HoMAT1206-1W-33mR-1%
    MILLIOHM(毫欧)
    33mΩ ±1% 1W
HoMAT1206-1W-33mR-1% 数据手册
HoMAT封体合金电阻规格书 系列号 HoMAT 修订日期 2021-7-12 版本号 Ho-A0 Application Features Entertainment product Low Resistance / Low TCR Power supply Excellent long term stability Measuring instrument RoHs compliant and halogen free. Industrial product Lead free. Battery management system High precision current sensing and voltage division. ■ Parts Number Explanation Example: Ho 制造商 MAT 2512 2W 5mR 1% 产品系列 封装 额定功率 阻值 精度 0.5W 0m20=0.2mR 0.75W 2m50=2.5mR D=±0.5% 1W R000=0mR 2W R005=5mR 3W R100=100mR 4W R500=500mR 0805 1206 毫欧电子 封体合金 2512 2725 2728 4527 F=±1% G=±2% J=±5% 5W ■ Construction 0805 1206、2512、2725、2728、4527 地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A栋 8 楼 深圳市毫欧电子有限公司 | 电话: 0755-81488408 | 传真: 0755-22630181 | 网址: www.moolee.com.cn HoMAT封体合金电阻规格书 ■ 系列号 HoMAT 修订日期 2021-07-12 版本号 Ho-A0 Standard Electrical Specifications TYPE Rating Power at 70 31.62A 70.71A --- 0.5~1 ±75 18.26A 40.82A --- 1.5~2 MnCuSn ±50 14.14A 31.62A 7~13 2.5~13 R002.5~R008: ±100 44.72A 89.44A --- 0.5~1 ±75 25.81A 51.63A --- 1.5~2 ±50 20.0A 40.0A 7~13 2.5~13 0.75W 3.83A 7.66A 51~100 51~100 R051~R100 FeCrAl 1W 31.62A 63.24A 7~50 1~50 R001 MnCuSn R002~R007 MnCu MAT0805 1W ±50 1.5W 1W ±75 MAT2728 Operating Temperature Range ( ) R0005~R002: MnCu R009~R010: FeCrAl R008~R050 FeCrAl 38.72A 77.49A 7~10 1~10 44.72A 100.00A --- 0.5~0.75 1W ±50 31.62A 70.71A 7~450 1~450 2W ±75 63.24A 141.42A --- 0.5~0.75 2W ±50 44.72A 100.00A 7~450 1~450 3W ±75 77.45A 154.91A --- 0.5~0.75 3W ±50 54.77A 109.54A 7~100 1~100 ±75 126.49A 252.98A ±50 89.44A 178.88A 4W ±50 31.62A 63.24A 2W ±75 63.24A 2W ±50 44.72A MAT2512 MAT2725 Material ±100 0.5W MAT1206 T.C.R. Max. Rating Max. Overload Current (ppm/ ) Current Resistance Range (m ) 1.0% (F) 0.5% (D) 2.0% (G) 5.0% (J) 0.25~0.3 --- 4W R001 MnCuSn R002~R007 MnCu R008~R010 FeCrAl R0005~R00075 MnCuSn R001~R006 MnCu R007~R450 FeCrAl R0005~R00075 MnCuSn R001~R006 MnCu R007~R450 FeCrAl R0005~R00075 MnCuSn R001~R006 MnCu R007~R100 FeCrAl R00025~R0003 MnCuSn 0.5~3 R0005~R0025 MnCu R003 FeCrAl 7~450 4~450 R004~R450 FeCrAl 141.42A --- 0.5 100.00A 7~100 1~100 MAT4527 - 55 ~ + 170 R0005 MnCuSn R001~R005 MnCu R006~R100 FeCrAl 地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A栋 8 楼 深圳市毫欧电子有限公司 | 电话: 0755-81488408 | 传真: 0755-22630181 | 网址: www.moolee.com.cn HoMAT封体合金电阻规格书 ■ 系列号 HoMAT 修订日期 2021-07-12 版本号 Ho-A0 Standard Electrical Specifications Rating Power at 70 TYPE MAT4527 T.C.R. Max. Rating Max. Overload Current (ppm/ ) Current Resistance