HoRS2512-1W-10mR-1%
HoRS2512-1W-10mR-1%
    MILLIOHM(毫欧)
    陶瓷电阻 10mΩ ±1% 1W
HoRS2512-1W-10mR-1% 数据手册
系列号 HoRS电流感应厚膜芯片电阻系列规格书 HoRS 修订日期 2021-11-19 Ho-A0 版本号 Scope This specification applies to all sizes of rectangular-type fixed chip resistors with Ruthenium-base as material. Features Low inductance Highly reliable multilayer electrode construction Higher component and equipment reliability Reduced size of final equipment reliability RoHS Compliance Construction Applications Power Management Applications L Switching Power Supply D1 Over Current Protection in Audio Application Voltage Regulation Module (VRM) W     T DC-DC Converter, Battery Pack, Charger, Adaptor Automotive Engine Control Disk Driver      D2  Alumina Substrate  Edge Electrode  Resistor Layer  Bottom Electrode  Barrier Layer  Primary Overcoat  Top Electrode  External Electrode  Secondary Overcoat Dimensions L W T D1 D2 (mm) (mm) (mm) (mm) (mm) Weight (g) (1000pcs) Type Size (Inch) RS 0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.20±0.10 0.620 RS 0603 1.60±0.10 0.80±0.10 0.45±0.10 0.30±0.20 0.30±0.20 2.042 RS 0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.40±0.20 4.368 RS 1206 3.10±0.10 1.55±0.10 0.55±0.10 0.50±0.25 0.50±0.20 8.947 RS 1210 3.10±0.10 2.60±0.15 0.55±0.10 0.50±0.25 0.50±0.20 15.959 RS 2010 5.00±0.10 2.50±0.15 0.55±0.10 0.60±0.25 0.50±0.20 24.241 RS 2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.25 0.50±0.20 39.448 地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A 栋 8 楼 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 系列号 HoRS电流感应厚膜芯片电阻系列规格书 HoRS 修订日期 2021-11-19 Ho-A0 版本号 Part Numbering 0603 Product Type Dimensions RF 0 - RS R 0 4 1% 7 Resistance Tolerance ±1% ±5% Resistance - 0R047: 0.047Ω - - - 0R1: 0.1Ω 0402 0603 0805 1206 1210 2010 2512 “-“ to fill up 6 spaces Recommend Land Pattern Derating Curve Derating Curve 100 B A A (mm) B (mm) C (mm) RS0402 0.50 0.45 0.60 RS0603 0.90 0.60 0.90 RS0805 1.20 0.70 1.30 RS1206 2.00 0.90 1.60 RS1210 2.00 0.90 2.80 RS2010 3.80 0.90 2.80 RS2512 3.80 1.60 3.50 Type Power ratio(%) C 80 60 40 20 0 0 20 40 60 80 100 120 140 160 Ambient Temperature(℃) Soldering Condition IR Reflow Soldering Wave Soldering (Flow Soldering) (1) Time of IR reflow soldering at maximum temperature point 260C:10s (2) Time of wave soldering at maximum temperature point 260C:10s (3) Time of soldering iron at maximum temperature point 410C:5s 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 180 系列号 修订日期 HoRS电流感应厚膜芯片电阻系列规格书 版本号 HoRS 2021-11-19 Ho-A0 Standard Electrical Specifications Item Power Rating at 70C Operating Temp. Max. Operating Range Current Type Resistance Range (mΩ) ±1% TCR (PPM/C) ±5% RS0402 1/16W -55 ~ +155C 1.11A 50 - 91 100 - 976 800 500 RS0603 1/10W -55 ~ +155C 2.23A 20 - 47 50 - 91 100 - 976 1200 800 500 RS0805 1/8W -55 ~ +155C 3.53A RS1206 1/4W -55 ~ +155C 5.00A 10 - 18 20 - 47 50 - 91 100 - 976 1500 1200 800 500 RS1210 1/3W -55 ~ +155C 5.77A RS2010 3/4W -55 ~ +155C 8.66A 10 - 18 20 - 91 100 - 976 1500 800 500 RS2512 1W -55 ~ +155C 10.0A Operating Voltage=√(P*R) ; Overload Voltage=2.5*√(P*R) High Power Electrical Specifications Item Type Power Rating at 70°C Operating Temp. Max. Operating Range Current Resistance Range (mΩ) ±1% TCR (PPM/°C) ±5% RS0402 1/10W -55 ~ +155C 1.40A 50 - 91 100 - 976 800 500 RS0603 1/8W -55 ~ +155C 2.50A 20 - 47 50 - 91 100 - 976 1200 800 500 RS0805 1/4W -55 ~ +155C 5.00A RS1206 1/2W -55 ~ +155C 7.07A 10 - 18 20 - 47 50 - 91 100 - 976 1500 1200 800 500 RS1210 1/2W -55 ~ +155C 7.07A RS2010 1W -55 ~ +155C 10.0A 10 - 18 20 - 91 100 - 976 1500 800 500 RS2512 2W -55 ~ +155C 14.1A Operating Voltage=√(P*R) Overload Voltage=2.5*√(P*R) Operating Current=√(P/R) Viking is capable of manufacturing the optional spec based on customer’s requirement. 