SS52A-SS520A
SCHOTTKY BARRIER DIODE
FEATURES
Small Surface Mount device
Low power loss, high efficiency
High forward surge current capability
For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
SMA
MECHANICAL DATA
Case: SMA(DO-214AC)
Case Material: Molded Plastic. UL flammability
Classification Rating: 94V-0
Weight: 0.065 grams (approximate)
MAXIMUM RATINGS AND CHARACTERISTICS(TA = 25°C unless otherwise noted)
Symbol SS52ASS53A SS54A SS55A SS56A SS58A SS510A SS515A SS520A Unit
Parameter
Repetitive peak reverse voltage
VRRM
40
50
60
80
100
150
200
V
RMS Reverse Voltage
VRMS
14
21
28
35
42
56
70
105
140
V
DC Reverse Voltage
VR
40
50
60
80
100
150
200
V
Mean rectifying current
IF
5.0
A
Non-Repetitive Peak Forward
Surge Current @ t = 8.3 ms
IFSM
100
A
Thermal Resistance From Junction
To Ambient(1)
RθJA
60
RθJL
22
Junction Temperature
TJ
Storage Temperature
TSTG
°C/W
-55 ~+125
-55 ~+125
°C
-55 ~+150
°C
ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified)
Parameter
Symbol SS52A SS53A SS54A SS55A SS56A SS58A SS510A SS515A SS520A
Forward voltage
VF
Reverse current
IR
Junction capacitance
CJ
0.60
265
0.70
0.90
0.85
Unit
Conditions
V
IF=5A
0.5
0.1
mA V=VR,Ta=25°C
10
5
mA V=VR,Ta=100°C
210
150
100
pF
VR=4V,f=1MHZ
NOTE:
(1)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
© SHENZHEN HOTTECH ELECTRONICS CO.,LTD
E-mail:hkt@heketai.com
1/4
SS52A-SS520A
Typical Characteristics
FIG.1 :IO -TL Curve
FIG.2:Surge Forward Current Capability
250
Peak Forward Surge Current(A)
Average Rectifield Output Current(A)
5.0
4.0
3.0
2.0
8.3ms Single Half Sine Wave
JEDEC Method
200
150
100
50
1.0
80
120
Lead Temperature(°C
1
160
Number of Cycles
FIG.3:Typical Forward Characteristics
FIG.4:Typical Reverse Characteristics
10000
100
TJ=25℃
Pulse width=300us
1% duty cycle
10
Instantaneous Reverse Leakage
Current(uA)
Instantaneous Forward Current(A)
10
SS54A
1
SS510A
0.1
TJ=100℃
1000
SS52A-SS56A
100
TJ=25℃
10
1
SS58A-SS520A
TJ=100℃
0.1
0.01
TJ=25℃
0.01
0.1
0.2
0.3
0.4
0.5
0.6
Instantaneous Forward Voltage(V)
0.7
0.8
0.001
60
80
100
Percent of Rated Reverse Voltage(%)
2/4
SS52A-SS520A
SMA Package Outline Dimensions
Symbol
Dimensions In Millimeters
Min.
Max.
A
2.20
B
Dimensions In Inches
Max.
2.80
Min.
0.086
1.30
1.70
0.051
0.067
C
4.70
5.30
0.185
0.209
D
1.70
2.55
0.067
0.100
E
0.90
1.50
0.035
0.059
F
0.90
1.50
0.035
0.059
0.110
SMA Suggested Pad Layout
Note:
1.Controlling dimension: in millimeters
2.General tolerance: ±0.05mm
3.The pad layout is for reference purposes only
3/4
SS52A-SS520A
SMA Tape and Reel
SMA Embossed Carrier Tape
DIMENSIONS ARE IN MILLIMETER
TYPE
A
B
C
d
E
F
P0
P
P1
W
SMA
2.89
5.35
2.68
Ø1.50
1.75
5.50
4.00
4.00
2.00
12.00
TOLERANCE
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
SMA Tape Leader and Trailer
SMA Reel
REEL OPTION
7’’ DIA
TOLERANCE
D
D1
D2
G
H
I
W1
W2
Ø178
54.40
13.00
R78
R25.60
R6.50
12.40
17.60
±2
±1
±1
±1
±1
±1
±1
±1
4/4
很抱歉,暂时无法提供与“SS510A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.35551
- 100+0.29406
- 300+0.26337
- 2000+0.22623
- 4000+0.20776
- 10000+0.19853