Range (m ) 1.0% (F) 0.5% (D) 2.0% (G) 5.0% (J) 3W ±75 77.45 173.20 --- 0.5 3W ±50 54.77 122.47 7~60 1~60 5W ±75 100.00 173.20 --- 0.5 5W ±50 70.71 122.47 7~500 1~500 Operating Temperature Range ( ) Material R0005 MnCuSn R001~R005 MnCu R006~R060 FeCrAl - 55 ~ + 170 R0005 MnCuSn R001~R005 MnCu R006~R500 FeCrAl Jumper Specifications Rating Power at 70 Max. Rating Current 0.5W 50A 0.20 1W 70.7A 0.20 MAT1206 1W 70.7A MAT2512 2W 100A Type Resistance Material Operating Temperature Range ( ) MAT0805 Jumper Cu -55~+170°C 0.2 Type Dimension Type MAT0805 Power Rating 0.5W&1 W Resistance Range L W H 0.5mR 0.60±0.20 1mR 0.55±0.20 1.5mR、2.5mR 2.05±0.25 1.30±0.30 0.45±0.20 2mR~8mR 0.35±0.20 9mR~13mR 0.37±0.20 T2 0.75±0.20 0.40±0.20 地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A栋 8 楼 深圳市毫欧电子有限公司 | 电话: 0755-81488408 | 传真: 0755-22630181 | 网址: www.moolee.com.cn HoMAT封体合金电阻规格书 系列号 HoMAT 修订日期 2021-07-12 版本号 Ho-A0 Type Dimension Type Power Rating 0.75W MAT1206 1W 1.5W Resistance Range L W H 51~75mR 0.40±0.25 76~100mR 0.35±0.25 1mR 0.77±0.25 2mR 3mR~20mR T1 0.65±0.25 3.2±0.254 1.65±0.254 0.55±0.25 0.508±0.25 0.47±0.25 1mR 0.77±0.25 2mR 0.65±0.25 3mR~10mR 0.55±0.25 0.5mR 0.77±0.25 2.20±0.25 0.75mR 0.65±0.25 1.98±0.25 2.20±0.25 1.5mR 0.67±0.25 1.15±0.25 2.5mR~6mR 0.55±0.25 7mR~10mR 0.60±0.25 11mR~75mR 0.60±0.25 76mR~100mR 0.55±0.25 101mR~135mR 6.35±0.25 3.05±0.25 1.05±0.25 0.47±0.25 0.40±0.25 201mR~450mR 0.85±0.25 0.5mR 0.77±0.25 2.20±0.25 0.75mR 0.65±0.25 1.98±0.25 1.15±0.25 1mR 1.5mR 1.15±0.25 2mR 2.5mR~6mR 0.55±0.25 7mR~75mR 0.60±0.25 76mR~100mR 0.55±0.25 0.75±0.25 0.5mR 1mR 6.80±0.25 1.80±0.25 1.15±0.254 6.35±0.25 1.10±0.25 2.30±0.25 0.77±0.25 0.3mR 4W 2.2±0.25 1.40±0.25 0.67±0.25 0.25mR MAT2725 1.10±0.25 0.75±0.25 136mR~200mR 3W 1.40±0.25 1.15±0.25 2mR MAT2512 0.508±0.20 21mR~50mR 1mR 1W 2W T2 0.65±0.25 2.30±0.25 1.80±0.25 1.5mR 2mR~3mR 0.55±0.25 1.50±0.25 地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A栋 8 楼 深圳市毫欧电子有限公司 | 电话: 0755-81488408 | 传真: 0755-22630181 | 网址: www.moolee.com.cn HoMAT封体合金电阻规格书 系列号 HoMAT 修订日期 2021-07-12 版本号 Ho-A0 Type Dimension Type Resistance Range Power Rating MAT2728 4mR~450mR 4W L W H T1 T2 6.60±0.25 6.70±0.25 0.58±0.25 0.40±0.25 1.05±0.25 0.5mR 0.77±0.25 3.00±0.25 1mR 2W 0.65±0.25 1.5mR~5mR 6mR~100mR 0.55±0.25 0.5mR 0.77±0.25 1mR MAT4527 3W 2.00±0.25 0.9±0.25 3.00±0.25 11.30±0.50 6.60±0.50 0.65±0.25 1.5mR~5mR 2.00±0.25 6mR~60mR 0.55±0.25 0.5mR 0.80±0.25 1mR 5W 0.68±0.25 1.5mR~5mR 3.00±0.25 0.65±0.25 2.00±0.25 6mR~450mR 0.58±0.25 Jumper Dimension Type Power Rating MAT0805 0.5W&1W