HoCS1225-3W-20mR-1%-TCR200
    MILLIOHM(毫欧)
    陶瓷电阻 20mΩ ±1% 3W
HoCS1225-3W-20mR-1%-TCR200 数据手册
系列号 修订日期 HoCS贴片陶瓷系列规格书 版本号 HoCS 2020-03-06 Ho-A0 ■Features -3 Watts power rating in 1 Watt size, 1225 package -Low TCR of ±100 PPM/°C -Resistance values from 1m to 1 ohm -High purity alumina substrate for high power dissipation -Long side terminations with higher power rating -RoHS Compliance ■Construction ■Applications L -Power Management Applications D1 -Switching Power Supply -Over Current Protection in Audio Applications w 3 4 5 6 T 9 8 7 1 2 D2 1 Alumina Substrate 2 Bottom Electrode 3 Top Electrode -Voltage Regulation Module (VRM) -DC-DC Converter, Battery Pack, Charger, Adaptor -Automotive Engine Control -Disk Driver 4 Edge Electrode 5 Barrier Layer 6 External Electrode 7 Resistor Layer 8 Primary Overcoat 9 Secondary Overcoat ■Dimensions Type Size (Inch) CS Weight (g) L W T D1 D2 (mm) (mm) (mm) (mm) (mm) (1000pcs) 0201 0.60±0.03 0.30±0.03 0.23±0.05 0.12±0.05 0.15±0.05 0.18 CS 0402 1.00±0.05 0.50±0.05 0.32±0.10 0.25±0.10 0.20±0.10 0.7 CS 0603 1.60±0.10 0.80±0.10 0.45±0.10 0.30±0.20 0.30±0.20 1.99 CS 0805 2.00±0.10 1.25±0.10 0.55±0.10 0.30±0.20 0.40±0.25 5.3 CS 1206 3.10±0.10 1.55±0.10 0.55±0.10 0.50±0.30 0.40±0.25 8.82 CS 1210 3.10±0.10 2.60±0.15 0.55±0.10 0.50±0.30 0.50±0.25 15.5 CS 2010 5.00±0.10 2.50±0.15 0.60±0.15 0.60±0.30 0.50±0.25 27.03 CS 2512 6.35±0.10 3.10±0.15 0.60±0.10 0.60±0.30 0.55±0.25 43.08 6.35±0.20 3.15±0.15 0.74±0.10 0.60±0.30 0.55±0.25 53.08 6.35±0.20 3.15±0.15 0.74±0.10 0.60±0.30 2.10±0.10 53.08 CS (2W) CS (2W) 2512 (10 - 99mΩ) 2512 (100 - 1000mΩ) CS 1225 3.10±0.15 6.30±0.15 0.90±0.15 0.60±0.30 0.80±0.25 64.88 CS 3720 2.00±0.20 3.75±0.20 0.60±0.10 0.40±0.20 0.40±0.20 19.96 CS 7520 2.00±0.20 7.50±0.30 0.60±0.10 0.40±0.20 0.40±0.20 35.71 CS 0612 1.55±0.10 3.10±0.15 0.55±0.10 0.30±0.15 0.45±0.15 10.19 地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A 栋 8 楼 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 系列号 HoCS 修订日期 HoCS贴片陶瓷系列规格书 2020-03-06 Ho-A0 版本号 ■Part Numbering CS Product Type 0603 1/4W Dimensions (L×W) Power Rating 0201 0402 0603 0805 1206 1210 2010 2512 1225 3720 7520 0612 1% R100 Resistance R010: 0.01Ω R100: 0.1Ω 1R00: 1Ω 2W 1.5W 1W 3/4W 1/2W 1/4W 1/5W 1/8W ±100 Resistance Tolerance TCR (PPM/°C) ±100 ±200 ±300 ±400 ±600 ±150 ±1000 ±0.5% ±1% ±2% ±5% ■Recommend Land Pattern ■Derating Curve Power ratio(%) . 