HX78M05
Features
Output Current of 0.5A
No external components
Output transistor safe area protection
Package:TO252
General Description
HX78M05 is three-terminal positive regulators.
Zener diode-resistor Combination, an effective
One of these regulators can deliver up to 1A of
improvement in output impedance can be
output current. When used as a replacement for a
obtained, together with lower quiescent current.
Pin Configuration
Ver1.3
PIN NO.
PIN NAME
FUNCTION
1
VIN
Input voltage pin
2
GND
Ground pin
3
VOUT
Output voltage pin
1
Jul 26,2021
HX78M05
Block Diagram
Absolute Maximum Ratings(Ta=25℃)
Parameter
Rating
Unit
Input supply voltage: VIN
40
V
MAX. Output current:Iout
500
mA
MAX Power:Pmax
1
W
Maximum junction temperature:Tj
-25~125
Storage temperature:Tstr
-55~125
Soldering temperature and time
+260(Recommended 10S)
Note: The absolute maximum ratings are rated values exceeding which the product could suffer physical
damage. These values must therefore not be exceeded under any conditions.
Ver1.3
2
Jul 26,2021
HX78M05
Electrical Characteristics
(Cin=0.33uF, Co=0.1uF, 0≤Tj≤125℃,unless otherwise noted)
Parameter
Symbol
Conditions
Min.
Typ.
Max.
Unit
Input Voltage
VIN
35
V
Io=40mA, VIN=10V
0.964vout
VOUT
1.036vout
0.96vout
VOUT
1.04vout
0.95vout
VOUT
1.05vout
VIN=7V~18V, Io=40mA
-150
150
VIN=8V~18V, Io=40mA
-100
100
VIN=10V, Io=1mA~100mA
-60
60
VIN=10V, Io=1mA~40mA
-30
30
Io=1mA~40mA
Output Voltage
Vout
VIN=7V~18V
Io=10mA
VIN=10V
V
Line Regulation
LNR
Load Regulation
LDR
Output Current
Iout
VIN=7.0V,VOUT=5.0v
500
mA
Dropout Voltage
VDIF
Tj=25℃,Io=500mA
1.7
V
Quiescent Current
IQ
VIN=10V
1.5
mA
VIN=8V~18V, IO=40mA
-1.5
1.5
-0.1
0.1
Quiescent Current
Change
△IQ
VIN=10V,
IOUT=1mA~40mA,
LNR: Line Regulation. The change in output voltage for a change in the input voltage. The measurement
is made under conditions of low dissipation or by using pulse techniques such that the average chip
temperature is not significantly affected.
LDR: Load Regulation.The change in output voltage for a change in load current at constant chip
temperature.
Ver1.3
3
Jul 26,2021
mV
mV
mA
HX78M05
Typical Application
Ver1.3
4
Jul 26,2021
HX78M05
Package Information
Ver1.3
5
Jul 26,2021
很抱歉,暂时无法提供与“78M05”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.41710
- 100+0.34064
- 300+0.30132
- 2500+0.24894
- 5000+0.23760
- 10000+0.23004