Resistance Range L W H ≤0.2mR 2.05±0.25 1.30±0.30 0.45±0.20 T1 T2 0.40±0.20 MAT1206 1W < 0.2mR 3.20±0.25 1.65±0.25 0.65±0.25 0.508±0.25 0.508±0.25 MAT2512 2W < 0.2mR 6.35±0.25 3.05±0.25 0.65±0.25 1.15±0.25 1.100±0.25 Performance Characteristics Power Derating Curve The Operating Temperature Range: -55°C ~+170°C. For resistors operated in ambient temperatures above 70°C, power rating must be derating in accordance with the curve below. 地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A栋 8 楼 深圳市毫欧电子有限公司 | 电话: 0755-81488408 | 传真: 0755-22630181 | 网址: www.moolee.com.cn HoMAT封体合金电阻规格书 系列号 HoMAT 修订日期 2021-07-12 版本号 Ho-A0 Rating Current The following equation may be used to determine the DC (Direct Current) or AC (Alternating Current) (RMS, root mean square value) of normal rated power. However, if the result value exceeds the highest current of regulated standards (paragraph 5), the highest normal rated power is to be used. I = Rating current (A) P= Rating Power (W) R= Resistance( ) Marking Format: All the other products marking are 4 digits. the decimal location in ohms location in milli-ohms duct marking is 0m25. ing is 0m50. 0 product marking is 0R. The criteria to distinguishing the mark on the surface of products are that characters can be identified. Reliability test and requirement Test Item Temperature Coefficient of Resistance (T.C.R) Test Method Procedure JIS-C-5201-1 4.8 At 25 /+150 IEC-60115-1 4.8 temperature , 25 is the reference Requirements As Spec The number of rated power are as follows: Short Time Overload JIS-C-5201-1 4.13 IEC-60115-1 4.13 MA0805-0.5W: 5 times of rated power MA0805-1W: 4 times of rated power MA1206-0.75W: 4 times of rated power MA1206-1W: 4 times of rated power MA1206-1.5W: 4 times of rated power MA2512-1W: 5 times of rated power MA2512-2W: 5 times of rated power MA2512-3W: 5 times of ratedpower*(Note)* MA2725-4W: 4 times of rated power MA2728-4W: 4 times of rated power MA4527-2W: 5 times of rated power MA4527-3W: 5 times of rated power MA4527-5W: 3 times of rated power MA4527 R/R1 ±2.0% The others: R/R1 ±0.5% for 5 seconds. 地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A栋 8 楼 深圳市毫欧电子有限公司 | 电话: 0755-81488408 | 传真: 0755-22630181 | 网址: www.moolee.com.cn HoMAT封体合金电阻规格书 系列号 HoMAT 修订日期 2021-07-12 版本号 Ho-A0 Reliability test and requirement Test Item Test Method High Temperature Exposure (Storage) MIL-STD-202 Method 108 Procedure 1000 hrs. @ T=170°C. Unpowered. Measurement at 24±4 hours after test conclusion. Resistance to Soldering JIS-C-5201-1 4.18 260±5 Heat IEC-60115-1 4.18 Temperature Cycling Biased Humidity Load Life (Endurance) JESD22 Method JA-104 MIL-STD-202 Method 103 J-STD-002 Dielectric Withstanding JIS-C5201-1 Board Flex Terminal Strength (SMD) Moisture Resistance R/R1= ± 1.0% R/R1= ± 0.5% for 10 seconds. 