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 系列号 HoRS电流感应厚膜芯片电阻系列规格书 修订日期 版本号 HoRS 2021-11-19 Ho-A0 Environmental Characteristics Requirement Item Temperature Coefficient of Resistance (T.C.R.) Test Method 5% 1% JIS-C-5201-1 4.8 IEC-60115-1 4.8 As Spec. Short Time Overload (1.0%+0.05Ω) Insulation Resistance 10G Endurance (1.0%+0.10Ω) (2.0%+0.05Ω) (2.0%+0.10Ω) (1.0%+0.10Ω) (2.0%+0.10Ω) Dry Heat (1.0%+0.05Ω) (1.5%+0.10Ω) (1.0%+0.05Ω) Solderability 95% min. coverage Resistance to Soldering Heat (0.5%+0.05Ω) Voltage Proof Leaching Rapid Change of Temperature (1.0%+0.05Ω) (1.0%+0.05Ω) No breakdown or flashover Individual leaching area ≦5% Total leaching area ≦ 10% (0.5%+0.05Ω) RCWV*2.5 or Max. Overload Voltage whichever is lower for 5 seconds, 2 seconds for High Power Series JIS-C-5201-1 4.6 IEC-60115-1 4.6 Damp Heat with Load Bending Strength -55C~+125C, 25C is the reference temperature JIS-C-5201-1 4.13 IEC-60115-1 4.13 (1.0%+0.05Ω) Max. Overload Voltage for 1 minute JIS-C-5201-1 4.25 IEC-60115-1 4.25.1 702C, RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” JIS-C-5201-1 4.24 IEC-60115-1 4.24 402C, 90~95% R.H., RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” JIS-C-5201-1 4.23 IEC-60115-1 4.23.2 at +155C for 1000 hrs JIS-C-5201-1 4.33 IEC-60115-1 4.33 Bending once for 5 seconds 2010, 2512 sizes: 2mm Other sizes: 3mm JIS-C-5201-1 4.17 IEC-60115-1 4.17 2455C for 3 seconds JIS-C-5201-1 4.18 IEC-60115-1 4.18 2605C for 10 seconds JIS-C-5201-1 4.7 IEC-60115-1 4.7 1.42 times Max. Operating Voltage for 1 minute JIS-C-5201-1 4.18 IEC-60068-2-58 8.2.1 2605C for 30 seconds JIS-C-5201-1 4.19 IEC-60115-1 4.19 -55C to +155C, 5 cycles RCWV(Rated Continuous Working Voltage)=√(P*R) or Max. Operating Voltage whichever is lower. ■ Storage Temperature: 15~28°C; Humidity < 80%RH 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 系列号 HoRS 修订日期 HoRS电流感应厚膜芯片电阻系列规格书 2021-11-19 Ho-A0 版本号 Packaging Reel Specifications & Packaging Quantity Tape Width Reel Diameter ΦA (mm) 10K 8mm 7 inch 178.5±1.5 20K 8mm 10 inch 254±1.0 40K 8mm 13 inch 330±1.0 5K 8mm 7 inch 178.5±1.5 10K 8mm 10 inch 254±1.0 RFS1210 20K 8mm 13 inch 330±1.0 RS2010 4K 12mm 7 inch 178.5±1.5 8K 12mm 10 inch 250±1.0 Bottom Tape Top Tape Type RS0402 Packaging Quantity Paper RS0603 RS0805 RS1206 RS2512 Paper Embossed Paper Tape Specifications ΦB (mm) ΦC (mm) W (mm) T (mm) 13.0±0.2 9.0±0.5 12.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 13.0±0.2 9.0±0.5 12.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 +1/-0 13.0±0.5 13.0±0.5 15.5±0.5 62±0.5 13.0±0.5 12.5±0.5 16.5±0.5 60 60 60 +1/-0 +1/-0 ψ D0 E A F W B T Paper Tape Type A (mm) B (mm) W (mm) P1 Resistor E (mm) F (mm) P0 (mm) P2 P0 P1 (mm) Direction of unreeling P2 (mm) ΦD0 (mm) T (mm) RS0402 0.65±0.10 1.15±0.10 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 2.00±0.05 2.00±0.05 1.50+0.1,-0 0.45±0.10 RS0603 1.10±0.10 1.90±0.10 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.70±0.10 RS0805 1.60±0.10 2.40±0.20 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 RS1206 1.90±0.10 3.50±0.20 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 RS1210 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 2.90±0.10 3.50±0.20 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 系列号 HoRS 修订日期 HoRS电流感应厚膜芯片电阻系列规格书 2021-11-19 Ho-A0 版本号 Embossed Plastic Tape Specifications Top Tape ψ D0 E A F W B ψD11.5+0.25,-0 T P1 Resistor P2 P0 Direction of unreeling Embossed Tape P2 (mm) ΦD0 (mm) A (mm) B (mm) W (mm) E (mm) F (mm) P0 (mm) P1 (mm) RS2010 2.8±0.10 5.5±0.10 12.0±0.30 1.75±0.10 5.5±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.50+0.1, -0 1.2 +0 RS2512 3.5±0.10 6.7±0.10 12.0±0.30 1.75±0.10 5.5±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.50+0.1, -0 1.2 +0 Type Marking No Marking for 0402 1%, 5% for 0805/1206/1210/2010/2512: 4 digits marking Example: Resistance Marking 47mΩ R047 75mΩ R075 15mΩ R015 750mΩ R750 820mΩ R820 5% for 0603: 3 digits marking in E24 1% for 0603: 3 digits marking with under-line in E96 (non-including E24 series) 3 digits marking for E24 or R value suffix is zero in E96: R10=100mΩ; R28=280mΩ 3 digits marking for E96: 243=243mΩ; 511=511mΩ 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn T (mm)
HoRS2512-1W-10mR-1% 价格&库存
很抱歉,暂时无法提供与“HoRS2512-1W-10mR-1%”相匹配的价格&库存,您可以联系我们找货
