MBR10150CD
MBR10150CD
    DOWO(东沃电子)
    TO-252(DPAK)
    电压:150V 电流:10A
MBR10150CD 数据手册
MBR10150CD Schottky Barrier Rectifiers Productor Character ● Multilayer Metal -Silicon Potential Structure. ● Low Leakage Current. ● High Current Capability, High Efficiency. ● High Junction Temperature Capability. ● RoHs Product. Primary Use ● Low Voltage High Frequency Switching Power Supply. ● Low Voltage High Frequency Invers Circuit. ● Low Voltage Continued Circuit and Protection Circuit. Summarize ● MBR10150CD Device optimized for ultra-low forward voltage drop to maximize efficiency in Power Supply applications. Equivalent Circuit K 2 1 A 3 A 2 Package:TO-263-2L 1 3 MBR10150CD MBR10150CD-HF HF=Halogen Free Absolute Maximum Ratings Item Symbol Data Unit VRRM 150 V Average Rectified Forward Current (Rated VR-20Khz Square Wave) - 50% duty cycle IFAV 10 A Forward Peak Surge Current(Rated Load 8.3 Half Mssine WaveAccording to JEDEC Method) IFSM 190×2 A TJ -40~150 ℃ TSTG -40~150 ℃ RθJC 2 ℃/W Value(min) Value(typ) Value(max) Unit Maximal Inverted Repetitive Peak Voltage Operating Junction Temperature Storage Temperature Typical Thermal Resistance(per leg) Package=TO-263-2L Electricity Character Item VB IR VF Test Condition TJ =25℃ IR=1mA 150 --- --- V TJ =25℃ VR=150V --- --- 0.01 mA TJ =125℃ VR=150V --- --- 10.00 mA TJ =25℃ IF=5A (IFAV=5A×2) --- 0.81 0.88 V --- --- 0.75 V TJ =125℃ DAKA010100292401 REV.E(8) HXM 0571-87006810 www.dowosemi.cn 1/3 MBR10150CD Schottky Barrier Rectifiers Characteristic Curves The forward voltage and forward current curve Current derating curve, perelement If, Average Forward Current (A) 5.0 4.0 125℃ 3.5 3.0 2.5 10 8 6 4 2 0 0 30 60 90 120 150 Tc, Case Temp (℃) 2.0 1.5 25℃ 1.0 0.5 0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 Vf, Instantaneous Forward Voltage (V) The reverse leak current and the reverse voltage (single-device) curve. 10000.00 1000.00 Ir, Reverse Current (uA) If, Instantaneous Forward Current (A) 4.5 12 125℃ 100.00 75℃ 10.00 1.00 25℃ 0.10 0 30 60 90 120 150 Vr, Reverse Voltage (V) DAKA010100292401 REV.E(8) HXM 0571-87006810 www.dowosemi.cn 2/3 MBR10150CD Schottky Barrier Rectifiers Package Outline Dimensions 1.27REF 8.70±0.20 1.27±0.15 4.57±0.25 深0.30REF 1.27±0.15 5.10±0.40 0.81±0.15 5.08REF 3.00REF 15.10±0.45 10.16±0.25 0.40±0.12 0°~5° TO-263-2L Unit:mm TO-263-2L Marking Information DOWO Marking Code “DOWO”= Product Logo “Marking Code”= The Following “XXXX”= Date Code Marking XXXX Package Marking Code TO-263-2L MBR10150CD Part Number MBR10150CD MBR10150CD-HF Packing Information Packaging Tube Reel Package TO-263-2L TO-263-2L Part Number Quantity Size Tube 50 pieces 530*33*7mm Inner Box 1000 pieces 558*150*40mm Outer Box 5000 pieces 570*235*170mm Reel 800 pieces 330*30mm Inner Box 800 pieces 345*345*35mm Outer Box 8000 pieces 375*375*350mm Notice: Hangzhou Dongwo Electronic Technology Co.,Ltd.,have the right to modify the specification revision, all information are subject to change without notice. DAKA010100292401 REV.E(8) HXM 0571-87006810 www.dowosemi.cn 3/3
MBR10150CD 价格&库存
很抱歉,暂时无法提供与“MBR10150CD”相匹配的价格&库存,您可以联系我们找货