1000 Cycles (-55°C to +155°C)Measurement at 24±4 hours after test conclusion. 30min maximum dwell time at each temperature extreme. R/R1= ± 0.5% 1,000 hours; 85°C / 85% RH, 10% of operating power. Measurement at 24±4 hours after test conclusion. R/R1= ± 0.5% JIS-C-5201-1 4.25 70±2 , RCWV or Max. working voltage whichever IEC-60115-1 4.25.1 is less for 1000 hrs with 1.5 hrs ON and 0.5 hr OFF Solderability Voltage Requirements (1) 4 hrs 155 dry heat (2) 245±5 3 sec. R/R1= ± 0.5% >95% coverage Applied 500VAC for 1 minute, and Limit surge current 50 No short or burned on the mA (max.) appearance. AEC Q200-005 Beading once for 60 seconds 0805:2mm No broken AEC Q200-006 Pressurizing force 17.7N for 60 seconds clause 4.7 MIL-STD 202 Method 106 R/R1 0.5% R/R1 0.5% No broken T=24 hours / Cycle ,10Cycles . Steps 7a& 7b not required. Unpowered .(Figure 1) ± 1.0% R/R1= For Jumper Test Item Test Method Procedure Requirements Short Time Overload JIS-C-5201-1 4.13 IEC-60115-1 4.13 4 times of rated power for 5 seconds. Temperature Cycling JESD22 Method JA-104 1000 Cycles (-55°C to +155°C) Measurement at 24±4 hours after test conclusion. 30min maximum dwell time at each temperature extreme. High Temperature Exposure JIS-C5201-1 4.25 IEC 60068-2-2 At 170 Biased Humidity MIL-STD-202 Method 103 0.2m for 1000 hours. 0.2m 1,000 hours; 85°C / 85% RH, 10% of operating power. Measurement at 24±4 hours after test conclusion. 70±2 0.2m , RCWV or Max. working voltage Load Life (Endurance) JIS-C-5201-1 4.25 whichever is less for 1000 hrs with 1.5 hrs IEC-60115-1 4.25.1 Solderability JIS-C-5201-1 4.17 IEC-60115-1 4.17 and 0.5 hr 245±5 0.2m ON 0.2m OFF. for 3 seconds. >95% coverage 地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A栋 8 楼 深圳市毫欧电子有限公司 | 电话: 0755-81488408 | 传真: 0755-22630181 | 网址: www.moolee.com.cn HoMAT封体合金电阻规格书 系列号 HoMAT 修订日期 2021-07-12 版本号 Ho-A0 Recommended Customer Soldering Parameters Wave solder Temperature condition Solder reflow Temperature condition Recommend Land Pattern Design Unit: mm TYPE Resistance Range 0.5m 0 / 1~13 MAT0805- 0.5W&1W MAT1206 -0.75W,1W,1.5W Jumper Jumper 0 0 MAT2512 -1W, 2W, 3W 45 MAT2725 - 4W 0.25m MAT2728 - 4W MAT4527 2W,3W,5W 101m ~50 a b i 1.35 1.00 1.80 1.80 0.3 1.00 1.46 2.15 1.68 1.46 2.15 1.68 2.30 3.68 3.15 