5KP200CA
5KP200CA
    LIOWN(里阳)
    R-6(P-600)
    双向TVS 200V截止 峰值浪涌电流:15.5A
5KP200CA 数据手册
TVS Diodes Datasheet 5KP Series Surface Mount – 5000W Description The 5KP series is designed specifically to protect sensitive electronic equipment from voltage transients induced by lightning and other transient voltage events. Features P600 Additional Information  Halogen free and RoHS compliant  Glass passivated junction  Low incremental surge resistance  Excellent clamping capability  5000W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.05%  Fast response time  Typical IR less than 2μA above 10V devices  High Temperature soldering guaranteed: 265℃/10 seconds/.375″, (9.5mm) lead length, 5lbs (2.3kg) Maximum Ratings and Characteristics (TA=25℃) tension  Plastic package has underwriters laboratory flammability 94V-0 Rating Symbol Value Peak pulse power dissipation at 10/1000μs waveform(Note1, Note2, Fig.1) PPPM 5000W Peak pulse current of at 10/1000 μs waveform (Note 1, Fig.3) IPPM See Table(A) Applications Steady state power dissipation at TL=75℃ (Fig.5) PM(AV) 8.0W  Meet MSL level1, per J-STD-020  IEC-61000-4-2 ESD 30kV(Air), 30kV (Contact)  Unit Weight: 2.1g TVS components are ideal for the protection of I/O Interfaces, VCC bus and other vulnerable circuits used in Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note3, Fig.6) IFSM 400A Operating junction and Storage Temperature Ranges TJ、TSTG -55℃ to +150℃ Typical thermal resistance junction to lead RθJL 8℃/W Typical thermal resistance junction to ambient RθJA 40℃/W telecom, computer, Industrial and consumer electronic applications. Functional Diagram Notes: 1. Non-repetitive current pulse, per Fig.3 and derating above TA=25℃ per Fig.2. 2. 8.3ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per minutes maximum. 1 © 2023 Liown Semiconductor Co., Ltd. Specifications are subject to change without notice. Version: V4 TVS Diodes Datasheet 5KP Series Surface Mount – 5000W Electrical Characteristics (TA=25℃) Part Number Reverse Breakdown Stand-Off Voltage Voltage @IT Maximum Test Clamping Current Voltage @IPP Peak Reverse Pulse Leakage Current @VR Uni. Bi. VR(V) VB MIn.(V) VB Max.(V) IT(mA) VC(V) IPP(A) IR(μA) 5KP5.0A 5KP5.0CA 5.0 6.40 7.00 50 9.2 554.3 3000 5KP6.0A 5KP6.0CA 6.0 6.67 7.37 50 10.3 495.1 2000 5KP6.5A 5KP6.5CA 6.5 7.22 7.98 50 11.2 455.4 1000 5KP7.0A 5KP7.0CA 7.0 7.78 8.60 50 12.0 425.0 800 5KP7.5A 5KP7.5CA 7.5 8.33 9.21 5 12.9 395.3 250 5KP8.0A 5KP8.0CA 8.0 8.89 9.83 5 13.6 375.0 150 5KP8.5A 5KP8.5CA 8.5 9.44 10.40 5 14.4 354.2 50 5KP9.0A 5KP9.0CA 9.0 10.00 11.10 5 15.4 331.2 20 5KP10A 5KP10CA 10.0 11.10 12.30 5 17.0 300.0 10 5KP11A 5KP11CA 11.0 12.20 13.50 5 18.2 280.2 2 5KP12A 5KP12CA 12.0 13.30 14.70 5 19.9 256.3 2 5KP13A 5KP13CA 13.0 14.40 15.90 5 21.5 237.2 2 5KP14A 5KP14CA 14.0 15.60 17.20 5 23.2 219.8 2 5KP15A 5KP15CA 15.0 16.70 18.50 5 24.4 209.0 2 5KP16A 5KP16CA 16.0 17.80 19.70 5 26.0 196.2 2 5KP17A 5KP17CA 17.0 18.90 20.90 5 27.6 184.8 2 5KP18A 5KP18CA 18.0 20.00 22.10 5 29.2 174.7 2 5KP20A 5KP20CA 20.0 22.20 24.50 5 32.4 157.4 2 5KP22A 5KP22CA 22.0 24.40 26.90 5 35.5 143.7 2 5KP24A 5KP24CA 24.0 26.70 29.50 5 38.9 131.1 2 5KP26A 5KP26CA 26.0 28.90 31.90 5 42.1 121.1 2 5KP28A 5KP28CA 28.0 