100 C B A 80 60 40 20 0 0 20 40 60 80 100 120 140 160 180 Ambient Temperature(℃) Pad Layout (Except For CS12:Ultra High Power Rating Series) ■Marking for 0603 A (mm) B (mm) C (mm) CS0201 0.25 0.30 0.40±0.2 CS0402 0.50 0.50 0.60±0.2 CS0603 0.80 1.00 CS0805 1.00 CS1206 Type Type Code 0.90±0.2 1R0 1.000Ω 1.00 1.35±0.2 R10 0.100Ω 2.00 1.15 1.70±0.2 R01 0.010Ω CS1210 2.00 1.15 2.50±0.2 102 0.102Ω CS2110 3.60 1.40 2.50±0.2 CS2512 4.90 1.60 3.20±0.2 024 0.024Ω CS1225 1.20 2.00 7.00±0.2 CS3720 1.00 1.80 3.90±0.2 CS7520 1.00 1.80 7.60±0.2 CS0612 0.60 1.00 3.20±0.2 Pad Layout ( For CS12: Ultra High Power Rating Series) Resistance Range A (mm) B (mm) C (mm) CS2512 10~99 mΩ 4.9 1.6 3.2±0.2 CS2512 100~1000mΩ 1.0 3.55 3.2±0.2 Type 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 系列号 修订日期 HoCS贴片陶瓷系列规格书 版本号 HoCS 2020-03-06 Ho-A0 ■Soldering Condition IR Reflow Soldering Wave Soldering (Flow Soldering) (1) Time of IR reflow soldering at maximum temperature point 260°C:10s (2) Time of wave soldering at maximum temperature point 260°C:10s (3) Time of soldering iron at maximum temperature point 410°C:5s ■Standard Electrical Specifications Item Type Power Rating at 70°C Operating Temp. Range Max. Operating Current Resistance Range (mΩ) TCR (PPM/°C) ±0.5% ±1% ±2% ±5% CS0201 1/20W 0.70A 100 - 147 150 - 500 510 - 1000 ±1000 ±600 ±300 CS0402 1/16W 1.11A 50 - 100 102 - 500 510 - 1000 ±400 ±300 ±200 2.23A 20 - 50 51 - 100 102 - 500 510 - 1000 ±600 ±400 ±300 ±200 ±600 ±400 ±300 ±200 CS0603 1/10W CS0805 1/8W 2.50A 20 - 50 51 - 100 102 -196 200 - 1000 CS1206 1/4W CS1210 1/2W CS2010 3/4W CS12512 1W 5.00A 7.07A 8.66A 10.0A 10 - 20 21 - 50 51 - 91 100 - 1000 ±600 ±400 ±300 ±200 ±300 ±200 ±150 ±100 ±300 ±150 -55 ~ +155°C CS1225 3W 31.6A 3-5 6 - 20 21 - 30 33 - 8000 CS3720 1W 10.0A 10 - 18 20 - 500 CS7520 2W 44.7A CS0612 1W 10.0A - 1-4 5 - 10 11 - 350 10 - 27 30 - 91 100 – 499 500 - 1000 ±300 ±200 ±150 ±600 ±300 ±200 ±100 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 系列号 修订日期 HoCS贴片陶瓷系列规格书 版本号 HoCS 2020-03-06 Ho-A0 ■High Power & Ultra High Power Rating Electrical Specifications Item Type Power Rating at 70°C Operating Temp. Range Max. Operating Current CS0402 1/8W 1.56A CS0603 1/8W 1/5W 1.98A CS0805 1/4W 2.21A CS1206 1/2W CS1210 3/4W 8.66A CS2010 1W 10.0A CS2512 1.5W 12.2A CS2512 *2W 14.1A -55 ~ +155°C Resistance Range (mΩ) ±0.5% ±1% ±2% ±5% TCR (PPM/°C) 51 - 100 102 - 500 510 - 1000 ±400 ±300 ±200 10 - 20 21 - 50 51 - 91 100 - 1000 ±600 ±400 ±300 ±200 7.07A *: Ultra High Power ■Low TCR Electrical Specifications Item Type Power Rating at 70°C Operating Temp. Range Max. Operating Current Resistance Range (mΩ) ±0.5% ±1% ±2% ±5% TCR (PPM/°C) CS0805 1/8W 1.11A 100 - 1000 ±100 CS1206 1/4W 1.58A 100 - 1000 ±100 CS1210 1/2W 2.58A 75 - 1000 ±100 CS2010 3/4W 3.87A 50 - 1000 ±100 CS2512 1W 7.07A 20 - 1000 ±100 CS2512 *2W 6.32A 50 - 1000 ±100 CS3720 1W 3.16A 100 - 500 ±100 CS7520 2W 6.32A 50 - 350 ±100 -55 ~ +155°C Operating Current=√(P/R) 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 系列号 HoCS贴片陶瓷系列规格书 修订日期 版本号 HoCS 2020-03-06 Ho-A0 ■Environmental Characteristics Item Temperature Coefficient of Resistance (T.C.R.) Requirement As Spec. Insulation Resistance Endurance JIS-C-5201-1 4.8 IEC-60115-1 4.8 -55°C~+125°C, 25°C is the reference temperature ±(0.5%+0.05Ω) Short Time Overload Test Method ±(1.0%+0.05Ω) For High power rating ≧10G ±(1.0%+0.05Ω) Damp Heat with Load ±(0.5%+0.05Ω) Dry Heat ±(0.5%+0.05Ω) JIS C 5201-1 4.13 IEC 60115-1 4.13 RCWV*2.5 or Max. Overload Voltage whichever is lower for 5 seconds JIS-C-5201-1 4.6 IEC-60115-1 4.6 Max. Overload Voltage for 1 minute JIS-C-5201-1 4.25 IEC-60115-1 4.25.1 70±2°C, RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” JIS-C-5201-1 4.24 IEC-60115-1 4.24 40±2°C, 90~95% R.H., RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” JIS-C-5201-1 4.23 IEC-60115-1 4.23.2 at +155°C for 1000 hrs Bending Strength ±(1.0%+0.05Ω) Solderability 95% min. coverage JIS-C-5201-1 4.33 IEC-60115-1 4.33 Bending once for 5 seconds with 3mm 2010, 2512 sizes: 2mm JIS-C-5201-1 4.17 IEC-60115-1 4.17 245±5°C for 3 seconds Resistance to Soldering Heat ±(0.5%+0.05Ω) JIS-C-5201-1 4.18 IEC-60115-1 4.18 260±5°C for 10 seconds Voltage Proof Leaching Rapid Change of Temperature No breakdown or flashover Individual leaching area ≦5% Total leaching area ≦10% ±(0.5%+0.05Ω) JIS-C-5201-1 4.7 IEC-60115-1 4.7 1.42 times Max. Operating Voltage for 1 minute JIS-C-5201-1 4.18 IEC-60068-2-58 8.2.1 260±5°C for 30 seconds JIS-C-5201-1 4.19 IEC-60115-1 4.19 -55°C to +155°C, 5 cycles RCWV(Rated Continuous Working Voltage)=√(P*R) or Max. Operating Voltage whichever is lower. ■ Storage Temperature: 15~28°C; Humidity < 80%RH 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 系列号 修订日期 HoCS贴片陶瓷系列规格书 版本号 HoCS 2020-03-06 Ho-A0 ▓Packaging Packaging Quantity & Reel Specifications Embossed ΦC (mm) W (mm) T (mm) Paper Tape (EA) CS0201 178.0±1.0 60.0+1.0 13.5±0.7 9.5±0.1 11.5±1.0 10,000 CS0402 178.0±1.0 60.0+1.0 13.5±0.7 9.5±0.1 11.5±1.0 10,000 - CS0603 178.0±1.0 60.0+1.0 13.5±0.7 9.5±0.1 11.5±1.0 5,000 - CS0805 178.0±1.0 60.0+1.0 13.5±0.7 9.5±0.1 11.5±1.0 5,000 - CS1206 178.0±1.0 60.0+1.0 13.5±0.7 