3.40 3.68 0.95 2.35 3.68 1.35 2.10 3.68 2.55 2.30 3.68 3.15 2.05 3.68 3.65 3.25 6.85 1.70 2.75 6.85 2.70 2.05 7.20 3.90 4.50 8.74 4.50 3.50 8.74 6.50 3.50 8.74 6.50 地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A栋 8 楼 深圳市毫欧电子有限公司 | 电话: 0755-81488408 | 传真: 0755-22630181 | 网址: www.moolee.com.cn HoMAT封体合金电阻规格书 系列号 HoMAT 修订日期 2021-07-12 版本号 Ho-A0 Embossed Dimensions Unit: mm Resista n Range ce (m ) W P E F 0805 0mR~2.5mR 8.0±0.30 4.0±0.10 1.75±0.10 3.5±0.10 1.0±0.10 4.0±0.10 2.0±0.10 0805 3mR~13mR 8.0±0.30 4.0±0.10 1.75±0.10 3.5±0.10 1.0±0.10 4.0±0.10 2.0±0.10 Item D D1 Item Resistance Range (m ) W 1206 1mR 8.0±0.30 4.0±0.10 1.75±0.10 3.5±0.10 1.0±0.10 1206 2~100mR 8.0±0.30 4.0±0.10 1.75±0.10 3.5±0.10 2512 0.5~2mR 2512 3~450mR 2725 2728 4527 0.25~3mR 4~450mR 0.5~500mR P E F D D1 G A T1 T 1.70±0.10 2.45±0.10 0.90±0.25 0.20±0.05 1.70±0.10 2.45±0.10 0.55±0.25 0.20±0.05 B T1 T 4.0±0.10 2.0±0.10 2.03±0.10 3.55±0.10 1.10±0.10 0.20±0.05 1.0±0.10 4.0±0.10 2.0±0.10 2.03±0.10 3.55±0.10 0.85±0.10 0.20±0.05 12.0±0.30 4.0±0.10 1.75±0.10 5.5±0.10 1.55±0.10 4.0±0.10 2.0±0.10 3.50±0.10 6.75±0.10 1.10±0.10 0.20±0.05 12.0±0.30 4.0±0.10 1.75±0.10 5.5±0.10 1.55±0.10 4.0±0.10 2.0±0.10 3.50±0.10 6.75±0.10 0.90±0.10 0.20±0.05 2.0±0.10 6.81±0.10 7.16±0.10 1.05±0.10 0.25±0.05 2.0±0.10 7.10±0.10 7.05±0.10 0.95±0.10 0.20±0.05 2.0±0.10 7.38±0.10 12.0±0.10 1.05±0.10 0.30±0.10 1.55±0.10 12.0±0.30 8.0±0.10 1.75±0.10 5.5±0.10 1.55±0.10 24.0±0.30 12.0±0.10 1.75±0.10 11.5±0.10 1.50±0.10 4.0±0.10 4.0±0.10 4.0±0.10 H B A 12.0±0.30 8.0±0.10 1.75±0.10 5.5±0.10 G H Appendix For SMD Chip Resistor Packaging Information Reel Dimensions Unit: mm Dimension Reel Type / Tape reel for 8 mm embossed (for MAT0805/1206) reel for 12 mm embossed 7 reel for 24 mm embossed A B C D W M 2.0±0.5 13.2±0.5 17.7±0.5 60.0±0.5 12.0±0.5 178±1.0 2.5±0.5 2.0±0.5 13.5±0.5 13.2±0.5 17.7±0.5 17.7±0.5 60.0±0.5 60.0±0.5 16.2±0.5 24.4±2.0 178±1.0 178±1.0 地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A栋 8 楼 深圳市毫欧电子有限公司 | 电话: 0755-81488408 | 传真: 0755-22630181 | 网址: www.moolee.com.cn
物料型号:HoMAT系列封体合金电阻 器件简介:低阻值、低温度系数、长期稳定性好、符合RoHS标准、无卤素、无铅、高精度电流检测和电压分配。
引脚分配:0805、1206、2512、2725、2728、4527封装,额定功率从0.5W到5W不等。
参数特性:额定功率、温度系数、最大额定电流、最大过载电流、阻值范围、材料、工作温度范围。
功能详解:适用于娱乐产品、电源、测量仪器、工业产品、电池管理系统等。
应用信息:适用于多种电子设备,包括但不限于电源、测量设备、电池管理系统等。
封装信息:提供多种封装尺寸,包括0805、1206、2512、2725、2728、4527,满足不同应用需求。
HoMAT1206-1W-33mR-1% 价格&库存
很抱歉,暂时无法提供与“HoMAT1206-1W-33mR-1%”相匹配的价格&库存,您可以联系我们找货
    • 10+0.43105
    • 100+0.35838
    • 1000+0.29472
    • 2000+0.29030
    • 5000+0.22641
    库存:4790