31.10 34.40 5 45.4 112.3 2 5KP30A 5KP30CA 30.0 33.30 36.80 5 48.4 105.4 2 5KP33A 5KP33CA 33.0 36.70 40.60 5 53.3 95.7 2 5KP36A 5KP36CA 36.0 40.00 44.20 5 58.1 87.8 2 5KP40A 5KP40CA 40.0 44.40 49.10 5 64.5 79.1 2 2 © 2023 Liown Semiconductor Co., Ltd. Specifications are subject to change without notice. Version: V4 TVS Diodes Datasheet 5KP Series Surface Mount – 5000W Part Number Reverse Breakdown Stand-Off Voltage Voltage @IT Maximum Test Clamping Current Voltage @IPP Peak Reverse Pulse Leakage Current @VR Uni. Bi. VR(V) VB MIn.(V) VB Max.(V) IT(mA) VC(V) IPP(A) IR(μA) 5KP43A 5KP43CA 43.0 47.80 52.80 5 69.4 73.5 2 5KP45A 5KP45CA 45.0 50.00 55.30 5 72.7 70.2 2 5KP48A 5KP48CA 48.0 53.30 58.90 5 77.4 65.9 2 5KP51A 5KP51CA 51.0 56.70 62.70 5 82.4 61.9 2 5KP54A 5KP54CA 54.0 60.00 66.30 5 87.1 58.6 2 5KP58A 5KP58CA 58.0 64.40 71.20 5 93.6 54.5 2 5KP60A 5KP60CA 60.0 66.70 73.70 5 96.8 52.7 2 5KP64A 5KP64CA 64.0 71.10 78.60 5 103.0 49.5 2 5KP70A 5KP70CA 70.0 77.80 86.00 5 113.0 45.1 2 5KP75A 5KP75CA 75.0 83.30 92.10 5 121.0 42.1 2 5KP78A 5KP78CA 78.0 86.70 95.80 5 126.0 40.5 2 5KP85A 5KP85CA 85.0 94.40 104.00 5 137.0 37.2 2 5KP90A 5KP90CA 90.0 100.00 111.00 5 146.0 34.9 2 5KP100A 5KP100CA 100.0 110.00 123.00 5 162.0 31.5 2 5KP110A 5KP110CA 110.0 122.00 135.00 5 177.0 28.8 2 5KP120A 5KP120CA 120.0 133.00 147.00 5 193.0 26.4 2 5KP130A 5KP130CA 130.0 144.00 159.00 5 209.0 24.4 2 5KP150A 5KP150CA 150.0 167.00 185.00 5 243.0 21.0 2 5KP160A 5KP160CA 160.0 178.00 197.00 5 259.0 19.7 2 5KP170A 5KP170CA 170.0 189.00 209.00 5 275.0 18.5 2 5KP180A 5KP180CA 180.0 201.00 222.00 5 292.0 17.5 2 5KP190A 5KP190CA 190.0 211.00 233.00 5 310.0 16.5 2 5KP200A 5KP200CA 200.0 224.00 247.00 5 329.2 15.5 2 5KP210A 5KP210CA 210.0 237.00 263.00 5 349.5 14.6 2 5KP220A 5KP220CA 220.0 246.00 272.00 5 371.1 13.7 2 3 © 2023 Liown Semiconductor Co., Ltd. Specifications are subject to change without notice. Version: V4 TVS Diodes Datasheet 5KP Series Surface Mount – 5000W Ratings and Characteristic Curves (TA=25℃) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve Figure 3. Pulse Waveform Figure 4. Typical Junction Capacitance Figure 5. Steady State Power Dissipation Derating Curve Figure 6. Maximum Non-Repetitive Forward Surge Current Uni-Directional 4 © 2023 Liown Semiconductor Co., Ltd. Specifications are subject to change without notice. Version: V4 TVS Diodes Datasheet 5KP Series Surface Mount – 5000W Soldering Parameters Peak Temperature : 265℃ Dipping Time : 10 seconds (max.) Soldering : 1 time Wave Soldering Dimensions (P600) Symbol Millimeters Inches Min. Max. Min. Max. A 25.40 - 1.000 - B 8.60 9.10 0.340 0.360 C 8.60 9.10 0.340 0.360 D 1.19 1.35 0.047 0.053 Part Number Code and Marking Code 5 © 2023 Liown Semiconductor Co., Ltd. Specifications are subject to change without notice. Version: V4 TVS Diodes Datasheet 5KP Series Surface Mount – 5000W Packaging Specification Tape(Unit: mm) Reel Box Quantity:800pcs/reel Quantity:300pcs/box 6 © 2023 Liown Semiconductor Co., Ltd. Specifications are subject to change without notice. Version: V4
5KP200CA 价格&库存
很抱歉,暂时无法提供与“5KP200CA”相匹配的价格&库存,您可以联系我们找货
5KP200CA
  • 1+5.71482
  • 10+4.86324
  • 30+4.43232
  • 300+3.90906
  • 600+3.66282
  • 900+3.52944
库存:69
