SM712-02HTG
Rev-1.1
www.elecsuper.com
SuperESD - SM712-02HTG
1. Description
The SM712-02HTG protects sensitive semiconductor components from damage or upset due to
electrostatic discharge (ESD) and other voltage induced transient events. They feature large crosssectional area junctions for conducting high transient currents, offer desirable electrical characteristics
for board level protection, such as fast response time, low operating voltage. It gives designer the
flexibility to protect one bi-directional line in applications where arrays are not practical.
2. Features
IEC 61000-4-2 Level 4 ESD Protection
RoHS compliance
±8kV Contact Discharge
Bidirectional configuration
±15kV Air Discharge
IO Capacitance: 55pF (Typical)
IEC 61000-4-4 EFT Protection
Low clamping voltage
SOT-23 package
40A (5/50ns)
350W Peak pulse Power (8/20us)
3. Applications
RS-485
Automatic teller machines
Security systems
HFC systems
4. Ordering Information
Part
Number
Package Marking
SM712-
SOT-23
712
Material
Packing
Quantity
per reel
Flammability
Rating
Reel Size
Halogen free
Tape &
Reel
3,000 PCS
UL 94V-0
7 inches
02HTG
Table-1
Copyright© ElecSuper Incorporated
Ordering information
Contact Us
1 / 7
SM712-02HTG
Rev-1.1
www.elecsuper.com
5. Pin Configuration and Functions
Pin
Name
Description
1
IO
Connect to IO
2
IO
Connect to IO
3
GND
Connect to GND
Outline
Circuit Diagram
3
3
712
1
Table-2
2
1
2
Pin configuration
6. Specification
6.1. Absolute Maximum rating
Over operating free-air temperature range (unless otherwise noted)
Parameters
Symbol
Min.
Max.
Unit
Peak pulse power (tp=8/20us)@25℃
Ppk
350
W
Peak pulse current (tp=8/20us)@25℃
IPP
17
A
ESD (IEC61000-4-2 air discharge) @25℃
VESD
±15
kV
ESD (IEC61000-4-2 contact discharge) @25℃
VESD
±8
kV
TJ
150
Operating temperature
TOP
-40
125
Storage temperature
TSTG
-55
150
TL
260
Junction temperature
Lead temperature
Table-3
Contact Us
2 / 7
SM712-02HTG
Rev-1.1
www.elecsuper.com
6.2. Electrical Characteristics
At TA = 25℃ unless otherwise noted
Parameters
Symbol
Reverse
stand-off
voltage
VRWM
Reverse
Breakdown
Voltage
VBR
Reverse
Leakage
Current
conditions
Min.
Typ.
Max.
Pin1 or Pin2 to Pin3
12
Pin3 to Pin1 or Pin2
7
V
Pin1 or Pin2 to Pin3; IR= 1mA
13.3
V
Pin3 to Pin 1or Pin2; IR= 1mA
7.5
Pin1 or Pin2 to Pin3; VRWM=12V
1
Pin3 to Pin1or Pin2; VRWM=7V
1
uA
IR
Peak Pulse
Current
IPP
Clamping
Voltage
VCL
Junction
capacitance
CO
Unit
17
A
17
Pin1 or Pin2 to Pin3; IPP=17A
26
V
Pin3 to Pin1 or Pin2; IPP=17A
19
VR=0V; f = 1MHz
55
Table-4
pF
Contact Us
3 / 7
SM712-02HTG
Rev-1.1
www.elecsuper.com
7. Typical Characteristic
Non-repetitive peak pulse power vs. pulse time
Peak Pulse Power(W)
1000
100
10
1
1
10
100
1000
Pulse Duration(us)
8. Typical Application
VCC
RS485
B
A
2
1
3
SM712-02HTG
Typical RS485 Interface Application
Contact Us
4 / 7
SM712-02HTG
Rev-1.1
www.elecsuper.com
9. Dimension
SOT-23
Symbol
A
A1
b
C
D
E
E1
e
Dimensions in Millimeters
Max.
Symbol
1.15
e1
0.10
L
0.50
L1
θ
0.15
3.00
1.40
2.55
Min.
0.9
0.00
0.30
0.08
2.80
1.20
2.25
Min.
1.80
Max.
2.00
0.55REF
0.30
0°
0.50
8°
0.95TYP
Contact Us
5 / 7
SM712-02HTG
Rev-1.1
Table-5
www.elecsuper.com
Product dimensions
10. Recommended Land Pattern
Note:
1. Controlling dimension: in millimeters
2. General tolerance: ±0.05mm
3. The pad layout is for reference only
Contact Us
6 / 7
SM712-02HTG
Rev-1.1
www.elecsuper.com
DISCLAIMER
ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES
(INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER
RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING
WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE
OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS.
These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for
(1) selecting the appropriate ElecSuper products for your application;
(2) designing, validating and testing your application;
(3) ensuring your application meets applicable standards, and any other safety, security, or other requirements.
These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for
development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of
these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party
intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives
against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products
are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or
provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise
alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products.
Contact Us
7 / 7
很抱歉,暂时无法提供与“SM712-02HTG-ES”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.15500
- 100+0.13000
- 300+0.11500
- 3000+0.10700
- 6000+0.09800
- 国内价格
- 10+0.18998
- 100+0.15736
- 300+0.13922
- 3000+0.12690
- 6000+0.11751
- 9000+0.11243
- 国内价格
- 1+0.57310
- 200+0.19140
- 1500+0.11990
- 3000+0.09482
