6.1. Absolute Maximum rating Over operating free-air temperature range (unless otherwise noted) Parameters Symbol Min. Max. Unit Peak pulse power (tp=8/20us)@25℃ Ppk - 250 W Peak pulse current (tp=8/20us)@25℃ IPP 16 A ESD (IEC61000-4-2 air discharge) @25℃ VESD - ±30 kV ESD (IEC61000-4-2 contact discharge) @25℃ VESD - ±30 kV TJ - 150 ℃ Operating temperature TOP -40 125 ℃ Storage temperature TSTG -55 150 ℃ TL - 260 ℃ Junction temperature Lead temperature Table-3 Copyright© ElecSuper Incorporated Absolute Maximum rating Contact Us 2 / 7 PESD5V0L1BA Rev-1.1 www.elecsuper.com 6.2. Electrical Characteristics At TA = 25℃ unless otherwise noted Parameter Symbol Conditions Reverse Stand-off Voltage Reverse Breakdown Voltage Min. Typ. VRWM Max. Units 5 V VBR IT=1mA 6 V Reverse Leakage Current IR VRWM=5V Clamping Voltage VC IPP=1A; tp=8/20us 10 V Clamping Voltage VC IPP=16A; tp=8/20us 18 V Junction Capacitance CJ I/O to GND; VR=0V; f=1MHz 30 1 45 uA pF Table-4 Electrical Characteristics Symbol VRWM IR VBR Parameters Peak Reverse Working Voltage Reverse Leakage Current @ VRWM Breakdown Voltage @ IT IT Test Current IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP Copyright© ElecSuper Incorporated Contact Us 3 / 7 PESD5V0L1BA Rev-1.1 www.elecsuper.com 7. Typical Characteristic 8. Typical Application I/O1 I/O2 IC I/O3 I/O4 1 1 1 1 PESD5V0L1BA 2 2 2 2 Typical Interface Application Copyright© ElecSuper Incorporated Contact Us 4 / 7 PESD5V0L1BA Rev-1.1 www.elecsuper.com 9. Dimension E A b D A1 E1 A2 θ C L Symbol A A1 A2 b C D E E1 L L1 θ L1 SOD-323 Dimensions in Millimeters Min. Max. 1.000 0.000 0.100 0.800 0.900 0.250 0.350 0.080 0.150 1.200 1.400 1.600 1.800 2.550 2.750 0.475REF 0.250 0.400 0° 8° Table-6 Copyright© ElecSuper Incorporated Dimensions in Inches Min. Max. 0.039 0.000 0.004 0.031 0.035 0.010 0.014 0.003 0.006 0.047 0.055 0.063 0.071 0.100 0.108 0.019REF 0.010 0.016 0° 8° product dimensions Contact Us 5 / 7 PESD5V0L1BA Rev-1.1 www.elecsuper.com 10. Recommended Land Pattern Note: 1. Controlling dimension: in millimeters 2. General tolerance: ±0.05mm 3. The pad layout is for reference only 4. Unit: mm Copyright© ElecSuper Incorporated Contact Us 6 / 7 PESD5V0L1BA Rev-1.1 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application; (2) designing, validating and testing your application; (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products. Copyright© ElecSuper Incorporated Contact Us 7 / 7
PESD5V0L1BA-ES 价格&库存
很抱歉,暂时无法提供与“PESD5V0L1BA-ES”相匹配的价格&库存,您可以联系我们找货
PESD5V0L1BA-ES
  • 5+0.16470
  • 50+0.12960
  • 150+0.11006
  • 500+0.09839
  • 3000+0.08241
  • 6000+0.07690
库存:1239