9.5±0.1 11.5±1.0 5,000 - CS1210 178.0±1.0 60.0+1.0 13.5±0.7 9.5±0.1 11.5±1.0 5,000 CS2010 178.0±1.0 60.0+1.0 13.5±0.7 13.5±1.0 15.5±1.0 - 4,000 CS2512 178.0±1.0 60.0+1.0 13.5±0.7 13.5±1.0 15.5±1.0 - 4,000 CS2512 178.0±1.0 60.0+1.0 (2W) 13.5±0.7 13.5±1.0 15.5±1.0 - 2,000 CS1225 178.0±1.0 60.0+1.0 13.5±0.7 13.5±1.0 15.5±1.0 - 2,000 CS3720 178.0±1.0 60.0+1.0 13.5±0.7 13.5±1.0 15.5±1.0 - 2,000 CS7520 178.0±1.0 60.0+1.0 13.5±0.7 17.5±1.0 19.5±1.0 - 2,000 CS0612 178.0±1.0 60.0+1.0 13.5±0.7 9.5±0.1 11.5±1.0 5,000 - Type ΦA (mm) ΦB (mm) Plastic Tape (EA) Paper Tape Specifications B ottom T ape T op T ape ψ D0 E A F B T P aper T ape P2 P0 d irection o f un reeling B (mm) W (mm) E (mm) F (mm) P0 (mm) P1 (mm) CS0201 0.38±0.05 0.68±0.05 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 2.00±0.05 2.00±0.05 1.50+0.1,-0 0.42±0.20 CS0402 0.65±0.10 1.15±0.10 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 2.00±0.05 2.00±0.05 1.50+0.1,-0 0.45±0.10 CS0603 1.10±0.10 1.90±0.10 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.70±0.10 CS0805 1.60±0.10 2.40±0.20 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 CS1206 1.90±0.10 3.50±0.20 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 CS1210 2.90±0.10 3.50±0.20 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 CS0612 1.90±0.10 3.50±0.20 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 Type A (mm) P1 R esistor W P2 (mm) ΦD0 (mm) T (mm) 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 系列号 修订日期 HoCS贴片陶瓷系列规格书 版本号 HoCS 2020-03-06 Ho-A0 Emboss Plastic Tape Specifications Top Tape ψ D0 E A F B W ψ D1 1.4Min. T P1 Resistor P2 P0 direction of unreeling Emboss Tape Type A (mm) B (mm) W (mm) E (mm) F (mm) P0 (mm) P1 (mm) P2 (mm) ΦD0 (mm) T (mm) CS2010 2.80±0.10 5.50±0.10 12.0±0.30 1.75±0.10 5.5±0.05 4.00±0.05 4.00±0.10 2.00±0.05 1.50+0.10 1.00±0.20 CS2512 3.50±0.10 6.70±0.10 12.0±0.30 1.75±0.10 5.5±0.05 4.00±0.05 4.00±0.10 2.00±0.05 1.50+0.10 1.00±0.20 CS2512 (2W)3.38±0.10 6.68±0.10 12.0±0.30 1.75±0.10 5.5±0.10 4.00±0.10 4.00±0.10 2.00±0.05 1.55+0.05 1.45±0.20 CS1225 3.38±0.10 6.68±0.10 12.0±0.30 1.75±0.10 5.5±0.10 4.00±0.10 4.00±0.10 2.00±0.05 1.55+0.05 1.45±0.20 CS3720 2.50±0.20 4.45±0.20 12.0±0.30 1.75±0.10 5.5±0.05 4.00 ±0.05 4.00±0.10 2.00±0.05 1.50+0.10 1.20 ±0.20 CS7520 2.50±0.20 8.30±0.20 16.0±0.30 1.75±0.10 7.8±0.05 4.00±0.05 4.00±0.10 2.00±0.05 1.50+0.10 1.20 ±0.20 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn
HoCS1225-3W-20mR-1%-TCR200 价格&库存
很抱歉,暂时无法提供与“HoCS1225-3W-20mR-1%-TCR200”相匹配的价格&库存,您可以联系我们找货
