SC0603F22R0F2BNRH
SC0603F22R0F2BNRH
    SUNWAY(信维)
    厚膜电阻 22Ω ±1% 100MW
SC0603F22R0F2BNRH 数据手册
SUNWAY R CHIP DATASHEET Thick Film General Purpose SC Series Tolerance : ±0.1% /±0.5% /±1% /±5% Sizes :0075 /01005 /0201 /0402 /0603 /0805 /1206 /1210 /2010 /2512 RoHS compliant & Halogen free CATALOGUE 1. ORDERING INFORMATION............................................................................................................... 1 2. MARKING................................................................................................................................................2 3. CONSTRUCTION AND DIMENSION................................................................................................ 4 4. ELECTRICAL CHARACTERISTICS....................................................................................................... 5 5. FUNCTIONAL DESCRIPTION............................................................................................................. 7 6. FOOTPRINT AND SOLDERING PROFILES...................................................................................... 8 7. PACKING STYLE AND PACKAGING QUANTITY......................................................................... 12 8. TESTS AND REQUIREMENTS...........................................................................................................17 9. REVISION HISTORY........................................................................................................................... 19 10. SUNWAY CONTACT........................................................................................................................ 20 Product Specification Chip Resistor Surface Mount SC SERIES 0075 to 2512 1. ORDERING INFORMATION SCOPE This specification describes SC series chip resistors with lead free terminations made by thick film process APPLICATIONS ORDERING INFORMATION-GLOBAL PART NUMBER Global part numbers are identified by the series, sizes, tolerance ,packing type, temperature coefficient, taping reel and resistance value. GLOBAL PART NUMBER SC XXXX X XXXX X XX X XH (1) (2) (3) (4) (5) (6) (7) All general purpose application (1) SIZE FEATURES  Halogen Free Epoxy  RoHS compliant  Products with lead free terminations meet RoHS requirements  Pb-glass contained in electrodes, resistors element and glass are exempted by RoHS  Reducing environmentally hazardous wastes  High component and equipment reliability Saving of PCB space  None forbidden-materials used in products/production 0075/0100/0201/0402/0603/0805/1206/1210/2010/2512 (2) TOLERANCE B=±0.1% F=±1.0% D=±0.5% J=±5.0% (3) RESISTANCE There are 2-4digits indicated the resistance value. Letter R/K/M is decimal point Example: 9R76 = 9.76 Ω 9761 = 9760 Ω 1004 = 1,000,000 Ω (4) TEMPERATURE COEFFICIENT OF RESISTANCE A=±5ppm D=±25ppm F=±100ppm H=±225ppm O=±300ppm Q=±700ppm B=±10ppm E=±50ppm L=±150ppm I=±300ppm J=±350ppm C=±15ppm M=±75ppm G=±200ppm N=±175ppm K=±400ppm (5) POWER NOTE All our RSMD products meet RoHS compliant and Halogen Free ORDERING EXAMPLE The ordering code for a SC0402 0.0625W chip resistor value 100KΩ with ±5% tolerance ,supplied in 7-inch paper tape reel of 10,000 unit per reel is : SC0402J1003F2ANRH www.sz-sunway.com 1A=1/32W ,1B=1/20W , 1C=1/2W,1D=3/4W,1E=1/50W, 1W=1W,2A=1/16W,2B=1/10W,4A=1/8W,4B=1/5W,8A=1/4W (6)CONTROL CODE N:Lead Free, P:Total Lead Free (7) PACKATING TYPE & PRODUCT CODE R = 7”Paper tape P = 10”Paper tape H =13”Paper tape K = 07” Embossed plastic tape T =10” Embossed plastic tape E = ESD safe reel G =13”Embossed plastic tape H = Default code 1 Product Specification Chip Resistor Surface Mount SC SERIES 0075 to 2512 2. MARKING Tolerance 1%, 0.5% Size Tolerance 5% Description SC0075/0100/ 0201/0402 NO marking NO marking 1%,0.5%,E24 exception values 10/11/13/15/20/75 of E24 series 240=24×100=24 SC0603 5%,E24 series: 3 digits First two digits for significant figure and 3rd digit for number of zeros 223=22×103=22K 1%,0.5%,E96 refer to EIA-96 marking method ,including values 10/11/13/15/20/75 of E24 series * 29B=196×10=1.96K 1%,0.5%,E96 refer to EIA-96 marking method ,including values 10/11/13/15/20/75 of E24 series First three digits for significant figure and 4th digit for number of zeros. 2203=220×103=220K SC0805/1206/ 1210/2010/ 2512 Description 5%,E24 series: 3 digits First two digits for significant figure and 3rd digit for number of zeros 223=22×103=22K Refer to below table code A B 0 C D 2 E 3 F 4 G 5 H 6 X 7 Y -1 Z Multiplier 10 10 10 10 10 10 10 10 10 10 10-3 Value Code Value Code Value Code Value Code Value Code Value Code 100 01 147 17 215 33 316 49 464 65 681 81 102 02 150 18 221 34 324 50 475 66 698 82 105 03 154 19 226 35 332 51 487 67 715 83 107 04 158 20 232 36 340 52 499 68 732 84 110 05 162 21 237 37 348 53 511 69 750 85 113 06 165 22 243 38 357 54 523 70 768 86 115 07 169 23 249 39 365 55 536 71 787 87 118 08 174 24 255 40 374 56 549 72 806 88 121 09 178 25 261 41 383 57 562 73 825 89 124 10 182 26 267 42 392 58 576 74 845 90 127 11 187 27 274 43 402 59 590 75 866 91 130 12 191 28 280 44 412 60 604 76 887 92 133 13 196 29 287 45 422 61 619 77 909 93 137 14 200 30 294 46 432 62 634 78 931 94 140 15 205 31 301 47 442 63 649 79 953 95 143 16 210 32 309 48 453 64 665 80 976 96 www.sz-sunway.com 1 -2 2 Product Specification Chip Resistor Surface Mount SC SERIES 0075 to 2512 Values of E3,E6,E12,E24 ,E48& E96 To simplify resistor manufacture, handling, purchase & electronic circuit design, resistor values are arranged into standard resistor values conforming to the E series. The different sets of standard resistor values are known by their E-series numbers: E3 has three resistors in each decade, E6 has six, E12 has twelve, and so forth. VALUES SERIES E3 1.0 2.2 4.7 E6 1.0 1.5 2.2 3.3 4.7 6.8 E12 1.0 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 1.0 1.1 1.2 1.3 1.5 1.6 1.8 2.0 2.2 2.4 2.7 3.0 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 1.00 1.05 1.10 1.15 1.21 1.27 1.33 1.40 1.47 1.54 1.62 1.69 1.78 1.87 1.96 2.05 2.15 2.26 2.37 2.49 2.61 2.74 2.87 3.01 3.16 3.32 3.48 3.65 3.83 4.02 4.22 4.42 4.64 4.87 5.11 5.36 5.62 5.90 6.19 6.49 6.81 7.15 7.50 7.87 8.25 8.66 9.09 9.53 1.00 1.02 1.05 1.07 1.10 1.13 1.15 1.18 1.21 1.24 1.27 1.30 1.33 1.37 1.40 1.43 1.47 1.50 1.54 1.58 1.62 1.65 1.69 1.74 1.78 1.82 1.87 1.91 1.96 2.00 2.05 2.10 2.15 2.21 2.26 2.32 2.37 2.43 2.49 2.55 2.61 2.67 2.74 2.80 2.87 2.94 3.01 3.09 3.16 3.24 3.32 3.40 3.48 3.57 3.65 3.74 3.83 3.92 4.02 4.12 4.22 4.32 4.42 4.53 4.64 4.75 4.87 4.99 5.11 5.23 5.36 5.49 5.62 5.76 5.90 6.04 6.19 6.34 6.49 6.65 6.81 6.98 7.15 7.32 7.50 7.68 7.87 8.06 8.25 8.45 8.66 8.87 9.09 9.31 9.53 9.76 E-24 E-48 E-96 Preferred value of resistance shall be composed by significant figures shown in the above table and multipliers including:"X10 ohm , X102 ohm , X103 ohm , X104 ohm , X105 ohm ." www.sz-sunway.com 3 Product Specification Chip Resistor Surface Mount SC SERIES 0075 to 2512 3. CONSTRUCTION AND DIMENSION CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body .Internal metal electrodes are added on each end to make the contacts to the thick film resistive element .The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environmental influences .The resistor is laser trimmed to the rated resistance value .The resistor is covered with a protective epoxy coat, finally the two external termination (matte tin on Ni –barrier ) are added , as shown in Fig 1 . Fig1:Chip resistor outlines DIMENSION ⌐ Table 1 TYPE L(mm) W(mm) H(mm) l1(mm) 12(mm) SC0075 0.30±0.01 0.15±001 0.13±0.01 0.08±0.03 0.08±0.03 SC0100 0.40±0.02 0.20±0.02 0.13±0.02 0.10±0.03 0.10±0.03 SC0201 0.60±0.03 0.30±0.03 0.23±0.03 0.10±0.05 0.15±0.05 SC0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.25±0.10 SC0603 1.60±0.10 0.80±0.10 0.45±0.10 0.25±0.15 0.25±0.15 SC0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.35±0.20 SC1206 3.10±0.10 1.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 SC1210 3.10±0.10 2.60±0.15 0.55±0.10 0.45±0.15 0.50±0.20 SC2010 5.00±0.10 2.50±0.15 0.55±0.10 0.60±0.20 0.50±0.20 SC2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.20 0.50±0.20 www.sz-sunway.com 4 Product Specification Chip Resistor Surface Mount SC SERIES 0075 to 2512 4. ELECTRICAL CHARACTERISTICS ELECTRICAL CHARACTERISTICS ⌐ Table1 OPERATING MAXIMUM MAXIMUM DIELECTRIC CHARACPOWER TEMPERATURE WORKING OVERLOAD WITHSTANDING TERISTICS RANCE VOLTAGE VOLTAGE VOLTAGE SC0075 SC0100 SC0201 1/50W 1/32W 1/20W 1/16W -55℃ to 125℃ -55℃ to 125℃ -55℃ to 125℃ -55℃ to 155℃ 10V 15V 25V 50V 25V 30V 50V 100V 25V 30V 50V 100V SC0402 1/8W 1/10W -55℃ to 155℃ -55℃ to 155℃ 50V 75V 100V 150V 100V 150V SC0603 1/5W -55℃ to 155℃ www.sz-sunway.com 75V 150V 150V RESISTANCE RANGE TEMPERATURE COEFFICIENT JUMPER CRITERIA 5% (E24) 10Ω≦R≦1MΩ 1% (E24/E96) 10Ω≦R≦1MΩ Jumper≦50mΩ 10Ω≦R≦100Ω Rated Current ±300ppm℃ 0.5A 100Ω
SC0603F22R0F2BNRH
1. 物料型号:SUNWAY SC系列芯片电阻,尺寸从0075到2512,公差范围为±0.1%至±5%。
2. 器件简介:SC系列芯片电阻采用厚膜工艺制造,具有无铅端子,符合RoHS标准,无卤素,适用于所有通用目的应用。
3. 引脚分配:文档中未明确提供引脚分配信息,但通常这类芯片电阻为表面贴装元件,具有两个端子用于与电路板连接。
4. 参数特性: - 工作温度范围:SC0402至SC2512为-55℃至+155℃,SC0075至SC0201为-55℃至+125℃。 - 额定功率和电压:根据电阻值和尺寸不同,额定功率和工作电压有所变化。 - 温度系数:提供不同的温度系数选项,如±5 ppm至±700 ppm。
5. 功能详解:电阻的构造包括高级陶瓷基板、内部金属电极、厚膜电阻元件、覆盖玻璃和激光修调至额定电阻值。电阻表面覆盖有保护性环氧涂层,并添加了外部端子。
6. 应用信息:适用于自动放置系统的陶瓷基板和印刷电路板(PCB)上的表面贴装。
7. 封装信息:提供了不同尺寸的封装细节,包括长度、宽度、高度以及端子的位置和尺寸。
SC0603F22R0F2BNRH 价格&库存
很抱歉,暂时无法提供与“SC0603F22R0F2BNRH”相匹配的价格&库存,您可以联系我们找货
